Installing drivers for Canon Pixma G2400
---Hi, not sure of the commands needed but was hoping for a step by step guide to install my printer thats a Canon Pixma G2400
Tips for posting
Use a "keyword search" to make sure your question has not already been asked. For example "failed to verify key" or "sound is muted".
Make sure you include enough detail so people know what you are running. A useful command is inxi -Fxz; copy and paste the text and format as "code" (e.g. use the </> button above).
If possible, paste text rather than upload a photo. Text is easier to read, searchable, and takes up less space on the server. Please don't upload high-resolution photos.
For more information read this post: How to provide good information in your posts
Remember to remove all of this help text before you post.
First of all, what desktop environment are you using, and do you have manjaro-printer installed?
Also, have you read this section of the Manjaro Wiki?
https://wiki.manjaro.org/index.php/Printer_Configuration
I have just installed it and it doesnt seem to detect it
Are you using Add Printer in Print Settings? I've got a Canon MG5750, and it detects it best on first installation just after I've switched the printer on and it has connected to the network. So, try the good old fashioned turning it off and on again.
PS I note that Canon do not supply Linux drivers for this particular model.
You could also try installing cnijfilter2 from the AUR.
really
Canon PIXMA MG5750
Yes, that's my printer. He is looking to install the Pixma G2400.
Awesome, how do I do that as am still unable to connect thru print settings or CUPS
Have a look here
https://wiki.manjaro.org/index.php?title=Pamac
and here
https://wiki.manjaro.org/index.php?title=Arch_User_Repository
I am sorry, my mistake
Canon PIXMA G2400
Unfortunately your device is no longer supported under the selected operating system
:rage:
:disappointed_relieved:
When going through the troubleshoot for the Printer setting it identifies the printer but when I try to connect it gives me the message belowScreenshot_2018-05-23_18-52-45
And when I try to type it in the terminal, this is what it gives meScreenshot_2018-05-23_19-27-25
a file was created " troubleshoot-log.txt "
open this with an editor
nano troubleshoot-log.txt
