HOWTO: RPi 4 Root on USB SSD
Here's how I got my root fs over to the USB SSD:
mSATA SSD USB 3.0 Adapter
Dogfish mSATA 256GB
1 - fdisk to create a single linux partition on the SATA drive
2 - Changed /boot/cmdline.txt to reference root=/dev/sda1.
3 - Reboot
4 - Used e2label to remove the ROOT label from the old SDcard partition and added ROOT to the new partition on /dev/sda1
5 - Edited /etc/fstab to add LABEL=ROOT / ext4 defaults,noatime 0 0.
6 - Rebooted
All set!! Only thing I could still do is remove the partition from the sd card if I wanted to. Might even set up a nightl rsync to copy the SSD back to the SDcard as a back up but probably not worth it.
This looks really cool. Can you tell me the model of the cpu cooler?
It's the GeekPi Case with ICE Tower Cooler :slight_smile:
I used an even simpler approach some years ago.
It is as simple as
  1. copying the content of the root to a usb device - anything ext formatted will do.
  2. modifying the boot.txt on the sdcard to use the new device for root
  3. leaving the sdcard as is and reboot
I guess the rpi4 is different in that regard - I haven't had the time to get one and play with it. :slight_smile:
It's probably the same. I just didn't want KDE to still show the drive as removable.
Thanks!
This topic was automatically closed after 90 days. New replies are no longer allowed.
