I figured how to stop gdm from a VT, with systemctl stop gdm.service
, but then when I try to run startdde
I get an error:
$ startdde
startdde[674]: main.go:39: empty display string
When GDM was running, I was able to run DISPLAY=:1 startdde
and avoided that error, but then it had other problems (I think because GDM is already running there).
If I try running startdde
in Gnome, I get some errors, but the Deepin mouse theme then overrides the Gnome mouse theme while I'm in Gnome.
~ ❯ startdde
help set brightness "intel_backlight" max 937 value 1 br 937
<info> manager.go:630: [updateMonitors] add monitor: eDP1 0 0 1920 1080
<info> session.go:328: swap sched disabled
<warning> session.go:398: failed to get current login session: Caller does not belong to any known session
<warning> switcher.go:360: Failed to set sogou skin: section "base" not found
<warning> session_process.go:91: Wait command env [GDK_SCALE=1 deepin-wm] failed: signal: segmentation fault (core dumped)
<info> session_process.go:104: env [GDK_SCALE=1 deepin-wm] startup duration: 562.748802ms
<warning> startmanager.go:92: open /usr/lib/UIAppSched.hooks/launched: no such file or directory
<info> session_process.go:104: /usr/lib/deepin-daemon/dde-session-daemon [] startup duration: 279.796804ms
<warning> session_process.go:91: Wait command /usr/bin/dde-dock [] failed: signal: aborted (core dumped)
<info> session_process.go:104: /usr/bin/dde-dock [] startup duration: 509.149072ms
<warning> session_process.go:91: Wait command /usr/bin/dde-desktop [] failed: signal: aborted (core dumped)
<info> session_process.go:104: /usr/bin/dde-desktop [] startup duration: 555.480582ms
<info> session_process.go:59: start dde-session-daemon part2 cost: 592.175191ms
<info> main.go:135: iowait disabled
<warning> startmanager.go:552: [/bin/sh -c export GIO_LAUNCHED_DESKTOP_FILE_PID=$$;exec start-pulseaudio-x11]: exit status 1
<warning> startmanager.go:552: [/bin/sh -c export GIO_LAUNCHED_DESKTOP_FILE_PID=$$;exec /usr/bin/libinput-gestures]: exit status 1
<warning> startmanager.go:552: [/bin/sh -c export GIO_LAUNCHED_DESKTOP_FILE_PID=$$;exec /usr/bin/caffeine]: exit status 253
<warning> startmanager.go:552: [env GDK_SCALE=1 deepin-metacity]: exit status 1
<warning> manager.go:99: Launch 'dde-dock' failed: org.freedesktop.DBus.Error.Spawn.ChildSignaled:Process com.deepin.dde.Dock received signal 6
<warning> manager.go:99: Launch 'dde-desktop' failed: org.freedesktop.DBus.Error.Spawn.ChildSignaled:Process com.deepin.dde.desktop received signal 6
<warning> dde_polkit_agent.go:75: dde-polkit-agent exit with error: signal: aborted (core dumped)
Any ideas?
