I am getting cannot copy ppd, dirty files, bad filter
cups error log
D [16/Oct/2019:19:52:10 -0400] [Client 24] Waiting for CGI data.
D [16/Oct/2019:19:52:10 -0400] [Client 24] CGI data ready to be sent.
D [16/Oct/2019:19:52:10 -0400] PID 15126 (/usr/lib/cups/daemon/cups-deviced) exited with no errors.
D [16/Oct/2019:19:52:10 -0400] [Client 24] con->http=0x55cdcc6393e0
D [16/Oct/2019:19:52:10 -0400] [Client 24] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_CHUNKED, data_remaining=0, response=(nil)(), pipe_pid=15126, file=19
D [16/Oct/2019:19:52:10 -0400] [Client 24] Sending 0-length chunk.
D [16/Oct/2019:19:52:10 -0400] [Client 24] Flushing write buffer.
D [16/Oct/2019:19:52:10 -0400] [Client 24] New state is HTTP_STATE_WAITING
D [16/Oct/2019:19:52:10 -0400] [Client 24] Waiting for request.
D [16/Oct/2019:19:52:10 -0400] cupsdSetBusyState: newbusy="Not busy", busy="Active clients"
I [16/Oct/2019:19:52:11 -0400] Expiring subscriptions...
D [16/Oct/2019:19:52:18 -0400] [Client 15] POST / HTTP/1.1
D [16/Oct/2019:19:52:18 -0400] cupsdSetBusyState: newbusy="Active clients", busy="Not busy"
D [16/Oct/2019:19:52:18 -0400] [Client 15] Read: status=200, state=6
D [16/Oct/2019:19:52:18 -0400] [Client 15] No authentication data provided.
D [16/Oct/2019:19:52:18 -0400] [Client 15] 2.0 CUPS-Get-Default 24
D [16/Oct/2019:19:52:18 -0400] CUPS-Get-Default
D [16/Oct/2019:19:52:18 -0400] CUPS-Get-Default client-error-not-found: No default printer.
D [16/Oct/2019:19:52:18 -0400] [Client 15] Returning IPP client-error-not-found for CUPS-Get-Default (no URI) from localhost.
D [16/Oct/2019:19:52:18 -0400] [Client 15] Content-Length: 113
D [16/Oct/2019:19:52:18 -0400] [Client 15] cupsdSendHeader: code=200, type="application/ipp", auth_type=0
I [16/Oct/2019:19:52:18 -0400] Expiring subscriptions...
D [16/Oct/2019:19:52:18 -0400] [Client 15] con->http=0x55cdcc635b90
D [16/Oct/2019:19:52:18 -0400] [Client 15] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=113, response=0x55cdcc63de40(IPP_STATE_DATA), pipe_pid=0, file=-1
D [16/Oct/2019:19:52:18 -0400] [Client 15] Writing IPP response, ipp_state=IPP_STATE_DATA, old wused=0, new wused=0
D [16/Oct/2019:19:52:18 -0400] [Client 15] bytes=0, http_state=0, data_remaining=113
D [16/Oct/2019:19:52:18 -0400] [Client 15] Flushing write buffer.
D [16/Oct/2019:19:52:18 -0400] [Client 15] New state is HTTP_STATE_WAITING
D [16/Oct/2019:19:52:18 -0400] [Client 15] Waiting for request.
D [16/Oct/2019:19:52:18 -0400] cupsdSetBusyState: newbusy="Not busy", busy="Active clients"
D [16/Oct/2019:19:52:18 -0400] [Client 15] Read: status=100, state=6
D [16/Oct/2019:19:52:18 -0400] [Client 15] 2.0 CUPS-Get-Printers 25
D [16/Oct/2019:19:52:18 -0400] CUPS-Get-Printers
D [16/Oct/2019:19:52:18 -0400] CUPS-Get-Printers client-error-not-found: No destinations added.
D [16/Oct/2019:19:52:18 -0400] [Client 15] Returning IPP client-error-not-found for CUPS-Get-Printers (no URI) from localhost.
D [16/Oct/2019:19:52:18 -0400] [Client 15] Content-Length: 116
D [16/Oct/2019:19:52:18 -0400] [Client 15] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=116, response=0x55cdcc5a0b90(IPP_STATE_DATA), pipe_pid=0, file=-1
D [16/Oct/2019:19:52:18 -0400] [Client 15] bytes=0, http_state=0, data_remaining=116
D [16/Oct/2019:19:52:18 -0400] [Client 24] POST / HTTP/1.1
D [16/Oct/2019:19:52:18 -0400] [Client 24] Read: status=200, state=6
D [16/Oct/2019:19:52:18 -0400] [Client 24] Authorized as root using PeerCred.
D [16/Oct/2019:19:52:18 -0400] [Client 24] 2.0 Get-Printer-Attributes 31
D [16/Oct/2019:19:52:18 -0400] Get-Printer-Attributes ipp://localhost/printers/ENVY-5000
D [16/Oct/2019:19:52:18 -0400] Get-Printer-Attributes client-error-not-found: The printer or class does not exist.
D [16/Oct/2019:19:52:18 -0400] [Client 24] Returning IPP client-error-not-found for Get-Printer-Attributes (ipp://localhost/printers/ENVY-5000) from localhost.
D [16/Oct/2019:19:52:18 -0400] [Client 24] Content-Length: 130
D [16/Oct/2019:19:52:18 -0400] [Client 24] cupsdSendHeader: code=200, type="application/ipp", auth_type=0
D [16/Oct/2019:19:52:18 -0400] [Client 24] con->http=0x55cdcc6393e0
D [16/Oct/2019:19:52:18 -0400] [Client 24] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=130, response=0x55cdcc63de60(IPP_STATE_DATA), pipe_pid=0, file=-1
D [16/Oct/2019:19:52:18 -0400] [Client 24] Writing IPP response, ipp_state=IPP_STATE_DATA, old wused=0, new wused=0
D [16/Oct/2019:19:52:18 -0400] [Client 24] bytes=0, http_state=0, data_remaining=130
D [16/Oct/2019:19:52:18 -0400] [Client 24] Flushing write buffer.
D [16/Oct/2019:19:52:18 -0400] [Client 24] New state is HTTP_STATE_WAITING
D [16/Oct/2019:19:52:18 -0400] [Client 24] Waiting for request.
D [16/Oct/2019:19:52:18 -0400] [Client 24] POST /admin/ HTTP/1.1
D [16/Oct/2019:19:52:18 -0400] [Client 24] 2.0 CUPS-Add-Modify-Printer 32
D [16/Oct/2019:19:52:18 -0400] CUPS-Add-Modify-Printer ipp://localhost/printers/ENVY-5000
D [16/Oct/2019:19:52:18 -0400] cupsdIsAuthorized: username="root"
D [16/Oct/2019:19:52:18 -0400] ENVY-5000 device-uri: Missing resource in URI
I [16/Oct/2019:19:52:18 -0400] Setting ENVY-5000 device-uri to "socket://10.0.0.194" (was "file:///dev/null".)
D [16/Oct/2019:19:52:18 -0400] copy_model: Running "cups-driverd cat hp/hp-envy_5000_series.ppd"...
E [16/Oct/2019:19:52:18 -0400] [cups-driverd] Unable to open \"/usr/share/cups/model/hp/hp-envy_5000_series.ppd\" - No such file or directory
E [16/Oct/2019:19:52:18 -0400] copy_model: empty PPD file
D [16/Oct/2019:19:52:18 -0400] CUPS-Add-Modify-Printer server-error-internal-error: Unable to copy PPD file.
D [16/Oct/2019:19:52:18 -0400] cupsdMarkDirty(P----)
D [16/Oct/2019:19:52:18 -0400] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients"
D [16/Oct/2019:19:52:18 -0400] cupsdDeregisterPrinter(p=0x55cdcc641090(ENVY-5000), removeit=1)
E [16/Oct/2019:19:52:18 -0400] [Client 24] Returning IPP server-error-internal-error for CUPS-Add-Modify-Printer (ipp://localhost/printers/ENVY-5000) from localhost.
D [16/Oct/2019:19:52:18 -0400] [Client 24] Content-Length: 118
D [16/Oct/2019:19:52:18 -0400] PID 15173 (/usr/lib/cups/daemon/cups-driverd) stopped with status 1.
D [16/Oct/2019:19:52:18 -0400] [Client 24] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=118, response=0x55cdcc63d8f0(IPP_STATE_DATA), pipe_pid=0, file=-1
D [16/Oct/2019:19:52:18 -0400] [Client 24] bytes=0, http_state=0, data_remaining=118
D [16/Oct/2019:19:52:18 -0400] cupsdSetBusyState: newbusy="Dirty files", busy="Active clients and dirty files"
D [16/Oct/2019:19:52:18 -0400] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Dirty files"
D [16/Oct/2019:19:52:18 -0400] [Client 28] Server address is "/run/cups/cups.sock".
D [16/Oct/2019:19:52:18 -0400] [Client 28] Accepted from localhost (Domain)
D [16/Oct/2019:19:52:18 -0400] [Client 28] Waiting for request.
D [16/Oct/2019:19:52:18 -0400] [Client 28] POST / HTTP/1.1
D [16/Oct/2019:19:52:18 -0400] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files"
D [16/Oct/2019:19:52:18 -0400] [Client 28] Read: status=200, state=6
D [16/Oct/2019:19:52:18 -0400] [Client 28] No authentication data provided.
D [16/Oct/2019:19:52:18 -0400] [Client 28] 2.0 Get-Printer-Attributes 26
D [16/Oct/2019:19:52:18 -0400] Get-Printer-Attributes ipp://localhost:631/printers/ENVY-5000
D [16/Oct/2019:19:52:18 -0400] [Client 28] Returning IPP client-error-not-found for Get-Printer-Attributes (ipp://localhost:631/printers/ENVY-5000) from localhost.
D [16/Oct/2019:19:52:18 -0400] [Client 28] Content-Length: 130
D [16/Oct/2019:19:52:18 -0400] [Client 28] cupsdSendHeader: code=200, type="application/ipp", auth_type=0
D [16/Oct/2019:19:52:18 -0400] [Client 28] con->http=0x55cdcc646e40
D [16/Oct/2019:19:52:18 -0400] [Client 28] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=130, response=0x55cdcc63ccd0(IPP_STATE_DATA), pipe_pid=0, file=-1
D [16/Oct/2019:19:52:18 -0400] [Client 28] Writing IPP response, ipp_state=IPP_STATE_DATA, old wused=0, new wused=0
D [16/Oct/2019:19:52:18 -0400] [Client 28] bytes=0, http_state=0, data_remaining=130
D [16/Oct/2019:19:52:18 -0400] [Client 28] Flushing write buffer.
D [16/Oct/2019:19:52:18 -0400] [Client 28] New state is HTTP_STATE_WAITING
D [16/Oct/2019:19:52:18 -0400] [Client 28] Read: status=100, state=6
D [16/Oct/2019:19:52:18 -0400] [Client 28] 2.0 CUPS-Get-Default 27
D [16/Oct/2019:19:52:18 -0400] [Client 28] Returning IPP client-error-not-found for CUPS-Get-Default (no URI) from localhost.
D [16/Oct/2019:19:52:18 -0400] [Client 28] Content-Length: 113
D [16/Oct/2019:19:52:18 -0400] [Client 28] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=113, response=0x55cdcc63d040(IPP_STATE_DATA), pipe_pid=0, file=-1
D [16/Oct/2019:19:52:18 -0400] [Client 28] bytes=0, http_state=0, data_remaining=113
D [16/Oct/2019:19:52:18 -0400] [Client 28] 2.0 CUPS-Get-Printers 28
D [16/Oct/2019:19:52:18 -0400] [Client 28] Returning IPP client-error-not-found for CUPS-Get-Printers (no URI) from localhost.
D [16/Oct/2019:19:52:18 -0400] [Client 28] Content-Length: 116
D [16/Oct/2019:19:52:18 -0400] [Client 28] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=116, response=0x55cdcc63ccd0(IPP_STATE_DATA), pipe_pid=0, file=-1
D [16/Oct/2019:19:52:18 -0400] [Client 28] bytes=0, http_state=0, data_remaining=116
D [16/Oct/2019:19:52:18 -0400] [Client 28] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [16/Oct/2019:19:52:18 -0400] [Client 28] Closing connection.
D [16/Oct/2019:19:52:18 -0400] cupsdSetBusyState: newbusy="Dirty files", busy="Dirty files"
D [16/Oct/2019:19:52:18 -0400] [Client 15] 2.0 CUPS-Get-Default 29
D [16/Oct/2019:19:52:18 -0400] [Client 15] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=113, response=0x55cdcc63d320(IPP_STATE_DATA), pipe_pid=0, file=-1
D [16/Oct/2019:19:52:18 -0400] [Client 15] 2.0 CUPS-Get-Printers 30
D [16/Oct/2019:19:52:18 -0400] [Client 29] Server address is "/run/cups/cups.sock".
D [16/Oct/2019:19:52:18 -0400] [Client 29] Accepted from localhost (Domain)
D [16/Oct/2019:19:52:18 -0400] [Client 29] Waiting for request.
D [16/Oct/2019:19:52:18 -0400] [Client 29] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [16/Oct/2019:19:52:18 -0400] [Client 29] Closing connection.
I [16/Oct/2019:19:52:19 -0400] Expiring subscriptions...
