Issue: My dashboard flicks every time I try to select+launch and application, if I manage to set an application as favorite I can click it to launch. Others in the full list just lost focus when I try to click on them, I need fast clicks to get it launched. If a do a search for the application, in the search result and I can click it and send it to favorites.
If I try to use another alternative, right click on the kde icon it shows a windows "Alternative Widgets" that flicks and goes from the first alternative to the third. I need to be "fast" to select one using the keyboard to "Switch" but the other alternatives are worse, because I can't click on the menus to select and application.
In some alternatives it shows a windows message overlapped on the menu that says "Applications updated".
In the launcher when I see the menu an click, the search box is selected automatically and I can select any item to launch.
I manage to capture a video, but it doesn't show the fickler just the jumping between the alternatives dashboard/launcher/menu. I move the mouse cursor and click on the 2nd and 3rd alternatives but it always return to the 1st one.
https://www.youtube.com/watch?v=lfFwGHBAo1w
I logout and delete the .config/kwinrc before take this video.
