Issue with installing ZFS on linux56 kernel
Hello!
There is an error with installing zfs on linux56 (5.6.8-1).
Here is the command i typed from the command line:
bash: sudo dkms install zfs/0.8.3 -k 5.6.8-1-MANJARO
Here is the prebuilt script: https://pastebin.com/ScxSviRP
Error description in the command line:
Building module:
cleaning build area....
make -j2 KERNELRELEASE=5.6.8-1-MANJARO.......(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.6.8-1-MANJARO (x86_64)
Consult /var/lib/dkms/zfs/0.8.3/build/make.log for more information.
Here is the make.log: https://pastebin.com/4MBz4zhb
Manjaro has prebuilt zfs modules. You can just install those.
sudo pacman -Syu linux56-zfs
