How to get wayland+nvidia working under plasma
Moderation Note: Moved from Plasma is Great!
Guys, has anyone managed to run a Plasma Wayland session with Nvidia proprietary drivers and VDPAU as backend? I'm only getting software rendering.
http://blog.davidedmundson.co.uk/blog/running-kwin-wayland-on-nvidia/
I have it running on arch with a gtx970 its a bit hit and miss though...
I'm starting to think that I can't get HW acceleration to work because of the way drivers are installed in Manjaro. On which driver did you manage to get it to run on and what are the outputs of vdpauinfo and vainfo ?
the latest nvidia 440.82
vdpauinfo
Xlib: extension "NV-GLX" missing on display ":1".
Error creating VDPAU device: 1
vainfo
libva error: vaGetDriverNameByIndex() failed with invalid VADisplay, driver_name = (null)
vaInitialize failed with error code 3 (invalid VADisplay),exit
Not sure what all that means, I assume No VDPAU?
Just started messing around with it the other day so I can report bugs etc, I was very surprised how smooth and snappy the desktop was :wink:
same here. The outputs should look more like this:
[george@george-pc ~]$ vainfo
vainfo: VA-API version: 1.7 (libva 2.7.1)
vainfo: Driver version: Splitted-Desktop Systems VDPAU backend for VA-API - 0.7.4
vainfo: Supported profile and entrypoints
      VAProfileMPEG2Simple            : VAEntrypointVLD
      VAProfileMPEG2Main              : VAEntrypointVLD
      VAProfileMPEG4Simple            : VAEntrypointVLD
      VAProfileMPEG4AdvancedSimple    : VAEntrypointVLD
      <unknown profile>               : VAEntrypointVLD
      VAProfileH264Main               : VAEntrypointVLD
      VAProfileH264High               : VAEntrypointVLD
      VAProfileVC1Simple              : VAEntrypointVLD
      VAProfileVC1Main                : VAEntrypointVLD
      VAProfileVC1Advanced            : VAEntrypointVLD
[george@george-pc ~]$ vdpauinfo
display: :0   screen: 0
API version: 1
Information string: NVIDIA VDPAU Driver Shared Library  440.82  Wed Apr  1 19:39:06 UTC 2020
Video surface:
name   width height types
420     8192  8192  NV12 YV12
422     8192  8192  UYVY YUYV
444     8192  8192  NV24 YV24
Decoder capabilities:
name                        level macbs width height
MPEG1                           0 65536  4096  4096
MPEG2_SIMPLE                    3 65536  4096  4096
MPEG2_MAIN                      3 65536  4096  4096
H264_BASELINE                  51 65536  4096  4096
H264_MAIN                      51 65536  4096  4096
H264_HIGH                      51 65536  4096  4096
VC1_SIMPLE                      1  8190  2048  2048
VC1_MAIN                        2  8190  2048  2048
VC1_ADVANCED                    4  8190  2048  2048
MPEG4_PART2_SP                  3  8192  2048  2048
MPEG4_PART2_ASP                 5  8192  2048  2048
DIVX4_QMOBILE                   0  8192  2048  2048
DIVX4_MOBILE                    0  8192  2048  2048
DIVX4_HOME_THEATER              0  8192  2048  2048
DIVX4_HD_1080P                  0  8192  2048  2048
DIVX5_QMOBILE                   0  8192  2048  2048
DIVX5_MOBILE                    0  8192  2048  2048
DIVX5_HOME_THEATER              0  8192  2048  2048
DIVX5_HD_1080P                  0  8192  2048  2048
H264_CONSTRAINED_BASELINE      51 65536  4096  4096
H264_EXTENDED                  51 65536  4096  4096
H264_PROGRESSIVE_HIGH          51 65536  4096  4096
H264_CONSTRAINED_HIGH          51 65536  4096  4096
H264_HIGH_444_PREDICTIVE       51 65536  4096  4096
VP9_PROFILE_0                   1 262144  8192  8192
VP9_PROFILE_1                  --- not supported ---
VP9_PROFILE_2                  --- not supported ---
VP9_PROFILE_3                  --- not supported ---
HEVC_MAIN                      153 262144  8192  8192
HEVC_MAIN_10                   --- not supported ---
HEVC_MAIN_STILL                --- not supported ---
HEVC_MAIN_12                   --- not supported ---
HEVC_MAIN_444                  --- not supported ---
HEVC_MAIN_444_10               --- not supported ---
HEVC_MAIN_444_12               --- not supported ---
Output surface:
name              width height nat types
B8G8R8A8         32768 32768    y  Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
R10G10B10A2      32768 32768    y  Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
Bitmap surface:
name              width height
R8G8B8A8         32768 32768
B10G10R10A2      32768 32768
A8               32768 32768
Video mixer:
feature name                    sup
DEINTERLACE_TEMPORAL             y
DEINTERLACE_TEMPORAL_SPATIAL     y
INVERSE_TELECINE                 y
NOISE_REDUCTION                  y
SHARPNESS                        y
LUMA_KEY                         y
HIGH QUALITY SCALING - L1        y
HIGH QUALITY SCALING - L2        -
HIGH QUALITY SCALING - L3        -
HIGH QUALITY SCALING - L4        -
HIGH QUALITY SCALING - L5        -
HIGH QUALITY SCALING - L6        -
HIGH QUALITY SCALING - L7        -
HIGH QUALITY SCALING - L8        -
HIGH QUALITY SCALING - L9        -
parameter name                  sup      min      max
VIDEO_SURFACE_WIDTH              y         1     8192
VIDEO_SURFACE_HEIGHT             y         1     8192
CHROMA_TYPE                      y
LAYERS                           y         0        4
attribute name                  sup      min      max
BACKGROUND_COLOR                 y
CSC_MATRIX                       y
NOISE_REDUCTION_LEVEL            y      0.00     1.00
SHARPNESS_LEVEL                  y     -1.00     1.00
LUMA_KEY_MIN_LUMA                y
LUMA_KEY_MAX_LUMA                y
Then we could potentially take advantage of the hardware accelerated browsing in Firefox with:
https://wiki.archlinux.org/index.php/Firefox#Hardware_video_acceleration
and a translation layer. But I just can't get it to work. I've tried blacklisting Mesa, various Kernels and video driver combinations, I've exported VDPAU_DRIVER=nvidia & LIBVA_DRIVER_NAME=vdpau. Tried different combinations of EGL packages, egl-wayland, eglexternalplatform. If you change the rendering backend, you get an orange screen of death. This is confirmed in Nvidia's linux dev forums. I thought it could be different on a clean Arch with different drivers but apparently it isn't..
I don't know what david edmundson did but he seems to have it working without many problems, while I have it working to a certain extent firefox works fine and most programs open, there are some gfx glitches, hovering over the menu some items disappear, changing theme etc will give me a black screen with a cursor.
I don't think its worth messing around with at the moment, well, if only for reporting bugs, helping find issues etc, although Plenty of issues being reported but no fixes
https://bugs.kde.org/buglist.cgi?quicksearch=wayland&list_id=1755659
If i find anything out I will report back here :wink:
he used the nouveau drivers! :smiley:
