Is there a top menu bar which can add to my top panel on KDE?
Does KDE have a top menu bar
Is there a way now?
Top bar is just a regular panel moved up.Feel free to create it and customize as you like
Screenshot_20190312_205144
You mean there is a way to move menu bar of an application like konsole to the panel, like picture above?
Right mouse click on any place of the interface >>> Add widget >>> Global Menu >>> drag to panel.
Thanks a lot!
You are welcome. Fell free to also check these other alternatives and complements by the great @psifidotos
Yes, I'm using latte-dock, also great which I installed an hour ago. As there is a bug for manjaro's latte-dock. I downloaded and installed the latest from Archlinux.
Hi, does your global menu worked with pycharm or clion?
I've installed appmenu-gtk-module-0.7.1-1 appmenu-qt4-0.2.6-2 libdbusmenu-glib 16.04.0-3 libdbusmenu-gtk2 16.04.0-3 libdbusmenu-qt4 0.9.3+16.04.20160218-2 libdbusmenu-qt5 0.9.3+16.04.20160218-2
and I've added linux.native.menu=true to /opt/pycharm-professional/bin/idea.properties.
But doesn't work.
I've created a new topic here
