Hi everyone,
I have trouble using the integrated microphone on my Dell Inspiron 7590. The audio (integrated speaker, usb adapter, blutooth, etc.) works perfectly, the webcam works great, but the microphone is not detected at all, not even in the settings.
I'm also kind of a noob so don't hesitate to ask for details... Thanks in advance!
Edit:
So there is information I should have provided so here it is ^^'
$ inxi -Fxxxza --no-host
Kernel: 5.3.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.3-x86_64
root=UUID=b8b8e174-70de-4977-a6d5-f9120a6e8e3e rw quiet apparmor=1
Desktop: Gnome 3.34.3 wm: gnome-shell dm: GDM 3.34.1 Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 7590 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 08717F v: A00 serial: <filter> UEFI: Dell v: 1.5.1
date: 11/06/2019
ID-1: BAT0 charge: 82.7 Wh condition: 92.1/97.0 Wh (95%) volts: 12.6/11.4
model: SMP DELL GPM0365 type: Li-ion serial: <filter> status: Discharging
Topology: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10)
microcode: CA L2 cache: 8192 KiB
bogomips: 38408
Speed: 900 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 900 2: 900
3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA driver: N/A bus ID: 01:00.0 chip ID: 10de:1f91
Display: x11 server: X.org 1.20.7 driver: intel compositor: gnome-shell
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2)
v: 4.6 Mesa 19.3.3 compat-v: 3.0 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.3.18-1-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
v: kernel port: 4000 bus ID: 00:14.3 chip ID: 8086:a370
Local Storage: total: 476.94 GiB used: 55.04 GiB (11.5%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC511 NVMe 512GB
size: 476.94 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 11001101 scheme: GPT
ID-1: / raw size: 97.66 GiB size: 95.62 GiB (97.92%)
used: 54.97 GiB (57.5%) fs: ext4 dev: /dev/nvme0n1p7
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 275 Uptime: 3m Memory: 15.49 GiB used: 1.49 GiB (9.6%)
Init: systemd v: 242 Compilers: gcc: 9.2.0 alt: 8 clang: 9.0.1 Shell: zsh
v: 5.7.1 running in: gnome-terminal inxi: 3.0.37
Then I tried looking the "dmesg" infos but I did not find any error related to what would be my internal microphone, and the journal did not contain anything related to the problem either. (i could have missed it though)
