Fast, Simple, Powerful... Grav is a modern flat-file CMS system that focuses on making web development fun again. It received the CMS Critic Award for Best Flat File CMS
several years consecutively. They say that there is Zero installation required. Just extract the ZIP archive, and you are already up and running. Up and running? Well...
I installed grav-admin from AUR and a directory named grav-admin was created in /usr/share/webapps/, not in the /srv/http/ folder. I searched the web for a solution and according to the instructions found on Reddit I opened the /etc/httpd/conf/httpd.conf file and changed both DocumentRoot "/opt/lampp/htdocs" and <Directory "/opt/lampp/htdocs"> accordingly, so they point to "/usr/share/webapps/".
Now when I open localhost or 127.0.1.1 or 127.0.0.1/grav-admin the browser detects the installation as it correctly redirects to 127.0.1.1/grav-admin/admin subfolder, but instead of the Grav Admin panel I get a 404 not found error.
I checked their Troubleshooting guide, but the things that I know what they mean are there:
.htaccess file is not missing, LoadModule rewrite_module modules/mod_rewrite.so is uncommented, their .htaccess Test Script runs fine and
mv .htaccess .htaccess-backup moves the file if I add sudo in front of it (I don't know if this is considered as test passed or not).
The other solutions don't seem relevant to me as my LAMP setup works fine otherways: test index.html and test.php load fine, Adminer also, and even my YII framework project works as expected. So I suspect there is something wrong with how the grav-admin that is on AUR is configured or that it just doesn't play well with Manjaro?
Any help would be appreciated!
