Hi really thanks for the replay and sorry for missing important information.
Basic info here:
System: Manjaro 18.1.5
Desktop: Xfce
GPU: Nvidia GTX 1060 & Intel
Driver: Video-hybrid-intel-nvidia-440xx-prime
I followed this link to configure the driver.
The following are from "inxi -Fxxxza --no-host":
Kernel: 5.5.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.5-x86_64
root=UUID=6af0b398-1d9e-43bf-a243-0f8345574cc7 rw quiet
udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.13 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Alienware product: Alienware 15 R3 v: 1.6.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Alienware model: Alienware 15 R3 v: 000 serial: <filter>
UEFI: Alienware v: 1.6.0 date: 11/15/2018
ID-1: BAT1 charge: 19.9 Wh condition: 19.9/68.0 Wh (29%) volts: 16.8/15.2
model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Full
Topology: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: D6
L2 cache: 6144 KiB
bogomips: 41621
Speed: 900 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 900 2: 900
3: 900 4: 901 5: 900 6: 900 7: 900 8: 900
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:191b
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Dell
driver: nvidia v: 440.59 bus ID: 01:00.0 chip ID: 10de:1c20
Display: x11 server: X.Org 1.20.7 driver: modesetting,nvidia
resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1060/PCIe/SSE2 v: 4.6.0 NVIDIA 440.59
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Sound Server: ALSA v: k5.5.2-1-MANJARO
Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Dell
driver: alx v: kernel port: d000 bus ID: 3d:00.0 chip ID: 1969:e0a1
IF: enp61s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Bigfoot Networks driver: ath10k_pci v: kernel port: d000
bus ID: 3e:00.0 chip ID: 168c:003e
IF: wlp62s0 state: up mac: <filter>
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-5:4
chip ID: 0cf3:e300
Local Storage: total: 1.14 TiB used: 23.98 GiB (2.0%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: THNSN5256GPUK NVMe 256GB
size: 238.47 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 5KDA4101 scheme: GPT
ID-2: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A3W0 scheme: GPT
ID-1: / raw size: 930.89 GiB size: 915.27 GiB (98.32%)
used: 23.98 GiB (2.6%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 59 C
Processes: 260 Uptime: 5h 50m Memory: 15.51 GiB used: 3.46 GiB (22.3%)
Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
running in: xfce4-terminal inxi: 3.0.37
I also installed "lxrandr 0.3.2-1" for dual screen display, and when connected, for "xrandr" command:
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
HDMI-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 59.93*+ 60.00 59.94 50.00 60.00 50.04 50.04
1680x1050 59.95
1600x900 75.00 60.00
1440x900 59.89
1280x1024 75.02 70.00 60.02
1280x720 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
eDP-1-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 60.00*+ 59.96 59.93
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1368x768 59.88 59.85
1280x800 59.81 59.91
1280x720 59.86 59.74
1024x768 60.00
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1-2 disconnected (normal left inverted right x axis y axis)
HDMI-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
HDMI-1-3 disconnected (normal left inverted right x axis y axis)
1920x1080 (0x1be) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1680x1050 (0x1c5) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1280x1024 (0x1cb) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1024x768 (0x1d1) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1d4) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x1d5) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
640x480 (0x1da) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
Sorry for the late reply, any info I missed, please let me know. Thanks!!!
