I can't see PCI-E Wireless card FENVI FV-HB1200 on Manjaro Cinnamon, but this card works on Hackintosh Mojave very well.
Maybe I need to install some drivers.
Please post:
inxi -Fxxxz
Host: office Kernel: 4.14.134-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 9.1.0 Desktop: Cinnamon 4.2.2 dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: VIGLEN product: DQ77MK v: N/A serial: <filter>
Chassis: Viglen type: 3 v: Medium Tower serial: <filter>
Mobo: Intel model: DQ77MK v: AAG39642-500 serial: <filter> BIOS: Intel
v: MKQ7710H.86A.0060.2013.0618.1012 date: 06/18/2013
Topology: Quad Core model: Intel Core i5-3570 bits: 64 type: MCP
arch: Ivy Bridge rev: 9 L2 cache: 6144 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27149
Speed: 1634 MHz min/max: 1600/3800 MHz Core speeds (MHz): 1: 1596 2: 1653
3: 1596 4: 1600
Device-1: NVIDIA GK107 [GeForce GTX 650] vendor: Gigabyte driver: nvidia
v: 430.26 bus ID: 01:00.0 chip ID: 10de:0fc6
Display: x11 server: X.Org 1.20.5 driver: nvidia tty: N/A
OpenGL: renderer: GeForce GTX 650/PCIe/SSE2 v: 4.6.0 NVIDIA 430.26
direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Device-2: NVIDIA GK107 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e1b
Sound Server: ALSA v: k4.14.134-1-MANJARO
Device-1: Intel 82579LM Gigabit Network driver: e1000e v: 3.2.6-k
port: f040 bus ID: 00:19.0 chip ID: 8086:1502
Device-2: Broadcom and subsidiaries BCM4360 802.11ac Wireless Network
Adapter
vendor: Apple driver: bcma-pci-bridge v: N/A port: e000 bus ID: 02:00.0
chip ID: 14e4:43a0
Device-3: Intel 82574L Gigabit Network driver: e1000e v: 3.2.6-k
port: d000 bus ID: 03:00.0 chip ID: 8086:10d3
IF: eth1 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 851.02 GiB (30.5%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC43 scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD10EZRZ-00HTKB0
size: 931.51 GiB speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 1A01 scheme: GPT
ID-3: /dev/sdc type: USB vendor: Samsung model: M3 Portable
size: 931.51 GiB serial: <filter> rev: 1301 scheme: MBR
ID-1: / size: 491.15 GiB used: 70.36 GiB (14.3%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 55 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 63%
Processes: 191 Uptime: 46m Memory: 15.62 GiB used: 6.08 GiB (38.9%)
Init: systemd v: 242 Compilers: gcc: 9.1.0 Shell: bash v: 5.0.7
running in: gnome-terminal inxi: 3.0.35
Oh great broadcom again, surprise, surprise.
Install some of the newer kernels. You may need to install 5.2 to get full support for the wl driver.
Follow my guide here:
I forgot to say that I used only this part from your guide:
Installing the required Linux kernel headers:
To automatically install all required Linux headers packages for all installed kernels, use the following command:
sudo pacman -S $(pacman -Qsq "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
*command courtesy of @dalto
Once you have completed the linux-headers package installation, install the "dkms" package with the following command:
sudo pacman -S dkms
After all those steps are complete unplug any tethering, LAN, or other internet connections and reboot.
After rebooting, your WiFi may be working with the native modules already included in the kernel. If you find the kernel driver works satisfactorily you may simply want to continue using it.
If your WiFi is not working (or the kernel driver performs poorly), then continue with the directions to install the proprietary broadcom-wl-dkms driver.
Perform some tests on your WiFi, and if it is not performing adequately proceed with installing the broadcom-wl-dkms driver. Reconnect to an alternate internet source to perform the driver installation.
Install the "broadcom-wl-dkms" driver package from the Manjaro extra repo with this command:
sudo pacman -S broadcom-wl-dkms
After the driver has finished installing, again unplug any tethering, LAN, or other internet connections and reboot.
and the card works very well now.
