How to remove the driver and restore the system?
video card and processor ATI AMD I accidentally installed Nvidia-340xx-utils and after restarting the computer Linux stopped loading how to fix it?IMG_20200808_101844_412
I guess you would need to use your live usb, chroot to your installed system and uninstall the package you have installed. Here is how to chroot:
open a terminal and type sudo manjaro-chroot -a (if only one linux system type 1 instead of 0).
When done type exit to quit the chroot. Reboot and hopefully you will be able to boot back into your system.
