[HowTo] Automatically retrieve missing GPG keys during making packages|20180218
Issue
Some files are signed with developers GPG sign. Without validation of source tarbals, build package fails. For automatically downloading and adding new keys to LOCAL GPG database follow once this guide.
Install GnuPG
sudo pacman -S gnupg pinentry --needed --noconfirm
Enable following services sockets:
systemctl --user enable gpg-agent.socket
systemctl --user start gpg-agent.socket
systemctl --user enable dirmngr.socket
systemctl --user start dirmngr.socket
Create files with code:
$HOME/.gnupg/dirmngr.conf
keyserver hkps://pgp.mit.edu
keyserver hkps://hkps.pool.sks-keyservers.net
$HOME/.gnupg/gpg.conf
keyserver-options auto-key-retrieve
require-cross-certification
keyring /etc/pacman.d/gnupg/pubring.gpg
use-agent
$HOME/.gnupg/gpg-agent.conf
If You are in NON-KDE use pinentry-qt or pinentry-gtk-2 .
default-cache-ttl 300
max-cache-ttl 999999
pinentry-program /usr/bin/pinentry-qt
### uncomment GTK2 or kwallet variant instead of QT if you needed.
# pinentry-program /usr/bin/pinentry-gtk-2
# pinentry-program /usr/bin/pinentry-kwallet
pinentry-kwallet is part of kwalletcli from AUR You need build and install (via yay/pacaur tool) if you want store passwords in kwallet.
Reload GPG Agent
gpg-connect-agent reloadagent /bye
Are there packages that need to be installed? As if I issue the systemctl commands the error returned indicates that "File or directory" isn't found.
Yep, I forgot mention about installing gnupg package :wink: Fixed. Thanks for hint :slight_smile:
Well I installed gnupg why I hadn't already is another storry -.-
But - still I get the Failed to connect to bus: File or Directory not found error; Am I still missing some package(s)?
Did you followed all guide?
almost I just noticed
:expressionless: please add for people like me to - NOT - run them as root.
Thanks for your patience and the guide!
WHERE you have mention about SUDO or ROOT in GUIDE???? :scream:
My fault - I somehow see systemctl and my mind adds sudo :expressionless: the blame is completely on me. :disappointed_relieved:
Can I suggest hkps:// for secure communication?
ipv4.pool.sks-keyservers.net
Don't have SSL Maybe another servers have it.
EDIT:
Switch from HKP to HKPS
Working like a charm.
@jonathon
i think it is worth mentioning at least some information below in your opening post:
as you have correctly marked, this method automatically retrieves keys to your local (=gpg) keyring. this keyring is used e.g. when installing packages manually or from the AUR.
it does not automatically retrieve any keys for pacman's keyring. this keyring is separate and used for installing packages from the manjaro repositories. it contains keys of arch linux and manjaro developers.
there is a command, which copies all pacman keys to your gpg keyring. this solves many (but not all) missing key problems when installing AUR packages:
echo 'keyring /etc/pacman.d/gnupg/pubring.gpg' >> $HOME/.gnupg/gpg.conf
the method presented in this tutorial solves ALL missing key problems when installing AUR packages while increasing the risk of (re)installing packages from unknown and untrusted sources.
Added to guide. :slight_smile:
Thanks
Have anyone configured GnuPG to get the key when the network is behind of a proxy?
See https://bbs.archlinux.org/viewtopic.php?pid=1264569#p1264569
@FadeMind Thank you. Have tried, but I have never got it working in this corporate network. Even using a different GPG server serving in 443 or 80 ports. Will continue trying...
2 posts were split to a new topic: Gpg setup issues
7 posts were merged into an existing topic: Gpg setup issues
I hate to be the crumudgeon on this, but I really wouldnt recommend auto-key-adoption in general.
It should at least have an option to enable auto-key via conf without haivng so much side configuration.
But, the guide works well, thanks much!
