Intel Ethernet 10G X550 driver: N/A
I just installed a new 10Gb/s ethernet card (Intel X550T2) - but it won't show up in Manjaro, not even in a live session from USB.
~ >>> inxi -N
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
           Device-2: Intel I211 Gigabit Network driver: igb
           Device-3: Intel Ethernet 10G X550T driver: N/A
           Device-4: Intel Ethernet 10G X550T driver: N/A
I tried installing the driver from the intel support page, but this didn't change anything, even though:
modinfo ixgbe
filename:       /lib/modules/5.6.16-1-MANJARO/updates/drivers/net/ethernet/intel/ixgbe/ixgbe.ko.xz
version:        5.7.1
license:        GPL
description:    Intel(R) 10GbE PCI Express Linux Network Driver
author:         Intel Corporation, <linux.nics@intel.com>
srcversion:     720A79B0425CF0E9E12CB84
alias:          pci:v00008086d000015E5sv*sd*bc*sc*i*
alias:          pci:v00008086d000015E4sv*sd*bc*sc*i*
alias:          pci:v00008086d000015CEsv*sd*bc*sc*i*
alias:          pci:v00008086d000015CCsv*sd*bc*sc*i*
alias:          pci:v00008086d000015CAsv*sd*bc*sc*i*
alias:          pci:v00008086d000015C8sv*sd*bc*sc*i*
alias:          pci:v00008086d000015C7sv*sd*bc*sc*i*
alias:          pci:v00008086d000015C6sv*sd*bc*sc*i*
alias:          pci:v00008086d000015C4sv*sd*bc*sc*i*
alias:          pci:v00008086d000015C3sv*sd*bc*sc*i*
alias:          pci:v00008086d000015C2sv*sd*bc*sc*i*
alias:          pci:v00008086d000015AEsv*sd*bc*sc*i*
alias:          pci:v00008086d000015ADsv*sd*bc*sc*i*
alias:          pci:v00008086d000015ACsv*sd*bc*sc*i*
alias:          pci:v00008086d000015ABsv*sd*bc*sc*i*
alias:          pci:v00008086d000015B0sv*sd*bc*sc*i*
alias:          pci:v00008086d000015AAsv*sd*bc*sc*i*
alias:          pci:v00008086d000015D1sv*sd*bc*sc*i*
alias:          pci:v00008086d00001563sv*sd*bc*sc*i*
alias:          pci:v00008086d00001560sv*sd*bc*sc*i*
alias:          pci:v00008086d00001558sv*sd*bc*sc*i*
alias:          pci:v00008086d0000154Asv*sd*bc*sc*i*
alias:          pci:v00008086d00001557sv*sd*bc*sc*i*
alias:          pci:v00008086d0000154Dsv*sd*bc*sc*i*
alias:          pci:v00008086d00001528sv*sd*bc*sc*i*
alias:          pci:v00008086d000010F8sv*sd*bc*sc*i*
alias:          pci:v00008086d0000151Csv*sd*bc*sc*i*
alias:          pci:v00008086d00001529sv*sd*bc*sc*i*
alias:          pci:v00008086d0000152Asv*sd*bc*sc*i*
alias:          pci:v00008086d000010F9sv*sd*bc*sc*i*
alias:          pci:v00008086d00001514sv*sd*bc*sc*i*
alias:          pci:v00008086d00001507sv*sd*bc*sc*i*
alias:          pci:v00008086d000010FBsv*sd*bc*sc*i*
alias:          pci:v00008086d00001517sv*sd*bc*sc*i*
alias:          pci:v00008086d000010FCsv*sd*bc*sc*i*
alias:          pci:v00008086d000010F7sv*sd*bc*sc*i*
alias:          pci:v00008086d00001508sv*sd*bc*sc*i*
alias:          pci:v00008086d000010DBsv*sd*bc*sc*i*
alias:          pci:v00008086d000010F4sv*sd*bc*sc*i*
alias:          pci:v00008086d000010E1sv*sd*bc*sc*i*
alias:          pci:v00008086d000010F1sv*sd*bc*sc*i*
alias:          pci:v00008086d000010ECsv*sd*bc*sc*i*
alias:          pci:v00008086d000010DDsv*sd*bc*sc*i*
alias:          pci:v00008086d0000150Bsv*sd*bc*sc*i*
alias:          pci:v00008086d000010C8sv*sd*bc*sc*i*
alias:          pci:v00008086d000010C7sv*sd*bc*sc*i*
alias:          pci:v00008086d000010C6sv*sd*bc*sc*i*
alias:          pci:v00008086d000010B6sv*sd*bc*sc*i*
depends:        dca
retpoline:      Y
vermagic:       5.6.16-1-MANJARO SMP preempt mod_unload modversions
parm:           IntMode:Change Interrupt Mode (0=Legacy, 1=MSI, 2=MSI-X), default 2 (array of int)
parm:           InterruptType:Change Interrupt Mode (0=Legacy, 1=MSI, 2=MSI-X), default IntMode (deprecated) (array of int)
parm:           MQ:Disable or enable Multiple Queues, default 1 (array of int)
parm:           DCA:Disable or enable Direct Cache Access, 0=disabled, 1=descriptor only, 2=descriptor and data (array of int)
parm:           RSS:Number of Receive-Side Scaling Descriptor Queues, default 0=number of cpus (array of int)
parm:           VMDQ:Number of Virtual Machine Device Queues: 0/1 = disable (1 queue) 2-16 enable (default=8) (array of int)
parm:           max_vfs:Number of Virtual Functions: 0 = disable (default), 1-63 = enable this many VFs (array of int)
parm:           VEPA:VEPA Bridge Mode: 0 = VEB (default), 1 = VEPA (array of int)
parm:           InterruptThrottleRate:Maximum interrupts per second, per vector, (0,1,956-488281), default 1 (array of int)
parm:           LLIPort:Low Latency Interrupt TCP Port (0-65535) (array of int)
parm:           LLIPush:Low Latency Interrupt on TCP Push flag (0,1) (array of int)
parm:           LLISize:Low Latency Interrupt on Packet Size (0-1500) (array of int)
parm:           LLIEType:Low Latency Interrupt Ethernet Protocol Type (array of int)
parm:           LLIVLANP:Low Latency Interrupt on VLAN priority threshold (array of int)
parm:           FdirPballoc:Flow Director packet buffer allocation level:
			1 = 8k hash filters or 2k perfect filters
			2 = 16k hash filters or 4k perfect filters
			3 = 32k hash filters or 8k perfect filters (array of int)
parm:           AtrSampleRate:Software ATR Tx packet sample rate (array of int)
parm:           FCoE:Disable or enable FCoE Offload, default 1 (array of int)
parm:           MDD:Malicious Driver Detection: (0,1), default 1 = on (array of int)
parm:           LRO:Large Receive Offload (0,1), default 0 = off (array of int)
parm:           allow_unsupported_sfp:Allow unsupported and untested SFP+ modules on 82599 based adapters, default 0 = Disable (array of int)
parm:           dmac_watchdog:DMA coalescing watchdog in microseconds (0,41-10000), default 0 = off (array of int)
parm:           vxlan_rx:VXLAN receive checksum offload (0,1), default 1 = Enable (array of int)
A couple of weeks ago I had another X550T2 in my exact same system which "just showed up". This one here does not. The LEDs on the card are flashing. I tried two different PCIe ports.
Any ideas how to get this card up and running?
Thank you very much in advance!
This is the only place i can think about to get some information
https://www.kernel.org/doc/html/latest/networking/device_drivers/intel/ixgbe.html
