On April 6th or twenty four days ago I created a topic for help with cinnamon crashing after logging in. Ever since then, my internet has been slow and at times very frustrating to use and typically has high latency to go with it.
So what is the question?
btw. On April 2nd, my lawnmower stopped working. Ever since then, my hairdryer did perform very bad and could not dry my hair anymore.
Sorry, for not being clear. What I was trying to get across is that my internet has been slow ever since an update for 55 packages that broke cinnamon and I suspect may have broken something else. Namely, my internet stability.
My question, in short, is how do I fix this?
A good place to start is this post: How to provide good information in your posts
Try searching the forum for mention of errors or warnings in your logs, you might find a solution. If not hopefully you can narrow the question down enough that someone can help you.
Thank you for the suggestion! I'm on it.
General information about my system from inxi:
Host: noah-pc Kernel: 4.19.36-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 8.3.0 Desktop: Cinnamon 4.0.10 dm: LightDM 1.28.0 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: AB350M-DS3H v: N/A
serial: <filter>
Mobo: Gigabyte model: AB350M-DS3H-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F21 date: 02/08/2018
Topology: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics
bits: 64 type: MCP arch: Zen L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 27956
Speed: 1464 MHz min/max: 1600/3500 MHz boost: enabled Core speeds (MHz):
1: 1638 2: 1552 3: 1411 4: 1584
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Gigabyte driver: amdgpu v: kernel bus ID: 08:00.0
chip ID: 1002:15dd
Display: x11 server: X.Org 1.20.4 driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa resolution: 1600x900~60Hz
OpenGL: renderer: AMD RAVEN (DRM 3.27.0 4.19.36-1-MANJARO LLVM 8.0.0)
v: 4.5 Mesa 19.0.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus ID: 08:00.1 chip ID: 1002:15de
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 08:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k4.19.36-1-MANJARO
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter
driver: rtl8192ee v: kernel port: e000 bus ID: 03:00.0 chip ID: 10ec:818b
vendor: Gigabyte driver: r8168 v: 8.045.08-NAPI port: d000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 52.75 GiB (5.7%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0
size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: 1A02 scheme: GPT
ID-1: / size: 908.30 GiB used: 52.71 GiB (5.8%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 7.41 GiB used: 40.2 MiB (0.5%) fs: swap dev: /dev/sda3
System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 32 C
Processes: 225 Uptime: 3h 08m Memory: 6.82 GiB used: 1.82 GiB (26.7%)
Init: systemd v: 242 Compilers: gcc: 8.3.0 clang: 8.0.0 Shell: zsh
v: 5.7.1 running in: gnome-terminal inxi: 3.0.33
See if this will help
Disable mac address randomization
and disable IPV6.
There is another recent post about slow internet speed. See my comment and others for possible solutions.
What driver source?
I would test several different kernels 5.0, 5.1, & 4.14.
Wrong, wrong, wrong. And to make matters worse you post a pic on a technical support thread. They should reintroduce capital punishment for that offence.
You guys are all barking up the wrong tree (the Ethernet is down). As far as I can see it is the Wifi being used.
Sorry Moson, That it took so long to get back to you with free tech support about for Lawnmower.
Have you been able to mow your lawn recently?
Ha ha, this thread is a laugh. Pretty hard to take seriously, when the OP doesn't even specify if the issue is with wireless or wired.
I'm already going straight to hell for using emoticons on a linux board so feel free to cast the first stone.
But please we are newbie corner, and hopefully amongst the noise the OP has got some signal about where to look for their problem.
More seriously, WiFi is slower than Ethernet usually, isn't it?
Sure, but latency can happen on either.
Followed only your first and third suggestion as I've already disabled mac randomization for Network Manager. I removed the blacklist file and turned off IPv6 before restarting the computer. I'll have to use the internet throughout the day and observe the changes.
If your problem persists I suggest posting the output of
journalctl -b -p3
after running into the the internet issue.
Bug report filed a couple days ago on r8168 & B360M-DS3H:
The mobo model numbers being so close it could be related.
Not the end of the day yet so I can't give a final conclusion but here is what the log currently contains after running the specified command:
-- Logs begin at Wed 2019-01-23 17:58:55 EST, end at Wed 2019-05-01 21:21:13 EDT. --
May 01 20:21:54 noah-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.SMIC], AE_ALREADY_EXI>
May 01 20:21:54 noah-pc kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810>
May 01 20:21:54 noah-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.SMIB], AE_ALREADY_EXI>
May 01 20:21:54 noah-pc kernel: AMD-Vi: Unable to write to IOMMU perf counter.
May 01 20:22:00 noah-pc kernel: kvm: disabled by bios
May 01 20:22:00 noah-pc kernel: [drm:construct [amdgpu]] *ERROR* construct: Invalid Connector Objec>
May 01 20:22:16 noah-pc lightdm[600]: gkr-pam: unable to locate daemon control file
