How to ignore `Can't load /etc/samba/smb.conf - run testparm to debug it` when open dolphin in Konsole?
As I found a solution: install manjaro-settings-samba from this thread Cant use samba ? No smb.conf or smb.conf.default
But is there another way to let dolphin not check smba? As I never used it.
Just and idea - may not work at all - create a bogus file
sudo mkdir /etc/samba
sudo touch /etc/samba/smb.conf
Hi, @linux-aarhus. I'm not sure, but anyway bogus file worked.
