i3 terminal transparency not working.
Hey there,
I'm new here, but by no means new to Manjaro or even Linux for that matter. Not really a newbie, but no expert either. I am however new to i3. I've recently installed Manjaro i3 on my test machine, and I'm having one seriously annoying problem. As I'm sure you've read, I can't seem to make my Terminal transparent. I've tried a mess of different things. From Terminator settings, config file, compton config, .Xresources, the works. I was wondering if you guys could point me in the right direction.
I'll give what is probably more information than needed, but hopefully it will help to solve my problem.
Also, apologies if my post formatting is strange, I'm not used to forum ethics.
Thannk you.
System Info
System:    Kernel: 5.7.0-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: i3 4.18.1
           info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Portable System: Dell product: Inspiron 5521 v: A07 serial: <filter> Chassis:
           type: 8 v: A07 serial: <filter>
           Mobo: Dell model: 0K08H3 v: A02 serial: <filter> UEFI: Dell v: A07 date: 04/18/2013
Battery:   ID-1: BAT1 charge: 47.4 Wh condition: 47.4/66.6 Wh (71%) volts: 12.9/11.1
           model: LGC DELL 0MF6934B type: Unknown serial: <filter> status: Full
           Device-1: hidpp_battery_1 model: Logitech Wireless Touch Keyboard K400 serial: <filter>
           charge: 100% (should be ignored) rechargeable: yes status: Discharging
Memory:    RAM: total: 3.72 GiB used: 1022.6 MiB (26.9%)
CPU:       Topology: Dual Core model: Intel Core i5-3337U bits: 64 type: MT MCP arch: Ivy Bridge
           rev: 9 L2 cache: 3072 KiB bogomips: 14373
           Speed: 798 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
           Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov constant_tsc
           cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms est f16c
           flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
           mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln
           pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1
           sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
           x2apic xsave xsaveopt xtopology xtpr
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:0166
           Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
           alternate: fbdev,vesa resolution: 1280x720~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.0.7
           compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
           Sound Server: ALSA v: k5.7.0-3-MANJARO
Network:   Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169
           v: kernel port: 2000 bus ID: 01:00.0 chip ID: 10ec:8136
           IF: enp1s0 state: down mac: <filter>
           Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel port: 2000
           bus ID: 02:00.0 chip ID: 8086:0887
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives:    Local Storage: total: 465.76 GiB used: 149.19 GiB (32.0%)
           ID-1: /dev/sda vendor: Seagate model: ST500LT012-9WS142 size: 465.76 GiB speed: 3.0 Gb/s
           rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
           Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU70N rev: A103 dev-links: cdrom
           Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram
           state: running
RAID:      Message: No RAID data was found.
Partition: ID-1: / size: 457.16 GiB used: 149.19 GiB (32.6%) fs: ext4 dev: /dev/sda2 label: N/A
           uuid: 6bdb4820-d2ab-44ba-8f29-365d9bd869be
           ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A
           uuid: 97AD-0E93
Unmounted: Message: No unmounted partitions found.
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
           chip ID: 1d6b:0002
           Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
           chip ID: 8087:0024
           Device-1: 1-1.1:3 info: Intel type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
           speed: 12 Mb/s chip ID: 8087:07da
           Device-2: 1-1.3:4 info: Realtek RTS5129 Card Reader Controller type: <vendor specific>
           driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc interfaces: 1 rev: 2.0 speed: 480 Mb/s
           chip ID: 0bda:0129 serial: <filter>
           Device-3: 1-1.4:5 info: Suyin type: Video driver: uvcvideo interfaces: 2 rev: 2.0
           speed: 480 Mb/s chip ID: 064e:812e
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
           chip ID: 1d6b:0002
           Device-4: 2-3:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
           chip ID: 046d:c52b
           Device-5: 2-4:3 info: Maxxter Wireless Optical Mouse ACT-MUSW-002 type: Mouse
           driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s chip ID: 248a:8366
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
           chip ID: 1d6b:0003
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
           chip ID: 1d6b:0002
           Hub: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
           chip ID: 8087:0024
Sensors:   System Temperatures: cpu: 54.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 196 Uptime: 1d 5h 55m Init: systemd v: 245 Compilers: gcc: 10.1.0 Shell: bash
           v: 5.0.17 running in: terminator inxi: 3.0.37
i3 Config
# i3 config file (v4)
# Please see http://i3wm.org/docs/userguide.html for a complete reference!
# Set mod key (Mod1=<Alt>, Mod4=<Super>)
set $mod Mod4
# set default desktop layout (default is tiling)
# workspace_layout tabbed <stacking|tabbed>
# Configure border style <normal|1pixel|pixel xx|none|pixel>
default_border pixel 1
default_floating_border normal
# Hide borders
hide_edge_borders none
# change borders
bindsym $mod+u border none
bindsym $mod+y border pixel 1
bindsym $mod+n border normal
# Font for window titles. Will also be used by the bar unless a different font
# is used in the bar {} block below.
font xft:System-ui 10
# Use Mouse+$mod to drag floating windows
floating_modifier $mod
# start a terminal
bindsym $mod+Return exec terminator
# kill focused window
bindsym $mod+q kill
# start program launcher
bindsym $mod+d exec --no-startup-id dmenu_recency
# launch categorized menu
bindsym $mod+z exec --no-startup-id morc_menu
## sound-section - DO NOT EDIT if you wish to automatically upgrade Alsa -> Pulseaudio later! ##
exec --no-startup-id volumeicon
bindsym $mod+Ctrl+m exec terminal -e 'alsamixer'
#exec --no-startup-id pulseaudio
#exec --no-startup-id pa-applet
#bindsym $mod+Ctrl+m exec pavucontrol
# Screen brightness controls
# bindsym XF86MonBrightnessUp exec "xbacklight -inc 10; notify-send 'brightness up'"
# bindsym XF86MonBrightnessDown exec "xbacklight -dec 10; notify-send 'brightness down'"
# Start Applications
bindsym $mod+b exec terminal -e 'bmenu'
bindsym $mod+F2 exec google-chrome-stable
bindsym $mod+F3 exec pcmanfm
# bindsym $mod+F3 exec ranger
bindsym $mod+Shift+F3 exec pcmanfm_pkexec
bindsym $mod+F5 exec terminal -e 'mocp'
bindsym $mod+t exec --no-startup-id pkill compton
bindsym $mod+Ctrl+t exec --no-startup-id compton -b
bindsym $mod+Shift+d --release exec "killall dunst; exec notify-send 'restart dunst'"
bindsym Print exec --no-startup-id i3-scrot
bindsym $mod+Print --release exec --no-startup-id i3-scrot -w
bindsym $mod+Shift+Print --release exec --no-startup-id i3-scrot -s
bindsym $mod+Shift+h exec xdg-open /usr/share/doc/manjaro/i3_help.pdf
bindsym $mod+Ctrl+x --release exec --no-startup-id xkill
# focus_follows_mouse no
# change focus
bindsym $mod+j focus left
bindsym $mod+k focus down
bindsym $mod+l focus up
bindsym $mod+semicolon focus right
# alternatively, you can use the cursor keys:
bindsym $mod+Left focus left
bindsym $mod+Down focus down
bindsym $mod+Up focus up
bindsym $mod+Right focus right
# move focused window
bindsym $mod+Shift+j move left
bindsym $mod+Shift+k move down
bindsym $mod+Shift+l move up
bindsym $mod+Shift+semicolon move right
bindsym $mod+Shift+Left move left
bindsym $mod+Shift+Down move down
bindsym $mod+Shift+Up move up
bindsym $mod+Shift+Right move right
# split orientation
bindsym $mod+h split h;exec notify-send 'tile horizontally'
bindsym $mod+v split v;exec notify-send 'tile vertically'
bindsym $mod+Shift+q split toggle
# toggle fullscreen mode for the focused container
bindsym $mod+f fullscreen toggle
# change container layout (stacked, tabbed, toggle split)
bindsym $mod+s layout stacking
bindsym $mod+w layout tabbed
bindsym $mod+e layout toggle split
# toggle tiling / floating
bindsym $mod+Shift+space floating toggle
# change focus between tiling / floating windows
bindsym $mod+space focus mode_toggle
# toggle sticky
bindsym $mod+Shift+s sticky toggle
# focus the parent container
bindsym $mod+a focus parent
# move the currently focused window to the scratchpad
bindsym $mod+Shift+minus move scratchpad
# Show the next scratchpad window or hide the focused scratchpad window.
# If there are multiple scratchpad windows, this command cycles through them.
bindsym $mod+minus scratchpad show
#navigate workspaces next / previous
bindsym $mod+Tab workspace next
# for transparency
# Workspace names
# to display names or symbols instead of plain workspace numbers you can use
# something like: set $ws1 1:mail
#                 set $ws2 2:
set $ws1 1 
set $ws2 2 
set $ws3 3 (3)
set $ws4 4 (4)
set $ws5 5 (5)
set $ws6 6 (6)
set $ws7 7 
set $ws8 8 
# switch to workspace
bindsym $mod+1 workspace $ws1
bindsym $mod+2 workspace $ws2
bindsym $mod+3 workspace $ws3
bindsym $mod+4 workspace $ws4
bindsym $mod+5 workspace $ws5
bindsym $mod+6 workspace $ws6
bindsym $mod+7 workspace $ws7
bindsym $mod+8 workspace $ws8
# Move focused container to workspace
bindsym $mod+Ctrl+1 move container to workspace $ws1
bindsym $mod+Ctrl+2 move container to workspace $ws2
bindsym $mod+Ctrl+3 move container to workspace $ws3
bindsym $mod+Ctrl+4 move container to workspace $ws4
bindsym $mod+Ctrl+5 move container to workspace $ws5
bindsym $mod+Ctrl+6 move container to workspace $ws6
bindsym $mod+Ctrl+7 move container to workspace $ws7
bindsym $mod+Ctrl+8 move container to workspace $ws8
# Move to workspace with focused container
bindsym $mod+Shift+1 move container to workspace $ws1; workspace $ws1
bindsym $mod+Shift+2 move container to workspace $ws2; workspace $ws2
bindsym $mod+Shift+3 move container to workspace $ws3; workspace $ws3
bindsym $mod+Shift+4 move container to workspace $ws4; workspace $ws4
bindsym $mod+Shift+5 move container to workspace $ws5; workspace $ws5
bindsym $mod+Shift+6 move container to workspace $ws6; workspace $ws6
bindsym $mod+Shift+7 move container to workspace $ws7; workspace $ws7
bindsym $mod+Shift+8 move container to workspace $ws8; workspace $ws8
# Open applications on specific workspaces
assign [class="Google-chrome"] $ws2
assign [class="Rhythmbox"] $ws8
# Open specific applications in floating mode
for_window [title="alsamixer"] floating enable border pixel 1
for_window [class="calamares"] floating enable border normal
for_window [class="Clipgrab"] floating enable
for_window [title="File Transfer*"] floating enable
for_window [class="fpakman"] floating enable
for_window [class="Galculator"] floating enable border pixel 1
for_window [class="GParted"] floating enable border normal
for_window [title="i3_help"] floating enable sticky enable border normal
for_window [class="Lightdm-settings"] floating enable
for_window [class="Lxappearance"] floating enable sticky enable border normal
for_window [class="Manjaro-hello"] floating enable
for_window [class="Manjaro Settings Manager"] floating enable border normal
for_window [title="MuseScore: Play Panel"] floating enable
for_window [class="Nitrogen"] floating enable sticky enable border normal
for_window [class="Oblogout"] fullscreen enable
for_window [class="octopi"] floating enable
for_window [title="About Pale Moon"] floating enable
for_window [class="Pamac-manager"] floating enable
for_window [class="Pavucontrol"] floating enable
for_window [class="qt5ct"] floating enable sticky enable border normal
for_window [class="Qtconfig-qt4"] floating enable sticky enable border normal
for_window [class="Simple-scan"] floating enable border normal
for_window [class="(?i)System-config-printer.py"] floating enable border normal
for_window [class="Skype"] floating enable border normal
for_window [class="Timeset-gui"] floating enable border normal
for_window [class="(?i)virtualbox"] floating enable border normal
for_window [class="Xfburn"] floating enable
# switch to workspace with urgent window automatically
for_window [urgent=latest] focus
# reload the configuration file
bindsym $mod+Shift+c reload
# restart i3 inplace (preserves your layout/session, can be used to upgrade i3)
bindsym $mod+Shift+r restart
# exit i3 (logs you out of your X session)
bindsym $mod+Shift+e exec "i3-nagbar -t warning -m 'You pressed the exit shortcut. Do you really want to exit i3? This will end your X session.' -b 'Yes, exit i3' 'i3-msg exit'"
# Set shut down, restart and locking features
bindsym $mod+0 mode "$mode_system"
set $mode_system (l)ock, (e)xit, switch_(u)ser, (s)uspend, (h)ibernate, (r)eboot, (Shift+s)hutdown
mode "$mode_system" {
    bindsym l exec --no-startup-id i3exit lock, mode "default"
    bindsym s exec --no-startup-id i3exit suspend, mode "default"
    bindsym u exec --no-startup-id i3exit switch_user, mode "default"
    bindsym e exec --no-startup-id i3exit logout, mode "default"
    bindsym h exec --no-startup-id i3exit hibernate, mode "default"
    bindsym r exec --no-startup-id i3exit reboot, mode "default"
    bindsym Shift+s exec --no-startup-id i3exit shutdown, mode "default"
    # exit system mode: "Enter" or "Escape"
    bindsym Return mode "default"
    bindsym Escape mode "default"
# Resize window (you can also use the mouse for that)
bindsym $mod+r mode "resize"
mode "resize" {
        # These bindings trigger as soon as you enter the resize mode
        # Pressing left will shrink the window’s width.
        # Pressing right will grow the window’s width.
        # Pressing up will shrink the window’s height.
        # Pressing down will grow the window’s height.
        bindsym j resize shrink width 5 px or 5 ppt
        bindsym k resize grow height 5 px or 5 ppt
        bindsym l resize shrink height 5 px or 5 ppt
        bindsym semicolon resize grow width 5 px or 5 ppt
        # same bindings, but for the arrow keys
        bindsym Left resize shrink width 10 px or 10 ppt
        bindsym Down resize grow height 10 px or 10 ppt
        bindsym Up resize shrink height 10 px or 10 ppt
        bindsym Right resize grow width 10 px or 10 ppt
        # exit resize mode: Enter or Escape
# Lock screen
bindsym $mod+9 exec --no-startup-id blurlock
# Autostart applications
exec --no-startup-id /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
exec --no-startup-id nitrogen --restore; sleep 1; compton -b
#exec --no-startup-id manjaro-hello
exec --no-startup-id nm-applet
exec --no-startup-id xfce4-power-manager
exec --no-startup-id pamac-tray
exec --no-startup-id clipit
# exec --no-startup-id blueman-applet
# exec_always --no-startup-id sbxkb
exec --no-startup-id start_conky_maia
# exec --no-startup-id start_conky_green
#exec --no-startup-id xautolock -time 60 -locker blurlock
exec_always --no-startup-id ff-theme-util
exec_always --no-startup-id fix_xcursor
exec xrandr --output LVDS1 --off --output DP1 --off --output HDMI1 --primary --mode 1280x720 --pos 0x0 --rotate normal --output VGA1 --off --output VIRTUAL1 --off
exec /usr/bin/compton --config /home/ben/.compton.conf~.i3/config
exec rhythmbox
# Color palette used for the terminal ( ~/.Xresources file )
# Colors are gathered based on the documentation:
# https://i3wm.org/docs/userguide.html#xresources
# Change the variable name at the place you want to match the color
# of your terminal like this:
# [example]
# If you want your bar to have the same background color as your
# terminal background change the line 362 from:
# background #14191D
# to:
# background $term_background
# Same logic applied to everything else.
set_from_resource $term_background background
set_from_resource $term_foreground foreground
set_from_resource $term_color0     color0
set_from_resource $term_color1     color1
set_from_resource $term_color2     color2
set_from_resource $term_color3     color3
set_from_resource $term_color4     color4
set_from_resource $term_color5     color5
set_from_resource $term_color6     color6
set_from_resource $term_color7     color7
set_from_resource $term_color8     color8
set_from_resource $term_color9     color9
set_from_resource $term_color10    color10
set_from_resource $term_color11    color11
set_from_resource $term_color12    color12
set_from_resource $term_color13    color13
set_from_resource $term_color14    color14
set_from_resource $term_color15    color15
# Start i3bar to display a workspace bar (plus the system information i3status if available)
bar {
	i3bar_command i3bar
	status_command i3status
	position bottom
## please set your primary output first. Example: 'xrandr --output eDP1 --primary'
#	tray_output primary
#	tray_output eDP1
	bindsym button4 nop
	bindsym button5 nop
#   font xft:System-ui 10
	strip_workspace_numbers yes
    colors {
        background #13191C
        statusline #16A085
        separator  #F9FAF9
#                      border  backgr. text
        focused_workspace  #222D31 #16a085 #292F34
        active_workspace   #222D31 #353836 #FDF6E3
        inactive_workspace #13191C #13191C #16A085
        binding_mode       #16a085 #2C2C2C #F9FAF9
        urgent_workspace   #16a085 #FDF6E3 #E5201D
# hide/unhide i3status bar
bindsym $mod+m bar mode toggle
# Theme colors
# class                   border  backgr. text    indic.   child_border
  client.focused          #556064 #556064 #13191C #FDF6E3
  client.focused_inactive #13191C #13191C #1ABC9C #454948
  client.unfocused        #13191C #13191C #1ABC9C #454948
  client.urgent           #000000 #13191C #000000 #268BD2
  client.placeholder      #000000 #0c0c0c #ffffff #000000
  client.background      #263238
### settings for i3-gaps: ###
# Set inner/outer gaps
gaps inner 14
gaps outer -2
# Additionally, you can issue commands with the following syntax. This is useful to bind keys to changing the gap size.
# gaps inner|outer current|all set|plus|minus <px>
# gaps inner all set 10
# gaps outer all plus 5
# Smart gaps (gaps used if only more than one container on the workspace)
smart_gaps on
# Smart borders (draw borders around container only if it is not the only container on this workspace)
# on|no_gaps (on=always activate and no_gaps=only activate if the gap size to the edge of the screen is 0)
smart_borders on
# Press $mod+Shift+g to enter the gap mode. Choose o or i for modifying outer/inner gaps. Press one of + / - (in-/decrement for current workspace) or 0 (remove gaps for current workspace). If you also press Shift with these keys, the change will be global for all workspaces.
set $mode_gaps Gaps: (o) outer, (i) inner
set $mode_gaps_outer Outer Gaps: +|-|0 (local), Shift + +|-|0 (global)
set $mode_gaps_inner Inner Gaps: +|-|0 (local), Shift + +|-|0 (global)
bindsym $mod+Shift+g mode "$mode_gaps"
mode "$mode_gaps" {
        bindsym o      mode "$mode_gaps_outer"
        bindsym i      mode "$mode_gaps_inner"
mode "$mode_gaps_inner" {
        bindsym plus  gaps inner current plus 5
        bindsym minus gaps inner current minus 5
        bindsym 0     gaps inner current set 0
        bindsym Shift+plus  gaps inner all plus 5
        bindsym Shift+minus gaps inner all minus 5
        bindsym Shift+0     gaps inner all set 0
mode "$mode_gaps_outer" {
        bindsym plus  gaps outer current plus 5
        bindsym minus gaps outer current minus 5
        bindsym 0     gaps outer current set 0
        bindsym Shift+plus  gaps outer all plus 5
        bindsym Shift+minus gaps outer all minus 5
        bindsym Shift+0     gaps outer all set 0
Compton config
# Thank you code_nomad: http://9m.no/ꪯ鵞
# and Arch Wiki contributors: https://wiki.archlinux.org/index.php/Compton
# Backend
# Backend to use: "xrender" or "glx".
# GLX backend is typically much faster but depends on a sane driver.
backend = "glx";
# GLX backend
glx-no-stencil = true;
# GLX backend: Copy unmodified regions from front buffer instead of redrawing them all.
# My tests with nvidia-drivers show a 10% decrease in performance when the whole screen is modified,
# but a 20% increase when only 1/4 is.
# My tests on nouveau show terrible slowdown.
glx-copy-from-front = false;
# GLX backend: Use MESA_copy_sub_buffer to do partial screen update.
# My tests on nouveau shows a 200% performance boost when only 1/4 of the screen is updated.
# May break VSync and is not available on some drivers.
# Overrides --glx-copy-from-front.
# glx-use-copysubbuffermesa = true;
# GLX backend: Avoid rebinding pixmap on window damage.
# Probably could improve performance on rapid window content changes, but is known to break things on some drivers (LLVMpipe).
# Recommended if it works.
# glx-no-rebind-pixmap = true;
# GLX backend: GLX buffer swap method we assume.
# Could be undefined (0), copy (1), exchange (2), 3-6, or buffer-age (-1).
# undefined is the slowest and the safest, and the default value.
# copy is fastest, but may fail on some drivers,
# 2-6 are gradually slower but safer (6 is still faster than 0).
# Usually, double buffer means 2, triple buffer means 3.
# buffer-age means auto-detect using GLX_EXT_buffer_age, supported by some drivers.
# Useless with --glx-use-copysubbuffermesa.
# Partially breaks --resize-damage.
# Defaults to undefined.
#glx-swap-method = "undefined";
# Shadows
# Enabled client-side shadows on windows.
shadow = true;
# The blur radius for shadows. (default 12)
shadow-radius = 5;
# The left offset for shadows. (default -15)
shadow-offset-x = -5;
# The top offset for shadows. (default -15)
shadow-offset-y = -5;
# The translucency for shadows. (default .75)
shadow-opacity = 0.5;
# Set if you want different colour shadows
# shadow-red = 0.0;
# shadow-green = 0.0;
# shadow-blue = 0.0;
# The shadow exclude options are helpful if you have shadows enabled. Due to the way picom draws its shadows, certain applications will have visual glitches
# (most applications are fine, only apps that do weird things with xshapes or argb are affected).
# This list includes all the affected apps I found in my testing. The "! name~=''" part excludes shadows on any "Unknown" windows, this prevents a visual glitch with the XFWM alt tab switcher.
shadow-exclude = [
    "! name~=''",
    "name = 'Notification'",
    "name = 'Plank'",
    "name = 'Docky'",
    "name = 'Kupfer'",
    "name = 'xfce4-notifyd'",
    "name = 'cpt_frame_window'",
    "name *= 'VLC'",
    "name *= 'compton'",
    "name *= 'picom'",
    "name *= 'Chromium'",
    "name *= 'Chrome'",
    "class_g = 'Firefox' && argb",
    "class_g = 'Conky'",
    "class_g = 'Kupfer'",
    "class_g = 'Synapse'",
    "class_g ?= 'Notify-osd'",
    "class_g ?= 'Cairo-dock'",
    "class_g ?= 'Xfce4-notifyd'",
    "class_g ?= 'Xfce4-power-manager'",
    "_GTK_FRAME_EXTENTS@:c",
    "_NET_WM_STATE@:32a *= '_NET_WM_STATE_HIDDEN'"
# Avoid drawing shadow on all shaped windows (see also: --detect-rounded-corners)
shadow-ignore-shaped = false;
# Opacity
inactive-opacity = 1;
active-opacity = 1;
frame-opacity = 1;
inactive-opacity-override = false;
# Dim inactive windows. (0.0 - 1.0)
# inactive-dim = 0.2;
# Do not let dimness adjust based on window opacity.
# inactive-dim-fixed = true;
# Blur background of transparent windows. Bad performance with X Render backend. GLX backend is preferred.
# blur-background = true;
# Blur background of opaque windows with transparent frames as well.
# blur-background-frame = true;
# Do not let blur radius adjust based on window opacity.
blur-background-fixed = false;
blur-background-exclude = [
    "window_type = 'dock'",
    "window_type = 'desktop'"
# Fading
# Fade windows during opacity changes.
fading = true;
# The time between steps in a fade in milliseconds. (default 10).
fade-delta = 4;
# Opacity change between steps while fading in. (default 0.028).
fade-in-step = 0.03;
# Opacity change between steps while fading out. (default 0.03).
fade-out-step = 0.03;
# Fade windows in/out when opening/closing
# no-fading-openclose = true;
# Specify a list of conditions of windows that should not be faded.
fade-exclude = [ ];
# Other
# Try to detect WM windows and mark them as active.
mark-wmwin-focused = true;
# Mark all non-WM but override-redirect windows active (e.g. menus).
mark-ovredir-focused = true;
# Use EWMH _NET_WM_ACTIVE_WINDOW to determine which window is focused instead of using FocusIn/Out events.
# Usually more reliable but depends on a EWMH-compliant WM.
use-ewmh-active-win = true;
# Detect rounded corners and treat them as rectangular when --shadow-ignore-shaped is on.
detect-rounded-corners = true;
# Detect _NET_WM_OPACITY on client windows, useful for window managers not passing _NET_WM_OPACITY of client windows to frame windows.
# This prevents opacity being ignored for some apps.
# For example without this enabled my xfce4-notifyd is 100% opacity no matter what.
detect-client-opacity = true;
# Specify refresh rate of the screen.
# If not specified or 0, picom will try detecting this with X RandR extension.
refresh-rate = 0;
# Vertical synchronization: match the refresh rate of the monitor
vsync = true;
# Enable DBE painting mode, intended to use with VSync to (hopefully) eliminate tearing.
# Reported to have no effect, though.
dbe = false;
# Limit picom to repaint at most once every 1 / refresh_rate second to boost performance.
# This should not be used with --vsync drm/opengl/opengl-oml as they essentially does --sw-opti's job already,
# unless you wish to specify a lower refresh rate than the actual value.
#sw-opti = true;
# Unredirect all windows if a full-screen opaque window is detected, to maximize performance for full-screen windows, like games.
# Known to cause flickering when redirecting/unredirecting windows.
unredir-if-possible = false;
# Specify a list of conditions of windows that should always be considered focused.
focus-exclude = [ ];
# Use WM_TRANSIENT_FOR to group windows, and consider windows in the same group focused at the same time.
detect-transient = true;
# Use WM_CLIENT_LEADER to group windows, and consider windows in the same group focused at the same time.
# WM_TRANSIENT_FOR has higher priority if --detect-transient is enabled, too.
detect-client-leader = true;
# Window type settings
wintypes:
    tooltip =
        # fade: Fade the particular type of windows.
        fade = true;
        # shadow: Give those windows shadow
        shadow = false;
        # opacity: Default opacity for the type of windows.
        opacity = 0.85;
        # focus: Whether to always consider windows of this type focused.
        focus = true;
# XSync
# See: https://github.com/yshui/picom/commit/b18d46bcbdc35a3b5620d817dd46fbc76485c20d
# Use X Sync fence to sync clients' draw calls. Needed on nvidia-drivers with GLX backend for some users.
xrender-sync-fence = true;
.Xresources
Xft.dpi:       96
Xft.antialias: true
Xft.hinting:   true
Xft.rgba:      rgb
Xft.autohint:  false
Xft.hintstyle: hintslight
Xft.lcdfilter: lcddefault
XTerm*background:        #13191C
XTerm*foreground:        #16A085
XTerm*pointerColor:      #1ABB9B
XTerm*faceName:          Fixed
XTerm*faceSize:          11
XTerm*reverseVideo:      on
XTerm*selectToClipboard: true
*fading:                          8
*fadeColor:                       black
*cursorColor:                     #1ABB9B
*pointerColorBackground:          #2B2C2B
*pointerColorForeground:          #16A085
!! black dark/light
*color0:                          #222D31
*color8:                          #585858
!! red dark/light
*color1:                          #ab4642
*color9:                          #ab4642
!! green dark/light
*color2:                          #7E807E
*color10:                         #8D8F8D
!! yellow dark/light
*color3:                          #f7ca88
*color11:                         #f7ca88
!! blue dark/light
*color4:                          #7cafc2
*color12:                         #7cafc2
!! magenta dark/light
*color5:                          #ba8baf
*color13:                         #ba8baf
!! cyan dark/light
*color6:                          #1ABB9B
*color14:                         #1ABB9B
!! white dark/light
*color7:                          #d8d8d8
*color15:                         #f8f8f8
Xcursor.theme: Adwaita
Xcursor.size:                     0
URxvt.font:                       9x15,xft:System-ui
! alternative font settings with 'terminus':
! URxvt.font:      -xos4-System-ui-medium-r-normal--16-160-72-72-c-80-iso10646-1
! URxvt.bold.font: -xos4-System-ui-bold-r-normal--16-160-72-72-c-80-iso10646-1
!! terminus names see end of file!
URxvt.depth:                      32
URxvt.background:                 [75]#13191C
URxvt*scrollBar:                  false
URxvt*mouseWheelScrollPage:       false
URxvt*cursorBlink:                true
URxvt*background:                 black
URxvt*foreground:                 #16A085
URxvt*saveLines:                  5000
! Normal copy-paste keybindings without perls
URxvt.iso14755:                   false
URxvt.keysym.Shift-Control-V:     eval:paste_clipboard
URxvt.keysym.Shift-Control-C:     eval:selection_to_clipboard
!Xterm escape codes, word by word movement
URxvt.keysym.Control-Left:        \033[1;5D
URxvt.keysym.Shift-Control-Left:  \033[1;6D
URxvt.keysym.Control-Right:       \033[1;5C
URxvt.keysym.Shift-Control-Right: \033[1;6C
URxvt.keysym.Control-Up:          \033[1;5A
URxvt.keysym.Shift-Control-Up:    \033[1;6A
URxvt.keysym.Control-Down:        \033[1;5B
URxvt.keysym.Shift-Control-Down:  \033[1;6B
! Rxvt.perl-ext-common:             ...,clipboard
! URxvt.keysym.M-C-c:               perl:clipboard:copy
! URxvt.keysym.M-v:                 perl:clipboard:paste
! URxvt.keysym.M-C-v:               perl:clipboard:paste_escaped
! URxvt*termName:                   string
! URxvt*geometry:                   geometry
! URxvt*chdir:                      string
! URxvt*loginShell:                 boolean
! URxvt*multiClickTime:             number
! URxvt*jumpScroll:                 boolean
! URxvt*skipScroll:                 boolean
! URxvt*pastableTabs:               boolean
! URxvt*scrollstyle:                plain
! URxvt*scrollBar_right:            boolean
! URxvt*scrollBar_floating:         true
! URxvt*scrollBar_align:            mode
! URxvt*thickness:                  number
! URxvt*scrollTtyOutput:            boolean
! URxvt*scrollTtyKeypress:          boolean
! URxvt*scrollWithBuffer:           boolean
! URxvt*tintColor:                  !7DA55
! URxvt*blurRadius:                 HxV
! URxvt*fading:                     number
! URxvt*fadeColor:                  color
! URxvt*utmpInhibit:                boolean
! URxvt*urgentOnBell:               boolean
! URxvt*visualBell:                 boolean
! URxvt*mapAlert:                   boolean
! URxvt*meta8:                      boolean
! URxvt*tripleclickwords:           boolean
! URxvt*insecure:                   boolean
! URxvt*cursorUnderline:            boolean
! URxvt*pointerBlank:               boolean
! URxvt*color0:                     color
! URxvt*color1:                     color
! URxvt*color2:                     color
! URxvt*color3:                     color
! URxvt*color4:                     color
! URxvt*color5:                     color
! URxvt*color6:                     color
! URxvt*color7:                     color
! URxvt*color8:                     color
! URxvt*color9:                     color
! URxvt*color10:                    color
! URxvt*color11:                    color
! URxvt*color12:                    color
! URxvt*color13:                    color
! URxvt*color14:                    color
! URxvt*color15:                    color
! URxvt*colorBD:                    color
! URxvt*colorIT:                    color
! URxvt*colorUL:                    color
! URxvt*colorRV:                    color
! URxvt*underlineColor:             color
! URxvt*scrollColor:                color
! URxvt*troughColor:                color
! URxvt*highlightColor:             color
! URxvt*highlightTextColor:         color
! URxvt*cursorColor:                color
! URxvt*cursorColor2:               color
! URxvt*pointerColor:               color
! URxvt*pointerColor2:              color
! URxvt*borderColor:                color
! URxvt*iconFile:                   file
! URxvt*font:                       fontname
! URxvt*boldFont:                   fontname
! URxvt*italicFont:                 fontname
! URxvt*boldItalicFont:             fontname
! URxvt*intensityStyles:            boolean
! URxvt*inputMethod:                name
! URxvt*preeditType:                style
! URxvt*imLocale:                   string
! URxvt*imFont:                     fontname
! URxvt*title:                      string
! URxvt*iconName:                   string
! URxvt*buffered:                   boolean
! URxvt*depth:                      number
! URxvt*visual:                     number
! URxvt*transient-for:              windowid
! URxvt*override-redirect:          boolean
! URxvt*hold:                       boolean
! URxvt*externalBorder:             number
! URxvt*internalBorder:             number
! URxvt*borderLess:                 true
! URxvt*lineSpace:                  number
! URxvt*letterSpace:                number
! URxvt*skipBuiltinGlyphs:          boolean
! URxvt*pointerBlankDelay:          number
! URxvt*backspacekey:               string
! URxvt*deletekey:                  string
! URxvt*print-pipe:                 string
! URxvt*modifier:                   modifier
! URxvt*cutchars:                   string
! URxvt*answerbackString:           string
! URxvt*secondaryScreen:            boolean
! URxvt*secondaryScroll:            boolean
! URxvt*perl-lib:                   string
! URxvt*perl-eval:                  perl-eval
! URxvt*perl-ext-common:            string
! URxvt*perl-ext:                   string
! URxvt*iso14755:                   boolean
! URxvt*iso14755_52:                boolean
! URxvt*xrm:                        string
! URxvt*keysym.sym:                 keysym
! URxvt*background.border:          boolean
! URxvt*background.expr:            string
! URxvt*background.interval:        seconds
! URxvt*bell-command:               string
! URxvt*kuake.hotkey:               string
! URxvt*matcher.button:             string
! URxvt*matcher.launcher:           string
! URxvt*matcher.launcher.*:         string
! URxvt*matcher.pattern.*:          string
! URxvt*matcher.rend.*:             string
! URxvt*remote-clipboard.fetch:     string
! URxvt*remote-clipboard.store:     string
! URxvt*searchable-scrollback:      string
! URxvt*selection-autotransform.*:  string
! URxvt*selection-pastebin.cmd:     string
! URxvt*selection-pastebin.url:     string
! URxvt*selection.pattern-0:        string
! URxvt*tab-bg:                     colour
! URxvt*tab-fg:                     colour
! URxvt*tabbar-bg:                  colour
! URxvt*tabbar-fg:                  colour
! URxvt*url-launcher:               string
! The Terminus font uses the following X-names:
! -xos4-terminus-medium-r-normal--12-120-72-72-c-60-iso10646-1
! -xos4-terminus-medium-r-normal--14-140-72-72-c-80-iso10646-1
! -xos4-terminus-medium-r-normal--16-160-72-72-c-80-iso10646-1
! -xos4-terminus-medium-r-normal--20-200-72-72-c-100-iso10646-1
! -xos4-terminus-medium-r-normal--22-220-72-72-c-110-iso10646-1
! -xos4-terminus-medium-r-normal--24-240-72-72-c-120-iso10646-1
! -xos4-terminus-medium-r-normal--28-280-72-72-c-140-iso10646-1
! -xos4-terminus-medium-r-normal--32-320-72-72-c-160-iso10646-1
! -xos4-terminus-bold-r-normal--12-120-72-72-c-60-iso10646-1
! -xos4-terminus-bold-r-normal--14-140-72-72-c-80-iso10646-1
! -xos4-terminus-bold-r-normal--16-160-72-72-c-80-iso10646-1
! -xos4-terminus-bold-r-normal--20-200-72-72-c-100-iso10646-1
! -xos4-terminus-bold-r-normal--24-240-72-72-c-120-iso10646-1
! -xos4-terminus-bold-r-normal--28-280-72-72-c-140-iso10646-1
! -xos4-terminus-bold-r-normal--32-320-72-72-c-160-iso10646-1
Any help would be appreciated, and again thank you for your time and patience.
Why didn't you post your terminator settings/configuration?
I've never used it; is the terminal window right-clickable (ala’ xfce4-terminal)?
It is, "right-clickable." As well there are settings for transparency in the Terminator settings, but they don't change anything. Well, at least the transparency ones don't. Colors, fonts, etc work.
If it'll help...
Terminator config
[global_config]
  borderless = True
[keybindings]
[profiles]
  [[default]]
    background_color = "#263238"
    background_type = transparent
    cursor_color = "#16A085"
    font = Source Code Pro 8
    foreground_color = "#16a085"
    show_titlebar = False
    scrollbar_position = hidden
    palette = "#000000:#aa0000:#00aa00:#aa5500:#0000aa:#aa00aa:#00aaaa:#aaaaaa:#555555:#ff5555:#55ff55:#ffff55:#5555ff:#ff55ff:#55ffff:#ffffff"
    use_system_font = False
[layouts]
  [[default]]
    [[[window0]]]
      type = Window
      parent = ""
    [[[child1]]]
      type = Terminal
      parent = window0
[plugins]
Work fine here.
2020-07-18_03-35
I'm guessing the problem is not in Terminator. If I had my guess, I think it's either in i3 config, or something wrong in Compton. Again though, I honestly don't know. Guess it's not Terminator.
Thanks fore trying though.
Here's a screenshot with the above configuration.
2020-07-17-214341_1280x720_scrot
*Small update, I don't think compton is even running, but I can't figure out why. This printout is beyond my comprehension.
[ 07/17/2020 22:50:57.065 open_config_file_at WARN ] This compositor has been renamed to "picom", the old config file paths is deprecated. Please replace the "compton"s in the path with "picom"
[ 07/17/2020 22:50:57.065 parse_config_libconfig FATAL ERROR ] Error when reading configuration file "/home/ben/.config/compton.conf", line 95: syntax error
[ 07/17/2020 22:50:57.065 main FATAL ERROR ] Failed to create new session.
Solved! It was Compton after all. after some digging apparently there was some trouble with the change from Compton to Picom. I kept seeing people talk about the Tyrone version of Picon. I backed up my Compton conf, uninstalled, and tried out the AUR version of the Tyrone version of Compton and it worked like a dream.
2020-07-17-232208_1280x720_scrot
2020-07-17-232220_1280x720_scrot
Glad you fix it. I mark it as solved :slight_smile:
