How to write/edit a proper and easily readable Discourse forum post
To create an easily read post, proper formatting is a must!
Terminal output
The most important!!!
For terminal output, text output which disables forum formatting for special characters, use Code wrapping (Pre-formated text):
  • It's easily done automatically with a shortcut. Select your text and press Ctrl - Shift+C
  • Full Paragraph text (manually)
    Create opening line with 3 "back-ticks" ` write or paste text and add on more similar line at the end of text.
Code text Bold text
Code text **No Bold text**
  • Inline code (manually)
    Enclose phrase with one "back-tick" `
Use `sudo` for root privs
Use sudo for root privs
Quoting paragraph (which is too often mis-used for code output :disappointed_relieved:):
  • Start the paragraph with >
>My super Quote
My super Quote
  • For combining paragraphes and/or empty lines, use more of this >
> Nice idea
> One more idea
Nice idea
One more idea
Section titles
Start paragraph with 1 to 5 # followed by a space, like
# Highest level
Highest level
## 2nd Highest level
2nd Highest level
### 3nd Highest level
3nd Highest level
Separate sections with a horizontal line
  • Create an empty paragraph line (with Enter) followed by a line with three dashes
Create lists
  • For Ordered list start the line with a number (in sequence), a dot and a space
1. First
2. Second
3. Third
  1. First
  2. Second
  3. Third
  • Unordered list, start with asterisk and space
* Think
* Draw
* Paint
  • Think
  • Draw
  • Paint
Disable special characters preceding it with backslash \
This is \*not bold*
This is *not bold*
Most of the above can be used with just "Select text" and click a button at the Post Edit Toolbar, on which, hovering, you can see their keyboard shortcuts.
And now...
Use the Power wisely!!
Bumblebee wont launch Nvidia driver
After fresh installation of Manjaro XFCE Windows 10 doesn't open
Login screen broken after last update
Manjaro goes black screen on boot up
Most settings are lost after every restart (sound, chrome default, mudita24/envy24control) [SOLVED]
[drm:intel_pipe_update_end [i915]] ERROR Atomic update failure on pipe A @ KabyLake Refresh
Polybar crashes system when using the intel GPU
Graphic drivers no longer outputting on three screens simultaneously.
enable 4k resolution external monitor
USB Ports stop working
Dual display blacks out 15 seconds after login
Xrandr: Configure crtc 0 failed
Can multiple commands be input and then enter once to activate in sequence?
[求助]无法安装intel+nVidia混合驱动
lxqt qt5ct don't save changes
Backlight problem at startup
Grub not showing when Dual Booted with Windows 10 (Worked fine before)
Bumblebee error - Could not enable discrete graphics card
Manjaro on acid (i915)
Boot problems - only seeing 1 out of 3 distros installed
Black screen after lock the screen
Cant paste text copied from Writer
Grub not showing up after fresh install (Manjaro 18 GNOME/HP Elitebook 8460p)
My System Is Broke? Newbie Needing Some Help
GParted - Long Delay Scanning All Devices in 4.19
Show mounted disc
Install Works, but black screen after login
Graphical Glitches after login (xfce)
Lost Manjaro - won't boot up - use Deja Dup Backup
No grub menu after manjaro installation
How to change video drivers or configuration and troubleshoot
GDM becoming unstable after switching to Nvidia-driver
Polishing my LxQT (personal checklist, plus occasional questions, and taking app recommendations)
Unable to maximize windows with multiple screens
Monitor flickering after suspend
MacBook Air won't turn on without USB Wifi inserted?
Tried to install Manjaro now I can't get into anything.
GNOME, two monitors and Qt problems.
New installation of Manjaro XFCE to its own hdd
Manjaro is refusing to read a HDD of mine causing the system to hang up; it runs fine in a live USB session
nVidia GK106GLM Quadro K2100M driver
How do I Set Up Dual Monitors? - KDE Plasma
reboot fails
plasma widget notes not displayed when starting from control panel since stable update 2019-28-10
RX580 Dual Monitor Display Issue
nvidia x driver errors
Login displayed on external disabled monitor
[solved with kernel downgrade] External USB disk not recognized
Kde login screen - display does not update even though mouse cursor works
[SOLVED]Conky double buffer error
