In the last stable update my KDE have been crashing every time when I use hot corners and multiple tabs. I tested the recent 5.19.4 in testing branch and not helps
I removed my plasmoids like you specified here but I do not get result. How can I proceed?
System details configs
System: Host: nicolas-linux Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: KDE Plasma 5.19.3 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: S400CA v: 1.0 serial:
Mobo: ASUSTeK model: S400CA v: 1.0 serial: UEFI: American Megatrends v: S400CA.210
date: 01/27/2014
Battery: ID-1: BAT0 charge: 34.4 Wh condition: 35.3/45.3 Wh (78%) volts: 11.2/11.2
model: ASUSTek X402--40 type: Li-ion serial: status: Unknown cycles: 450
CPU: Topology: Dual Core model: Intel Core i5-3317U bits: 64 type: MT MCP arch: Ivy Bridge rev: 9
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13574
Speed: 798 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0166
Display: x11 server: X.Org 1.20.8 driver: intel compositor: kwin_x11
resolution: 1366x768~60Hz, 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.1.3 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.6.19-2-MANJARO
Network: Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave driver: ath9k
v: kernel port: f040 bus ID: 02:00.0 chip ID: 168c:0032
IF: wlp2s0 state: up mac:
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK driver: alx v: kernel
port: e000 bus ID: 03:00.0 chip ID: 1969:1091
IF: enp3s0 state: down mac:
IF-ID-1: docker0 state: down mac:
Drives: Local Storage: total: 689.33 GiB used: 88.39 GiB (12.8%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB speed: 6.0 Gb/s
serial: rev: B1D2 scheme: GPT
ID-2: /dev/sdb type: USB vendor: JMicron Tech model: Generic size: 465.76 GiB serial:
rev: 0508 scheme: GPT
Partition: ID-1: / size: 42.71 GiB used: 29.23 GiB (68.4%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 174.21 GiB used: 59.16 GiB (34.0%) fs: ext4 dev: /dev/sda3
Sensors: System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3400
Info: Processes: 200 Uptime: 6m Memory: 7.67 GiB used: 1.40 GiB (18.3%) Init: systemd v: 245
target: graphical.target Compilers: gcc: 10.1.0 clang: 10.0.0 Shell: fish
v: 3.1.0-444-g23339ae15 running in: konsole inxi: 3.0.37
PS: When I start manjaro the "crash" is only compositor, I run Alt+Shift+F12
and turn back. But I don't know what causing this. The other crash causes every time I use this "hot corners" or multiple tabs needs to reboot all system. Mouse and terminal it's no acessible.
