KDE volume and brightness indicators are not working here.
Zero pertinent information here!
Please post:
inxi -Fxxxz
Please post all terminal commands as text with code tags, (not as pics).
Information on how to properly post hardware specs and logs:
Please format any terminal output with three backticks before and after, as shown in this picture:
Please provide at least:
inxi -Gxz
Describe if the issue is by using keyboard shortcuts or from System Tray icons.
System: Host: AsusX510UR Kernel: 4.20.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1
Desktop: KDE Plasma 5.15.0 tk: Qt 5.12.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: X510UR v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X510UR v: 1.0 serial: <filter> UEFI: American Megatrends v: X510UR.307
date: 08/08/2018
Battery: ID-1: BAT0 charge: 37.0 Wh condition: 38.2/42.1 Wh (91%) volts: 11.5/11.5
model: ASUSTeK ASUS Battery type: Li-ion serial: <filter> status: Not charging cycles: 53
CPU: Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Kaby Lake rev: 9
L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21704
Speed: 500 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 547 2: 592 3: 570 4: 568
Graphics: Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:5916
Device-2: NVIDIA GM108M [GeForce 930MX] driver: N/A bus ID: 01:00.0 chip ID: 10de:134e
Display: x11 server: X.Org 1.20.3 driver: intel compositor: kwin_x11 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.5 Mesa 18.3.3 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k4.20.7-1-MANJARO
Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: f040 bus ID: 02:00.0
chip ID: 8086:095a
Drives: Local Storage: total: 1.13 TiB used: 35.80 GiB (3.1%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-2: /dev/sdb vendor: KingDian model: N480 240GB size: 223.57 GiB speed: 6.0 Gb/s serial: <filter>
rev: 7A scheme: GPT
Partition: ID-1: / size: 44.04 GiB used: 22.99 GiB (52.2%) fs: ext4 dev: /dev/sdb6
ID-2: /home size: 53.95 GiB used: 12.81 GiB (23.7%) fs: ext4 dev: /dev/sdb7
Sensors: System Temperatures: cpu: 53.0 C mobo: N/A
Info: Processes: 168 Uptime: 2h 51m Memory: 11.61 GiB used: 1.22 GiB (10.5%) Init: systemd v: 241
Compilers: gcc: 8.2.1 Shell: bash v: 5.0.0 running in: konsole inxi: 3.0.30
Display: x11 server: X.Org 1.20.3 driver: intel resolution: 1920x1080~60Hz
direct render: Yes
I can increase / decrease the brightness and volume through the keyboard shortcuts, but the icone / widget is not displayed on the screen.
Ah, ok ... not that bad as i thought. Please check if somehow you unchecked the Visual feedback for status changes under Desktop Behavior > Workspace Behavior.
Thank you very much, that's right.
