How to mount my phone from a terminal?
Hi!
When I connected my phone, set it to MTP mode and opened Thunar (or any file manager), my phone appears on the left panel. It's not mounted, which I can see in a terminal:
~ $ cd /run/user/$UID/gvfs
gvfs $ LC_ALL=C ll
total 0
gvfs $
When clicking the phone icon in Thunar the phone is mounted:
gvfs $ LC_ALL=C ll
total 0
dr-x------ 1 $USER $USER 0 1970-01-01 01:00 mtp:host=PhoneBrand_PhoneModel_AHexNumber
My questions are:
  1. How can I make my phone mount automatically when it's plugged in and set to MTP mode?
  2. How can I mount the phone from the terminal? I guess the mount command won't do, since this is a phone and not a hard drive or similar. I've found a lot of guides on how to mount smartphones, but none so far on how to mount smartphones in a terminal.
I guess what you are searching is this: https://wiki.archlinux.org/index.php/Media_Transfer_Protocol#File_manager_integration
:wink:
With file manager nnn and sshfs/rclone you can mount not only your mobile phone but also any cloud sharing service like Dropbox in a few keystrokes. For phone, instead of MTP mode, you need to have a SSH server running on it.
Here's the relevant wiki section with mode details: https://github.com/jarun/nnn/wiki/Basic-use-cases#remote-mounts
Please feel free to ask any questions. I am the author.
Yes, thanks! That helped a lot! :slight_smile:
Thanks for that information! Look promising. :slight_smile:
