I have two eth: eth0 and eth1. Both eths cannot have any ip shown in eth0/1 if I use ip a
command.
Here is some ethtool output:
ethtool -i eth0:
driver: ixgbe
version: 4.2.1-k
firmware-version: 0x800006da
expansion-rom-version:
bus-info: 0000:01:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
eth -k eth0:
Features for eth0:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: on [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: on [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off
busy-poll: on [fixed]
ethtool -g eth0
Ring parameters for eth0:
Pre-set maximums:
RX: 4096
RX Mini: 0
RX Jumbo: 0
TX: 4096
Current hardware settings:
RX: 128
RX Mini: 0
RX Jumbo: 0
TX: 512
ethtool -d eth0:
0x042A4: LINKS (Link Status register) 0x39080000
Link Status: down
Link Speed: 10G
0x05080: FCTRL (Filter Control register) 0x00000400
Broadcast Accept: enabled
Unicast Promiscuous: disabled
Multicast Promiscuous: disabled
Store Bad Packets: disabled
0x04294: MFLCN (TabMAC Flow Control register) 0x00000000
Receive Flow Control Packets: disabled
Discard Pause Frames: disabled
Pass MAC Control Frames: disabled
Receive Priority Flow Control Packets: disabled
0x05088: VLNCTRL (VLAN Control register) 0x40008100
VLAN Mode: disabled
VLAN Filter: enabled
0x02100: SRRCTL0 (Split and Replic Rx Control 0) 0x02000402
Receive Buffer Size: 2KB
0x03D00: FCCFG (Flow Control Configuration) 0x00000000
Transmit Flow Control: disabled
Priority Flow Control: disabled
0x04240: HLREG0 (Highlander Control 0 register) 0x08002FFF
Transmit CRC: enabled
Receive CRC Strip: enabled
Jumbo Frames: enabled
Pad Short Frames: enabled
Loopback: disabled
0x00000: CTRL (Device Control) 0x00000000
0x00008: STATUS (Device Status) 0x00080004
0x00018: CTRL_EXT (Extended Device Control) 0x10010000
0x00020: ESDP (Extended SDP Control) 0x000008F1
0x00028: EODSDP (Extended OD SDP Control) 0x0000000F
0x00200: LEDCTL (LED Control) 0x05040100
0x00048: FRTIMER (Free Running Timer) 0x06969955
0x0004C: TCPTIMER (TCP Timer) 0x00000000
0x10010: EEC (EEPROM/Flash Control) 0x003FC718
0x10014: EERD (EEPROM Read) 0x010A1736
0x1001C: FLA (Flash Access) 0x00000008
0x10110: EEMNGCTL (Manageability EEPROM Control) 0x80000196
0x10114: EEMNGDATA (Manageability EEPROM R/W Data) 0xFFFF0000
0x10118: FLMNGCTL (Manageability Flash Control) 0xC0000000
0x1011C: FLMNGDATA (Manageability Flash Read Data) 0x00000000
0x10120: FLMNGCNT (Manageability Flash Read Count) 0x00000000
0x1013C: FLOP (Flash Opcode) 0x00006252
0x10200: GRC (General Receive Control) 0x00000001
0x00800: EICR (Extended Interrupt Cause) 0x00000000
0x00808: EICS (Extended Interrupt Cause Set) 0x00000000
0x00880: EIMS (Extended Interr. Mask Set/Read) 0xD619FFFF
0x00888: EIMC (Extended Interrupt Mask Clear) 0xD619FFFF
0x00810: EIAC (Extended Interrupt Auto Clear) 0x4000FFFF
0x00890: EIAM (Extended Interr. Auto Mask EN) 0x0000FFFF
0x00820: EITR0 (Extended Interrupt Throttle 0) 0x00000028
0x00900: IVAR0 (Interrupt Vector Allocation 0) 0x81818080
0x00000: MSIXT (MSI-X Table) 0x00000000
0x11068: PBACL (MSI-X PBA Clear) 0x00000000
0x00898: GPIE (General Purpose Interrupt EN) 0xC0000036
0x03008: PFCTOP (Priority Flow Ctrl Type Opcode) 0x01018808
0x03200: FCCTV0 (Flow Ctrl Tx Timer Value 0) 0x00000000
0x03204: FCCTV1 (Flow Ctrl Tx Timer Value 1) 0x00000000
0x03208: FCCTV2 (Flow Ctrl Tx Timer Value 2) 0x00000000
0x0320C: FCCTV3 (Flow Ctrl Tx Timer Value 3) 0x00000000
0x03220: FCRTL0 (Flow Ctrl Rx Threshold low 0) 0x00000000
0x03228: FCRTL1 (Flow Ctrl Rx Threshold low 1) 0x00000000
0x03230: FCRTL2 (Flow Ctrl Rx Threshold low 2) 0x00000000
0x03238: FCRTL3 (Flow Ctrl Rx Threshold low 3) 0x00000000
0x03240: FCRTL4 (Flow Ctrl Rx Threshold low 4) 0x00000000
0x03248: FCRTL5 (Flow Ctrl Rx Threshold low 5) 0x00000000
0x03250: FCRTL6 (Flow Ctrl Rx Threshold low 6) 0x00000000
0x03258: FCRTL7 (Flow Ctrl Rx Threshold low 7) 0x00000000
0x03260: FCRTH0 (Flow Ctrl Rx Threshold High 0) 0x00000000
0x03268: FCRTH1 (Flow Ctrl Rx Threshold High 1) 0x00000000
0x03270: FCRTH2 (Flow Ctrl Rx Threshold High 2) 0x00000000
0x03278: FCRTH3 (Flow Ctrl Rx Threshold High 3) 0x00000000
0x03280: FCRTH4 (Flow Ctrl Rx Threshold High 4) 0x00000000
0x03288: FCRTH5 (Flow Ctrl Rx Threshold High 5) 0x00000000
0x03290: FCRTH6 (Flow Ctrl Rx Threshold High 6) 0x00000000
0x03298: FCRTH7 (Flow Ctrl Rx Threshold High 7) 0x00000000
0x032A0: FCRTV (Flow Control Refresh Threshold) 0x00000000
0x0CE00: TFCS (Transmit Flow Control Status) 0x000000FF
0x01000: RDBAL00 (Rx Desc Base Addr Low 00) 0xDB724000
0x01040: RDBAL01 (Rx Desc Base Addr Low 01) 0xDB792000
0x01080: RDBAL02 (Rx Desc Base Addr Low 02) 0xDB01A000
0x010C0: RDBAL03 (Rx Desc Base Addr Low 03) 0xDB744000
0x01100: RDBAL04 (Rx Desc Base Addr Low 04) 0xDB0AE000
0x01140: RDBAL05 (Rx Desc Base Addr Low 05) 0xDB71E000
0x01180: RDBAL06 (Rx Desc Base Addr Low 06) 0xDB078000
0x011C0: RDBAL07 (Rx Desc Base Addr Low 07) 0xDB130000
0x01200: RDBAL08 (Rx Desc Base Addr Low 08) 0xDB104000
0x01240: RDBAL09 (Rx Desc Base Addr Low 09) 0xDB120000
0x01280: RDBAL10 (Rx Desc Base Addr Low 10) 0xDB060000
0x012C0: RDBAL11 (Rx Desc Base Addr Low 11) 0xDB770000
0x01300: RDBAL12 (Rx Desc Base Addr Low 12) 0xDB774000
0x01340: RDBAL13 (Rx Desc Base Addr Low 13) 0xDB126000
0x01380: RDBAL14 (Rx Desc Base Addr Low 14) 0xDB01E000
0x013C0: RDBAL15 (Rx Desc Base Addr Low 15) 0xDB108000
0x01400: RDBAL16 (Rx Desc Base Addr Low 16) 0x00000000
0x01440: RDBAL17 (Rx Desc Base Addr Low 17) 0x00000000
0x01480: RDBAL18 (Rx Desc Base Addr Low 18) 0x00000000
0x014C0: RDBAL19 (Rx Desc Base Addr Low 19) 0x00000000
0x01500: RDBAL20 (Rx Desc Base Addr Low 20) 0x00000000
0x01540: RDBAL21 (Rx Desc Base Addr Low 21) 0x00000000
0x01580: RDBAL22 (Rx Desc Base Addr Low 22) 0x00000000
0x015C0: RDBAL23 (Rx Desc Base Addr Low 23) 0x00000000
0x01600: RDBAL24 (Rx Desc Base Addr Low 24) 0x00000000
0x01640: RDBAL25 (Rx Desc Base Addr Low 25) 0x00000000
0x01680: RDBAL26 (Rx Desc Base Addr Low 26) 0x00000000
0x016C0: RDBAL27 (Rx Desc Base Addr Low 27) 0x00000000
0x01700: RDBAL28 (Rx Desc Base Addr Low 28) 0x00000000
0x01740: RDBAL29 (Rx Desc Base Addr Low 29) 0x00000000
0x01780: RDBAL30 (Rx Desc Base Addr Low 30) 0x00000000
0x017C0: RDBAL31 (Rx Desc Base Addr Low 31) 0x00000000
0x01800: RDBAL32 (Rx Desc Base Addr Low 32) 0x00000000
0x01840: RDBAL33 (Rx Desc Base Addr Low 33) 0x00000000
0x01880: RDBAL34 (Rx Desc Base Addr Low 34) 0x00000000
0x018C0: RDBAL35 (Rx Desc Base Addr Low 35) 0x00000000
0x01900: RDBAL36 (Rx Desc Base Addr Low 36) 0x00000000
0x01940: RDBAL37 (Rx Desc Base Addr Low 37) 0x00000000
0x01980: RDBAL38 (Rx Desc Base Addr Low 38) 0x00000000
0x019C0: RDBAL39 (Rx Desc Base Addr Low 39) 0x00000000
0x01A00: RDBAL40 (Rx Desc Base Addr Low 40) 0x00000000
0x01A40: RDBAL41 (Rx Desc Base Addr Low 41) 0x00000000
0x01A80: RDBAL42 (Rx Desc Base Addr Low 42) 0x00000000
0x01AC0: RDBAL43 (Rx Desc Base Addr Low 43) 0x00000000
0x01B00: RDBAL44 (Rx Desc Base Addr Low 44) 0x00000000
0x01B40: RDBAL45 (Rx Desc Base Addr Low 45) 0x00000000
0x01B80: RDBAL46 (Rx Desc Base Addr Low 46) 0x00000000
0x01BC0: RDBAL47 (Rx Desc Base Addr Low 47) 0x00000000
0x01C00: RDBAL48 (Rx Desc Base Addr Low 48) 0x00000000
0x01C40: RDBAL49 (Rx Desc Base Addr Low 49) 0x00000000
0x01C80: RDBAL50 (Rx Desc Base Addr Low 50) 0x00000000
0x01CC0: RDBAL51 (Rx Desc Base Addr Low 51) 0x00000000
0x01D00: RDBAL52 (Rx Desc Base Addr Low 52) 0x00000000
0x01D40: RDBAL53 (Rx Desc Base Addr Low 53) 0x00000000
0x01D80: RDBAL54 (Rx Desc Base Addr Low 54) 0x00000000
0x01DC0: RDBAL55 (Rx Desc Base Addr Low 55) 0x00000000
0x01E00: RDBAL56 (Rx Desc Base Addr Low 56) 0x00000000
0x01E40: RDBAL57 (Rx Desc Base Addr Low 57) 0x00000000
0x01E80: RDBAL58 (Rx Desc Base Addr Low 58) 0x00000000
0x01EC0: RDBAL59 (Rx Desc Base Addr Low 59) 0x00000000
0x01F00: RDBAL60 (Rx Desc Base Addr Low 60) 0x00000000
0x01F40: RDBAL61 (Rx Desc Base Addr Low 61) 0x00000000
0x01F80: RDBAL62 (Rx Desc Base Addr Low 62) 0x00000000
0x01FC0: RDBAL63 (Rx Desc Base Addr Low 63) 0x00000000
0x01004: RDBAH00 (Rx Desc Base Addr High 00) 0x00000000
0x01044: RDBAH01 (Rx Desc Base Addr High 01) 0x00000000
0x01084: RDBAH02 (Rx Desc Base Addr High 02) 0x00000000
0x010C4: RDBAH03 (Rx Desc Base Addr High 03) 0x00000000
0x01104: RDBAH04 (Rx Desc Base Addr High 04) 0x00000000
0x01144: RDBAH05 (Rx Desc Base Addr High 05) 0x00000000
0x01184: RDBAH06 (Rx Desc Base Addr High 06) 0x00000000
0x011C4: RDBAH07 (Rx Desc Base Addr High 07) 0x00000000
0x01204: RDBAH08 (Rx Desc Base Addr High 08) 0x00000000
0x01244: RDBAH09 (Rx Desc Base Addr High 09) 0x00000000
0x01284: RDBAH10 (Rx Desc Base Addr High 10) 0x00000000
0x012C4: RDBAH11 (Rx Desc Base Addr High 11) 0x00000000
0x01304: RDBAH12 (Rx Desc Base Addr High 12) 0x00000000
0x01344: RDBAH13 (Rx Desc Base Addr High 13) 0x00000000
0x01384: RDBAH14 (Rx Desc Base Addr High 14) 0x00000000
0x013C4: RDBAH15 (Rx Desc Base Addr High 15) 0x00000000
0x01404: RDBAH16 (Rx Desc Base Addr High 16) 0x00000000
0x01444: RDBAH17 (Rx Desc Base Addr High 17) 0x00000000
0x01484: RDBAH18 (Rx Desc Base Addr High 18) 0x00000000
0x014C4: RDBAH19 (Rx Desc Base Addr High 19) 0x00000000
0x01504: RDBAH20 (Rx Desc Base Addr High 20) 0x00000000
0x01544: RDBAH21 (Rx Desc Base Addr High 21) 0x00000000
0x01584: RDBAH22 (Rx Desc Base Addr High 22) 0x00000000
0x015C4: RDBAH23 (Rx Desc Base Addr High 23) 0x00000000
0x01604: RDBAH24 (Rx Desc Base Addr High 24) 0x00000000
0x01644: RDBAH25 (Rx Desc Base Addr High 25) 0x00000000
0x01684: RDBAH26 (Rx Desc Base Addr High 26) 0x00000000
0x016C4: RDBAH27 (Rx Desc Base Addr High 27) 0x00000000
0x01704: RDBAH28 (Rx Desc Base Addr High 28) 0x00000000
0x01744: RDBAH29 (Rx Desc Base Addr High 29) 0x00000000
0x01784: RDBAH30 (Rx Desc Base Addr High 30) 0x00000000
0x017C4: RDBAH31 (Rx Desc Base Addr High 31) 0x00000000
0x01804: RDBAH32 (Rx Desc Base Addr High 32) 0x00000000
0x01844: RDBAH33 (Rx Desc Base Addr High 33) 0x00000000
0x01884: RDBAH34 (Rx Desc Base Addr High 34) 0x00000000
0x018C4: RDBAH35 (Rx Desc Base Addr High 35) 0x00000000
0x01904: RDBAH36 (Rx Desc Base Addr High 36) 0x00000000
0x01944: RDBAH37 (Rx Desc Base Addr High 37) 0x00000000
0x01984: RDBAH38 (Rx Desc Base Addr High 38) 0x00000000
0x019C4: RDBAH39 (Rx Desc Base Addr High 39) 0x00000000
0x01A04: RDBAH40 (Rx Desc Base Addr High 40) 0x00000000
0x01A44: RDBAH41 (Rx Desc Base Addr High 41) 0x00000000
0x01A84: RDBAH42 (Rx Desc Base Addr High 42) 0x00000000
0x01AC4: RDBAH43 (Rx Desc Base Addr High 43) 0x00000000
0x01B04: RDBAH44 (Rx Desc Base Addr High 44) 0x00000000
0x01B44: RDBAH45 (Rx Desc Base Addr High 45) 0x00000000
0x01B84: RDBAH46 (Rx Desc Base Addr High 46) 0x00000000
0x01BC4: RDBAH47 (Rx Desc Base Addr High 47) 0x00000000
0x01C04: RDBAH48 (Rx Desc Base Addr High 48) 0x00000000
0x01C44: RDBAH49 (Rx Desc Base Addr High 49) 0x00000000
0x01C84: RDBAH50 (Rx Desc Base Addr High 50) 0x00000000
0x01CC4: RDBAH51 (Rx Desc Base Addr High 51) 0x00000000
0x01D04: RDBAH52 (Rx Desc Base Addr High 52) 0x00000000
0x01D44: RDBAH53 (Rx Desc Base Addr High 53) 0x00000000
0x01D84: RDBAH54 (Rx Desc Base Addr High 54) 0x00000000
0x01DC4: RDBAH55 (Rx Desc Base Addr High 55) 0x00000000
0x01E04: RDBAH56 (Rx Desc Base Addr High 56) 0x00000000
0x01E44: RDBAH57 (Rx Desc Base Addr High 57) 0x00000000
0x01E84: RDBAH58 (Rx Desc Base Addr High 58) 0x00000000
0x01EC4: RDBAH59 (Rx Desc Base Addr High 59) 0x00000000
0x01F04: RDBAH60 (Rx Desc Base Addr High 60) 0x00000000
0x01F44: RDBAH61 (Rx Desc Base Addr High 61) 0x00000000
0x01F84: RDBAH62 (Rx Desc Base Addr High 62) 0x00000000
0x01FC4: RDBAH63 (Rx Desc Base Addr High 63) 0x00000000
0x01008: RDLEN00 (Receive Descriptor Length 00) 0x00000800
0x01048: RDLEN01 (Receive Descriptor Length 01) 0x00000800
0x01088: RDLEN02 (Receive Descriptor Length 02) 0x00000800
0x010C8: RDLEN03 (Receive Descriptor Length 03) 0x00000800
0x01108: RDLEN04 (Receive Descriptor Length 04) 0x00000800
0x01148: RDLEN05 (Receive Descriptor Length 05) 0x00000800
0x01188: RDLEN06 (Receive Descriptor Length 06) 0x00000800
0x011C8: RDLEN07 (Receive Descriptor Length 07) 0x00000800
0x01208: RDLEN08 (Receive Descriptor Length 08) 0x00000800
0x01248: RDLEN09 (Receive Descriptor Length 09) 0x00000800
0x01288: RDLEN10 (Receive Descriptor Length 10) 0x00000800
0x012C8: RDLEN11 (Receive Descriptor Length 11) 0x00000800
0x01308: RDLEN12 (Receive Descriptor Length 12) 0x00000800
0x01348: RDLEN13 (Receive Descriptor Length 13) 0x00000800
0x01388: RDLEN14 (Receive Descriptor Length 14) 0x00000800
0x013C8: RDLEN15 (Receive Descriptor Length 15) 0x00000800
0x01408: RDLEN16 (Receive Descriptor Length 16) 0x00000000
0x01448: RDLEN17 (Receive Descriptor Length 17) 0x00000000
0x01488: RDLEN18 (Receive Descriptor Length 18) 0x00000000
0x014C8: RDLEN19 (Receive Descriptor Length 19) 0x00000000
0x01508: RDLEN20 (Receive Descriptor Length 20) 0x00000000
0x01548: RDLEN21 (Receive Descriptor Length 21) 0x00000000
0x01588: RDLEN22 (Receive Descriptor Length 22) 0x00000000
0x015C8: RDLEN23 (Receive Descriptor Length 23) 0x00000000
0x01608: RDLEN24 (Receive Descriptor Length 24) 0x00000000
0x01648: RDLEN25 (Receive Descriptor Length 25) 0x00000000
0x01688: RDLEN26 (Receive Descriptor Length 26) 0x00000000
0x016C8: RDLEN27 (Receive Descriptor Length 27) 0x00000000
0x01708: RDLEN28 (Receive Descriptor Length 28) 0x00000000
0x01748: RDLEN29 (Receive Descriptor Length 29) 0x00000000
0x01788: RDLEN30 (Receive Descriptor Length 30) 0x00000000
0x017C8: RDLEN31 (Receive Descriptor Length 31) 0x00000000
0x01808: RDLEN32 (Receive Descriptor Length 32) 0x00000000
0x01848: RDLEN33 (Receive Descriptor Length 33) 0x00000000
0x01888: RDLEN34 (Receive Descriptor Length 34) 0x00000000
0x018C8: RDLEN35 (Receive Descriptor Length 35) 0x00000000
0x01908: RDLEN36 (Receive Descriptor Length 36) 0x00000000
0x01948: RDLEN37 (Receive Descriptor Length 37) 0x00000000
0x01988: RDLEN38 (Receive Descriptor Length 38) 0x00000000
0x019C8: RDLEN39 (Receive Descriptor Length 39) 0x00000000
0x01A08: RDLEN40 (Receive Descriptor Length 40) 0x00000000
0x01A48: RDLEN41 (Receive Descriptor Length 41) 0x00000000
0x01A88: RDLEN42 (Receive Descriptor Length 42) 0x00000000
0x01AC8: RDLEN43 (Receive Descriptor Length 43) 0x00000000
0x01B08: RDLEN44 (Receive Descriptor Length 44) 0x00000000
0x01B48: RDLEN45 (Receive Descriptor Length 45) 0x00000000
0x01B88: RDLEN46 (Receive Descriptor Length 46) 0x00000000
0x01BC8: RDLEN47 (Receive Descriptor Length 47) 0x00000000
0x01C08: RDLEN48 (Receive Descriptor Length 48) 0x00000000
0x01C48: RDLEN49 (Receive Descriptor Length 49) 0x00000000
0x01C88: RDLEN50 (Receive Descriptor Length 50) 0x00000000
0x01CC8: RDLEN51 (Receive Descriptor Length 51) 0x00000000
0x01D08: RDLEN52 (Receive Descriptor Length 52) 0x00000000
0x01D48: RDLEN53 (Receive Descriptor Length 53) 0x00000000
0x01D88: RDLEN54 (Receive Descriptor Length 54) 0x00000000
0x01DC8: RDLEN55 (Receive Descriptor Length 55) 0x00000000
0x01E08: RDLEN56 (Receive Descriptor Length 56) 0x00000000
0x01E48: RDLEN57 (Receive Descriptor Length 57) 0x00000000
0x01E88: RDLEN58 (Receive Descriptor Length 58) 0x00000000
0x01EC8: RDLEN59 (Receive Descriptor Length 59) 0x00000000
0x01F08: RDLEN60 (Receive Descriptor Length 60) 0x00000000
0x01F48: RDLEN61 (Receive Descriptor Length 61) 0x00000000
0x01F88: RDLEN62 (Receive Descriptor Length 62) 0x00000000
0x01FC8: RDLEN63 (Receive Descriptor Length 63) 0x00000000
0x01010: RDH00 (Receive Descriptor Head 00) 0x00000000
0x01050: RDH01 (Receive Descriptor Head 01) 0x00000000
0x01090: RDH02 (Receive Descriptor Head 02) 0x00000000
0x010D0: RDH03 (Receive Descriptor Head 03) 0x00000000
0x01110: RDH04 (Receive Descriptor Head 04) 0x00000000
0x01150: RDH05 (Receive Descriptor Head 05) 0x00000000
0x01190: RDH06 (Receive Descriptor Head 06) 0x00000000
0x011D0: RDH07 (Receive Descriptor Head 07) 0x00000000
0x01210: RDH08 (Receive Descriptor Head 08) 0x00000000
0x01250: RDH09 (Receive Descriptor Head 09) 0x00000000
0x01290: RDH10 (Receive Descriptor Head 10) 0x00000000
0x012D0: RDH11 (Receive Descriptor Head 11) 0x00000000
0x01310: RDH12 (Receive Descriptor Head 12) 0x00000000
0x01350: RDH13 (Receive Descriptor Head 13) 0x00000000
0x01390: RDH14 (Receive Descriptor Head 14) 0x00000000
0x013D0: RDH15 (Receive Descriptor Head 15) 0x00000000
0x01410: RDH16 (Receive Descriptor Head 16) 0x00000000
0x01450: RDH17 (Receive Descriptor Head 17) 0x00000000
0x01490: RDH18 (Receive Descriptor Head 18) 0x00000000
0x014D0: RDH19 (Receive Descriptor Head 19) 0x00000000
0x01510: RDH20 (Receive Descriptor Head 20) 0x00000000
0x01550: RDH21 (Receive Descriptor Head 21) 0x00000000
0x01590: RDH22 (Receive Descriptor Head 22) 0x00000000
0x015D0: RDH23 (Receive Descriptor Head 23) 0x00000000
0x01610: RDH24 (Receive Descriptor Head 24) 0x00000000
0x01650: RDH25 (Receive Descriptor Head 25) 0x00000000
0x01690: RDH26 (Receive Descriptor Head 26) 0x00000000
0x016D0: RDH27 (Receive Descriptor Head 27) 0x00000000
0x01710: RDH28 (Receive Descriptor Head 28) 0x00000000
0x01750: RDH29 (Receive Descriptor Head 29) 0x00000000
0x01790: RDH30 (Receive Descriptor Head 30) 0x00000000
0x017D0: RDH31 (Receive Descriptor Head 31) 0x00000000
0x01810: RDH32 (Receive Descriptor Head 32) 0x00000000
0x01850: RDH33 (Receive Descriptor Head 33) 0x00000000
0x01890: RDH34 (Receive Descriptor Head 34) 0x00000000
0x018D0: RDH35 (Receive Descriptor Head 35) 0x00000000
0x01910: RDH36 (Receive Descriptor Head 36) 0x00000000
0x01950: RDH37 (Receive Descriptor Head 37) 0x00000000
0x01990: RDH38 (Receive Descriptor Head 38) 0x00000000
0x019D0: RDH39 (Receive Descriptor Head 39) 0x00000000
0x01A10: RDH40 (Receive Descriptor Head 40) 0x00000000
0x01A50: RDH41 (Receive Descriptor Head 41) 0x00000000
0x01A90: RDH42 (Receive Descriptor Head 42) 0x00000000
0x01AD0: RDH43 (Receive Descriptor Head 43) 0x00000000
0x01B10: RDH44 (Receive Descriptor Head 44) 0x00000000
0x01B50: RDH45 (Receive Descriptor Head 45) 0x00000000
0x01B90: RDH46 (Receive Descriptor Head 46) 0x00000000
0x01BD0: RDH47 (Receive Descriptor Head 47) 0x00000000
0x01C10: RDH48 (Receive Descriptor Head 48) 0x00000000
0x01C50: RDH49 (Receive Descriptor Head 49) 0x00000000
0x01C90: RDH50 (Receive Descriptor Head 50) 0x00000000
0x01CD0: RDH51 (Receive Descriptor Head 51) 0x00000000
0x01D10: RDH52 (Receive Descriptor Head 52) 0x00000000
0x01D50: RDH53 (Receive Descriptor Head 53) 0x00000000
0x01D90: RDH54 (Receive Descriptor Head 54) 0x00000000
0x01DD0: RDH55 (Receive Descriptor Head 55) 0x00000000
0x01E10: RDH56 (Receive Descriptor Head 56) 0x00000000
0x01E50: RDH57 (Receive Descriptor Head 57) 0x00000000
0x01E90: RDH58 (Receive Descriptor Head 58) 0x00000000
0x01ED0: RDH59 (Receive Descriptor Head 59) 0x00000000
0x01F10: RDH60 (Receive Descriptor Head 60) 0x00000000
0x01F50: RDH61 (Receive Descriptor Head 61) 0x00000000
0x01F90: RDH62 (Receive Descriptor Head 62) 0x00000000
0x01FD0: RDH63 (Receive Descriptor Head 63) 0x00000000
0x01018: RDT00 (Receive Descriptor Tail 00) 0x0000007F
0x01058: RDT01 (Receive Descriptor Tail 01) 0x0000007F
0x01098: RDT02 (Receive Descriptor Tail 02) 0x0000007F
0x010D8: RDT03 (Receive Descriptor Tail 03) 0x0000007F
0x01118: RDT04 (Receive Descriptor Tail 04) 0x0000007F
0x01158: RDT05 (Receive Descriptor Tail 05) 0x0000007F
0x01198: RDT06 (Receive Descriptor Tail 06) 0x0000007F
0x011D8: RDT07 (Receive Descriptor Tail 07) 0x0000007F
0x01218: RDT08 (Receive Descriptor Tail 08) 0x0000007F
0x01258: RDT09 (Receive Descriptor Tail 09) 0x0000007F
0x01298: RDT10 (Receive Descriptor Tail 10) 0x0000007F
0x012D8: RDT11 (Receive Descriptor Tail 11) 0x0000007F
0x01318: RDT12 (Receive Descriptor Tail 12) 0x0000007F
0x01358: RDT13 (Receive Descriptor Tail 13) 0x0000007F
0x01398: RDT14 (Receive Descriptor Tail 14) 0x0000007F
0x013D8: RDT15 (Receive Descriptor Tail 15) 0x0000007F
0x01418: RDT16 (Receive Descriptor Tail 16) 0x00000000
0x01458: RDT17 (Receive Descriptor Tail 17) 0x00000000
0x01498: RDT18 (Receive Descriptor Tail 18) 0x00000000
0x014D8: RDT19 (Receive Descriptor Tail 19) 0x00000000
0x01518: RDT20 (Receive Descriptor Tail 20) 0x00000000
0x01558: RDT21 (Receive Descriptor Tail 21) 0x00000000
0x01598: RDT22 (Receive Descriptor Tail 22) 0x00000000
0x015D8: RDT23 (Receive Descriptor Tail 23) 0x00000000
0x01618: RDT24 (Receive Descriptor Tail 24) 0x00000000
0x01658: RDT25 (Receive Descriptor Tail 25) 0x00000000
0x01698: RDT26 (Receive Descriptor Tail 26) 0x00000000
0x016D8: RDT27 (Receive Descriptor Tail 27) 0x00000000
0x01718: RDT28 (Receive Descriptor Tail 28) 0x00000000
0x01758: RDT29 (Receive Descriptor Tail 29) 0x00000000
0x01798: RDT30 (Receive Descriptor Tail 30) 0x00000000
0x017D8: RDT31 (Receive Descriptor Tail 31) 0x00000000
0x01818: RDT32 (Receive Descriptor Tail 32) 0x00000000
0x01858: RDT33 (Receive Descriptor Tail 33) 0x00000000
0x01898: RDT34 (Receive Descriptor Tail 34) 0x00000000
0x018D8: RDT35 (Receive Descriptor Tail 35) 0x00000000
0x01918: RDT36 (Receive Descriptor Tail 36) 0x00000000
0x01958: RDT37 (Receive Descriptor Tail 37) 0x00000000
0x01998: RDT38 (Receive Descriptor Tail 38) 0x00000000
0x019D8: RDT39 (Receive Descriptor Tail 39) 0x00000000
0x01A18: RDT40 (Receive Descriptor Tail 40) 0x00000000
0x01A58: RDT41 (Receive Descriptor Tail 41) 0x00000000
0x01A98: RDT42 (Receive Descriptor Tail 42) 0x00000000
0x01AD8: RDT43 (Receive Descriptor Tail 43) 0x00000000
0x01B18: RDT44 (Receive Descriptor Tail 44) 0x00000000
0x01B58: RDT45 (Receive Descriptor Tail 45) 0x00000000
0x01B98: RDT46 (Receive Descriptor Tail 46) 0x00000000
0x01BD8: RDT47 (Receive Descriptor Tail 47) 0x00000000
0x01C18: RDT48 (Receive Descriptor Tail 48) 0x00000000
0x01C58: RDT49 (Receive Descriptor Tail 49) 0x00000000
0x01C98: RDT50 (Receive Descriptor Tail 50) 0x00000000
0x01CD8: RDT51 (Receive Descriptor Tail 51) 0x00000000
0x01D18: RDT52 (Receive Descriptor Tail 52) 0x00000000
0x01D58: RDT53 (Receive Descriptor Tail 53) 0x00000000
0x01D98: RDT54 (Receive Descriptor Tail 54) 0x00000000
0x01DD8: RDT55 (Receive Descriptor Tail 55) 0x00000000
0x01E18: RDT56 (Receive Descriptor Tail 56) 0x00000000
0x01E58: RDT57 (Receive Descriptor Tail 57) 0x00000000
0x01E98: RDT58 (Receive Descriptor Tail 58) 0x00000000
0x01ED8: RDT59 (Receive Descriptor Tail 59) 0x00000000
0x01F18: RDT60 (Receive Descriptor Tail 60) 0x00000000
0x01F58: RDT61 (Receive Descriptor Tail 61) 0x00000000
0x01F98: RDT62 (Receive Descriptor Tail 62) 0x00000000
0x01FD8: RDT63 (Receive Descriptor Tail 63) 0x00000000
0x01028: RXDCTL00 (Receive Descriptor Control 00) 0x42000000
0x01068: RXDCTL01 (Receive Descriptor Control 01) 0x42000000
0x010A8: RXDCTL02 (Receive Descriptor Control 02) 0x42000000
0x010E8: RXDCTL03 (Receive Descriptor Control 03) 0x42000000
0x01128: RXDCTL04 (Receive Descriptor Control 04) 0x42000000
0x01168: RXDCTL05 (Receive Descriptor Control 05) 0x42000000
0x011A8: RXDCTL06 (Receive Descriptor Control 06) 0x42000000
0x011E8: RXDCTL07 (Receive Descriptor Control 07) 0x42000000
0x01228: RXDCTL08 (Receive Descriptor Control 08) 0x42000000
0x01268: RXDCTL09 (Receive Descriptor Control 09) 0x42000000
0x012A8: RXDCTL10 (Receive Descriptor Control 10) 0x42000000
0x012E8: RXDCTL11 (Receive Descriptor Control 11) 0x42000000
0x01328: RXDCTL12 (Receive Descriptor Control 12) 0x42000000
0x01368: RXDCTL13 (Receive Descriptor Control 13) 0x42000000
0x013A8: RXDCTL14 (Receive Descriptor Control 14) 0x42000000
0x013E8: RXDCTL15 (Receive Descriptor Control 15) 0x42000000
0x01428: RXDCTL16 (Receive Descriptor Control 16) 0x00000000
0x01468: RXDCTL17 (Receive Descriptor Control 17) 0x00000000
0x014A8: RXDCTL18 (Receive Descriptor Control 18) 0x00000000
0x014E8: RXDCTL19 (Receive Descriptor Control 19) 0x00000000
0x01528: RXDCTL20 (Receive Descriptor Control 20) 0x00000000
0x01568: RXDCTL21 (Receive Descriptor Control 21) 0x00000000
0x015A8: RXDCTL22 (Receive Descriptor Control 22) 0x00000000
0x015E8: RXDCTL23 (Receive Descriptor Control 23) 0x00000000
0x01628: RXDCTL24 (Receive Descriptor Control 24) 0x00000000
0x01668: RXDCTL25 (Receive Descriptor Control 25) 0x00000000
0x016A8: RXDCTL26 (Receive Descriptor Control 26) 0x00000000
0x016E8: RXDCTL27 (Receive Descriptor Control 27) 0x00000000
0x01728: RXDCTL28 (Receive Descriptor Control 28) 0x00000000
0x01768: RXDCTL29 (Receive Descriptor Control 29) 0x00000000
0x017A8: RXDCTL30 (Receive Descriptor Control 30) 0x00000000
0x017E8: RXDCTL31 (Receive Descriptor Control 31) 0x00000000
0x01828: RXDCTL32 (Receive Descriptor Control 32) 0x00000000
0x01868: RXDCTL33 (Receive Descriptor Control 33) 0x00000000
0x018A8: RXDCTL34 (Receive Descriptor Control 34) 0x00000000
0x018E8: RXDCTL35 (Receive Descriptor Control 35) 0x00000000
0x01928: RXDCTL36 (Receive Descriptor Control 36) 0x00000000
0x01968: RXDCTL37 (Receive Descriptor Control 37) 0x00000000
0x019A8: RXDCTL38 (Receive Descriptor Control 38) 0x00000000
0x019E8: RXDCTL39 (Receive Descriptor Control 39) 0x00000000
0x01A28: RXDCTL40 (Receive Descriptor Control 40) 0x00000000
0x01A68: RXDCTL41 (Receive Descriptor Control 41) 0x00000000
0x01AA8: RXDCTL42 (Receive Descriptor Control 42) 0x00000000
0x01AE8: RXDCTL43 (Receive Descriptor Control 43) 0x00000000
0x01B28: RXDCTL44 (Receive Descriptor Control 44) 0x00000000
0x01B68: RXDCTL45 (Receive Descriptor Control 45) 0x00000000
0x01BA8: RXDCTL46 (Receive Descriptor Control 46) 0x00000000
0x01BE8: RXDCTL47 (Receive Descriptor Control 47) 0x00000000
0x01C28: RXDCTL48 (Receive Descriptor Control 48) 0x00000000
0x01C68: RXDCTL49 (Receive Descriptor Control 49) 0x00000000
0x01CA8: RXDCTL50 (Receive Descriptor Control 50) 0x00000000
0x01CE8: RXDCTL51 (Receive Descriptor Control 51) 0x00000000
0x01D28: RXDCTL52 (Receive Descriptor Control 52) 0x00000000
0x01D68: RXDCTL53 (Receive Descriptor Control 53) 0x00000000
0x01DA8: RXDCTL54 (Receive Descriptor Control 54) 0x00000000
0x01DE8: RXDCTL55 (Receive Descriptor Control 55) 0x00000000
0x01E28: RXDCTL56 (Receive Descriptor Control 56) 0x00000000
0x01E68: RXDCTL57 (Receive Descriptor Control 57) 0x00000000
0x01EA8: RXDCTL58 (Receive Descriptor Control 58) 0x00000000
0x01EE8: RXDCTL59 (Receive Descriptor Control 59) 0x00000000
0x01F28: RXDCTL60 (Receive Descriptor Control 60) 0x00000000
0x01F68: RXDCTL61 (Receive Descriptor Control 61) 0x00000000
0x01FA8: RXDCTL62 (Receive Descriptor Control 62) 0x00000000
0x01FE8: RXDCTL63 (Receive Descriptor Control 63) 0x00000000
0x02100: SRRCTL00 (Split and Replic Rx Control 00) 0x02000402
0x02104: SRRCTL01 (Split and Replic Rx Control 01) 0x02000402
0x02108: SRRCTL02 (Split and Replic Rx Control 02) 0x02000402
0x0210C: SRRCTL03 (Split and Replic Rx Control 03) 0x02000402
0x02110: SRRCTL04 (Split and Replic Rx Control 04) 0x02000402
0x02114: SRRCTL05 (Split and Replic Rx Control 05) 0x02000402
0x02118: SRRCTL06 (Split and Replic Rx Control 06) 0x02000402
0x0211C: SRRCTL07 (Split and Replic Rx Control 07) 0x02000402
0x02120: SRRCTL08 (Split and Replic Rx Control 08) 0x02000402
0x02124: SRRCTL09 (Split and Replic Rx Control 09) 0x02000402
0x02128: SRRCTL10 (Split and Replic Rx Control 10) 0x02000402
0x0212C: SRRCTL11 (Split and Replic Rx Control 11) 0x02000402
0x02130: SRRCTL12 (Split and Replic Rx Control 12) 0x02000402
0x02134: SRRCTL13 (Split and Replic Rx Control 13) 0x02000402
0x02138: SRRCTL14 (Split and Replic Rx Control 14) 0x02000402
0x0213C: SRRCTL15 (Split and Replic Rx Control 15) 0x02000402
0x02200: DCA_RXCTRL00 (Rx DCA Control 00) 0x00001200
0x02204: DCA_RXCTRL01 (Rx DCA Control 01) 0x00001200
0x02208: DCA_RXCTRL02 (Rx DCA Control 02) 0x00001200
0x0220C: DCA_RXCTRL03 (Rx DCA Control 03) 0x00001200
0x02210: DCA_RXCTRL04 (Rx DCA Control 04) 0x00001200
0x02214: DCA_RXCTRL05 (Rx DCA Control 05) 0x00001200
0x02218: DCA_RXCTRL06 (Rx DCA Control 06) 0x00001200
0x0221C: DCA_RXCTRL07 (Rx DCA Control 07) 0x00001200
0x02220: DCA_RXCTRL08 (Rx DCA Control 08) 0x00001200
0x02224: DCA_RXCTRL09 (Rx DCA Control 09) 0x00001200
0x02228: DCA_RXCTRL10 (Rx DCA Control 10) 0x00001200
0x0222C: DCA_RXCTRL11 (Rx DCA Control 11) 0x00001200
0x02230: DCA_RXCTRL12 (Rx DCA Control 12) 0x00001200
0x02234: DCA_RXCTRL13 (Rx DCA Control 13) 0x00001200
0x02238: DCA_RXCTRL14 (Rx DCA Control 14) 0x00001200
0x0223C: DCA_RXCTRL15 (Rx DCA Control 15) 0x00001200
0x02F00: RDRXCTL (Receive DMA Control) 0x0600880A
0x03C00: RXPBSIZE0 (Receive Packet Buffer Size 0) 0x00070000
0x03C04: RXPBSIZE1 (Receive Packet Buffer Size 1) 0x00000000
0x03C08: RXPBSIZE2 (Receive Packet Buffer Size 2) 0x00000000
0x03C0C: RXPBSIZE3 (Receive Packet Buffer Size 3) 0x00000000
0x03C10: RXPBSIZE4 (Receive Packet Buffer Size 4) 0x00000000
0x03C14: RXPBSIZE5 (Receive Packet Buffer Size 5) 0x00000000
0x03C18: RXPBSIZE6 (Receive Packet Buffer Size 6) 0x00000000
0x03C1C: RXPBSIZE7 (Receive Packet Buffer Size 7) 0x00000000
0x03000: RXCTRL (Receive Control) 0x00000001
0x05000: RXCSUM (Receive Checksum Control) 0x00002000
0x05008: RFCTL (Receive Filter Control) 0x00000020
0x05400: RAL00 (Receive Address Low00) 0x172F0B00
0x05408: RAL01 (Receive Address Low01) 0x00000000
0x05410: RAL02 (Receive Address Low02) 0x00000000
0x05418: RAL03 (Receive Address Low03) 0x00000000
0x05420: RAL04 (Receive Address Low04) 0x00000000
0x05428: RAL05 (Receive Address Low05) 0x00000000
0x05430: RAL06 (Receive Address Low06) 0x00000000
0x05438: RAL07 (Receive Address Low07) 0x00000000
0x05440: RAL08 (Receive Address Low08) 0x00000000
0x05448: RAL09 (Receive Address Low09) 0x00000000
0x05450: RAL10 (Receive Address Low10) 0x00000000
0x05458: RAL11 (Receive Address Low11) 0x00000000
0x05460: RAL12 (Receive Address Low12) 0x00000000
0x05468: RAL13 (Receive Address Low13) 0x00000000
0x05470: RAL14 (Receive Address Low14) 0x00000000
0x05478: RAL15 (Receive Address Low15) 0x00000000
0x05404: RAH00 (Receive Address High 00) 0x800091F6
0x0540C: RAH01 (Receive Address High 01) 0x00000000
0x05414: RAH02 (Receive Address High 02) 0x00000000
0x0541C: RAH03 (Receive Address High 03) 0x00000000
0x05424: RAH04 (Receive Address High 04) 0x00000000
0x0542C: RAH05 (Receive Address High 05) 0x00000000
0x05434: RAH06 (Receive Address High 06) 0x00000000
0x0543C: RAH07 (Receive Address High 07) 0x00000000
0x05444: RAH08 (Receive Address High 08) 0x00000000
0x0544C: RAH09 (Receive Address High 09) 0x00000000
0x05454: RAH10 (Receive Address High 10) 0x00000000
0x0545C: RAH11 (Receive Address High 11) 0x00000000
0x05464: RAH12 (Receive Address High 12) 0x00000000
0x0546C: RAH13 (Receive Address High 13) 0x00000000
0x05474: RAH14 (Receive Address High 14) 0x00000000
0x0547C: RAH15 (Receive Address High 15) 0x00000000
0x05480: PSRTYPE (Packet Split Receive Type) 0x40001330
0x05090: MCSTCTRL (Multicast Control) 0x00000004
0x05818: MRQC (Multiple Rx Queues Command) 0x00330001
0x0581C: VMD_CTL (VMDq Control) 0x00000000
0x05A80: IMIR0 (Immediate Interrupt Rx 0) 0x00000000
0x05A84: IMIR1 (Immediate Interrupt Rx 1) 0x00000000
0x05A88: IMIR2 (Immediate Interrupt Rx 2) 0x00000000
0x05A8C: IMIR3 (Immediate Interrupt Rx 3) 0x00000000
0x05A90: IMIR4 (Immediate Interrupt Rx 4) 0x00000000
0x05A94: IMIR5 (Immediate Interrupt Rx 5) 0x00000000
0x05A98: IMIR6 (Immediate Interrupt Rx 6) 0x00000000
0x05A9C: IMIR7 (Immediate Interrupt Rx 7) 0x00000000
0x05AA0: IMIREXT0 (Immed. Interr. Rx Extended 0) 0x00000000
0x05AA4: IMIREXT1 (Immed. Interr. Rx Extended 1) 0x00000000
0x05AA8: IMIREXT2 (Immed. Interr. Rx Extended 2) 0x00000000
0x05AAC: IMIREXT3 (Immed. Interr. Rx Extended 3) 0x00000000
0x05AB0: IMIREXT4 (Immed. Interr. Rx Extended 4) 0x00000000
0x05AB4: IMIREXT5 (Immed. Interr. Rx Extended 5) 0x00000000
0x05AB8: IMIREXT6 (Immed. Interr. Rx Extended 6) 0x00000000
0x05ABC: IMIREXT7 (Immed. Interr. Rx Extended 7) 0x00000000
0x05AC0: IMIRVP (Immed. Interr. Rx VLAN Prior.) 0x00000000
0x06000: TDBAL00 (Tx Desc Base Addr Low 00) 0xDB0F0000
0x06040: TDBAL01 (Tx Desc Base Addr Low 01) 0xDB050000
0x06080: TDBAL02 (Tx Desc Base Addr Low 02) 0xDB006000
0x060C0: TDBAL03 (Tx Desc Base Addr Low 03) 0xDB710000
0x06100: TDBAL04 (Tx Desc Base Addr Low 04) 0xDB124000
0x06140: TDBAL05 (Tx Desc Base Addr Low 05) 0xDB0C6000
0x06180: TDBAL06 (Tx Desc Base Addr Low 06) 0xDB004000
0x061C0: TDBAL07 (Tx Desc Base Addr Low 07) 0xDB0D0000
0x06200: TDBAL08 (Tx Desc Base Addr Low 08) 0xDB102000
0x06240: TDBAL09 (Tx Desc Base Addr Low 09) 0xDB704000
0x06280: TDBAL10 (Tx Desc Base Addr Low 10) 0xDB714000
0x062C0: TDBAL11 (Tx Desc Base Addr Low 11) 0xDB0A4000
0x06300: TDBAL12 (Tx Desc Base Addr Low 12) 0xDB0A6000
0x06340: TDBAL13 (Tx Desc Base Addr Low 13) 0xDB12A000
0x06380: TDBAL14 (Tx Desc Base Addr Low 14) 0xDB122000
0x063C0: TDBAL15 (Tx Desc Base Addr Low 15) 0xDB02C000
0x06400: TDBAL16 (Tx Desc Base Addr Low 16) 0x00000000
0x06440: TDBAL17 (Tx Desc Base Addr Low 17) 0x00000000
0x06480: TDBAL18 (Tx Desc Base Addr Low 18) 0x00000000
0x064C0: TDBAL19 (Tx Desc Base Addr Low 19) 0x00000000
0x06500: TDBAL20 (Tx Desc Base Addr Low 20) 0x00000000
0x06540: TDBAL21 (Tx Desc Base Addr Low 21) 0x00000000
0x06580: TDBAL22 (Tx Desc Base Addr Low 22) 0x00000000
0x065C0: TDBAL23 (Tx Desc Base Addr Low 23) 0x00000000
0x06600: TDBAL24 (Tx Desc Base Addr Low 24) 0x00000000
0x06640: TDBAL25 (Tx Desc Base Addr Low 25) 0x00000000
0x06680: TDBAL26 (Tx Desc Base Addr Low 26) 0x00000000
0x066C0: TDBAL27 (Tx Desc Base Addr Low 27) 0x00000000
0x06700: TDBAL28 (Tx Desc Base Addr Low 28) 0x00000000
0x06740: TDBAL29 (Tx Desc Base Addr Low 29) 0x00000000
0x06780: TDBAL30 (Tx Desc Base Addr Low 30) 0x00000000
0x067C0: TDBAL31 (Tx Desc Base Addr Low 31) 0x00000000
0x06004: TDBAH00 (Tx Desc Base Addr High 00) 0x00000000
0x06044: TDBAH01 (Tx Desc Base Addr High 01) 0x00000000
0x06084: TDBAH02 (Tx Desc Base Addr High 02) 0x00000000
0x060C4: TDBAH03 (Tx Desc Base Addr High 03) 0x00000000
0x06104: TDBAH04 (Tx Desc Base Addr High 04) 0x00000000
0x06144: TDBAH05 (Tx Desc Base Addr High 05) 0x00000000
0x06184: TDBAH06 (Tx Desc Base Addr High 06) 0x00000000
0x061C4: TDBAH07 (Tx Desc Base Addr High 07) 0x00000000
0x06204: TDBAH08 (Tx Desc Base Addr High 08) 0x00000000
0x06244: TDBAH09 (Tx Desc Base Addr High 09) 0x00000000
0x06284: TDBAH10 (Tx Desc Base Addr High 10) 0x00000000
0x062C4: TDBAH11 (Tx Desc Base Addr High 11) 0x00000000
0x06304: TDBAH12 (Tx Desc Base Addr High 12) 0x00000000
0x06344: TDBAH13 (Tx Desc Base Addr High 13) 0x00000000
0x06384: TDBAH14 (Tx Desc Base Addr High 14) 0x00000000
0x063C4: TDBAH15 (Tx Desc Base Addr High 15) 0x00000000
0x06404: TDBAH16 (Tx Desc Base Addr High 16) 0x00000000
0x06444: TDBAH17 (Tx Desc Base Addr High 17) 0x00000000
0x06484: TDBAH18 (Tx Desc Base Addr High 18) 0x00000000
0x064C4: TDBAH19 (Tx Desc Base Addr High 19) 0x00000000
0x06504: TDBAH20 (Tx Desc Base Addr High 20) 0x00000000
0x06544: TDBAH21 (Tx Desc Base Addr High 21) 0x00000000
0x06584: TDBAH22 (Tx Desc Base Addr High 22) 0x00000000
0x065C4: TDBAH23 (Tx Desc Base Addr High 23) 0x00000000
0x06604: TDBAH24 (Tx Desc Base Addr High 24) 0x00000000
0x06644: TDBAH25 (Tx Desc Base Addr High 25) 0x00000000
0x06684: TDBAH26 (Tx Desc Base Addr High 26) 0x00000000
0x066C4: TDBAH27 (Tx Desc Base Addr High 27) 0x00000000
0x06704: TDBAH28 (Tx Desc Base Addr High 28) 0x00000000
0x06744: TDBAH29 (Tx Desc Base Addr High 29) 0x00000000
0x06784: TDBAH30 (Tx Desc Base Addr High 30) 0x00000000
0x067C4: TDBAH31 (Tx Desc Base Addr High 31) 0x00000000
0x06008: TDLEN00 (Tx Descriptor Length 00) 0x00002000
0x06048: TDLEN01 (Tx Descriptor Length 01) 0x00002000
0x06088: TDLEN02 (Tx Descriptor Length 02) 0x00002000
0x060C8: TDLEN03 (Tx Descriptor Length 03) 0x00002000
0x06108: TDLEN04 (Tx Descriptor Length 04) 0x00002000
0x06148: TDLEN05 (Tx Descriptor Length 05) 0x00002000
0x06188: TDLEN06 (Tx Descriptor Length 06) 0x00002000
0x061C8: TDLEN07 (Tx Descriptor Length 07) 0x00002000
0x06208: TDLEN08 (Tx Descriptor Length 08) 0x00002000
0x06248: TDLEN09 (Tx Descriptor Length 09) 0x00002000
0x06288: TDLEN10 (Tx Descriptor Length 10) 0x00002000
0x062C8: TDLEN11 (Tx Descriptor Length 11) 0x00002000
0x06308: TDLEN12 (Tx Descriptor Length 12) 0x00002000
0x06348: TDLEN13 (Tx Descriptor Length 13) 0x00002000
0x06388: TDLEN14 (Tx Descriptor Length 14) 0x00002000
0x063C8: TDLEN15 (Tx Descriptor Length 15) 0x00002000
0x06408: TDLEN16 (Tx Descriptor Length 16) 0x00000000
0x06448: TDLEN17 (Tx Descriptor Length 17) 0x00000000
0x06488: TDLEN18 (Tx Descriptor Length 18) 0x00000000
0x064C8: TDLEN19 (Tx Descriptor Length 19) 0x00000000
0x06508: TDLEN20 (Tx Descriptor Length 20) 0x00000000
0x06548: TDLEN21 (Tx Descriptor Length 21) 0x00000000
0x06588: TDLEN22 (Tx Descriptor Length 22) 0x00000000
0x065C8: TDLEN23 (Tx Descriptor Length 23) 0x00000000
0x06608: TDLEN24 (Tx Descriptor Length 24) 0x00000000
0x06648: TDLEN25 (Tx Descriptor Length 25) 0x00000000
0x06688: TDLEN26 (Tx Descriptor Length 26) 0x00000000
0x066C8: TDLEN27 (Tx Descriptor Length 27) 0x00000000
0x06708: TDLEN28 (Tx Descriptor Length 28) 0x00000000
0x06748: TDLEN29 (Tx Descriptor Length 29) 0x00000000
0x06788: TDLEN30 (Tx Descriptor Length 30) 0x00000000
0x067C8: TDLEN31 (Tx Descriptor Length 31) 0x00000000
0x06010: TDH00 (Transmit Descriptor Head 00) 0x00000000
0x06050: TDH01 (Transmit Descriptor Head 01) 0x00000000
0x06090: TDH02 (Transmit Descriptor Head 02) 0x00000000
0x060D0: TDH03 (Transmit Descriptor Head 03) 0x00000000
0x06110: TDH04 (Transmit Descriptor Head 04) 0x00000000
0x06150: TDH05 (Transmit Descriptor Head 05) 0x00000000
0x06190: TDH06 (Transmit Descriptor Head 06) 0x00000000
0x061D0: TDH07 (Transmit Descriptor Head 07) 0x00000000
0x06210: TDH08 (Transmit Descriptor Head 08) 0x00000000
0x06250: TDH09 (Transmit Descriptor Head 09) 0x00000000
0x06290: TDH10 (Transmit Descriptor Head 10) 0x00000000
0x062D0: TDH11 (Transmit Descriptor Head 11) 0x00000000
0x06310: TDH12 (Transmit Descriptor Head 12) 0x00000000
0x06350: TDH13 (Transmit Descriptor Head 13) 0x00000000
0x06390: TDH14 (Transmit Descriptor Head 14) 0x00000000
0x063D0: TDH15 (Transmit Descriptor Head 15) 0x00000000
0x06410: TDH16 (Transmit Descriptor Head 16) 0x00000000
0x06450: TDH17 (Transmit Descriptor Head 17) 0x00000000
0x06490: TDH18 (Transmit Descriptor Head 18) 0x00000000
0x064D0: TDH19 (Transmit Descriptor Head 19) 0x00000000
0x06510: TDH20 (Transmit Descriptor Head 20) 0x00000000
0x06550: TDH21 (Transmit Descriptor Head 21) 0x00000000
0x06590: TDH22 (Transmit Descriptor Head 22) 0x00000000
0x065D0: TDH23 (Transmit Descriptor Head 23) 0x00000000
0x06610: TDH24 (Transmit Descriptor Head 24) 0x00000000
0x06650: TDH25 (Transmit Descriptor Head 25) 0x00000000
0x06690: TDH26 (Transmit Descriptor Head 26) 0x00000000
0x066D0: TDH27 (Transmit Descriptor Head 27) 0x00000000
0x06710: TDH28 (Transmit Descriptor Head 28) 0x00000000
0x06750: TDH29 (Transmit Descriptor Head 29) 0x00000000
0x06790: TDH30 (Transmit Descriptor Head 30) 0x00000000
0x067D0: TDH31 (Transmit Descriptor Head 31) 0x00000000
0x06018: TDT00 (Transmit Descriptor Tail 00) 0x00000000
0x06058: TDT01 (Transmit Descriptor Tail 01) 0x00000000
0x06098: TDT02 (Transmit Descriptor Tail 02) 0x00000000
0x060D8: TDT03 (Transmit Descriptor Tail 03) 0x00000000
0x06118: TDT04 (Transmit Descriptor Tail 04) 0x00000000
0x06158: TDT05 (Transmit Descriptor Tail 05) 0x00000000
0x06198: TDT06 (Transmit Descriptor Tail 06) 0x00000000
0x061D8: TDT07 (Transmit Descriptor Tail 07) 0x00000000
0x06218: TDT08 (Transmit Descriptor Tail 08) 0x00000000
0x06258: TDT09 (Transmit Descriptor Tail 09) 0x00000000
0x06298: TDT10 (Transmit Descriptor Tail 10) 0x00000000
0x062D8: TDT11 (Transmit Descriptor Tail 11) 0x00000000
0x06318: TDT12 (Transmit Descriptor Tail 12) 0x00000000
0x06358: TDT13 (Transmit Descriptor Tail 13) 0x00000000
0x06398: TDT14 (Transmit Descriptor Tail 14) 0x00000000
0x063D8: TDT15 (Transmit Descriptor Tail 15) 0x00000000
0x06418: TDT16 (Transmit Descriptor Tail 16) 0x00000000
0x06458: TDT17 (Transmit Descriptor Tail 17) 0x00000000
0x06498: TDT18 (Transmit Descriptor Tail 18) 0x00000000
0x064D8: TDT19 (Transmit Descriptor Tail 19) 0x00000000
0x06518: TDT20 (Transmit Descriptor Tail 20) 0x00000000
0x06558: TDT21 (Transmit Descriptor Tail 21) 0x00000000
0x06598: TDT22 (Transmit Descriptor Tail 22) 0x00000000
0x065D8: TDT23 (Transmit Descriptor Tail 23) 0x00000000
0x06618: TDT24 (Transmit Descriptor Tail 24) 0x00000000
0x06658: TDT25 (Transmit Descriptor Tail 25) 0x00000000
0x06698: TDT26 (Transmit Descriptor Tail 26) 0x00000000
0x066D8: TDT27 (Transmit Descriptor Tail 27) 0x00000000
0x06718: TDT28 (Transmit Descriptor Tail 28) 0x00000000
0x06758: TDT29 (Transmit Descriptor Tail 29) 0x00000000
0x06798: TDT30 (Transmit Descriptor Tail 30) 0x00000000
0x067D8: TDT31 (Transmit Descriptor Tail 31) 0x00000000
0x06028: TXDCTL00 (Tx Descriptor Control 00) 0x02080120
0x06068: TXDCTL01 (Tx Descriptor Control 01) 0x02080120
0x060A8: TXDCTL02 (Tx Descriptor Control 02) 0x02080120
0x060E8: TXDCTL03 (Tx Descriptor Control 03) 0x02080120
0x06128: TXDCTL04 (Tx Descriptor Control 04) 0x02080120
0x06168: TXDCTL05 (Tx Descriptor Control 05) 0x02080120
0x061A8: TXDCTL06 (Tx Descriptor Control 06) 0x02080120
0x061E8: TXDCTL07 (Tx Descriptor Control 07) 0x02080120
0x06228: TXDCTL08 (Tx Descriptor Control 08) 0x02080120
0x06268: TXDCTL09 (Tx Descriptor Control 09) 0x02080120
0x062A8: TXDCTL10 (Tx Descriptor Control 10) 0x02080120
0x062E8: TXDCTL11 (Tx Descriptor Control 11) 0x02080120
0x06328: TXDCTL12 (Tx Descriptor Control 12) 0x02080120
0x06368: TXDCTL13 (Tx Descriptor Control 13) 0x02080120
0x063A8: TXDCTL14 (Tx Descriptor Control 14) 0x02080120
0x063E8: TXDCTL15 (Tx Descriptor Control 15) 0x02080120
0x06428: TXDCTL16 (Tx Descriptor Control 16) 0x00000000
0x06468: TXDCTL17 (Tx Descriptor Control 17) 0x00000000
0x064A8: TXDCTL18 (Tx Descriptor Control 18) 0x00000000
0x064E8: TXDCTL19 (Tx Descriptor Control 19) 0x00000000
0x06528: TXDCTL20 (Tx Descriptor Control 20) 0x00000000
0x06568: TXDCTL21 (Tx Descriptor Control 21) 0x00000000
0x065A8: TXDCTL22 (Tx Descriptor Control 22) 0x00000000
0x065E8: TXDCTL23 (Tx Descriptor Control 23) 0x00000000
0x06628: TXDCTL24 (Tx Descriptor Control 24) 0x00000000
0x06668: TXDCTL25 (Tx Descriptor Control 25) 0x00000000
0x066A8: TXDCTL26 (Tx Descriptor Control 26) 0x00000000
0x066E8: TXDCTL27 (Tx Descriptor Control 27) 0x00000000
0x06728: TXDCTL28 (Tx Descriptor Control 28) 0x00000000
0x06768: TXDCTL29 (Tx Descriptor Control 29) 0x00000000
0x067A8: TXDCTL30 (Tx Descriptor Control 30) 0x00000000
0x067E8: TXDCTL31 (Tx Descriptor Control 31) 0x00000000
0x06038: TDWBAL00 (Tx Desc Compl. WB Addr low 00) 0x00000000
0x06078: TDWBAL01 (Tx Desc Compl. WB Addr low 01) 0x00000000
0x060B8: TDWBAL02 (Tx Desc Compl. WB Addr low 02) 0x00000000
0x060F8: TDWBAL03 (Tx Desc Compl. WB Addr low 03) 0x00000000
0x06138: TDWBAL04 (Tx Desc Compl. WB Addr low 04) 0x00000000
0x06178: TDWBAL05 (Tx Desc Compl. WB Addr low 05) 0x00000000
0x061B8: TDWBAL06 (Tx Desc Compl. WB Addr low 06) 0x00000000
0x061F8: TDWBAL07 (Tx Desc Compl. WB Addr low 07) 0x00000000
0x06238: TDWBAL08 (Tx Desc Compl. WB Addr low 08) 0x00000000
0x06278: TDWBAL09 (Tx Desc Compl. WB Addr low 09) 0x00000000
0x062B8: TDWBAL10 (Tx Desc Compl. WB Addr low 10) 0x00000000
0x062F8: TDWBAL11 (Tx Desc Compl. WB Addr low 11) 0x00000000
0x06338: TDWBAL12 (Tx Desc Compl. WB Addr low 12) 0x00000000
0x06378: TDWBAL13 (Tx Desc Compl. WB Addr low 13) 0x00000000
0x063B8: TDWBAL14 (Tx Desc Compl. WB Addr low 14) 0x00000000
0x063F8: TDWBAL15 (Tx Desc Compl. WB Addr low 15) 0x00000000
0x06438: TDWBAL16 (Tx Desc Compl. WB Addr low 16) 0x00000000
0x06478: TDWBAL17 (Tx Desc Compl. WB Addr low 17) 0x00000000
0x064B8: TDWBAL18 (Tx Desc Compl. WB Addr low 18) 0x00000000
0x064F8: TDWBAL19 (Tx Desc Compl. WB Addr low 19) 0x00000000
0x06538: TDWBAL20 (Tx Desc Compl. WB Addr low 20) 0x00000000
0x06578: TDWBAL21 (Tx Desc Compl. WB Addr low 21) 0x00000000
0x065B8: TDWBAL22 (Tx Desc Compl. WB Addr low 22) 0x00000000
0x065F8: TDWBAL23 (Tx Desc Compl. WB Addr low 23) 0x00000000
0x06638: TDWBAL24 (Tx Desc Compl. WB Addr low 24) 0x00000000
0x06678: TDWBAL25 (Tx Desc Compl. WB Addr low 25) 0x00000000
0x066B8: TDWBAL26 (Tx Desc Compl. WB Addr low 26) 0x00000000
0x066F8: TDWBAL27 (Tx Desc Compl. WB Addr low 27) 0x00000000
0x06738: TDWBAL28 (Tx Desc Compl. WB Addr low 28) 0x00000000
0x06778: TDWBAL29 (Tx Desc Compl. WB Addr low 29) 0x00000000
0x067B8: TDWBAL30 (Tx Desc Compl. WB Addr low 30) 0x00000000
0x067F8: TDWBAL31 (Tx Desc Compl. WB Addr low 31) 0x00000000
0x0603C: TDWBAH00 (Tx Desc Compl. WB Addr High 00) 0x00000000
0x0607C: TDWBAH01 (Tx Desc Compl. WB Addr High 01) 0x00000000
0x060BC: TDWBAH02 (Tx Desc Compl. WB Addr High 02) 0x00000000
0x060FC: TDWBAH03 (Tx Desc Compl. WB Addr High 03) 0x00000000
0x0613C: TDWBAH04 (Tx Desc Compl. WB Addr High 04) 0x00000000
0x0617C: TDWBAH05 (Tx Desc Compl. WB Addr High 05) 0x00000000
0x061BC: TDWBAH06 (Tx Desc Compl. WB Addr High 06) 0x00000000
0x061FC: TDWBAH07 (Tx Desc Compl. WB Addr High 07) 0x00000000
0x0623C: TDWBAH08 (Tx Desc Compl. WB Addr High 08) 0x00000000
0x0627C: TDWBAH09 (Tx Desc Compl. WB Addr High 09) 0x00000000
0x062BC: TDWBAH10 (Tx Desc Compl. WB Addr High 10) 0x00000000
0x062FC: TDWBAH11 (Tx Desc Compl. WB Addr High 11) 0x00000000
0x0633C: TDWBAH12 (Tx Desc Compl. WB Addr High 12) 0x00000000
0x0637C: TDWBAH13 (Tx Desc Compl. WB Addr High 13) 0x00000000
0x063BC: TDWBAH14 (Tx Desc Compl. WB Addr High 14) 0x00000000
0x063FC: TDWBAH15 (Tx Desc Compl. WB Addr High 15) 0x00000000
0x0643C: TDWBAH16 (Tx Desc Compl. WB Addr High 16) 0x00000000
0x0647C: TDWBAH17 (Tx Desc Compl. WB Addr High 17) 0x00000000
0x064BC: TDWBAH18 (Tx Desc Compl. WB Addr High 18) 0x00000000
0x064FC: TDWBAH19 (Tx Desc Compl. WB Addr High 19) 0x00000000
0x0653C: TDWBAH20 (Tx Desc Compl. WB Addr High 20) 0x00000000
0x0657C: TDWBAH21 (Tx Desc Compl. WB Addr High 21) 0x00000000
0x065BC: TDWBAH22 (Tx Desc Compl. WB Addr High 22) 0x00000000
0x065FC: TDWBAH23 (Tx Desc Compl. WB Addr High 23) 0x00000000
0x0663C: TDWBAH24 (Tx Desc Compl. WB Addr High 24) 0x00000000
0x0667C: TDWBAH25 (Tx Desc Compl. WB Addr High 25) 0x00000000
0x066BC: TDWBAH26 (Tx Desc Compl. WB Addr High 26) 0x00000000
0x066FC: TDWBAH27 (Tx Desc Compl. WB Addr High 27) 0x00000000
0x0673C: TDWBAH28 (Tx Desc Compl. WB Addr High 28) 0x00000000
0x0677C: TDWBAH29 (Tx Desc Compl. WB Addr High 29) 0x00000000
0x067BC: TDWBAH30 (Tx Desc Compl. WB Addr High 30) 0x00000000
0x067FC: TDWBAH31 (Tx Desc Compl. WB Addr High 31) 0x00000000
0x07E00: DTXCTL (DMA Tx Control) 0x00000000
0x07200: DCA_TXCTRL00 (Tx DCA Control 00) 0x00000000
0x07204: DCA_TXCTRL01 (Tx DCA Control 01) 0x00000000
0x07208: DCA_TXCTRL02 (Tx DCA Control 02) 0x00000000
0x0720C: DCA_TXCTRL03 (Tx DCA Control 03) 0x00002200
0x07210: DCA_TXCTRL04 (Tx DCA Control 04) 0x00000000
0x07214: DCA_TXCTRL05 (Tx DCA Control 05) 0x00000000
0x07218: DCA_TXCTRL06 (Tx DCA Control 06) 0x00000000
0x0721C: DCA_TXCTRL07 (Tx DCA Control 07) 0x00000000
0x07220: DCA_TXCTRL08 (Tx DCA Control 08) 0x00000000
0x07224: DCA_TXCTRL09 (Tx DCA Control 09) 0x00000000
0x07228: DCA_TXCTRL10 (Tx DCA Control 10) 0x00000000
0x0722C: DCA_TXCTRL11 (Tx DCA Control 11) 0x00000000
0x07230: DCA_TXCTRL12 (Tx DCA Control 12) 0x00000000
0x07234: DCA_TXCTRL13 (Tx DCA Control 13) 0x00030008
0x07238: DCA_TXCTRL14 (Tx DCA Control 14) 0x00000000
0x0723C: DCA_TXCTRL15 (Tx DCA Control 15) 0x00000000
0x0CC00: TXPBSIZE0 (Transmit Packet Buffer Size 0) 0x00028000
0x0CC04: TXPBSIZE1 (Transmit Packet Buffer Size 1) 0x00000000
0x0CC08: TXPBSIZE2 (Transmit Packet Buffer Size 2) 0x00000000
0x0CC0C: TXPBSIZE3 (Transmit Packet Buffer Size 3) 0x00000000
0x0CC10: TXPBSIZE4 (Transmit Packet Buffer Size 4) 0x00000000
0x0CC14: TXPBSIZE5 (Transmit Packet Buffer Size 5) 0x00000000
0x0CC18: TXPBSIZE6 (Transmit Packet Buffer Size 6) 0x00000000
0x0CC1C: TXPBSIZE7 (Transmit Packet Buffer Size 7) 0x00000000
0x0CD10: MNGTXMAP (Manageability Tx TC Mapping) 0x00000000
0x05800: WUC (Wake up Control) 0x00000010
0x05808: WUFC (Wake Up Filter Control) 0x00000000
0x05810: WUS (Wake Up Status) 0x00000000
0x05838: IPAV (IP Address Valid) 0x00000000
0x05840: IP4AT (IPv4 Address Table) 0x00000000
0x05880: IP6AT (IPv6 Address Table) 0x00000000
0x05900: WUPL (Wake Up Packet Length) 0x00000000
0x05A00: WUPM (Wake Up Packet Memory) 0x00000000
0x09000: FHFT (Flexible Host Filter Table) 0x8440A204
0x04900: RTTDCS (Tx Descr Plane Ctrl&Status) 0x00C00000
0x0CD00: RTTPCS (Tx Pkt Plane Ctrl&Status) 0x89000000
0x02430: RTRPCS (Rx Packet Plane Ctrl&Status) 0x60000000
0x02140: RTRPT4C0 (Rx Packet Plane T4 Config 0) 0x00000000
0x02144: RTRPT4C1 (Rx Packet Plane T4 Config 1) 0x00000000
0x02148: RTRPT4C2 (Rx Packet Plane T4 Config 2) 0x00000000
0x0214C: RTRPT4C3 (Rx Packet Plane T4 Config 3) 0x00000000
0x02150: RTRPT4C4 (Rx Packet Plane T4 Config 4) 0x00000000
0x02154: RTRPT4C5 (Rx Packet Plane T4 Config 5) 0x00000000
0x02158: RTRPT4C6 (Rx Packet Plane T4 Config 6) 0x00000000
0x0215C: RTRPT4C7 (Rx Packet Plane T4 Config 7) 0x00000000
0x02160: RTRPT4S0 (Rx Packet Plane T4 Status 0) 0x00000000
0x02164: RTRPT4S1 (Rx Packet Plane T4 Status 1) 0x00000000
0x02168: RTRPT4S2 (Rx Packet Plane T4 Status 2) 0x00000000
0x0216C: RTRPT4S3 (Rx Packet Plane T4 Status 3) 0x00000000
0x02170: RTRPT4S4 (Rx Packet Plane T4 Status 4) 0x00000000
0x02174: RTRPT4S5 (Rx Packet Plane T4 Status 5) 0x00000000
0x02178: RTRPT4S6 (Rx Packet Plane T4 Status 6) 0x00000000
0x0217C: RTRPT4S7 (Rx Packet Plane T4 Status 7) 0x00000000
0x04910: RTTDT2C0 (Tx Descr Plane T2 Config 0) 0x00000000
0x04914: RTTDT2C1 (Tx Descr Plane T2 Config 1) 0x00000000
0x04918: RTTDT2C2 (Tx Descr Plane T2 Config 2) 0x00000000
0x0491C: RTTDT2C3 (Tx Descr Plane T2 Config 3) 0x00000000
0x04920: RTTDT2C4 (Tx Descr Plane T2 Config 4) 0x00000000
0x04924: RTTDT2C5 (Tx Descr Plane T2 Config 5) 0x00000000
0x04928: RTTDT2C6 (Tx Descr Plane T2 Config 6) 0x00000000
0x0492C: RTTDT2C7 (Tx Descr Plane T2 Config 7) 0x00000000
0x04930: RTTDT2S0 (Tx Descr Plane T2 Status 0) 0x00000000
0x04934: RTTDT2S1 (Tx Descr Plane T2 Status 1) 0x00000000
0x04938: RTTDT2S2 (Tx Descr Plane T2 Status 2) 0x00000000
0x0493C: RTTDT2S3 (Tx Descr Plane T2 Status 3) 0x00000000
0x04940: RTTDT2S4 (Tx Descr Plane T2 Status 4) 0x00000000
0x04944: RTTDT2S5 (Tx Descr Plane T2 Status 5) 0x00000000
0x04948: RTTDT2S6 (Tx Descr Plane T2 Status 6) 0x00000000
0x0494C: RTTDT2S7 (Tx Descr Plane T2 Status 7) 0x00000000
0x0CD20: RTTPT2C0 (Tx Packet Plane T2 Config 0) 0x00000000
0x0CD24: RTTPT2C1 (Tx Packet Plane T2 Config 1) 0x00000000
0x0CD28: RTTPT2C2 (Tx Packet Plane T2 Config 2) 0x00000000
0x0CD2C: RTTPT2C3 (Tx Packet Plane T2 Config 3) 0x00000000
0x0CD30: RTTPT2C4 (Tx Packet Plane T2 Config 4) 0x00000000
0x0CD34: RTTPT2C5 (Tx Packet Plane T2 Config 5) 0x00000000
0x0CD38: RTTPT2C6 (Tx Packet Plane T2 Config 6) 0x00000000
0x0CD3C: RTTPT2C7 (Tx Packet Plane T2 Config 7) 0x00000000
0x0CD40: RTTPT2S0 (Tx Packet Plane T2 Status 0) 0x00000000
0x0CD44: RTTPT2S1 (Tx Packet Plane T2 Status 1) 0x00000000
0x0CD48: RTTPT2S2 (Tx Packet Plane T2 Status 2) 0x00000000
0x0CD4C: RTTPT2S3 (Tx Packet Plane T2 Status 3) 0x00000000
0x0CD50: RTTPT2S4 (Tx Packet Plane T2 Status 4) 0x00000000
0x0CD54: RTTPT2S5 (Tx Packet Plane T2 Status 5) 0x00000000
0x0CD58: RTTPT2S6 (Tx Packet Plane T2 Status 6) 0x00000000
0x0CD5C: RTTPT2S7 (Tx Packet Plane T2 Status 7) 0x00000000
0x03020: RTRUP2TC (Rx User Prio to Traffic Classes)0x00000000
0x0C800: RTTUP2TC (Tx User Prio to Traffic Classes)0x00000000
0x082E0: TXLLQ0 (Strict Low Lat Tx Queues 0) 0x00000000
0x082E4: TXLLQ1 (Strict Low Lat Tx Queues 1) 0x00000000
0x082E8: TXLLQ2 (Strict Low Lat Tx Queues 2) 0x00000000
0x082EC: TXLLQ3 (Strict Low Lat Tx Queues 3) 0x00000000
0x04980: RTTBCNRM (DCB TX Rate Sched MMW) 0x00000000
0x0498C: RTTBCNRD (DCB TX Rate-Scheduler Drift) 0x00000000
0x04000: crcerrs (CRC Error Count) 0x00000000
0x04004: illerrc (Illegal Byte Error Count) 0x00000000
0x04008: errbc (Error Byte Count) 0x00000000
0x04010: mspdc (MAC Short Packet Discard Count) 0x00000000
0x03FA0: mpc0 (Missed Packets Count 0) 0x00000000
0x03FA4: mpc1 (Missed Packets Count 1) 0x00000000
0x03FA8: mpc2 (Missed Packets Count 2) 0x00000000
0x03FAC: mpc3 (Missed Packets Count 3) 0x00000000
0x03FB0: mpc4 (Missed Packets Count 4) 0x00000000
0x03FB4: mpc5 (Missed Packets Count 5) 0x00000000
0x03FB8: mpc6 (Missed Packets Count 6) 0x00000000
0x03FBC: mpc7 (Missed Packets Count 7) 0x00000000
0x04034: mlfc (MAC Local Fault Count) 0x00000000
0x04038: mrfc (MAC Remote Fault Count) 0x00000000
0x04040: rlec (Receive Length Error Count) 0x00000000
0x03F60: lxontxc (Link XON Transmitted Count) 0x00000000
0x0CF60: lxonrxc (Link XON Received Count) 0x00000000
0x03F68: lxofftxc (Link XOFF Transmitted Count) 0x00000000
0x0CF68: lxoffrxc (Link XOFF Received Count) 0x00000000
0x03F00: pxontxc0 (Priority XON Tx Count 0) 0x00000000
0x03F04: pxontxc1 (Priority XON Tx Count 1) 0x00000000
0x03F08: pxontxc2 (Priority XON Tx Count 2) 0x00000000
0x03F0C: pxontxc3 (Priority XON Tx Count 3) 0x00000000
0x03F10: pxontxc4 (Priority XON Tx Count 4) 0x00000000
0x03F14: pxontxc5 (Priority XON Tx Count 5) 0x00000000
0x03F18: pxontxc6 (Priority XON Tx Count 6) 0x00000000
0x03F1C: pxontxc7 (Priority XON Tx Count 7) 0x00000000
0x0CF00: pxonrxc0 (Priority XON Received Count 0) 0x00000000
0x0CF04: pxonrxc1 (Priority XON Received Count 1) 0x00000000
0x0CF08: pxonrxc2 (Priority XON Received Count 2) 0x00000000
0x0CF0C: pxonrxc3 (Priority XON Received Count 3) 0x00000000
0x0CF10: pxonrxc4 (Priority XON Received Count 4) 0x00000000
0x0CF14: pxonrxc5 (Priority XON Received Count 5) 0x00000000
0x0CF18: pxonrxc6 (Priority XON Received Count 6) 0x00000000
0x0CF1C: pxonrxc7 (Priority XON Received Count 7) 0x00000000
0x03F20: pxofftxc0 (Priority XOFF Tx Count 0) 0x00000000
0x03F24: pxofftxc1 (Priority XOFF Tx Count 1) 0x00000000
0x03F28: pxofftxc2 (Priority XOFF Tx Count 2) 0x00000000
0x03F2C: pxofftxc3 (Priority XOFF Tx Count 3) 0x00000000
0x03F30: pxofftxc4 (Priority XOFF Tx Count 4) 0x00000000
0x03F34: pxofftxc5 (Priority XOFF Tx Count 5) 0x00000000
0x03F38: pxofftxc6 (Priority XOFF Tx Count 6) 0x00000000
0x03F3C: pxofftxc7 (Priority XOFF Tx Count 7) 0x00000000
0x0CF20: pxoffrxc0 (Priority XOFF Received Count 0) 0x00000000
0x0CF24: pxoffrxc1 (Priority XOFF Received Count 1) 0x00000000
0x0CF28: pxoffrxc2 (Priority XOFF Received Count 2) 0x00000000
0x0CF2C: pxoffrxc3 (Priority XOFF Received Count 3) 0x00000000
0x0CF30: pxoffrxc4 (Priority XOFF Received Count 4) 0x00000000
0x0CF34: pxoffrxc5 (Priority XOFF Received Count 5) 0x00000000
0x0CF38: pxoffrxc6 (Priority XOFF Received Count 6) 0x00000000
0x0CF3C: pxoffrxc7 (Priority XOFF Received Count 7) 0x00000000
0x0405C: prc64 (Packets Received (64B) Count) 0x00000000
0x04060: prc127 (Packets Rx (65-127B) Count) 0x00000000
0x04064: prc255 (Packets Rx (128-255B) Count) 0x00000000
0x04068: prc511 (Packets Rx (256-511B) Count) 0x00000000
0x0406C: prc1023 (Packets Rx (512-1023B) Count) 0x00000000
0x04070: prc1522 (Packets Rx (1024-Max) Count) 0x00000000
0x04074: gprc (Good Packets Received Count) 0x00000000
0x04078: bprc (Broadcast Packets Rx Count) 0x00000000
0x0407C: mprc (Multicast Packets Rx Count) 0x00000000
0x04080: gptc (Good Packets Transmitted Count) 0x00000000
0x04088: gorcl (Good Octets Rx Count Low) 0x00000000
0x0408C: gorch (Good Octets Rx Count High) 0x00000000
0x04090: gotcl (Good Octets Tx Count Low) 0x00000000
0x04094: gotch (Good Octets Tx Count High) 0x00000000
0x03FC0: rnbc0 (Receive No Buffers Count 0) 0x00000000
0x03FC4: rnbc1 (Receive No Buffers Count 1) 0x00000000
0x03FC8: rnbc2 (Receive No Buffers Count 2) 0x00000000
0x03FCC: rnbc3 (Receive No Buffers Count 3) 0x00000000
0x03FD0: rnbc4 (Receive No Buffers Count 4) 0x00000000
0x03FD4: rnbc5 (Receive No Buffers Count 5) 0x00000000
0x03FD8: rnbc6 (Receive No Buffers Count 6) 0x00000000
0x03FDC: rnbc7 (Receive No Buffers Count 7) 0x00000000
0x040A4: ruc (Receive Undersize count) 0x00000000
0x040A8: rfc (Receive Fragment Count) 0x00000000
0x040AC: roc (Receive Oversize Count) 0x00000000
0x040B0: rjc (Receive Jabber Count) 0x00000000
0x040B4: mngprc (Management Packets Rx Count) 0x00000000
0x040B8: mngpdc (Management Pkts Dropped Count) 0x00000000
0x0CF90: mngptc (Management Packets Tx Count) 0x00000000
0x040C0: torl (Total Octets Rx Count Low) 0x00000000
0x040C4: torh (Total Octets Rx Count High) 0x00000000
0x040D0: tpr (Total Packets Received) 0x00000000
0x040D4: tpt (Total Packets Transmitted) 0x00000000
0x040D8: ptc64 (Packets Tx (64B) Count) 0x00000000
0x040DC: ptc127 (Packets Tx (65-127B) Count) 0x00000000
0x040E0: ptc255 (Packets Tx (128-255B) Count) 0x00000000
0x040E4: ptc511 (Packets Tx (256-511B) Count) 0x00000000
0x040E8: ptc1023 (Packets Tx (512-1023B) Count) 0x00000000
0x040EC: ptc1522 (Packets Tx (1024-Max) Count) 0x00000000
0x040F0: mptc (Multicast Packets Tx Count) 0x00000000
0x040F4: bptc (Broadcast Packets Tx Count) 0x00000000
0x04120: xec (XSUM Error Count) 0x00000000
0x01030: qprc00 (Queue Packets Rx Count 00) 0x00000000
0x01070: qprc01 (Queue Packets Rx Count 01) 0x00000000
0x010B0: qprc02 (Queue Packets Rx Count 02) 0x00000000
0x010F0: qprc03 (Queue Packets Rx Count 03) 0x00000000
0x01130: qprc04 (Queue Packets Rx Count 04) 0x00000000
0x01170: qprc05 (Queue Packets Rx Count 05) 0x00000000
0x011B0: qprc06 (Queue Packets Rx Count 06) 0x00000000
0x011F0: qprc07 (Queue Packets Rx Count 07) 0x00000000
0x01230: qprc08 (Queue Packets Rx Count 08) 0x00000000
0x01270: qprc09 (Queue Packets Rx Count 09) 0x00000000
0x012B0: qprc10 (Queue Packets Rx Count 10) 0x00000000
0x012F0: qprc11 (Queue Packets Rx Count 11) 0x00000000
0x01330: qprc12 (Queue Packets Rx Count 12) 0x00000000
0x01370: qprc13 (Queue Packets Rx Count 13) 0x00000000
0x013B0: qprc14 (Queue Packets Rx Count 14) 0x00000000
0x013F0: qprc15 (Queue Packets Rx Count 15) 0x00000000
0x06030: qptc00 (Queue Packets Tx Count 00) 0x00000000
0x06070: qptc01 (Queue Packets Tx Count 01) 0x00000000
0x060B0: qptc02 (Queue Packets Tx Count 02) 0x00000000
0x060F0: qptc03 (Queue Packets Tx Count 03) 0x00000000
0x06130: qptc04 (Queue Packets Tx Count 04) 0x00000000
0x06170: qptc05 (Queue Packets Tx Count 05) 0x00000000
0x061B0: qptc06 (Queue Packets Tx Count 06) 0x00000000
0x061F0: qptc07 (Queue Packets Tx Count 07) 0x00000000
0x06230: qptc08 (Queue Packets Tx Count 08) 0x00000000
0x06270: qptc09 (Queue Packets Tx Count 09) 0x00000000
0x062B0: qptc10 (Queue Packets Tx Count 10) 0x00000000
0x062F0: qptc11 (Queue Packets Tx Count 11) 0x00000000
0x06330: qptc12 (Queue Packets Tx Count 12) 0x00000000
0x06370: qptc13 (Queue Packets Tx Count 13) 0x00000000
0x063B0: qptc14 (Queue Packets Tx Count 14) 0x00000000
0x063F0: qptc15 (Queue Packets Tx Count 15) 0x00000000
0x01034: qbrc00 (Queue Bytes Rx Count 00) 0x00000000
0x01074: qbrc01 (Queue Bytes Rx Count 01) 0x00000000
0x010B4: qbrc02 (Queue Bytes Rx Count 02) 0x00000000
0x010F4: qbrc03 (Queue Bytes Rx Count 03) 0x00000000
0x01134: qbrc04 (Queue Bytes Rx Count 04) 0x00000000
0x01174: qbrc05 (Queue Bytes Rx Count 05) 0x00000000
0x011B4: qbrc06 (Queue Bytes Rx Count 06) 0x00000000
0x011F4: qbrc07 (Queue Bytes Rx Count 07) 0x00000000
0x01234: qbrc08 (Queue Bytes Rx Count 08) 0x00000000
0x01274: qbrc09 (Queue Bytes Rx Count 09) 0x00000000
0x012B4: qbrc10 (Queue Bytes Rx Count 10) 0x00000000
0x012F4: qbrc11 (Queue Bytes Rx Count 11) 0x00000000
0x01334: qbrc12 (Queue Bytes Rx Count 12) 0x00000000
0x01374: qbrc13 (Queue Bytes Rx Count 13) 0x00000000
0x013B4: qbrc14 (Queue Bytes Rx Count 14) 0x00000000
0x013F4: qbrc15 (Queue Bytes Rx Count 15) 0x00000000
0x06034: qbtc00 (Queue Bytes Tx Count 00) 0x00000000
0x06074: qbtc01 (Queue Bytes Tx Count 01) 0x00000000
0x060B4: qbtc02 (Queue Bytes Tx Count 02) 0x00000000
0x060F4: qbtc03 (Queue Bytes Tx Count 03) 0x00000000
0x06134: qbtc04 (Queue Bytes Tx Count 04) 0x00000000
0x06174: qbtc05 (Queue Bytes Tx Count 05) 0x00000000
0x061B4: qbtc06 (Queue Bytes Tx Count 06) 0x00000000
0x061F4: qbtc07 (Queue Bytes Tx Count 07) 0x00000000
0x06234: qbtc08 (Queue Bytes Tx Count 08) 0x00000000
0x06274: qbtc09 (Queue Bytes Tx Count 09) 0x00000000
0x062B4: qbtc10 (Queue Bytes Tx Count 10) 0x00000000
0x062F4: qbtc11 (Queue Bytes Tx Count 11) 0x00000000
0x06334: qbtc12 (Queue Bytes Tx Count 12) 0x00000000
0x06374: qbtc13 (Queue Bytes Tx Count 13) 0x00000000
0x063B4: qbtc14 (Queue Bytes Tx Count 14) 0x00000000
0x063F4: qbtc15 (Queue Bytes Tx Count 15) 0x00000000
0x04200: PCS1GCFIG (PCS_1G Gloabal Config 1) 0x80000008
0x04208: PCS1GLCTL (PCS_1G Link Control) 0x0204000E
0x0420C: PCS1GLSTA (PCS_1G Link Status) 0x0000000E
0x04210: PCS1GDBG0 (PCS_1G Debug 0) 0x00000060
0x04214: PCS1GDBG1 (PCS_1G Debug 1) 0x00001010
0x04218: PCS1GANA (PCS-1G Auto Neg. Adv.) 0x000001A0
0x0421C: PCS1GANLP (PCS-1G AN LP Ability) 0x00000000
0x04220: PCS1GANNP (PCS_1G Auto Neg Next Page Tx) 0x00000000
0x04224: PCS1GANLPNP (PCS_1G Auto Neg LPs Next Page) 0x00000000
0x04244: HLREG1 (Highlander Status 1) 0x00000101
0x04248: PAP (Pause and Pace) 0x0000FFFF
0x0424C: MACA (MDI Auto-Scan Command and Addr) 0x22000000
0x04250: APAE (Auto-Scan PHY Address Enable) 0x00000000
0x04254: ARD (Auto-Scan Read Data) 0x00000000
0x04258: AIS (Auto-Scan Interrupt Status) 0x00000000
0x0425C: MSCA (MDI Single Command and Addr) 0x10000000
0x04260: MSRWD (MDI Single Read and Write Data) 0x00000000
0x04264: MLADD (MAC Address Low) 0x00000000
0x04268: MHADD (MAC Addr High/Max Frame size) 0x05EE0000
0x0426C: TREG (Test Register) 0x00040000
0x04288: PCSS1 (XGXS Status 1) 0x00000080
0x0428C: PCSS2 (XGXS Status 2) 0x00008400
0x04290: XPCSS (10GBASE-X PCS Status) 0x00000000
0x04298: SERDESC (SERDES Interface Control) 0x1B1B0000
0x0429C: MACS (FIFO Status/CNTL Report) 0x061F02F0
0x042A0: AUTOC (Auto Negotiation Control) 0xC09C6084
0x042A8: AUTOC2 (Auto Negotiation Control 2) 0x000A0000
0x042AC: AUTOC3 (Auto Negotiation Control 3) 0x00000000
0x042B0: ANLP1 (Auto Neg Lnk Part. Ctrl Word 1) 0x00080000
0x042B4: ANLP2 (Auto Neg Lnk Part. Ctrl Word 2) 0x00000000
0x02F20: RDPROBE (Rx Probe Mode Status) 0x00000000
0x07C20: TDSTATCTL (Tx DMA Statistic Control) 0x00000000
0x07C00: TDSTAT0 (Tx DMA Statistics 0) 0x00000000
0x07C04: TDSTAT1 (Tx DMA Statistics 1) 0x00000000
0x07C08: TDSTAT2 (Tx DMA Statistics 2) 0x00000000
0x07C0C: TDSTAT3 (Tx DMA Statistics 3) 0x00002200
0x07C10: TDSTAT4 (Tx DMA Statistics 4) 0x00000000
0x07C14: TDSTAT5 (Tx DMA Statistics 5) 0x00000000
0x07C18: TDSTAT6 (Tx DMA Statistics 6) 0x00000000
0x07C1C: TDSTAT7 (Tx DMA Statistics 7) 0x00000000
0x07F08: TDHMPN (Tx Desc Handler Mem Page Num) 0x00000000
0x07F10: TIC_DW0 (Tx Desc Hand. Mem Read Data 0) 0x00000000
0x07F14: TIC_DW1 (Tx Desc Hand. Mem Read Data 1) 0x00000000
0x07F18: TIC_DW2 (Tx Desc Hand. Mem Read Data 2) 0x00000000
0x07F1C: TIC_DW3 (Tx Desc Hand. Mem Read Data 3) 0x00000000
0x07F20: TDPROBE (Tx Probe Mode Status) 0x00000000
0x0C600: TXBUFCTRL (TX Buffer Access Control) 0x00000000
0x0C610: TXBUFDATA0 (TX Buffer DATA 0) 0x00000000
0x0C614: TXBUFDATA1 (TX Buffer DATA 1) 0x00000000
0x0C618: TXBUFDATA2 (TX Buffer DATA 2) 0x00000000
0x0C61C: TXBUFDATA3 (TX Buffer DATA 3) 0x00000000
0x03600: RXBUFCTRL (RX Buffer Access Control) 0x00000000
0x03610: RXBUFDATA0 (RX Buffer DATA 0) 0x00000000
0x03614: RXBUFDATA1 (RX Buffer DATA 1) 0x00000000
0x03618: RXBUFDATA2 (RX Buffer DATA 2) 0x00000000
0x0361C: RXBUFDATA3 (RX Buffer DATA 3) 0x00000000
0x11090: PCIE_DIAG0 (PCIe Diagnostic 0) 0x00BA3BDF
0x11094: PCIE_DIAG1 (PCIe Diagnostic 1) 0x001F0003
0x11098: PCIE_DIAG2 (PCIe Diagnostic 2) 0x00000000
0x1109C: PCIE_DIAG3 (PCIe Diagnostic 3) 0xFFFF1003
0x110A0: PCIE_DIAG4 (PCIe Diagnostic 4) 0x10A6FFFF
0x110A4: PCIE_DIAG5 (PCIe Diagnostic 5) 0x07F70001
0x110A8: PCIE_DIAG6 (PCIe Diagnostic 6) 0x173F073F
0x110AC: PCIE_DIAG7 (PCIe Diagnostic 7) 0x10FB10FB
0x050A4: RFVAL (Receive Filter Validation) 0x00000000
0x042B8: MDFTC1 (MAC DFT Control 1) 0x1E000000
0x042C0: MDFTC2 (MAC DFT Control 2) 0x78400000
0x042C4: MDFTFIFO1 (MAC DFT FIFO 1) 0x0FAC14FA
0x042C8: MDFTFIFO2 (MAC DFT FIFO 2) 0x00000305
0x042CC: MDFTS (MAC DFT Status) 0x00000000
eth -S eth0
NIC statistics:
rx_packets: 0
tx_packets: 0
rx_bytes: 0
tx_bytes: 0
rx_pkts_nic: 0
tx_pkts_nic: 0
rx_bytes_nic: 0
tx_bytes_nic: 0
lsc_int: 0
tx_busy: 0
non_eop_descs: 0
rx_errors: 0
tx_errors: 0
rx_dropped: 0
tx_dropped: 0
multicast: 0
broadcast: 0
rx_no_buffer_count: 0
collisions: 0
rx_over_errors: 0
rx_crc_errors: 0
rx_frame_errors: 0
hw_rsc_aggregated: 0
hw_rsc_flushed: 0
fdir_match: 0
fdir_miss: 0
fdir_overflow: 0
rx_fifo_errors: 0
rx_missed_errors: 0
tx_aborted_errors: 0
tx_carrier_errors: 0
tx_fifo_errors: 0
tx_heartbeat_errors: 0
tx_timeout_count: 0
tx_restart_queue: 0
rx_long_length_errors: 0
rx_short_length_errors: 0
tx_flow_control_xon: 0
rx_flow_control_xon: 0
tx_flow_control_xoff: 0
rx_flow_control_xoff: 0
rx_csum_offload_errors: 0
alloc_rx_page_failed: 0
alloc_rx_buff_failed: 0
rx_no_dma_resources: 0
os2bmc_rx_by_bmc: 0
os2bmc_tx_by_bmc: 0
os2bmc_tx_by_host: 0
os2bmc_rx_by_host: 0
fcoe_bad_fccrc: 0
rx_fcoe_dropped: 0
rx_fcoe_packets: 0
rx_fcoe_dwords: 0
fcoe_noddp: 0
fcoe_noddp_ext_buff: 0
tx_fcoe_packets: 0
tx_fcoe_dwords: 0
tx_queue_0_packets: 0
tx_queue_0_bytes: 0
tx_queue_0_bp_napi_yield: 0
tx_queue_0_bp_misses: 0
tx_queue_0_bp_cleaned: 0
tx_queue_1_packets: 0
tx_queue_1_bytes: 0
tx_queue_1_bp_napi_yield: 0
tx_queue_1_bp_misses: 0
tx_queue_1_bp_cleaned: 0
tx_queue_2_packets: 0
tx_queue_2_bytes: 0
tx_queue_2_bp_napi_yield: 0
tx_queue_2_bp_misses: 0
tx_queue_2_bp_cleaned: 0
tx_queue_3_packets: 0
tx_queue_3_bytes: 0
tx_queue_3_bp_napi_yield: 0
tx_queue_3_bp_misses: 0
tx_queue_3_bp_cleaned: 0
tx_queue_4_packets: 0
tx_queue_4_bytes: 0
tx_queue_4_bp_napi_yield: 0
tx_queue_4_bp_misses: 0
tx_queue_4_bp_cleaned: 0
tx_queue_5_packets: 0
tx_queue_5_bytes: 0
tx_queue_5_bp_napi_yield: 0
tx_queue_5_bp_misses: 0
tx_queue_5_bp_cleaned: 0
tx_queue_6_packets: 0
tx_queue_6_bytes: 0
tx_queue_6_bp_napi_yield: 0
tx_queue_6_bp_misses: 0
tx_queue_6_bp_cleaned: 0
tx_queue_7_packets: 0
tx_queue_7_bytes: 0
tx_queue_7_bp_napi_yield: 0
tx_queue_7_bp_misses: 0
tx_queue_7_bp_cleaned: 0
tx_queue_8_packets: 0
tx_queue_8_bytes: 0
tx_queue_8_bp_napi_yield: 0
tx_queue_8_bp_misses: 0
tx_queue_8_bp_cleaned: 0
tx_queue_9_packets: 0
tx_queue_9_bytes: 0
tx_queue_9_bp_napi_yield: 0
tx_queue_9_bp_misses: 0
tx_queue_9_bp_cleaned: 0
tx_queue_10_packets: 0
tx_queue_10_bytes: 0
tx_queue_10_bp_napi_yield: 0
tx_queue_10_bp_misses: 0
tx_queue_10_bp_cleaned: 0
tx_queue_11_packets: 0
tx_queue_11_bytes: 0
tx_queue_11_bp_napi_yield: 0
tx_queue_11_bp_misses: 0
tx_queue_11_bp_cleaned: 0
tx_queue_12_packets: 0
tx_queue_12_bytes: 0
tx_queue_12_bp_napi_yield: 0
tx_queue_12_bp_misses: 0
tx_queue_12_bp_cleaned: 0
tx_queue_13_packets: 0
tx_queue_13_bytes: 0
tx_queue_13_bp_napi_yield: 0
tx_queue_13_bp_misses: 0
tx_queue_13_bp_cleaned: 0
tx_queue_14_packets: 0
tx_queue_14_bytes: 0
tx_queue_14_bp_napi_yield: 0
tx_queue_14_bp_misses: 0
tx_queue_14_bp_cleaned: 0
tx_queue_15_packets: 0
tx_queue_15_bytes: 0
tx_queue_15_bp_napi_yield: 0
tx_queue_15_bp_misses: 0
tx_queue_15_bp_cleaned: 0
tx_queue_16_packets: 0
tx_queue_16_bytes: 0
tx_queue_16_bp_napi_yield: 0
tx_queue_16_bp_misses: 0
tx_queue_16_bp_cleaned: 0
tx_queue_17_packets: 0
tx_queue_17_bytes: 0
tx_queue_17_bp_napi_yield: 0
tx_queue_17_bp_misses: 0
tx_queue_17_bp_cleaned: 0
tx_queue_18_packets: 0
tx_queue_18_bytes: 0
tx_queue_18_bp_napi_yield: 0
tx_queue_18_bp_misses: 0
tx_queue_18_bp_cleaned: 0
tx_queue_19_packets: 0
tx_queue_19_bytes: 0
tx_queue_19_bp_napi_yield: 0
tx_queue_19_bp_misses: 0
tx_queue_19_bp_cleaned: 0
tx_queue_20_packets: 0
tx_queue_20_bytes: 0
tx_queue_20_bp_napi_yield: 0
tx_queue_20_bp_misses: 0
tx_queue_20_bp_cleaned: 0
tx_queue_21_packets: 0
tx_queue_21_bytes: 0
tx_queue_21_bp_napi_yield: 0
tx_queue_21_bp_misses: 0
tx_queue_21_bp_cleaned: 0
tx_queue_22_packets: 0
tx_queue_22_bytes: 0
tx_queue_22_bp_napi_yield: 0
tx_queue_22_bp_misses: 0
tx_queue_22_bp_cleaned: 0
tx_queue_23_packets: 0
tx_queue_23_bytes: 0
tx_queue_23_bp_napi_yield: 0
tx_queue_23_bp_misses: 0
tx_queue_23_bp_cleaned: 0
tx_queue_24_packets: 0
tx_queue_24_bytes: 0
tx_queue_24_bp_napi_yield: 0
tx_queue_24_bp_misses: 0
tx_queue_24_bp_cleaned: 0
tx_queue_25_packets: 0
tx_queue_25_bytes: 0
tx_queue_25_bp_napi_yield: 0
tx_queue_25_bp_misses: 0
tx_queue_25_bp_cleaned: 0
tx_queue_26_packets: 0
tx_queue_26_bytes: 0
tx_queue_26_bp_napi_yield: 0
tx_queue_26_bp_misses: 0
tx_queue_26_bp_cleaned: 0
tx_queue_27_packets: 0
tx_queue_27_bytes: 0
tx_queue_27_bp_napi_yield: 0
tx_queue_27_bp_misses: 0
tx_queue_27_bp_cleaned: 0
tx_queue_28_packets: 0
tx_queue_28_bytes: 0
tx_queue_28_bp_napi_yield: 0
tx_queue_28_bp_misses: 0
tx_queue_28_bp_cleaned: 0
tx_queue_29_packets: 0
tx_queue_29_bytes: 0
tx_queue_29_bp_napi_yield: 0
tx_queue_29_bp_misses: 0
tx_queue_29_bp_cleaned: 0
tx_queue_30_packets: 0
tx_queue_30_bytes: 0
tx_queue_30_bp_napi_yield: 0
tx_queue_30_bp_misses: 0
tx_queue_30_bp_cleaned: 0
tx_queue_31_packets: 0
tx_queue_31_bytes: 0
tx_queue_31_bp_napi_yield: 0
tx_queue_31_bp_misses: 0
tx_queue_31_bp_cleaned: 0
tx_queue_32_packets: 0
tx_queue_32_bytes: 0
tx_queue_32_bp_napi_yield: 0
tx_queue_32_bp_misses: 0
tx_queue_32_bp_cleaned: 0
tx_queue_33_packets: 0
tx_queue_33_bytes: 0
tx_queue_33_bp_napi_yield: 0
tx_queue_33_bp_misses: 0
tx_queue_33_bp_cleaned: 0
tx_queue_34_packets: 0
tx_queue_34_bytes: 0
tx_queue_34_bp_napi_yield: 0
tx_queue_34_bp_misses: 0
tx_queue_34_bp_cleaned: 0
tx_queue_35_packets: 0
tx_queue_35_bytes: 0
tx_queue_35_bp_napi_yield: 0
tx_queue_35_bp_misses: 0
tx_queue_35_bp_cleaned: 0
tx_queue_36_packets: 0
tx_queue_36_bytes: 0
tx_queue_36_bp_napi_yield: 0
tx_queue_36_bp_misses: 0
tx_queue_36_bp_cleaned: 0
tx_queue_37_packets: 0
tx_queue_37_bytes: 0
tx_queue_37_bp_napi_yield: 0
tx_queue_37_bp_misses: 0
tx_queue_37_bp_cleaned: 0
tx_queue_38_packets: 0
tx_queue_38_bytes: 0
tx_queue_38_bp_napi_yield: 0
tx_queue_38_bp_misses: 0
tx_queue_38_bp_cleaned: 0
tx_queue_39_packets: 0
tx_queue_39_bytes: 0
tx_queue_39_bp_napi_yield: 0
tx_queue_39_bp_misses: 0
tx_queue_39_bp_cleaned: 0
tx_queue_40_packets: 0
tx_queue_40_bytes: 0
tx_queue_40_bp_napi_yield: 0
tx_queue_40_bp_misses: 0
tx_queue_40_bp_cleaned: 0
tx_queue_41_packets: 0
tx_queue_41_bytes: 0
tx_queue_41_bp_napi_yield: 0
tx_queue_41_bp_misses: 0
tx_queue_41_bp_cleaned: 0
tx_queue_42_packets: 0
tx_queue_42_bytes: 0
tx_queue_42_bp_napi_yield: 0
tx_queue_42_bp_misses: 0
tx_queue_42_bp_cleaned: 0
tx_queue_43_packets: 0
tx_queue_43_bytes: 0
tx_queue_43_bp_napi_yield: 0
tx_queue_43_bp_misses: 0
tx_queue_43_bp_cleaned: 0
tx_queue_44_packets: 0
tx_queue_44_bytes: 0
tx_queue_44_bp_napi_yield: 0
tx_queue_44_bp_misses: 0
tx_queue_44_bp_cleaned: 0
tx_queue_45_packets: 0
tx_queue_45_bytes: 0
tx_queue_45_bp_napi_yield: 0
tx_queue_45_bp_misses: 0
tx_queue_45_bp_cleaned: 0
tx_queue_46_packets: 0
tx_queue_46_bytes: 0
tx_queue_46_bp_napi_yield: 0
tx_queue_46_bp_misses: 0
tx_queue_46_bp_cleaned: 0
tx_queue_47_packets: 0
tx_queue_47_bytes: 0
tx_queue_47_bp_napi_yield: 0
tx_queue_47_bp_misses: 0
tx_queue_47_bp_cleaned: 0
tx_queue_48_packets: 0
tx_queue_48_bytes: 0
tx_queue_48_bp_napi_yield: 0
tx_queue_48_bp_misses: 0
tx_queue_48_bp_cleaned: 0
tx_queue_49_packets: 0
tx_queue_49_bytes: 0
tx_queue_49_bp_napi_yield: 0
tx_queue_49_bp_misses: 0
tx_queue_49_bp_cleaned: 0
tx_queue_50_packets: 0
tx_queue_50_bytes: 0
tx_queue_50_bp_napi_yield: 0
tx_queue_50_bp_misses: 0
tx_queue_50_bp_cleaned: 0
tx_queue_51_packets: 0
tx_queue_51_bytes: 0
tx_queue_51_bp_napi_yield: 0
tx_queue_51_bp_misses: 0
tx_queue_51_bp_cleaned: 0
tx_queue_52_packets: 0
tx_queue_52_bytes: 0
tx_queue_52_bp_napi_yield: 0
tx_queue_52_bp_misses: 0
tx_queue_52_bp_cleaned: 0
tx_queue_53_packets: 0
tx_queue_53_bytes: 0
tx_queue_53_bp_napi_yield: 0
tx_queue_53_bp_misses: 0
tx_queue_53_bp_cleaned: 0
tx_queue_54_packets: 0
tx_queue_54_bytes: 0
tx_queue_54_bp_napi_yield: 0
tx_queue_54_bp_misses: 0
tx_queue_54_bp_cleaned: 0
tx_queue_55_packets: 0
tx_queue_55_bytes: 0
tx_queue_55_bp_napi_yield: 0
tx_queue_55_bp_misses: 0
tx_queue_55_bp_cleaned: 0
tx_queue_56_packets: 0
tx_queue_56_bytes: 0
tx_queue_56_bp_napi_yield: 0
tx_queue_56_bp_misses: 0
tx_queue_56_bp_cleaned: 0
tx_queue_57_packets: 0
tx_queue_57_bytes: 0
tx_queue_57_bp_napi_yield: 0
tx_queue_57_bp_misses: 0
tx_queue_57_bp_cleaned: 0
tx_queue_58_packets: 0
tx_queue_58_bytes: 0
tx_queue_58_bp_napi_yield: 0
tx_queue_58_bp_misses: 0
tx_queue_58_bp_cleaned: 0
tx_queue_59_packets: 0
tx_queue_59_bytes: 0
tx_queue_59_bp_napi_yield: 0
tx_queue_59_bp_misses: 0
tx_queue_59_bp_cleaned: 0
tx_queue_60_packets: 0
tx_queue_60_bytes: 0
tx_queue_60_bp_napi_yield: 0
tx_queue_60_bp_misses: 0
tx_queue_60_bp_cleaned: 0
tx_queue_61_packets: 0
tx_queue_61_bytes: 0
tx_queue_61_bp_napi_yield: 0
tx_queue_61_bp_misses: 0
tx_queue_61_bp_cleaned: 0
tx_queue_62_packets: 0
tx_queue_62_bytes: 0
tx_queue_62_bp_napi_yield: 0
tx_queue_62_bp_misses: 0
tx_queue_62_bp_cleaned: 0
tx_queue_63_packets: 0
tx_queue_63_bytes: 0
tx_queue_63_bp_napi_yield: 0
tx_queue_63_bp_misses: 0
tx_queue_63_bp_cleaned: 0
rx_queue_0_packets: 0
rx_queue_0_bytes: 0
rx_queue_0_bp_poll_yield: 0
rx_queue_0_bp_misses: 0
rx_queue_0_bp_cleaned: 0
rx_queue_1_packets: 0
rx_queue_1_bytes: 0
rx_queue_1_bp_poll_yield: 0
rx_queue_1_bp_misses: 0
rx_queue_1_bp_cleaned: 0
rx_queue_2_packets: 0
rx_queue_2_bytes: 0
rx_queue_2_bp_poll_yield: 0
rx_queue_2_bp_misses: 0
rx_queue_2_bp_cleaned: 0
rx_queue_3_packets: 0
rx_queue_3_bytes: 0
rx_queue_3_bp_poll_yield: 0
rx_queue_3_bp_misses: 0
rx_queue_3_bp_cleaned: 0
rx_queue_4_packets: 0
rx_queue_4_bytes: 0
rx_queue_4_bp_poll_yield: 0
rx_queue_4_bp_misses: 0
rx_queue_4_bp_cleaned: 0
rx_queue_5_packets: 0
rx_queue_5_bytes: 0
rx_queue_5_bp_poll_yield: 0
rx_queue_5_bp_misses: 0
rx_queue_5_bp_cleaned: 0
rx_queue_6_packets: 0
rx_queue_6_bytes: 0
rx_queue_6_bp_poll_yield: 0
rx_queue_6_bp_misses: 0
rx_queue_6_bp_cleaned: 0
rx_queue_7_packets: 0
rx_queue_7_bytes: 0
rx_queue_7_bp_poll_yield: 0
rx_queue_7_bp_misses: 0
rx_queue_7_bp_cleaned: 0
rx_queue_8_packets: 0
rx_queue_8_bytes: 0
rx_queue_8_bp_poll_yield: 0
rx_queue_8_bp_misses: 0
rx_queue_8_bp_cleaned: 0
rx_queue_9_packets: 0
rx_queue_9_bytes: 0
rx_queue_9_bp_poll_yield: 0
rx_queue_9_bp_misses: 0
rx_queue_9_bp_cleaned: 0
rx_queue_10_packets: 0
rx_queue_10_bytes: 0
rx_queue_10_bp_poll_yield: 0
rx_queue_10_bp_misses: 0
rx_queue_10_bp_cleaned: 0
rx_queue_11_packets: 0
rx_queue_11_bytes: 0
rx_queue_11_bp_poll_yield: 0
rx_queue_11_bp_misses: 0
rx_queue_11_bp_cleaned: 0
rx_queue_12_packets: 0
rx_queue_12_bytes: 0
rx_queue_12_bp_poll_yield: 0
rx_queue_12_bp_misses: 0
rx_queue_12_bp_cleaned: 0
rx_queue_13_packets: 0
rx_queue_13_bytes: 0
rx_queue_13_bp_poll_yield: 0
rx_queue_13_bp_misses: 0
rx_queue_13_bp_cleaned: 0
rx_queue_14_packets: 0
rx_queue_14_bytes: 0
rx_queue_14_bp_poll_yield: 0
rx_queue_14_bp_misses: 0
rx_queue_14_bp_cleaned: 0
rx_queue_15_packets: 0
rx_queue_15_bytes: 0
rx_queue_15_bp_poll_yield: 0
rx_queue_15_bp_misses: 0
rx_queue_15_bp_cleaned: 0
rx_queue_16_packets: 0
rx_queue_16_bytes: 0
rx_queue_16_bp_poll_yield: 0
rx_queue_16_bp_misses: 0
rx_queue_16_bp_cleaned: 0
rx_queue_17_packets: 0
rx_queue_17_bytes: 0
rx_queue_17_bp_poll_yield: 0
rx_queue_17_bp_misses: 0
rx_queue_17_bp_cleaned: 0
rx_queue_18_packets: 0
rx_queue_18_bytes: 0
rx_queue_18_bp_poll_yield: 0
rx_queue_18_bp_misses: 0
rx_queue_18_bp_cleaned: 0
rx_queue_19_packets: 0
rx_queue_19_bytes: 0
rx_queue_19_bp_poll_yield: 0
rx_queue_19_bp_misses: 0
rx_queue_19_bp_cleaned: 0
rx_queue_20_packets: 0
rx_queue_20_bytes: 0
rx_queue_20_bp_poll_yield: 0
rx_queue_20_bp_misses: 0
rx_queue_20_bp_cleaned: 0
rx_queue_21_packets: 0
rx_queue_21_bytes: 0
rx_queue_21_bp_poll_yield: 0
rx_queue_21_bp_misses: 0
rx_queue_21_bp_cleaned: 0
rx_queue_22_packets: 0
rx_queue_22_bytes: 0
rx_queue_22_bp_poll_yield: 0
rx_queue_22_bp_misses: 0
rx_queue_22_bp_cleaned: 0
rx_queue_23_packets: 0
rx_queue_23_bytes: 0
rx_queue_23_bp_poll_yield: 0
rx_queue_23_bp_misses: 0
rx_queue_23_bp_cleaned: 0
rx_queue_24_packets: 0
rx_queue_24_bytes: 0
rx_queue_24_bp_poll_yield: 0
rx_queue_24_bp_misses: 0
rx_queue_24_bp_cleaned: 0
rx_queue_25_packets: 0
rx_queue_25_bytes: 0
rx_queue_25_bp_poll_yield: 0
rx_queue_25_bp_misses: 0
rx_queue_25_bp_cleaned: 0
rx_queue_26_packets: 0
rx_queue_26_bytes: 0
rx_queue_26_bp_poll_yield: 0
rx_queue_26_bp_misses: 0
rx_queue_26_bp_cleaned: 0
rx_queue_27_packets: 0
rx_queue_27_bytes: 0
rx_queue_27_bp_poll_yield: 0
rx_queue_27_bp_misses: 0
rx_queue_27_bp_cleaned: 0
rx_queue_28_packets: 0
rx_queue_28_bytes: 0
rx_queue_28_bp_poll_yield: 0
rx_queue_28_bp_misses: 0
rx_queue_28_bp_cleaned: 0
rx_queue_29_packets: 0
rx_queue_29_bytes: 0
rx_queue_29_bp_poll_yield: 0
rx_queue_29_bp_misses: 0
rx_queue_29_bp_cleaned: 0
rx_queue_30_packets: 0
rx_queue_30_bytes: 0
rx_queue_30_bp_poll_yield: 0
rx_queue_30_bp_misses: 0
rx_queue_30_bp_cleaned: 0
rx_queue_31_packets: 0
rx_queue_31_bytes: 0
rx_queue_31_bp_poll_yield: 0
rx_queue_31_bp_misses: 0
rx_queue_31_bp_cleaned: 0
rx_queue_32_packets: 0
rx_queue_32_bytes: 0
rx_queue_32_bp_poll_yield: 0
rx_queue_32_bp_misses: 0
rx_queue_32_bp_cleaned: 0
rx_queue_33_packets: 0
rx_queue_33_bytes: 0
rx_queue_33_bp_poll_yield: 0
rx_queue_33_bp_misses: 0
rx_queue_33_bp_cleaned: 0
rx_queue_34_packets: 0
rx_queue_34_bytes: 0
rx_queue_34_bp_poll_yield: 0
rx_queue_34_bp_misses: 0
rx_queue_34_bp_cleaned: 0
rx_queue_35_packets: 0
rx_queue_35_bytes: 0
rx_queue_35_bp_poll_yield: 0
rx_queue_35_bp_misses: 0
rx_queue_35_bp_cleaned: 0
rx_queue_36_packets: 0
rx_queue_36_bytes: 0
rx_queue_36_bp_poll_yield: 0
rx_queue_36_bp_misses: 0
rx_queue_36_bp_cleaned: 0
rx_queue_37_packets: 0
rx_queue_37_bytes: 0
rx_queue_37_bp_poll_yield: 0
rx_queue_37_bp_misses: 0
rx_queue_37_bp_cleaned: 0
rx_queue_38_packets: 0
rx_queue_38_bytes: 0
rx_queue_38_bp_poll_yield: 0
rx_queue_38_bp_misses: 0
rx_queue_38_bp_cleaned: 0
rx_queue_39_packets: 0
rx_queue_39_bytes: 0
rx_queue_39_bp_poll_yield: 0
rx_queue_39_bp_misses: 0
rx_queue_39_bp_cleaned: 0
rx_queue_40_packets: 0
rx_queue_40_bytes: 0
rx_queue_40_bp_poll_yield: 0
rx_queue_40_bp_misses: 0
rx_queue_40_bp_cleaned: 0
rx_queue_41_packets: 0
rx_queue_41_bytes: 0
rx_queue_41_bp_poll_yield: 0
rx_queue_41_bp_misses: 0
rx_queue_41_bp_cleaned: 0
rx_queue_42_packets: 0
rx_queue_42_bytes: 0
rx_queue_42_bp_poll_yield: 0
rx_queue_42_bp_misses: 0
rx_queue_42_bp_cleaned: 0
rx_queue_43_packets: 0
rx_queue_43_bytes: 0
rx_queue_43_bp_poll_yield: 0
rx_queue_43_bp_misses: 0
rx_queue_43_bp_cleaned: 0
rx_queue_44_packets: 0
rx_queue_44_bytes: 0
rx_queue_44_bp_poll_yield: 0
rx_queue_44_bp_misses: 0
rx_queue_44_bp_cleaned: 0
rx_queue_45_packets: 0
rx_queue_45_bytes: 0
rx_queue_45_bp_poll_yield: 0
rx_queue_45_bp_misses: 0
rx_queue_45_bp_cleaned: 0
rx_queue_46_packets: 0
rx_queue_46_bytes: 0
rx_queue_46_bp_poll_yield: 0
rx_queue_46_bp_misses: 0
rx_queue_46_bp_cleaned: 0
rx_queue_47_packets: 0
rx_queue_47_bytes: 0
rx_queue_47_bp_poll_yield: 0
rx_queue_47_bp_misses: 0
rx_queue_47_bp_cleaned: 0
rx_queue_48_packets: 0
rx_queue_48_bytes: 0
rx_queue_48_bp_poll_yield: 0
rx_queue_48_bp_misses: 0
rx_queue_48_bp_cleaned: 0
rx_queue_49_packets: 0
rx_queue_49_bytes: 0
rx_queue_49_bp_poll_yield: 0
rx_queue_49_bp_misses: 0
rx_queue_49_bp_cleaned: 0
rx_queue_50_packets: 0
rx_queue_50_bytes: 0
rx_queue_50_bp_poll_yield: 0
rx_queue_50_bp_misses: 0
rx_queue_50_bp_cleaned: 0
rx_queue_51_packets: 0
rx_queue_51_bytes: 0
rx_queue_51_bp_poll_yield: 0
rx_queue_51_bp_misses: 0
rx_queue_51_bp_cleaned: 0
rx_queue_52_packets: 0
rx_queue_52_bytes: 0
rx_queue_52_bp_poll_yield: 0
rx_queue_52_bp_misses: 0
rx_queue_52_bp_cleaned: 0
rx_queue_53_packets: 0
rx_queue_53_bytes: 0
rx_queue_53_bp_poll_yield: 0
rx_queue_53_bp_misses: 0
rx_queue_53_bp_cleaned: 0
rx_queue_54_packets: 0
rx_queue_54_bytes: 0
rx_queue_54_bp_poll_yield: 0
rx_queue_54_bp_misses: 0
rx_queue_54_bp_cleaned: 0
rx_queue_55_packets: 0
rx_queue_55_bytes: 0
rx_queue_55_bp_poll_yield: 0
rx_queue_55_bp_misses: 0
rx_queue_55_bp_cleaned: 0
rx_queue_56_packets: 0
rx_queue_56_bytes: 0
rx_queue_56_bp_poll_yield: 0
rx_queue_56_bp_misses: 0
rx_queue_56_bp_cleaned: 0
rx_queue_57_packets: 0
rx_queue_57_bytes: 0
rx_queue_57_bp_poll_yield: 0
rx_queue_57_bp_misses: 0
rx_queue_57_bp_cleaned: 0
rx_queue_58_packets: 0
rx_queue_58_bytes: 0
rx_queue_58_bp_poll_yield: 0
rx_queue_58_bp_misses: 0
rx_queue_58_bp_cleaned: 0
rx_queue_59_packets: 0
rx_queue_59_bytes: 0
rx_queue_59_bp_poll_yield: 0
rx_queue_59_bp_misses: 0
rx_queue_59_bp_cleaned: 0
rx_queue_60_packets: 0
rx_queue_60_bytes: 0
rx_queue_60_bp_poll_yield: 0
rx_queue_60_bp_misses: 0
rx_queue_60_bp_cleaned: 0
rx_queue_61_packets: 0
rx_queue_61_bytes: 0
rx_queue_61_bp_poll_yield: 0
rx_queue_61_bp_misses: 0
rx_queue_61_bp_cleaned: 0
rx_queue_62_packets: 0
rx_queue_62_bytes: 0
rx_queue_62_bp_poll_yield: 0
rx_queue_62_bp_misses: 0
rx_queue_62_bp_cleaned: 0
rx_queue_63_packets: 0
rx_queue_63_bytes: 0
rx_queue_63_bp_poll_yield: 0
rx_queue_63_bp_misses: 0
rx_queue_63_bp_cleaned: 0
tx_pb_0_pxon: 0
tx_pb_0_pxoff: 0
tx_pb_1_pxon: 0
tx_pb_1_pxoff: 0
tx_pb_2_pxon: 0
tx_pb_2_pxoff: 0
tx_pb_3_pxon: 0
tx_pb_3_pxoff: 0
tx_pb_4_pxon: 0
tx_pb_4_pxoff: 0
tx_pb_5_pxon: 0
tx_pb_5_pxoff: 0
tx_pb_6_pxon: 0
tx_pb_6_pxoff: 0
tx_pb_7_pxon: 0
tx_pb_7_pxoff: 0
rx_pb_0_pxon: 0
rx_pb_0_pxoff: 0
rx_pb_1_pxon: 0
rx_pb_1_pxoff: 0
rx_pb_2_pxon: 0
rx_pb_2_pxoff: 0
rx_pb_3_pxon: 0
rx_pb_3_pxoff: 0
rx_pb_4_pxon: 0
rx_pb_4_pxoff: 0
rx_pb_5_pxon: 0
rx_pb_5_pxoff: 0
rx_pb_6_pxon: 0
rx_pb_6_pxoff: 0
rx_pb_7_pxon: 0
rx_pb_7_pxoff: 0
ethtool -P:
Permanent address: 00:0b:2f:17:f6:90
