HP Envy x360 13 (Ryzen 3500U): Suspend and Resume not working
Hi,
EDIT: I found a solution to the problem; it turns out ryzen processors really don't like s2idle, and HP don't advertise support for traditional deep sleep; hence you have to recompile parts of the ACPI tables and override the defaults.
Instructions here: https://gitlab.freedesktop.org/drm/amd/-/issues/1230#note_580057
I recently purchased a HP Envy x360 13 and have installed Manjaro on it. I'm pretty pleased, however I'm having some issues with Suspend and Resume.
First of all, I can only get s2idle, which isn't Ideal. I'm pretty sure this is due to HP botching the ACPI tables, but to this day I haven't found a solution to the issue.
Secondly, as of now, any attempt to remove from s2idle suspend results in a graphics driver (amdgpu for the ryzen 3500U APU) crash. I have included dmesg output, including an attempt at suspend and resume below, as well as output concerning ACPI in particular.
I have tried every kernel available, and have tried simulating other acpi platforms through kernel arguments.
If anyone has any solutions or suggestions, notably concerning getting proper suspend, I'd really appreciate them.
[  733.733980] PM: suspend entry (s2idle)
[  733.736326] Filesystems sync: 0.002 seconds
[  733.736727] Freezing user space processes ... (elapsed 0.003 seconds) done.
[  733.739885] OOM killer disabled.
[  733.739886] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[  733.741515] printk: Suspending console(s) (use no_console_suspend to debug)
[  733.742827] wlo1: deauthenticating from 2c:79:d7:65:6e:6e by local choice (Reason: 3=DEAUTH_LEAVING)
[  733.743399] rtw_pci 0000:02:00.0: sta 2c:79:d7:65:6e:6e with macid 0 left
[  733.744464] rtw_pci 0000:02:00.0: stop vif e8:6f:38:8b:93:09 on port 0
[  737.746252] kfd2kgd: cp queue preemption time out.
[  745.415100] [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
[  745.415143] [drm] PSP is resuming...
[  745.435177] [drm] reserve 0x400000 from 0xf47f800000 for PSP TMR
[  745.445213] [drm] psp command failed and response status is (0x7)
[  745.594034] usb 3-2: reset full-speed USB device number 3 using xhci_hcd
[  745.888544] rtw_pci 0000:02:00.0: start vif e8:6f:38:8b:93:09 on port 0
[  746.253002] amdgpu 0000:04:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110)
[  746.253055] [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <gfx_v9_0> failed -110
[  746.253107] [drm:amdgpu_device_resume [amdgpu]] *ERROR* amdgpu_device_ip_resume failed (-110).
[  746.253113] PM: dpm_run_callback(): pci_pm_resume+0x0/0x90 returns -110
[  746.253118] PM: Device 0000:04:00.0 failed to resume async: error -110
[  746.258530] OOM killer enabled.
[  746.258531] Restarting tasks ...
[  746.262851] wlo1: authenticate with 2c:79:d7:65:6e:6e
[  746.264990] Bluetooth: hci0: RTL: examining hci_ver=07 hci_rev=000b lmp_ver=07 lmp_subver=8822
[  746.265368] done.
[  746.265486] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.265671] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.265681] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.265782] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.265789] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.265896] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.265901] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.266021] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.266025] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.266119] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.266122] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.266227] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.266232] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.266325] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.266330] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.266433] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.266437] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.266578] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.266582] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.266711] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.266716] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.266839] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.266846] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.266966] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.266973] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.267056] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.267058] Bluetooth: hci0: RTL: rom_version status=0 version=2
[  746.267064] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_fw.bin
[  746.267065] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.267150] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.267151] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_config.bin
[  746.267155] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.267236] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.267238] Bluetooth: hci0: RTL: cfg_sz 14, total sz 20270
[  746.267242] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.267332] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.267340] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.267454] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.267461] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.267574] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.267579] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.267693] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.267700] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.267824] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.267830] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.267952] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.267961] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.268083] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.268095] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.268196] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.268217] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.268307] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.268313] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.268410] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.268417] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.268513] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.268518] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.268615] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.268622] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.268724] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.268732] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.268830] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.268836] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.268943] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.268949] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269033] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269038] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269137] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269142] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269231] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269236] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269328] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269332] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269432] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269436] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269536] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269540] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269636] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269642] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269739] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269745] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269839] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269843] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.269946] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.269950] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.270037] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.270042] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.270133] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.270138] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.270235] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.270240] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.270330] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.270375] amdgpu 0000:04:00.0: couldn't schedule ib on ring <gfx>
[  746.270478] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.292941] audit: type=1130 audit(1586461629.933:204): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  746.302550] PM: suspend exit
[  746.326238] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.326429] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.326444] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.326515] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.326518] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.326589] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.326591] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.326662] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.326665] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.326735] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.326737] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.326807] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.326810] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.326879] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.326881] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.326963] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.326966] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327053] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327057] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327132] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327134] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327204] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327207] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327276] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327279] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327348] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327351] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327420] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327425] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327495] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327499] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327569] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327572] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327644] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327652] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327721] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327725] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327795] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327798] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327868] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327873] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.327943] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.327948] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328017] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328020] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328090] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328094] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328163] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328212] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328283] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328286] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328355] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328363] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328433] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328437] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328507] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328511] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328580] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328584] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328653] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328657] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328727] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328731] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328800] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328805] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328875] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328879] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.328948] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.328953] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329022] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329026] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329097] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329102] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329171] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329175] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329245] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329249] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329319] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329322] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329391] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329395] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329464] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329469] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329539] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329542] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329611] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329615] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329684] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329688] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329757] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329762] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329832] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329836] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329906] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329909] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.329990] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.329993] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330070] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330074] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330143] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330146] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330216] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330221] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330290] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330293] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330363] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330367] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330436] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330442] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330512] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330516] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330585] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330589] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330659] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330662] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330732] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330736] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330805] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330808] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330878] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330882] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.330952] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.330956] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331025] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331031] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331100] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331104] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331174] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331177] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331246] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331250] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331320] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331324] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331394] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331396] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331466] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331470] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331539] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331559] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331629] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331632] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331702] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331706] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331776] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331780] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331849] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331852] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331922] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.331925] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.331995] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332000] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332069] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332074] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332143] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332148] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332218] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332221] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332290] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332294] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332363] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332368] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332438] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332442] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332512] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332515] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332584] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332588] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332657] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332661] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332730] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332735] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332805] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332809] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332878] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332882] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.332960] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.332965] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333035] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333041] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333115] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333119] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333188] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333192] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333261] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333265] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333334] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333339] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333408] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333412] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333481] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333485] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333554] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333558] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333628] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333631] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333700] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333704] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333774] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333778] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333848] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333852] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333921] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333925] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.333994] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.333998] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334068] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334071] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334140] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334143] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334213] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334217] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334287] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334291] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334361] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334365] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334434] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334438] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334507] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334511] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334580] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334585] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334654] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334659] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334728] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334736] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334805] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334810] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334887] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334903] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.334973] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.334977] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335046] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335050] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335120] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335123] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335193] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335197] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335267] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335270] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335339] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335343] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335412] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335417] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335486] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335491] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335561] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335567] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335636] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335640] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335709] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335714] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335783] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335787] amdgpu 0000:04:00.0: couldn't schedule ib on ring <sdma0>
[  746.335857] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.335916] amdgpu 0000:04:00.0: couldn't schedule ib on ring <gfx>
[  746.336041] [drm:amdgpu_job_run [amdgpu]] *ERROR* Error scheduling IBs (-22)
[  746.681607] BUG: kernel NULL pointer dereference, address: 0000000000000008
[  746.681614] #PF: supervisor read access in kernel mode
[  746.681617] #PF: error_code(0x0000) - not-present page
[  746.681620] PGD 0 P4D 0
[  746.681626] Oops: 0000 [#1] PREEMPT SMP NOPTI
[  746.681631] CPU: 2 PID: 1812 Comm: Xorg Not tainted 5.4.30-1-MANJARO #1
[  746.681635] Hardware name: HP HP ENVY x360 Convertible 13-ar0xxx/85DE, BIOS F.19 12/26/2019
[  746.681793] RIP: 0010:enable_link_dp+0x186/0x300 [amdgpu]
[  746.681798] Code: 47 08 81 b8 14 03 00 00 80 00 00 00 74 68 69 44 24 0c 78 69 00 00 41 89 87 24 01 00 00 49 8b bc 24 60 cd 00 00 31 d2 4c 89 e6 <48> 8b 47 08 48 8b 00 e8 6e 6f ce c1 49 8b 47 08 e9 07 ff ff ff 31
[  746.681801] RSP: 0018:ffffa2b742f4f5e8 EFLAGS: 00010246
[  746.681804] RAX: 0000000000041eb0 RBX: ffff92d912052800 RCX: 000000008040003f
[  746.681807] RDX: 0000000000000000 RSI: ffff92d8be560000 RDI: 0000000000000000
[  746.681809] RBP: ffffa2b742f4f630 R08: 0000000000000000 R09: 0000000000000001
[  746.681811] R10: 0000000000000001 R11: 0000000000cc8401 R12: ffff92d8be560000
[  746.681813] R13: ffff92d99372e400 R14: ffffa2b742f4f5f0 R15: ffff92d8be5601b8
[  746.681816] FS:  00007f8afe45edc0(0000) GS:ffff92d998a80000(0000) knlGS:0000000000000000
[  746.681819] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[  746.681821] CR2: 0000000000000008 CR3: 00000001777b6000 CR4: 00000000003406e0
[  746.681823] Call Trace:
[  746.681968]  core_link_enable_stream+0x66e/0x910 [amdgpu]
[  746.682103]  ? dce110_apply_ctx_to_hw+0x58a/0x5d0 [amdgpu]
[  746.682234]  dce110_apply_ctx_to_hw+0x58a/0x5d0 [amdgpu]
[  746.682367]  dc_commit_state+0x280/0x5e0 [amdgpu]
[  746.682505]  amdgpu_dm_atomic_commit_tail+0x1151/0x1da0 [amdgpu]
[  746.682601]  ? amdgpu_bo_move+0x205/0x2b0 [amdgpu]
[  746.682623]  ? commit_tail+0x94/0x110 [drm_kms_helper]
[  746.682634]  commit_tail+0x94/0x110 [drm_kms_helper]
[  746.682648]  drm_atomic_helper_commit+0x108/0x110 [drm_kms_helper]
[  746.682660]  drm_atomic_helper_set_config+0x81/0x90 [drm_kms_helper]
[  746.682683]  drm_mode_setcrtc+0x1f0/0x730 [drm]
[  746.682707]  ? drm_mode_getcrtc+0x180/0x180 [drm]
[  746.682725]  drm_ioctl_kernel+0xb2/0x100 [drm]
[  746.682744]  drm_ioctl+0x209/0x360 [drm]
[  746.682765]  ? drm_mode_getcrtc+0x180/0x180 [drm]
[  746.682854]  amdgpu_drm_ioctl+0x49/0x80 [amdgpu]
[  746.682864]  do_vfs_ioctl+0x43d/0x6c0
[  746.682869]  ksys_ioctl+0x5e/0x90
[  746.682873]  __x64_sys_ioctl+0x16/0x20
[  746.682879]  do_syscall_64+0x4e/0x140
[  746.682886]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[  746.682890] RIP: 0033:0x7f8aff2a02eb
[  746.682894] Code: 0f 1e fa 48 8b 05 a5 8b 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 0f 1f 44 00 00 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 75 8b 0c 00 f7 d8 64 89 01 48
[  746.682896] RSP: 002b:00007ffc07fa90b8 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[  746.682899] RAX: ffffffffffffffda RBX: 00007ffc07fa90f0 RCX: 00007f8aff2a02eb
[  746.682901] RDX: 00007ffc07fa90f0 RSI: 00000000c06864a2 RDI: 000000000000000c
[  746.682902] RBP: 00000000c06864a2 R08: 0000000000000000 R09: 000055c6ef5f97b0
[  746.682904] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
[  746.682906] R13: 000000000000000c R14: 000055c6ee4a1a50 R15: 0000000000000000
[  746.682910] Modules linked in: fuse usbhid ccm rfcomm cmac algif_hash algif_skcipher af_alg lz4 lz4_compress bnep squashfs uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev loop btusb btrtl btbcm btintel bluetooth mc ecdh_generic ecc zram mousedev joydev amdgpu hid_multitouch hid_generic hp_wmi wmi_bmof sparse_keymap rtwpci rtw88 snd_hda_codec_realtek snd_hda_codec_generic edac_mce_amd snd_hda_codec_hdmi ledtrig_audio gpu_sched kvm_amd mac80211 snd_hda_intel i2c_algo_bit ccp nls_iso8859_1 rng_core snd_intel_nhlt nls_cp437 snd_hda_codec ttm vfat snd_hda_core fat kvm drm_kms_helper snd_hwdep snd_pcm irqbypass cfg80211 drm input_leds pcspkr snd_timer k10temp sp5100_tco agpgart snd syscopyarea rfkill sysfillrect sysimgblt rtsx_pci_ms ucsi_acpi soundcore snd_pci_acp3x memstick fb_sys_fops libarc4 i2c_piix4 typec_ucsi typec wmi evdev battery ac mac_hid i2c_hid pinctrl_amd hid hp_accel lis3lv02d hp_wireless input_polldev acpi_tad acpi_cpufreq uinput crypto_user
[  746.682977]  ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 dm_crypt dm_mod crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel rtsx_pci_sdmmc serio_raw mmc_core atkbd libps2 aesni_intel crypto_simd xhci_pci cryptd glue_helper xhci_hcd rtsx_pci i8042 serio
[  746.683003] CR2: 0000000000000008
[  746.683007] ---[ end trace dd7bf68dd6fe2a7d ]---
[  746.683137] RIP: 0010:enable_link_dp+0x186/0x300 [amdgpu]
[  746.683141] Code: 47 08 81 b8 14 03 00 00 80 00 00 00 74 68 69 44 24 0c 78 69 00 00 41 89 87 24 01 00 00 49 8b bc 24 60 cd 00 00 31 d2 4c 89 e6 <48> 8b 47 08 48 8b 00 e8 6e 6f ce c1 49 8b 47 08 e9 07 ff ff ff 31
[  746.683143] RSP: 0018:ffffa2b742f4f5e8 EFLAGS: 00010246
[  746.683146] RAX: 0000000000041eb0 RBX: ffff92d912052800 RCX: 000000008040003f
[  746.683148] RDX: 0000000000000000 RSI: ffff92d8be560000 RDI: 0000000000000000
[  746.683149] RBP: ffffa2b742f4f630 R08: 0000000000000000 R09: 0000000000000001
[  746.683151] R10: 0000000000000001 R11: 0000000000cc8401 R12: ffff92d8be560000
[  746.683153] R13: ffff92d99372e400 R14: ffffa2b742f4f5f0 R15: ffff92d8be5601b8
[  746.683156] FS:  00007f8afe45edc0(0000) GS:ffff92d998a80000(0000) knlGS:0000000000000000
[  746.683158] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[  746.683159] CR2: 0000000000000008 CR3: 00000001777b6000 CR4: 00000000003406e0
[  746.756246] wlo1: send auth to 2c:79:d7:65:6e:6e (try 1/3)
[  746.757998] wlo1: authenticated
[  746.761622] wlo1: associate with 2c:79:d7:65:6e:6e (try 1/3)
[  746.778516] wlo1: RX AssocResp from 2c:79:d7:65:6e:6e (capab=0x1411 status=0 aid=2)
[  746.778558] rtw_pci 0000:02:00.0: sta 2c:79:d7:65:6e:6e joined with macid 0
[  746.831731] wlo1: associated
[  746.898498] audit: type=1130 audit(1586461630.540:205): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  746.898505] audit: type=1131 audit(1586461630.540:206): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  746.921140] wlo1: deauthenticating from 2c:79:d7:65:6e:6e by local choice (Reason: 3=DEAUTH_LEAVING)
[  746.921947] rtw_pci 0000:02:00.0: sta 2c:79:d7:65:6e:6e with macid 0 left
[  746.926023] rtw_pci 0000:02:00.0: stop vif e8:6f:38:8b:93:09 on port 0
[  746.985505] audit: type=1130 audit(1586461630.626:207): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  747.172050] Bluetooth: hci0: RTL: fw version 0xab6b705c
[  747.412270] rtw_pci 0000:02:00.0: start vif e8:6f:38:8b:93:09 on port 0
[  747.413250] rtw_pci 0000:02:00.0: stop vif e8:6f:38:8b:93:09 on port 0
[  747.885244] rtw_pci 0000:02:00.0: start vif b6:a6:19:56:b3:45 on port 0
[  751.297391] audit: type=1131 audit(1586461634.936:208): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  752.270269] rtw_pci 0000:02:00.0: stop vif b6:a6:19:56:b3:45 on port 0
[  752.745362] rtw_pci 0000:02:00.0: start vif e8:6f:38:8b:93:09 on port 0
[  757.010649] wlo1: authenticate with 2c:79:d7:65:6e:6e
[  757.486113] wlo1: send auth to 2c:79:d7:65:6e:6e (try 1/3)
[  757.487795] wlo1: authenticated
[  757.488048] wlo1: associate with 2c:79:d7:65:6e:6e (try 1/3)
[  757.491943] wlo1: RX AssocResp from 2c:79:d7:65:6e:6e (capab=0x1411 status=0 aid=2)
[  757.491986] rtw_pci 0000:02:00.0: sta 2c:79:d7:65:6e:6e joined with macid 0
[  757.521719] audit: type=1131 audit(1586461641.163:209): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  757.545256] wlo1: associated
[  759.146002] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[  759.299513] audit: type=1130 audit(1586461642.940:210): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  769.522119] audit: type=1131 audit(1586461653.163:211): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  775.208792] audit: type=1130 audit(1586461658.850:212): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  779.216338] audit: type=1100 audit(1586461662.857:213): pid=7954 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="jmaris" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  779.216448] audit: type=1101 audit(1586461662.857:214): pid=7954 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="jmaris" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  779.216700] audit: type=1110 audit(1586461662.857:215): pid=7954 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  779.222434] audit: type=1105 audit(1586461662.864:216): pid=7954 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
and
[    0.024179] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.577951] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.706889] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.707110] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR]
[    0.707301] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.707302] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.707317] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[    0.742350] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.889259] acpi device:0f: registered as cooling_device0
[    0.918687] hpet_acpi_add: no address or irqs in _CRS
[    7.003237] acpi-tad ACPI000E:00: Missing _PRW
[    7.004456] acpi_cpufreq: overriding BIOS provided _PSD data
[    7.075114] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[    7.075352] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[    7.076413] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
EDIT : This bug has been reported in multiple places, however few people have confirmed they are experiencing it. See the following list of bug reports:
https://bugs.freedesktop.org/show_bug.cgi?id=110258
https://bugzilla.kernel.org/show_bug.cgi?id=204241
https://bugs.archlinux.org/task/59271
https://bugzilla.redhat.com/show_bug.cgi?id=1704792
https://bbs.archlinux.org/viewtopic.php?id=247761
