I just booted up manjaro xfce in my laptop with usb stick.
I am trying to connect to my wifi, but i am not even seeing an option to connect to a wifi.
Wifi-menu not working (showing command not found)
Kindly help setting up
Hey mate, i posted that thread using my mobile since my laptop was connected through internet at that time,
I have verified the ISO integrity, and i have used this same usb stick to boot my another laptop but in which i am able to use my wifi
well here is my system information;
Kernel: 5.3.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.3-x86_64
root=UUID=c376f9e5-0b29-41e9-9322-3f2ec652fedc rw quiet apparmor=1
Desktop: Xfce 4.14.1 tk: Gtk 3.24.12 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81FS v: Lenovo E41-25
serial: <filter> Chassis: type: 10 v: Lenovo E41-25 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0K88286 WIN serial: <filter>
UEFI: LENOVO v: 7UCN27WW(V2.01) date: 01/30/2019
ID-1: BAT1 charge: 13.8 Wh condition: 47.9/48.0 Wh (100%) volts: 10.6/10.8
model: LG PABAS0241231 type: Li-ion serial: <filter> status: Discharging
Topology: Dual Core model: AMD PRO A4-4350B R4 5 COMPUTE CORES 2C+3G
bits: 64 type: MCP arch: Excavator family: 15 (21) model-id: 70 (112)
stepping: N/A microcode: 6006705 L2 cache: 1024 KiB
bogomips: 9985
Speed: 1297 MHz min/max: 1300/2500 MHz boost: enabled Core speeds (MHz):
1: 1404 2: 1337
Vulnerabilities: Type: l1tf status: Not affected
disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo
driver: amdgpu v: kernel bus ID: 00:01.0 chip ID: 1002:98e4
Display: x11 server: X.Org 1.20.5 driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD STONEY (DRM 3.33.0 5.3.7-2-MANJARO LLVM 9.0.0)
v: 4.5 Mesa 19.2.2 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:01.1 chip ID: 1002:15b3
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:09.2 chip ID: 1022:157a
Sound Server: ALSA v: k5.3.7-2-MANJARO
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
chip ID: 10ec:8168
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: N/A port: 3000 bus ID: 02:00.0 chip ID: 168c:0042
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 3-1.4:3
chip ID: 0cf3:e500
Local Storage: total: 465.76 GiB used: 7.98 GiB (1.7%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E660
size: 465.76 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: B230 scheme: GPT
ID-1: / raw size: 465.46 GiB size: 457.16 GiB (98.22%)
used: 7.98 GiB (1.7%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 53.9 C mobo: N/A gpu: amdgpu temp: 53 C
Processes: 161 Uptime: 1h 16m Memory: 3.80 GiB used: 1.02 GiB (27.0%)
Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
running in: xfce4-terminal inxi: 3.0.36
That adapter is known for having firmware issues, just look at the forum posts and search for a solution:
https://archived.forum.manjaro.org/search?q=QCA9377
There isn't even a driver loaded for your wifi card. I'd suggest you first try a different kernel , unless such a new Kernel is absolutely necessary. Maybe start with 4.19.
If you still have you issues afterwards this thread might help you:
Okay mate let me try and i will let you know
Mate i downgraded my kernel to 4.19 and even lesser but the problem continues
Still the driver status is N/A
Have you tried installing the kvallo firmware from Github. There are countless posts on the forum regarding this adapter. If you use kernel 4.14 or earlier you must use the version 5 firmware. On kernels 4.19 and above you must use version 6 firmware. Some people have luck renaming the version 6 firmware to version 5 (or vice versa).
There are many many different things you can attempt to fix your issue. Most have all been posted numerous times on the forum. Search your adapter model for fixes you can test. Generally you will find modifying your firmware will be the most likely solution.
Post any and all fixes you have attempted. If you want to find a solution, helpers must know exactly which methods you have attempted to correct your issue.
Mate I am new to linux, can you guide me how to install kvallo from Github
I will try those and let you know the progress mate @tbg
This should help:
https://lmgtfy.com/?q=kvallo+firmware+github&s=g
If you are having issues following links, then perhaps this excerpt may be of help:
Update firmware
First download the firmware image from the links above. In this example we use firmware-2.bin_10.1.467.2-1 from QCA988X 10.1 directory. Then just copy that file as firmware-2.bin to the ath10k firmware directory:
You will be looking to copy the firmware-6.bin
