Increase FD limits to let Steam Play works reliably
I tested this parmeter even before this topic was created (see post #11)
//Tested with following kernel and parameters
Kernel 4.14
Kernel 4.18
GRUB_CMDLINE_LINUX_DEFAULT="quiet acpi_osi=! acpi_osi=\"Windows 2009\" acpi_backlight=vendor video.report_key_events=0"
GRUB_CMDLINE_LINUX_DEFAULT="quiet acpi_osi=! acpi_osi=\"Windows 2009\" video.report_key_events=0"
GRUB_CMDLINE_LINUX_DEFAULT="quiet acpi_osi=! acpi_osi=\"Windows 2009\""
DefaultLimitNOFILE=1048576  = backlight change is very laggy
DefaultLimitNOFILE=524288   = backlight change is a bit less laggy
#DefaultLimitNOFILE=1048576 = no more lag (see first character of line :D)
// That's the output of journalctl when I change backlight
sept. 03 09:56:36 yo-gs pkexec[27959]: pam_unix(polkit-1:session): session opened for user root by (uid=1000)
sept. 03 09:56:36 yo-gs pkexec[27959]: yo: Executing command [USER=root] [TTY=unknown] [CWD=/home/yo] [COMMAND=/usr/lib/gsd-backlight-helper --set-brightness 62]
If I change backlight with xorg-xbacklight I got no more bug,
that's why I think it's related to the way /usr/lib/gsd-backlight-helper work or maybe pkexec.
The "laggyness" increase as DefaultLimitNOFILE increase,
that's why I think it's related to DefaultLimitNOFILE
Not relevant.
TROLL ON
I don’t understand how the initial reporter you came to this fd limits upower <-> backlight connection.
TROLL OFF
Not less than yours at least, and I did not ask for revert, just for .pacnew files:
You convinced me your report is real. And I'm not here to argue so I apologize if I came off as attacking you. I just wanted to understand how one user can affect the entire distro's update process.
As for your original problem, did you ever try this?
Seems to be the same solution (ignore keystroke from videobus) at an other level, it should work, I never thought of doing it that way thanks for the hint. But we are going off topic, it's an other issue :sweat_smile:.
pamac install https://manjaro.moson.eu/pool/overlay/steam-manjaro-1.0.0.55-4-x86_64.pkg.tar.xz
Is it possible to have a new package called steamplay-manjaro which carries only the configs needed to run Steam Play out of the box? This way people will continue installing only steam-manjarofor Steam, and add up this new package if he wants to stay on the edge? This new package can be added as an optional dependency to steam-manjaro.
IMHO seems the best of both worlds, lets us easy circumscribe the issues related to the changes and make all users happy! :slight_smile:
It looks like the post above yours is the resolution. It puts the increased limits back in place and backs up the files as @Yoy0 requested.
@ziabice steam-manjaro 1.0.0.55-4 with the increased limits is currently in unstable.
BTW, there is a typo in the config. Limits is misspelled in the comment.
@korealinux thanks for the info, actually I decided to stay with steam-manjaro-1.0.0.55-2from stable, avoiding the -3 update
DefaultLimitNOFILE=1024:1048576
What is the first number designating?
Soft limit vs. hard limit.
