How to add audio output - ALSA output Plugin- _Direct Hardware Without any conversions_ (Deadbeef & VLC)
Hello, hello, every one.
I'm here and write this first post because i search something in Manjaro (KDE).
I have used (and continue to use) some Debian distros base (Ubuntu flavours, Mint, MXlinux, Debian, etc...).
Distros. where i can find, in Deadbeef and VLC the setting:
Greffon de Sortie : ALSA output plugin
Périphérique de sortie: Name of the device -direct hardware devices without any conversions-
Wich i using to output to my DAC Audiophonic Usabre easily and losslessy, without messing into ALSA et Pulseaudio config files.
In Manjaro, this settings does not exist, so i have try to add them, but...
But, i 'm not able to find a way to do this in Manjaro, i haved look and read the arch man. page about ALSA, but without find my needs, or without understand how to do this, it's not impossible :grin:
I also made some research on the forum, but the only topic about this, what i find is a dead topic without great answer, started in Est European language. :thinking:
If someone know how to add this functionality to ALSA/MANJARO, i'm being very great-full (and i finaly to be able to drop MX to going on Manjaro on my daily use laptop) :grin:
-A French guy without a good English ^-^"-
(sorry if i post in the wrong channel :confused: )
EDIT : 26/04/2020 :
The solution what i have found :
I find by modify only one line in the config file:
/usr/share/alsa/alsa.conf
  • defaults.namehint.extended off
to
  • default.namehint.extended on
That make that output show-up and working identically (great :slight_smile: ) as in my Debian's distros/flavours.
i can think of two simple ways to work around Pulseaudio and play audio direct to ALSA
first is to suspend Pulseaudio completely with this command - pacmd suspend 1
to remove suspend after using Deadbeef/VLC - pacmd suspend 0
or
install Pulseaudio Volume Control - pavucontrol-qt
go to Configuration tab - pavucontrol --tab 5
find the USB DAC and change Profile: to Off
Screenshot_2020-04-14_05-03-23
Hello, thank for the reply, i look at/try this soon as possible. :slight_smile:
So, i have tried, and it's work, but it is the case before, because it is not a problem to make my DAC working, he as always working.
I think, i have made my question blurry ^^, my bad.
But, don't mind, thank you again for the help :slight_smile:
What i try to do, it's find a way, to add possibility to ALSA (i think) to set the setting :
  • Direct hardware device without any conversions
like the all distros based on Debian, i had try, have.
More precisely, this setting is available for all audio peripherals on the computer, and also them exact opposite :
  • Direct hardware device with all software conversions (which i don't use, of course ^^)
I want it, because ALSA still ressampling on the fly...
(i have find some tweaking to do in some text file but it's not flexible at all, if i choose to listen a title with a different sampling i have need to re-edit this text file according ALSA sampling and the music title sample, same fore the Bit...)
But it's not the case with this setting, all the decoding work are made by the DAC or the peripheral choosen, if it's kHz and Bits compatible (if not, speed up/down crack and glich join the party ^^).
(clearly visible on toasty pc, on the cpu usage, is nearly at zero if this no conversions ouptut is choose, and way more higher if i choose the all software conversion or the standard output )
I have checked the sampling and Bit output from ALSA, with and without this output option set, with an cli, found in obscure and unknown audiophile forum (but i don't remember it and where i found it...yep, i haven't wrote them...:confused: first error...) and it work like a charm, the result sampling changed accordingly to the listen file statistics when without any conversions is piked. And stayed to 48000kHz with all they other output option.
I don't understand why this option is not here on Manjaro, it's seem the same standard audio things are installed, Pulseaudio, Alsa, etc...
Here a print screen of my Linux mint to show what i speak :
screen_directardwr_sound
i think i see the problem
the text for ALSA devices in Manjaro is not the same as in Linux Mint
that might be due to differences between Arch and Ubuntu based distributions
but may also be due to Manjaro having later versions of kernel and ALSA packages
suggest get listing of ALSA devices in Linux Mint - aplay -L
that should be similar to list of output devices in Deadbeef
same command aplay -L in Manjaro should be similar to output devices listed in Deadbeef
for example:
the 'hardware device without any conversions' for my USB DAC is listed in aplay -L:
sysdefault:CARD=DAC
    USB Audio DAC, USB Audio
    Default Audio Device
and in Deadbeef:
Hello, thank for the reply :slight_smile:
I 'm on it, up to 4 am ^-^
And i have found this command in the night, that give me a hint. I saw in parallel the plugin page of ALSA (and more and more man. ...), and that put me on the track of the ALSA plugin hw , is used for they output, that showed me by that command.
So, i have searched how install that, but i figure is already installed, i have search how to activate setup this plugin, with partial understanding (complex text file editing) .
Next, i made some more research, and have find the config file in:
/usr/share/asla/alsa.conf
So in crazy test mode, i have fresh install Manjaro KDE a old laptop/netbook to testing some nasty things (^^) in real condition without any worry. In my Linux Mint i have copy the alsa.conf and on my Manjaro test machine, i paste the all the contents of the first file in the alsa.conf of Manjaro.
And
Tada, the option show up in Deadbeef and VLC :3 NICE!
But, i agree it's not pretty solution at all, so i have compared the file with the diff command, to look at the differences.
Some line change but not many as i was thinking. But my competence stop here, i global undertsand what append and what they lines do, but i have no idea about the meaning of the coding language :confused:
By the way, i found (again) the cli who give a check of the ALSA resampling (or not):
cat /proc/asound/card0/pcm0p/sub0/hw_params
(card0 may vary card1, card2, etc... fonction of number of audio card present)
I have made some new test with that cli on the Manjaro distro, and the results are :
  • closed when no audio is playing (obvioulsy)
  • access : MMAP_INTERLEAVED
    format : S16_LE
    subformat : STD
    channels : 2
    rate : 48000 (48000/1)
    periode_size : 44100
    buffer_size : 88200
    When i playing a 96000 khz title with Default Audio Device
    format : S16_LE
    subformat : STD
    channels : 2
    rate : 44100 (44100/1)
    buffer_size : 88200
    When i play a 88200 khz title with Default Audio Device
And when i (poorly) mod my alsa.conf the result with the same title are :
    format : S16_LE
    subformat : STD
    channels : 2
    rate : 96000 (96000/1)
    periode_size : 1024 (i think it's the setup in deadbeef in the ALSA section made that change)
    buffer_size : 8192 (i think it's the setup in deadbeef in the ALSA section made that change)
    When i playing a 96000 khz title with Direct hardware device without any conversions
    format : S16_LE
    subformat : STD
    channels : 2
    periode_size : 1024
    buffer_size : 8192
    When i playing a 88200 khz title with Direct hardware device without any conversions
    (because the card actually put in test is not compatible, and temporary, so it's spead up the song , but it's not a problem :yum: )
It's clearly make something and work.
So, now, i need to understand what part in the alsa.conf make that ... and i not a developer :sweat_smile:
They files alsa.conf and they differences are :
  • What i have that in mint :
#  ALSA library configuration file
# pre-load the configuration files
@hooks [
		func load
		files [
				@func concat
				strings [
					{ @func datadir }
					"/alsa.conf.d/"
			"/etc/asound.conf"
			"~/.asoundrc"
		errors false
# load card-specific configuration files (on request)
cards.@hooks [
		func load
		files [
				@func concat
				strings [
					{ @func datadir }
					"/cards/aliases.conf"
		func load_for_all_cards
		files [
				@func concat
				strings [
					{ @func datadir }
					"/cards/"
					{ @func private_string }
					".conf"
		errors false
# defaults
# show all name hints also for definitions without hint {} section
defaults.namehint.showall on
# show just basic name hints
defaults.namehint.basic on
# show extended name hints
defaults.namehint.extended on
defaults.ctl.card 0
defaults.pcm.card 0
defaults.pcm.device 0
defaults.pcm.subdevice -1
defaults.pcm.nonblock 1
defaults.pcm.compat 0
defaults.pcm.minperiodtime 5000		# in us
defaults.pcm.ipc_key 5678293
defaults.pcm.ipc_gid audio
defaults.pcm.ipc_perm 0660
defaults.pcm.dmix.max_periods 0
defaults.pcm.dmix.rate 48000
defaults.pcm.dmix.format "unchanged"
defaults.pcm.dmix.card defaults.pcm.card
defaults.pcm.dmix.device defaults.pcm.device
defaults.pcm.dsnoop.card defaults.pcm.card
defaults.pcm.dsnoop.device defaults.pcm.device
defaults.pcm.front.card defaults.pcm.card
defaults.pcm.front.device defaults.pcm.device
defaults.pcm.rear.card defaults.pcm.card
defaults.pcm.rear.device defaults.pcm.device
defaults.pcm.center_lfe.card defaults.pcm.card
defaults.pcm.center_lfe.device defaults.pcm.device
defaults.pcm.side.card defaults.pcm.card
defaults.pcm.side.device defaults.pcm.device
defaults.pcm.surround21.card defaults.pcm.card
defaults.pcm.surround21.device defaults.pcm.device
defaults.pcm.surround40.card defaults.pcm.card
defaults.pcm.surround40.device defaults.pcm.device
defaults.pcm.surround41.card defaults.pcm.card
defaults.pcm.surround41.device defaults.pcm.device
defaults.pcm.surround50.card defaults.pcm.card
defaults.pcm.surround50.device defaults.pcm.device
defaults.pcm.surround51.card defaults.pcm.card
defaults.pcm.surround51.device defaults.pcm.device
defaults.pcm.surround71.card defaults.pcm.card
defaults.pcm.surround71.device defaults.pcm.device
defaults.pcm.iec958.card defaults.pcm.card
defaults.pcm.iec958.device defaults.pcm.device
defaults.pcm.modem.card defaults.pcm.card
defaults.pcm.modem.device defaults.pcm.device
# truncate files via file or tee PCM
defaults.pcm.file_format	"raw"
defaults.pcm.file_truncate	true
defaults.rawmidi.card 0
defaults.rawmidi.device 0
defaults.rawmidi.subdevice -1
defaults.hwdep.card 0
defaults.hwdep.device 0
defaults.timer.class 2
defaults.timer.sclass 0
defaults.timer.card 0
defaults.timer.device 0
defaults.timer.subdevice 0
#  PCM interface
# redirect to load-on-demand extended pcm definitions
pcm.cards cards.pcm
pcm.default cards.pcm.default
pcm.sysdefault cards.pcm.default
pcm.front cards.pcm.front
pcm.rear cards.pcm.rear
pcm.center_lfe cards.pcm.center_lfe
pcm.side cards.pcm.side
pcm.surround21 cards.pcm.surround21
pcm.surround40 cards.pcm.surround40
pcm.surround41 cards.pcm.surround41
pcm.surround50 cards.pcm.surround50
pcm.surround51 cards.pcm.surround51
pcm.surround71 cards.pcm.surround71
pcm.iec958 cards.pcm.iec958
pcm.spdif iec958
pcm.hdmi cards.pcm.hdmi
pcm.dmix cards.pcm.dmix
pcm.dsnoop cards.pcm.dsnoop
pcm.modem cards.pcm.modem
pcm.phoneline cards.pcm.phoneline
pcm.hw {
	@args [ CARD DEV SUBDEV ]
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_PCM_CARD
				ALSA_CARD
			default {
				@func refer
				name defaults.pcm.card
	@args.DEV {
		type integer
		default {
			@func igetenv
			vars [
				ALSA_PCM_DEVICE
			default {
				@func refer
				name defaults.pcm.device
	@args.SUBDEV {
		type integer
		default {
			@func refer
			name defaults.pcm.subdevice
	type hw
	card $CARD
	device $DEV
	subdevice $SUBDEV
	hint {
		show {
			@func refer
			name defaults.namehint.extended
		description "Direct hardware device without any conversions"
pcm.plughw {
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_PCM_CARD
				ALSA_CARD
			default {
				@func refer
	@args.DEV {
		type integer
		default {
			@func igetenv
			vars [
				ALSA_PCM_DEVICE
			default {
				@func refer
	@args.SUBDEV {
		type integer
		default {
			@func refer
	type plug
	slave.pcm {
		type hw
		card $CARD
		device $DEV
		subdevice $SUBDEV
	hint {
		show {
			@func refer
		description "Hardware device with all software conversions"
pcm.plug {
	@args [ SLAVE ]
	@args.SLAVE {
		type string
	type plug
	slave.pcm $SLAVE
pcm.shm {
	@args [ SOCKET PCM ]
	@args.SOCKET {
		type string
	@args.PCM {
		type string
	type shm
	server $SOCKET
	pcm $PCM
pcm.tee {
	@args [ SLAVE FILE FORMAT ]
	@args.SLAVE {
		type string
	@args.FILE {
		type string
	@args.FORMAT {
		type string
		default {
			@func refer
			name defaults.pcm.file_format
	type file
	slave.pcm $SLAVE
	file $FILE
	format $FORMAT
	truncate {
		@func refer
		name defaults.pcm.file_truncate
pcm.file {
	@args [ FILE FORMAT ]
	@args.FILE {
		type string
	@args.FORMAT {
		type string
		default {
			@func refer
	type file
	slave.pcm null
	file $FILE
	format $FORMAT
	truncate {
		@func refer
pcm.null {
	type null
	hint {
		show {
			@func refer
			name defaults.namehint.basic
		description "Discard all samples (playback) or generate zero samples (capture)"
#  Control interface
ctl.sysdefault {
	type hw
	card {
		@func getenv
		vars [
			ALSA_CTL_CARD
			ALSA_CARD
		default {
			@func refer
			name defaults.ctl.card
	hint.description "Default control device"
ctl.default ctl.sysdefault
ctl.hw {
	@args [ CARD ]
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_CTL_CARD
				ALSA_CARD
			default {
				@func refer
	type hw
	card $CARD
	hint.description "Direct control device"
ctl.shm {
	@args [ SOCKET CTL ]
	@args.SOCKET {
		type string
	@args.CTL {
		type string
	type shm
	server $SOCKET
	ctl $CTL
#  RawMidi interface
rawmidi.default {
	type hw
	card {
		@func getenv
		vars [
			ALSA_RAWMIDI_CARD
			ALSA_CARD
		default {
			@func refer
			name defaults.rawmidi.card
	device {
		@func igetenv
		vars [
			ALSA_RAWMIDI_DEVICE
		default {
			@func refer
			name defaults.rawmidi.device
	hint.description "Default raw MIDI device"
rawmidi.hw {
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_RAWMIDI_CARD
				ALSA_CARD
			default {
				@func refer
	@args.DEV {
		type integer
		default {
			@func igetenv
			vars [
				ALSA_RAWMIDI_DEVICE
			default {
				@func refer
	@args.SUBDEV {
		type integer
		default -1
	type hw
	card $CARD
	device $DEV
	subdevice $SUBDEV
	hint {
		description "Direct rawmidi driver device"
		device $DEV
rawmidi.virtual {
	@args [ MERGE ]
	@args.MERGE {
		type string
		default 1
	type virtual
	merge $MERGE
#  Sequencer interface
seq.default {
	type hw
	hint.description "Default sequencer device"
seq.hw {
	type hw
#  HwDep interface
hwdep.default {
	type hw
	card {
		@func getenv
		vars [
			ALSA_HWDEP_CARD
			ALSA_CARD
		default {
			@func refer
			name defaults.hwdep.card
	device {
		@func igetenv
		vars [
			ALSA_HWDEP_DEVICE
		default {
			@func refer
			name defaults.hwdep.device
	hint.description "Default hardware dependent device"
hwdep.hw {
	@args [ CARD DEV ]
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_HWDEP_CARD
				ALSA_CARD
			default {
				@func refer
	@args.DEV {
		type integer
		default {
			@func igetenv
			vars [
				ALSA_HWDEP_DEVICE
			default {
				@func refer
	type hw
	card $CARD
	device $DEV
	hint {
		description "Direct hardware dependent device"
		device $DEV
#  Timer interface
timer_query.default {
	type hw
timer_query.hw {
	type hw
timer.default {
	type hw
	class {
		@func refer
		name defaults.timer.class
	sclass {
		@func refer
		name defaults.timer.sclass
	card {
		@func refer
		name defaults.timer.card
	device {
		@func refer
		name defaults.timer.device
	subdevice {
		@func refer
		name defaults.timer.subdevice
	hint.description "Default timer device"
timer.hw {
	@args [ CLASS SCLASS CARD DEV SUBDEV ]
	@args.CLASS {
		type integer
		default {
			@func refer
	@args.SCLASS {
		type integer
		default {
			@func refer
	@args.CARD {
		type string
		default {
			@func refer
	@args.DEV {
		type integer
		default {
			@func refer
	@args.SUBDEV {
		type integer
		default {
			@func refer
	type hw
	class $CLASS
	sclass $SCLASS
	card $CARD
	device $DEV
	subdevice $SUBDEV
	hint {
		description "Direct timer device"
		device $DEV
  • What i have in Manjaro:
@hooks [
		func load
		files [
			"/etc/alsa/conf.d"
			"/etc/asound.conf"
			"~/.asoundrc"
		errors false
cards.@hooks [
		func load
		files [
				@func concat
				strings [
					{ @func datadir }
		files [
				@func concat
				strings [
					{ @func datadir }
					"/cards/"
					".conf"
		errors false
# defaults
defaults.namehint.showall off
defaults.ctl.card 0
defaults.pcm.card 0
defaults.pcm.dmix.channels 2
#  PCM interface
pcm.cards cards.pcm
pcm.spdif iec958
pcm.hw {
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_PCM_CARD
				ALSA_CARD
			default {
				@func refer
	@args.DEV {
		type integer
		default {
			@func igetenv
			vars [
				ALSA_PCM_DEVICE
			default {
				@func refer
	@args.SUBDEV {
		type integer
		default {
			@func refer
	type hw
	card $CARD
	device $DEV
	subdevice $SUBDEV
	hint {
		show {
			@func refer
pcm.plughw {
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_PCM_CARD
				ALSA_CARD
			default {
				@func refer
	@args.DEV {
		type integer
		default {
			@func igetenv
			vars [
				ALSA_PCM_DEVICE
			default {
				@func refer
	@args.SUBDEV {
		type integer
		default {
			@func refer
	type plug
	slave.pcm {
		type hw
		card $CARD
		device $DEV
		subdevice $SUBDEV
	hint {
		show {
			@func refer
pcm.plug {
	@args [ SLAVE ]
	@args.SLAVE {
		type string
	type plug
	slave.pcm $SLAVE
pcm.shm {
	@args.SOCKET {
		type string
	@args.PCM {
		type string
	type shm
	server $SOCKET
	pcm $PCM
pcm.tee {
	@args.SLAVE {
		type string
	@args.FILE {
		type string
	@args.FORMAT {
		type string
		default {
			@func refer
	type file
	slave.pcm $SLAVE
	file $FILE
	format $FORMAT
	truncate {
		@func refer
pcm.file {
	@args.FILE {
		type string
	@args.FORMAT {
		type string
		default {
			@func refer
	type file
	slave.pcm null
	file $FILE
	format $FORMAT
	truncate {
		@func refer
pcm.null {
	type null
	hint {
		show {
			@func refer
#  Control interface
ctl.sysdefault {
	type hw
	card {
		@func getenv
		vars [
			ALSA_CTL_CARD
			ALSA_CARD
		default {
			@func refer
ctl.hw {
	@args [ CARD ]
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_CTL_CARD
				ALSA_CARD
			default {
				@func refer
	type hw
	card $CARD
ctl.shm {
	@args.SOCKET {
		type string
	@args.CTL {
		type string
	type shm
	server $SOCKET
	ctl $CTL
#  RawMidi interface
rawmidi.default {
	type hw
	card {
		@func getenv
		vars [
			ALSA_RAWMIDI_CARD
			ALSA_CARD
		default {
			@func refer
	device {
		@func igetenv
		vars [
			ALSA_RAWMIDI_DEVICE
		default {
			@func refer
rawmidi.hw {
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_RAWMIDI_CARD
				ALSA_CARD
			default {
				@func refer
	@args.DEV {
		type integer
		default {
			@func igetenv
			vars [
				ALSA_RAWMIDI_DEVICE
			default {
				@func refer
	@args.SUBDEV {
		type integer
		default -1
	type hw
	card $CARD
	device $DEV
	subdevice $SUBDEV
	hint {
		device $DEV
rawmidi.virtual {
	@args [ MERGE ]
	@args.MERGE {
		type string
		default 1
	type virtual
	merge $MERGE
seq.default {
	type hw
seq.hw {
	type hw
#  HwDep interface
hwdep.default {
	type hw
	card {
		@func getenv
		vars [
			ALSA_HWDEP_CARD
			ALSA_CARD
		default {
			@func refer
	device {
		@func igetenv
		vars [
			ALSA_HWDEP_DEVICE
		default {
			@func refer
hwdep.hw {
	@args [ CARD DEV ]
	@args.CARD {
		type string
		default {
			@func getenv
			vars [
				ALSA_HWDEP_CARD
				ALSA_CARD
			default {
				@func refer
	@args.DEV {
		type integer
		default {
			@func igetenv
			vars [
				ALSA_HWDEP_DEVICE
			default {
				@func refer
	type hw
	card $CARD
	device $DEV
	hint {
		device $DEV
#  Timer interface
	type hw
timer_query.hw {
	type hw
timer.default {
	type hw
	class {
		@func refer
	sclass {
		@func refer
	card {
		@func refer
	device {
		@func refer
	subdevice {
		@func refer
timer.hw {
	@args.CLASS {
		type integer
		default {
			@func refer
	@args.SCLASS {
		type integer
		default {
			@func refer
	@args.CARD {
		type string
		default {
			@func refer
	@args.DEV {
		type integer
		default {
			@func refer
	@args.SUBDEV {
		type integer
		default {
			@func refer
	type hw
	class $CLASS
	sclass $SCLASS
	card $CARD
	device $DEV
	subdevice $SUBDEV
	hint {
		device $DEV
  • They diffences between they two files (with the diff command) :
11,17c11
< 				@func concat
< 				strings [
< 					{ @func datadir }
< 					"/alsa.conf.d/"
> 			"/etc/alsa/conf.d"
62c56
< defaults.namehint.showall on
66c60
< defaults.namehint.extended on
78a73
If you have an idea what change activate this output i taking :slight_smile:
Thank again for you time and you help :3
Well, after some many more hours of try and error, i have tweaking around that alsa.conf and made some incremental change by replace one by one, they differences
(because, maybe i don't understand that language, but i'm pretty skilled at Mastermind, so go for that strategy :rofl: ).
And i find By changing only the line (in /usr/share/alsa/alsa.conf ) :
to
I made it work ! :grin:
That output is show up and the line cat /proc/asound/card0/pcm0p/sub0/hw_params show me good result (what i wanted to see :3 )
It's seem too simple to be thru :confused: but meh i take that :slight_smile:
I need to search what is default.namehint.extend *** or what they do.
(and need see if this setup stay after kernel updating
Edit: i have made some manual kernel downgrade and upgrade, and the setting stay. )
By the way thank you for your help, after all you put me on the good track :3
(later, i think about editing my first post to put in the solution what have found, for more clarity , if it is possible also the title to put resolve or something like that. May be useful for some audiophile ^-^ )
I guess all this is rooted in an assumption there is some
unwanted manipulation on the audio signal happening in case you use a device named different to direct hardware devices without any conversions. This is not the case.
I'm sorry, i don't totally understand what you mean... You said the audio thru the DAC are lossless by default ? This is that ?
Exactly.
:confused: I'm not so sure about that, firstly because the appellation :
And because my test with :
Show me when an high khz music title is playing, it is play at 48000 in place of the original 96000 when this output option is not chosen. Same thing for an tilte at 88200, it is played at 44100 khz.
But with the direct output i have this results more like what i want (and they periode_size and buffer_size are they numbers in the Deadbeef player from the alsa greffon, they data make me think, they are direct send from the player to the audiocard/DAC) :
Have you something to help me to check if, it is true lossless ("bitperfect") at stock setting ?
Like a CLI, or something ?
Because at this state, i'm sorry, but don't totally agree with that.
But if i was wrong (it is one possibility :slight_smile: ), i want to know how too demonstrate it.
Fine by me, you don't have to.
Here's my alsa.conf excerpt:
cat /usr/share/alsa/alsa.conf | grep hint
No samplerate conversion happening.
You might want to have a look at this:
https://alsa-project.org/wiki/DeviceNames#hw
