Installing PyCharm Proffesional
I have an issue when installing PyCharm on my Manjaro VM. I answer no to both editing questions, but after it proceeds to build the package it stops with error no space left on the device. I checked my "/tmp" is full. The issue persists after rebooting to clear the tmp folder. I'm running VM with 2 GB RAM and 20 GB HDD. My "/tmp" is roughly 1 GB. What could be the cause and how to fix it?
AUR packages are built in /tmp, which is your memory, you must be running out or memory during the build process.
You can specify a non memory directory to build your AUR package in using yaourt, or within Pamac.
Found solution earlier on antergos, but thanks anyway.
