HP Laptop mute led not working
After the first update of the system when I press the mute button the LED does not turn on, I don't know if this is a bug but the same thing happens with LinuxMint and Debian. I
already probe adding the file alsa-base.conf in /etc/modprobe.d/ but it doesn't work, I used this configuration:
options snd_hda_intel model=hp-led
options snd_hda_intel model=hp-gpio-led
Inxi:
  Host: HP-Notebook Kernel: 4.19.62-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.1.0 Desktop: Xfce 4.13.6 Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Notebook v: N/A
  serial: <root required>
  Mobo: HP model: 81E1 v: KBC Version 71.17 serial: <root required>
  UEFI: Insyde v: F.34 date: 10/31/2018
  ID-1: BAT0 charge: 2.1 Wh condition: 26.4/26.4 Wh (100%)
  model: Hewlett-Packard Primary status: Discharging
  Topology: Dual Core model: Intel Celeron N3060 bits: 64 type: MCP
  arch: Airmont rev: 4 L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6402
  Speed: 2399 MHz min/max: 480/2480 MHz Core speeds (MHz): 1: 2243 2: 1656
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
  Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  Display: x11 server: X.Org 1.20.5 driver: intel unloaded: modesetting
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (Braswell)
  v: 4.5 Mesa 19.1.3 direct render: Yes
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
  High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k4.19.62-1-MANJARO
  Device-1: Broadcom and subsidiaries BCM43142 802.11b/g/n
  vendor: Hewlett-Packard driver: wl v: kernel port: 2040 bus ID: 02:00.0
  IF: wlp2s0 state: up mac: 44:1c:a8:94:9d:cb
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 1000 bus ID: 03:00.0
  IF: enp3s0 state: down mac: a0:8c:fd:a4:f8:60
  Local Storage: total: 931.51 GiB used: 111.50 GiB (12.0%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541010A9E680
  ID-1: / size: 45.13 GiB used: 15.08 GiB (33.4%) fs: ext4 dev: /dev/sda7
  ID-2: swap-1 size: 14.90 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
  System Temperatures: cpu: 50.0 C mobo: 0.0 C
  Processes: 173 Uptime: 28m Memory: 7.63 GiB used: 2.60 GiB (34.0%)
  Init: systemd Compilers: gcc: 9.1.0 Shell: bash v: 5.0.7 inxi: 3.0.35
Perhaps it is not a fault of the software but of the hardware?
Yeah, also maybe try the kernel 3.16.70 and also the 5.2.4 kernel
Remember to reboot after installing! And to remove the older ones
No, the led works in Windows :slight_smile:
I will try another kernel to see if it works, I hope the Broadcom Wi-Fi driver does not become unstable with kernel 5
I already tried with the kernel 5.2.4 and the led not works :frowning:
Uninstall all newer kernels and install kernel 3.16.70
Then reboot and see if the LED works
I confirm this issue on my hp notebook 15-da0001nk.
Forum rules recommend posting a new topic rather than resurrecting an old discussion
Old Threads/"Necro-Bumping
Please start a new topic and post system information similar to post #1 here
inxi -Fxxxz
and also get ALSA audio information
sudo alsa-info.sh --upload
and post the link to data uploaded to alsa-info
Linux kernel has more patches for HP laptop mute LED problems
need to find audio device ID number to work out which patch is needed
