I can't open my trash folder anymore
Hello!
Please, I am having a new problem after the latest update of Manjaro.
My Trash folder is not opening but instead, I am getting the following error:
Could not make folder /home/kenshiwara/.local/share/Trash
Note: "kenshiwara" is my username and I am the only user on my system. I am running the latest version of Manjaro KDE and the latest kernel (5.4).
I am also getting the same error when the system boots.
Your help will be greatly appreciated. Thanks in advance!
Can you manually create it by way of the command line?
mkdir -p /home/kenshiwara/.local/share/Trash
If it doesn't work, take note of the error message ─ there will be one, and it's important that you tell us ─ and then try this... :arrow_down:
sudo chown -R kenshiwara:kenshiwara /home/kenshiwara
Thank you very much for your reply.
Here is the error message that I am getting when typing your command above:
mkdir: cannot create directory β€˜/home/kenshiwara/.local/share/Trash’: Bad message
Trying the second set of commands is also triggering a "bad message" suffix after every command.
Here is a pastebin of the error message:
https://paste.ubuntu.com/p/7WxkjDyvxy/
Okay, I've done some Google'ing, and according to what I found, "Bad message" seems to indicate filesystem corruption. Either you shut down the computer uncleanly at some point, or you've attempted an fsck on an already mounted filesystem.
I would suggest booting up with a live distro and running fsck on the filesystem that holds /home on your computer. Then, try booting up again from the installed system and see what gives. :thinking:
