How to run script properly at startup to automount google drive (gcsf)?
There is this AUR package gcsf which works great. However I don't want to remount the drive manually after every reboot and would like this to happen automatically. Moreover when I do this manually the script must remain running in the terminal window and I can't kill it or it will terminate the program. So I would like this script to run in the background without any GUI attachment or visibly open terminal window.
Added a file "~/.config/autostart-scripts/googledrive"
with content:
gcsf mount ~/googledrive -s deemon
gave it +x with chmod
it does show up in Settings => Startup and Shutdown => Autostart => under scripts as Enabled and run on startup.
however it doesn't seem to have any effect and the mounting does not happen.
(when I run the script from command line manually, it works perfectly.)
What am I doing wrong? :blush:
Or is there a better way (create service for it?) to make the mount happen automatically at login?
Check the logs to see what is preventing from doing this task.
I can move it. Don't need to create a new one.
From terminal
gcsf login deemon
That will prompt you for authorization, then create the credential file gcsf.toml in it's place.
then run
In KDE Plasma is better to make use of *.desktop files inside ~/.config/autostart to have something running automatically.
Call it as you like it, gcsf.desktop would work.
For you it means should be like this:
[Desktop Entry]
Name=googledrive mount
Icon=googledrive
Exec=gcsf mount ~/googledrive -s deemon
Terminal=false
StartupNotify=true
Type=Application
X-KDE-SubstituteUID=false
or instead of Exec=gcsf mount ~/googledrive -s deemon
to point to the script you have
Exec=/home/deemon/.config/autostart-scripts/googledrive.sh
Thank you very much! Now it works perfectly. :smile:
used the Exec=gcsf version for simplicity and for no additional files needed.
Although there is this "StartupNotify=true" I didn't see any notifications about it starting up. Where should it output this?
Not quite sure if is creating a notification automatically or not, or you have to create one, manually by adding a file in ~/.local/share/knotifications5/ and call it for instance gcsf.notifyrc and add this lines to it:
[Global]
IconName=googledrive
Comment=Notification for googledrive mount
[Event/startup]
Name=gcsf mount
Comment=Your googledrive has been mounted
Action=
Sound=
Then in Notifications settings you chose more options.
Or maybe that line can be removed from the gcsf.desktop file :slight_smile:
Edit: i had to make some corrections.
