KDE: GUI Transition Not Smooth From Splash into Main Desktop
For the first time after fresh install, or using with live-usb, transition GUI from splash screen into main desktop is smooth. After several time, after custom desktop with widgets or some Conky themes, transition from splash into main desktop degraded, not smooth anymore. I'm using Nvidia propietary driver 340 and 4.18.x kernel.
I'm just gonna go ahead and assume then that it is either the extra load or possibly a greedy/buggy widget.
I'm just using 1 widget on desktop (and 2 installed on panel) and three small themes of Conky. Just wondering... overall transition work smooth, except on login.
Check the times spent
systemd-analyze --user blame
[leo4kw@leo-pckde ~]$ systemd-analyze --user blame
           234ms pulseaudio.service
           193ms gvfs-udisks2-volume-monitor.service
            40ms xdg-user-dirs-update.service
            16ms dbus.socket
            12ms gvfs-daemon.service
             9ms gvfs-gphoto2-volume-monitor.service
             9ms obex.service
             7ms gvfs-mtp-volume-monitor.service
             6ms gvfs-afc-volume-monitor.service
Fast, it seems.
Give more info
inxi -SMGDPIxxxz
journalctl -p 3
systemctl --failed
#journalctl -p 3```
Agu 23 13:47:50 leo-pckde kernel: usb 1-5: device not accepting address 6, error -71
Agu 23 13:47:50 leo-pckde kernel: usb usb1-port5: unable to enumerate USB device
Agu 23 13:50:53 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Agu 23 13:50:53 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
-- Reboot --
Agu 23 21:00:39 leo-pckde kernel: kvm: disabled by bios
Agu 23 21:51:32 leo-pckde kcheckpass[894]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 23 21:51:32 leo-pckde kcheckpass[894]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 23 21:51:32 leo-pckde kcheckpass[894]: pam_tally(kde:setcred): Error opening /var/log/faillog for update
Agu 24 00:24:31 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 24 00:24:37 leo-pckde kcheckpass[1473]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 24 00:24:37 leo-pckde kcheckpass[1473]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 24 00:24:42 leo-pckde kcheckpass[1473]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 24 00:24:42 leo-pckde kcheckpass[1473]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 24 00:24:42 leo-pckde kcheckpass[1473]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
Agu 24 00:33:33 leo-pckde systemsettings5[22350]: Error loading text-to-speech plug-in "flite"
Agu 24 03:24:01 leo-pckde crond[363]: (root) CAN'T OPEN (/etc/crontab): No such file or directory
Agu 24 03:26:00 leo-pckde plasmashell[624]: Command ' "kpackagetool5 --install /tmp/v2.5.zip --type Plasma/>
Agu 24 03:33:44 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 24 03:34:02 leo-pckde kernel: kvm: disabled by bios
Agu 24 03:37:40 leo-pckde sudo[1171]: leo4kw : a password is required ; TTY=pts/1 ; PWD=/tmp/yaourt-tmp-l>
Agu 24 03:52:44 leo-pckde sudo[11041]: leo4kw : a password is required ; TTY=pts/1 ; PWD=/tmp/yaourt-tmp->
Agu 24 03:57:44 leo-pckde sudo[11043]: pam_unix(sudo:auth): conversation failed
Agu 24 03:57:44 leo-pckde sudo[11043]: pam_unix(sudo:auth): auth could not identify password for [leo4kw]
Agu 24 03:58:13 leo-pckde sudo[11070]: leo4kw : a password is required ; TTY=pts/1 ; PWD=/tmp/yaourt-tmp->
Agu 24 05:07:57 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 24 05:08:08 leo-pckde kcheckpass[14958]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 24 05:08:08 leo-pckde kcheckpass[14958]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 24 05:08:13 leo-pckde kcheckpass[14958]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 24 05:08:13 leo-pckde kcheckpass[14958]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 24 05:08:13 leo-pckde kcheckpass[14958]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 24 05:11:15 leo-pckde sudo[16937]: leo4kw : a password is required ; TTY=pts/1 ; PWD=/tmp/yaourt-tmp->
Agu 24 05:51:13 leo-pckde sudo[19212]: leo4kw : a password is required ; TTY=pts/2 ; PWD=/tmp/yaourt-tmp->
Agu 24 07:37:08 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 24 07:37:36 leo-pckde kcheckpass[24578]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 24 07:37:36 leo-pckde kcheckpass[24578]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 24 07:37:36 leo-pckde kcheckpass[24578]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 24 07:39:42 leo-pckde signon-ui[25047]: browser-request.cpp 757 initializeField Couldn't find element: >
Agu 24 07:40:55 leo-pckde signon-ui[25047]: browser-request.cpp 757 initializeField Couldn't find element: >
Agu 24 07:41:23 leo-pckde signon-ui[25047]: browser-request.cpp 757 initializeField Couldn't find element: >
Agu 24 07:41:28 leo-pckde signon-ui[25047]: browser-request.cpp 757 initializeField Couldn't find element: >
Agu 24 07:42:56 leo-pckde signon-ui[25047]: browser-request.cpp 757 initializeField Couldn't find element: >
Agu 24 08:01:08 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Agu 24 08:01:08 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Agu 24 08:08:59 leo-pckde dolphin[25451]: Error loading text-to-speech plug-in "speechd"
Agu 24 08:10:53 leo-pckde systemd-coredump[30796]: Process 30532 (docky) of user 1000 dumped core.
                                               Stack trace of thread 30532:
                                               #0  0x00007fad46186d7f raise (libc.so.6)
                                               #1  0x00007fad46171672 abort (libc.so.6)
                                               #2  0x000056253930a063 n/a (mono-sgen)
                                               #3  0x000056253941f8b9 n/a (mono-sgen)
                                               #4  0x00007fad461d4f41 __libc_free (libc.so.6)
                                               #5  0x0000000041f47160 n/a (n/a)
Agu 24 08:33:21 leo-pckde dolphin[25451]: Error loading text-to-speech plug-in "speechd"
Agu 24 08:35:41 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 24 08:36:03 leo-pckde kernel: kvm: disabled by bios
Agu 24 12:20:39 leo-pckde dolphin[4183]: Error loading text-to-speech plug-in "flite"
Agu 24 12:20:48 leo-pckde dolphin[4183]: Error loading text-to-speech plug-in "flite"
Agu 24 12:43:53 leo-pckde dolphin[4183]: Error loading text-to-speech plug-in "flite"
Agu 24 16:05:11 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 24 16:05:20 leo-pckde kcheckpass[25222]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 24 16:05:20 leo-pckde kcheckpass[25222]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 24 16:05:20 leo-pckde kcheckpass[25222]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 24 17:12:39 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Agu 24 17:12:39 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Agu 24 17:21:40 leo-pckde kernel: xhci_hcd 0000:00:14.0: ERROR Transfer event TRB DMA ptr not part of curre>
Agu 24 18:55:08 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 24 19:13:14 leo-pckde kernel: kvm: disabled by bios
Agu 24 23:58:08 leo-pckde kcheckpass[29753]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 24 23:58:08 leo-pckde kcheckpass[29753]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 24 23:58:14 leo-pckde kcheckpass[29753]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 24 23:58:14 leo-pckde kcheckpass[29753]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 24 23:58:14 leo-pckde kcheckpass[29753]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 25 00:12:27 leo-pckde sudo[9288]: leo4kw : a password is required ; TTY=pts/1 ; PWD=/tmp/yaourt-tmp-l>
Agu 25 05:12:34 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 25 05:12:45 leo-pckde kcheckpass[15902]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 05:12:45 leo-pckde kcheckpass[15902]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 05:12:45 leo-pckde kcheckpass[15902]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 25 06:27:55 leo-pckde sudo[28769]: leo4kw : a password is required ; TTY=pts/2 ; PWD=/tmp/yaourt-tmp->
Agu 25 06:43:00 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Agu 25 06:43:00 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Agu 25 07:58:13 leo-pckde kcheckpass[18708]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 07:58:13 leo-pckde kcheckpass[18708]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 07:58:21 leo-pckde kcheckpass[18708]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 07:58:21 leo-pckde kcheckpass[18708]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 07:58:21 leo-pckde kcheckpass[18708]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 25 09:38:07 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 25 09:38:13 leo-pckde kcheckpass[21713]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 09:38:13 leo-pckde kcheckpass[21713]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 09:38:18 leo-pckde kcheckpass[21713]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 09:38:18 leo-pckde kcheckpass[21713]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 09:38:18 leo-pckde kcheckpass[21713]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 25 12:23:56 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 25 12:24:03 leo-pckde kcheckpass[25998]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 12:24:03 leo-pckde kcheckpass[25998]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 12:24:09 leo-pckde kcheckpass[25998]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 12:24:09 leo-pckde kcheckpass[25998]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 12:24:09 leo-pckde kcheckpass[25998]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 25 14:38:05 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 25 14:38:13 leo-pckde kcheckpass[24072]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 14:38:13 leo-pckde kcheckpass[24072]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 14:38:13 leo-pckde kcheckpass[24072]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 25 14:38:21 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 25 14:38:39 leo-pckde kernel: kvm: disabled by bios
Agu 25 14:51:07 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Agu 25 14:51:07 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Agu 25 15:05:04 leo-pckde kernel: xhci_hcd 0000:00:14.0: ERROR Transfer event TRB DMA ptr not part of curre>
-- Reboot --
Agu 25 17:15:08 leo-pckde kernel: kvm: disabled by bios
Agu 25 23:18:55 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 25 23:19:01 leo-pckde kcheckpass[21976]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 23:19:01 leo-pckde kcheckpass[21976]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 23:19:07 leo-pckde kcheckpass[21976]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 25 23:19:07 leo-pckde kcheckpass[21976]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 25 23:19:07 leo-pckde kcheckpass[21976]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 26 00:23:25 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 26 00:23:35 leo-pckde kcheckpass[8240]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 26 00:23:35 leo-pckde kcheckpass[8240]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 26 00:23:38 leo-pckde systemd-coredump[8608]: Process 754 (clementine) of user 1000 dumped core.
                                              Stack trace of thread 754:
                                              #0  0x00007f74970dd849 n/a (libQt5Core.so.5)
                                              #1  0x00007f74970de0b9 n/a (libQt5Core.so.5)
                                              #2  0x00007f74970e4416 _ZN11QMetaObject19normalizedSignat>
                                              #3  0x00007f749710383f _ZN7QObject10disconnectEPKS_PKcS1_>
                                              #4  0x00007f74973a9f75 n/a (libQt5Network.so.5)
                                              #5  0x00007f74973aa13c n/a (libQt5Network.so.5)
                                              #6  0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #7  0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #8  0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #9  0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #10 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #11 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #12 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #13 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #14 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #15 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #16 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #17 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #18 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #19 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #20 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #21 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #22 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #23 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #24 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #25 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #26 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #27 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #28 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #29 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #30 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #31 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #32 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #33 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #34 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #35 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #36 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #37 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #38 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #39 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #40 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #41 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #42 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #43 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #44 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #45 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #46 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #47 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #48 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #49 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #50 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #51 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #52 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #53 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #54 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #55 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #56 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #57 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #58 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #59 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #60 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #61 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #62 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #63 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              Stack trace of thread 775:
                                              #0  0x00007f7492864bb1 __poll (libc.so.6)
                                              #1  0x00007f748b5e9180 n/a (libxcb.so.1)
                                              #2  0x00007f748b5eae4b xcb_wait_for_event (libxcb.so.1)
                                              #3  0x00007f74825cee1a n/a (libQt5XcbQpa.so.5)
                                              #4  0x00007f7496f27005 n/a (libQt5Core.so.5)
                                              #5  0x00007f74961f1a9d start_thread (libpthread.so.0)
                                              #6  0x00007f749286fa43 __clone (libc.so.6)
                                              Stack trace of thread 777:
                                              #1  0x00007f7495540ec0 n/a (libglib-2.0.so.0)
                                              #2  0x00007f7495540fee g_main_context_iteration (libglib->
                                              #3  0x00007f74971284a9 _ZN20QEventDispatcherGlib13process>
                                              #4  0x00007f74970d3dac _ZN10QEventLoop4execE6QFlagsINS_17>
                                              #5  0x00007f7496f1cf59 _ZN7QThread4execEv (libQt5Core.so.>
                                              #6  0x00007f7496109ba6 n/a (libQt5DBus.so.5)
                                              #7  0x00007f7496f27005 n/a (libQt5Core.so.5)
                                              #8  0x00007f74961f1a9d start_thread (libpthread.so.0)
                                              #9  0x00007f749286fa43 __clone (libc.so.6)
                                              Stack trace of thread 786:
                                              #3  0x00007f74971284c4 _ZN20QEventDispatcherGlib13process>
                                              #6  0x00007f7496f27005 n/a (libQt5Core.so.5)
                                              #7  0x00007f74961f1a9d start_thread (libpthread.so.0)
                                              #8  0x00007f749286fa43 __clone (libc.so.6)
                                              Stack trace of thread 780:
                                              Stack trace of thread 783:
                                              Stack trace of thread 787:
                                              Stack trace of thread 784:
                                              Stack trace of thread 779:
                                              #0  0x00007f74970dd496 n/a (libQt5Core.so.5)
                                              #1  0x00007f74970e4380 _ZN11QMetaObject19normalizedSignat>
                                              #2  0x00007f74971038b4 _ZN7QObject10disconnectEPKS_PKcS1_>
                                              #3  0x00007f74973a9f91 n/a (libQt5Network.so.5)
                                              #4  0x00007f74973aa13c n/a (libQt5Network.so.5)
                                              #5  0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #6  0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #7  0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #8  0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #9  0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #10 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #11 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #12 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #13 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #14 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #15 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #16 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #17 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #18 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #19 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #20 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #21 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #22 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #23 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #24 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #25 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #26 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #27 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #28 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #29 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #30 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #31 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #32 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #33 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #34 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #35 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #36 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #37 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #38 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #39 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #40 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #41 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #42 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #43 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #44 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #45 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #46 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #47 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #48 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #49 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #50 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #51 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #52 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #53 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #54 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #55 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #56 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #57 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #58 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #59 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #60 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #61 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              #62 0x00007f74973aa153 n/a (libQt5Network.so.5)
                                              #63 0x00007f74973aa588 n/a (libQt5Network.so.5)
                                              Stack trace of thread 797:
                                              Stack trace of thread 799:
                                              Stack trace of thread 798:
                                              Stack trace of thread 800:
                                              Stack trace of thread 802:
                                              #2  0x00007f7495541272 g_main_loop_run (libglib-2.0.so.0)
                                              #3  0x00007f7496b77e78 n/a (libgio-2.0.so.0)
                                              #4  0x00007f74955691ea n/a (libglib-2.0.so.0)
                                              Stack trace of thread 801:
                                              #3  0x00007f7495541042 n/a (libglib-2.0.so.0)
Agu 26 00:23:40 leo-pckde kcheckpass[8240]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 26 00:23:40 leo-pckde kcheckpass[8240]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 26 00:23:40 leo-pckde kcheckpass[8240]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
Agu 26 04:17:38 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 26 04:17:54 leo-pckde kcheckpass[10183]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 26 04:17:54 leo-pckde kcheckpass[10183]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 26 04:17:54 leo-pckde kcheckpass[10183]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 26 05:18:23 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 26 05:18:31 leo-pckde kcheckpass[21957]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 26 05:18:31 leo-pckde kcheckpass[21957]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 26 05:18:36 leo-pckde kcheckpass[21957]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 26 05:18:36 leo-pckde kcheckpass[21957]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 26 05:18:37 leo-pckde kcheckpass[21957]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 26 07:39:31 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Agu 26 07:39:31 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Agu 26 18:41:26 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 26 18:41:55 leo-pckde kcheckpass[32006]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 26 18:41:55 leo-pckde kcheckpass[32006]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 26 18:41:55 leo-pckde kcheckpass[32006]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 26 22:05:35 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 26 22:05:44 leo-pckde kcheckpass[29838]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 26 22:05:44 leo-pckde kcheckpass[29838]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 26 22:05:44 leo-pckde kcheckpass[29838]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 27 00:18:01 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 27 00:18:21 leo-pckde kernel: kvm: disabled by bios
Agu 27 05:46:48 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 27 05:46:58 leo-pckde kcheckpass[23527]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 27 05:46:58 leo-pckde kcheckpass[23527]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 27 05:47:04 leo-pckde kcheckpass[23527]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 27 05:47:04 leo-pckde kcheckpass[23527]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 27 05:47:04 leo-pckde kcheckpass[23527]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 27 11:15:27 leo-pckde kcheckpass[22403]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 27 11:15:27 leo-pckde kcheckpass[22403]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 27 11:15:27 leo-pckde kcheckpass[22403]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 27 12:59:27 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 27 12:59:32 leo-pckde kcheckpass[21085]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 27 12:59:32 leo-pckde kcheckpass[21085]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 27 12:59:37 leo-pckde kcheckpass[21085]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 27 12:59:37 leo-pckde kcheckpass[21085]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 27 12:59:37 leo-pckde kcheckpass[21085]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
-- Reboot --
Agu 27 18:18:15 leo-pckde kernel: kvm: disabled by bios
Agu 27 21:31:41 leo-pckde kcheckpass[9545]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 27 21:31:41 leo-pckde kcheckpass[9545]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 27 21:31:41 leo-pckde kcheckpass[9545]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
-- Reboot --
Agu 28 00:57:01 leo-pckde kernel: kvm: disabled by bios
Agu 28 04:13:34 leo-pckde kcheckpass[16240]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 28 04:13:34 leo-pckde kcheckpass[16240]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 28 04:13:34 leo-pckde kcheckpass[16240]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 28 05:07:38 leo-pckde kcheckpass[810]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 28 05:07:38 leo-pckde kcheckpass[810]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 28 05:07:38 leo-pckde kcheckpass[810]: pam_tally(kde:setcred): Error opening /var/log/faillog for update
Agu 28 06:28:11 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Agu 28 06:28:11 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Agu 28 11:45:18 leo-pckde kcheckpass[7278]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 28 11:45:18 leo-pckde kcheckpass[7278]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 28 11:45:18 leo-pckde kcheckpass[7278]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
Agu 28 18:06:56 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 28 18:07:07 leo-pckde kcheckpass[19705]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 28 18:07:07 leo-pckde kcheckpass[19705]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 28 18:07:07 leo-pckde kcheckpass[19705]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 28 20:12:01 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 28 20:12:25 leo-pckde kcheckpass[27876]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 28 20:12:25 leo-pckde kcheckpass[27876]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 28 20:12:25 leo-pckde kcheckpass[27876]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 29 00:14:57 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 29 00:15:05 leo-pckde kcheckpass[17972]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 29 00:15:05 leo-pckde kcheckpass[17972]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 29 00:15:05 leo-pckde kcheckpass[17972]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 29 01:10:37 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 29 01:10:54 leo-pckde kernel: kvm: disabled by bios
Agu 29 02:06:50 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 29 02:45:05 leo-pckde kernel: kvm: disabled by bios
Agu 29 02:46:27 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 29 07:04:37 leo-pckde kernel: kvm: disabled by bios
Agu 29 07:05:26 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 29 07:05:45 leo-pckde kernel: kvm: disabled by bios
Agu 29 07:07:29 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Agu 29 07:07:29 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Agu 29 08:10:19 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 29 08:40:12 leo-pckde kernel: kvm: disabled by bios
Agu 29 17:34:09 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 29 17:34:20 leo-pckde kcheckpass[1909]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 29 17:34:20 leo-pckde kcheckpass[1909]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 29 17:34:20 leo-pckde kcheckpass[1909]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
Agu 29 17:35:03 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 29 18:22:48 leo-pckde kernel: kvm: disabled by bios
Agu 29 20:44:32 leo-pckde kcheckpass[21257]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 29 20:44:32 leo-pckde kcheckpass[21257]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 29 20:44:33 leo-pckde kcheckpass[21257]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 30 02:03:47 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 30 02:04:00 leo-pckde kcheckpass[445]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 30 02:04:00 leo-pckde kcheckpass[445]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 30 02:04:00 leo-pckde kcheckpass[445]: pam_tally(kde:setcred): Error opening /var/log/faillog for update
Agu 30 02:04:25 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 30 05:44:23 leo-pckde kernel: kvm: disabled by bios
Agu 30 06:27:25 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 30 07:58:17 leo-pckde kernel: kvm: disabled by bios
Agu 30 08:45:56 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Agu 30 08:45:56 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Agu 30 11:52:03 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 30 11:52:41 leo-pckde kcheckpass[4081]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 30 11:52:41 leo-pckde kcheckpass[4081]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 30 11:52:48 leo-pckde kcheckpass[4081]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 30 11:52:48 leo-pckde kcheckpass[4081]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 30 11:52:48 leo-pckde kcheckpass[4081]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
Agu 30 14:08:50 leo-pckde sudo[30652]: leo4kw : a password is required ; TTY=unknown ; PWD=/home/leo4kw ;>
Agu 30 14:08:50 leo-pckde sudo[30654]: leo4kw : a password is required ; TTY=unknown ; PWD=/home/leo4kw ;>
Agu 30 14:08:50 leo-pckde sudo[30656]: leo4kw : a password is required ; TTY=unknown ; PWD=/home/leo4kw ;>
Agu 30 14:08:50 leo-pckde sudo[30658]: leo4kw : a password is required ; TTY=unknown ; PWD=/home/leo4kw ;>
Agu 30 16:17:25 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 30 17:15:42 leo-pckde kernel: kvm: disabled by bios
Agu 30 17:46:25 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 30 17:46:45 leo-pckde kernel: kvm: disabled by bios
Agu 30 17:48:13 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 30 17:48:29 leo-pckde kernel: kvm: disabled by bios
Agu 30 20:59:04 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 30 20:59:14 leo-pckde kcheckpass[15573]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 30 20:59:14 leo-pckde kcheckpass[15573]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 30 20:59:14 leo-pckde kcheckpass[15573]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 30 21:10:02 leo-pckde systemsettings5[18072]: Error loading text-to-speech plug-in "speechd"
Agu 30 21:17:05 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 30 21:17:10 leo-pckde kcheckpass[19810]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 30 21:17:10 leo-pckde kcheckpass[19810]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 30 21:17:17 leo-pckde kcheckpass[19810]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 30 21:17:17 leo-pckde kcheckpass[19810]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 30 21:17:17 leo-pckde kcheckpass[19810]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 30 22:43:20 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 30 22:55:23 leo-pckde kernel: kvm: disabled by bios
Agu 31 03:35:32 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 31 03:35:58 leo-pckde kcheckpass[27724]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 31 03:35:58 leo-pckde kcheckpass[27724]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 31 03:35:58 leo-pckde kcheckpass[27724]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 31 03:46:09 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 31 03:56:07 leo-pckde kernel: kvm: disabled by bios
Agu 31 03:58:25 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 31 04:34:53 leo-pckde kernel: kvm: disabled by bios
Agu 31 05:05:08 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 31 05:05:18 leo-pckde kcheckpass[1039]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 31 05:05:18 leo-pckde kcheckpass[1039]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 31 05:05:18 leo-pckde kcheckpass[1039]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
Agu 31 06:23:38 leo-pckde kcheckpass[10435]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 31 06:23:38 leo-pckde kcheckpass[10435]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 31 06:23:38 leo-pckde kcheckpass[10435]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 31 06:30:03 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 31 06:42:04 leo-pckde kernel: kvm: disabled by bios
Agu 31 06:43:36 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 31 09:20:37 leo-pckde kernel: kvm: disabled by bios
Agu 31 09:22:07 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 31 10:03:55 leo-pckde kernel: kvm: disabled by bios
Agu 31 10:50:35 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Agu 31 15:19:37 leo-pckde kernel: kvm: disabled by bios
Agu 31 19:52:39 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Agu 31 19:52:48 leo-pckde kcheckpass[14800]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Agu 31 19:52:48 leo-pckde kcheckpass[14800]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Agu 31 19:52:49 leo-pckde kcheckpass[14800]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Agu 31 19:57:51 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 01 01:29:17 leo-pckde kernel: kvm: disabled by bios
Sep 01 02:24:32 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Sep 01 02:24:32 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Sep 01 02:31:49 leo-pckde kernel: xhci_hcd 0000:00:14.0: ERROR Transfer event TRB DMA ptr not part of curre>
Sep 01 02:32:04 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 01 05:02:51 leo-pckde kernel: kvm: disabled by bios
Sep 01 06:22:25 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Sep 01 06:22:34 leo-pckde kcheckpass[9826]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Sep 01 06:22:34 leo-pckde kcheckpass[9826]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Sep 01 06:22:40 leo-pckde kcheckpass[9826]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Sep 01 06:22:40 leo-pckde kcheckpass[9826]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Sep 01 06:22:40 leo-pckde kcheckpass[9826]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
Sep 01 06:23:11 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Sep 01 06:23:11 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Sep 01 06:49:01 leo-pckde kernel: xhci_hcd 0000:00:14.0: ERROR Transfer event TRB DMA ptr not part of curre>
Sep 01 06:49:14 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 01 15:44:04 leo-pckde kernel: kvm: disabled by bios
-- Reboot --
Sep 01 20:48:04 leo-pckde kernel: kvm: disabled by bios
Sep 02 02:00:54 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 15:26:16 leo-pckde kernel: kvm: disabled by bios
Sep 02 15:28:42 leo-pckde deepin-turbo-invoker[2307]: error: Failed to initiate connect on the socket for t>
Sep 02 15:28:42 leo-pckde deepin-turbo-invoker[2307]: error: Start application /usr/bin/deepin-screenshot a>
Sep 02 15:57:41 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 17:46:49 leo-pckde kernel: kvm: disabled by bios
Sep 02 17:47:56 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 17:48:13 leo-pckde kernel: kvm: disabled by bios
Sep 02 17:50:22 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 17:50:43 leo-pckde kernel: kvm: disabled by bios
Sep 02 17:53:15 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 17:53:36 leo-pckde kernel: kvm: disabled by bios
Sep 02 17:54:05 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 17:54:24 leo-pckde kernel: kvm: disabled by bios
Sep 02 19:37:30 leo-pckde kdeconnectd[2298]: Could not connect to any X display.
Sep 02 19:37:31 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 19:37:51 leo-pckde kernel: kvm: disabled by bios
Sep 02 19:39:52 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 19:40:11 leo-pckde kernel: kvm: disabled by bios
Sep 02 19:41:35 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 19:41:54 leo-pckde kernel: kvm: disabled by bios
Sep 02 19:45:32 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 19:45:49 leo-pckde kernel: kvm: disabled by bios
Sep 02 20:27:35 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Sep 02 20:27:53 leo-pckde kcheckpass[3738]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Sep 02 20:27:53 leo-pckde kcheckpass[3738]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Sep 02 20:27:53 leo-pckde kcheckpass[3738]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
Sep 02 20:48:53 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 20:49:18 leo-pckde kernel: kvm: disabled by bios
Sep 02 20:49:19 leo-pckde systemd[1]: Failed to mount /run/media/leo4kw/5fa83115-825b-432d-9139-4686a875a90>
Sep 02 20:50:27 leo-pckde kernel: do_IRQ: 0.55 No irq handler for vector
Sep 02 20:50:35 leo-pckde kcheckpass[1224]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Sep 02 20:50:35 leo-pckde kcheckpass[1224]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Sep 02 20:50:35 leo-pckde kcheckpass[1224]: pam_tally(kde:setcred): Error opening /var/log/faillog for upda>
Sep 02 20:53:06 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Sep 02 20:53:06 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Sep 02 20:56:40 leo-pckde kernel: xhci_hcd 0000:00:14.0: ERROR Transfer event TRB DMA ptr not part of curre>
Sep 02 21:07:29 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 02 23:04:57 leo-pckde kernel: kvm: disabled by bios
Sep 02 23:59:40 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 03 05:49:23 leo-pckde kernel: kvm: disabled by bios
Sep 03 05:51:01 leo-pckde kernel: watchdog: watchdog0: watchdog did not stop!
-- Reboot --
Sep 03 05:51:17 leo-pckde kernel: kvm: disabled by bios
Sep 03 05:59:15 leo-pckde kernel: usb 1-5: 1:1: cannot get freq at ep 0x5
Sep 03 05:59:15 leo-pckde kernel: usb 1-5: 2:1: cannot get freq at ep 0x86
Sep 03 10:33:46 leo-pckde kcheckpass[25960]: pam_tally(kde:auth): Error opening /var/log/faillog for update
Sep 03 10:33:46 leo-pckde kcheckpass[25960]: pam_tally(kde:auth): Error opening /var/log/faillog for read
Sep 03 10:33:46 leo-pckde kcheckpass[25960]: pam_tally(kde:setcred): Error opening /var/log/faillog for upd>
Sep 03 10:33:50 leo-pckde systemd-coredump[26332]: Process 761 (clementine) of user 1000 dumped core.
                                               Stack trace of thread 761:
                                               #0  0x00007f6299a6d664 n/a (libQt5Core.so.5)
                                               #1  0x00007f6299a6e0b9 n/a (libQt5Core.so.5)
                                               #2  0x00007f6299a74416 _ZN11QMetaObject19normalizedSigna>
                                               #3  0x00007f6299a9383f _ZN7QObject10disconnectEPKS_PKcS1>
                                               #4  0x00007f6299d39f75 n/a (libQt5Network.so.5)
                                               #5  0x00007f6299d3a13c n/a (libQt5Network.so.5)
                                               #6  0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #7  0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #8  0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #9  0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #10 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #11 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #12 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #13 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #14 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #15 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #16 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #17 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #18 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #19 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #20 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #21 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #22 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #23 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #24 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #25 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #26 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #27 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #28 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #29 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #30 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #31 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #32 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #33 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #34 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #35 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #36 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #37 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #38 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #39 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #40 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #41 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #42 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #43 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #44 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #45 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #46 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #47 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #48 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #49 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #50 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #51 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #52 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #53 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #54 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #55 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #56 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #57 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #58 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #59 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #60 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #61 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               #62 0x00007f6299d3a588 n/a (libQt5Network.so.5)
                                               #63 0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               Stack trace of thread 792:
                                               #0  0x00007f62951f4bb1 __poll (libc.so.6)
                                               #1  0x00007f6297ed0ec0 n/a (libglib-2.0.so.0)
                                               #2  0x00007f6297ed0fee g_main_context_iteration (libglib>
                                               #3  0x00007f6299ab84a9 _ZN20QEventDispatcherGlib13proces>
                                               #4  0x00007f6299a63dac _ZN10QEventLoop4execE6QFlagsINS_1>
                                               #5  0x00007f62998acf59 _ZN7QThread4execEv (libQt5Core.so>
                                               #6  0x00007f62998b7005 n/a (libQt5Core.so.5)
                                               #7  0x00007f6298b81a9d start_thread (libpthread.so.0)
                                               #8  0x00007f62951ffa43 __clone (libc.so.6)
                                               Stack trace of thread 795:
                                               Stack trace of thread 772:
                                               #1  0x00007f628df79180 n/a (libxcb.so.1)
                                               #2  0x00007f628df7ae4b xcb_wait_for_event (libxcb.so.1)
                                               #3  0x00007f6284f5ee1a n/a (libQt5XcbQpa.so.5)
                                               #4  0x00007f62998b7005 n/a (libQt5Core.so.5)
                                               #5  0x00007f6298b81a9d start_thread (libpthread.so.0)
                                               #6  0x00007f62951ffa43 __clone (libc.so.6)
                                               #6  0x00007f6298a99ba6 n/a (libQt5DBus.so.5)
                                               #7  0x00007f62998b7005 n/a (libQt5Core.so.5)
                                               #8  0x00007f6298b81a9d start_thread (libpthread.so.0)
                                               #9  0x00007f62951ffa43 __clone (libc.so.6)
                                               #0  0x00007f6299a76b80 n/a (libQt5Core.so.5)
                                               #1  0x00007f6299a78ade n/a (libQt5Core.so.5)
                                               #2  0x00007f6299a6e904 n/a (libQt5Core.so.5)
                                               #3  0x00007f6299a9449e _ZN7QObject7connectEPKS_PKcS1_S3_>
                                               #4  0x00007f6299d3a568 n/a (libQt5Network.so.5)
                                               #5  0x00007f6299d3a153 n/a (libQt5Network.so.5)
                                               Stack trace of thread 778:
                                               Stack trace of thread 793:
                                               Stack trace of thread 782:
                                               Stack trace of thread 781:
                                               #3  0x00007f6299ab84c4 _ZN20QEventDispatcherGlib13proces>
                                               Stack trace of thread 796:
                                               #3  0x00007f6297ed1042 n/a (libglib-2.0.so.0)
                                               #4  0x00007f6297ef91ea n/a (libglib-2.0.so.0)
                                               Stack trace of thread 794:
                                               #2  0x00007f6297ed1272 g_main_loop_run (libglib-2.0.so.0)
                                               #3  0x00007f6299507e78 n/a (libgio-2.0.so.0)
Sep 03 10:35:06 leo-pckde sudo[27307]: leo4kw : a password is required ; TTY=pts/1 ; PWD=/home/leo4kw ; U>
Sep 03 10:35:06 leo-pckde sudo[27310]: leo4kw : a password is required ; TTY=pts/1 ; PWD=/home/leo4kw ; U>
Sep 03 10:35:06 leo-pckde sudo[27313]: leo4kw : a password is required ; TTY=pts/1 ; PWD=/home/leo4kw ; U>
Sep 03 10:35:06 leo-pckde sudo[27316]: leo4kw : a password is required ; TTY=pts/1 ; PWD=/home/leo4kw ; U>
lines 1047-1076/1076 (END)
[leo4kw@leo-pckde ~]$ inxi -SMGDPIxxxz
System:    Host: leo-pckde Kernel: 4.19.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.0
          Desktop: KDE Plasma 5.13.4 tk: Qt 5.11.1 wm: kwin_x11 dm: sddm Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: H110M-E D3 v: Rev X.0x serial: <filter>
          UEFI: American Megatrends v: 2604 date: 02/22/2018
Graphics:  Device-1: NVIDIA G94 [GeForce 9600 GT] vendor: Gigabyte driver: nvidia v: 340.107
          bus ID: 01:00.0 chip ID: 10de:0622
          Display: x11 server: X.Org 1.20.1 driver: nvidia compositor: kwin x11
          resolution: 1366x768~60Hz
          OpenGL: renderer: GeForce 9600 GT/PCIe/SSE2 v: 3.3.0 NVIDIA 340.107 direct render: Yes
Drives:    Local Storage: total: 1.48 TiB used: 231.75 GiB (15.3%)
          ID-1: /dev/sda vendor: Intel model: SSDSC2BW180A3L size: 167.68 GiB speed: 6.0 Gb/s
          serial: <filter> rev: LE1i scheme: GPT
          ID-2: /dev/sdb vendor: Samsung model: HD103SJ size: 931.51 GiB speed: 3.0 Gb/s
          rotation: 7200 rpm serial: <filter> rev: 00E5 scheme: MBR
          ID-3: /dev/sdc vendor: Seagate model: ST3320311CS size: 298.09 GiB speed: 3.0 Gb/s
          rotation: 5900 rpm serial: <filter> rev: SC13 scheme: MBR
          ID-4: /dev/sdd vendor: SanDisk model: SD6SB1M128G1022 size: 119.24 GiB speed: 6.0 Gb/s
          serial: <filter> rev: 600 scheme: MBR
Partition: ID-1: / size: 43.79 GiB used: 8.61 GiB (19.7%) fs: ext4 dev: /dev/sda5
          ID-2: /home size: 50.93 GiB used: 5.52 GiB (10.8%) fs: ext4 dev: /dev/sdd7
          ID-3: swap-1 size: 8.62 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdd3
Info:      Processes: 192 Uptime: 4h 58m Memory: 7.74 GiB used: 1.76 GiB (22.8%) Init: systemd v: 239
          Compilers: gcc: 8.2.0 Shell: bash v: 4.4.23 running in: konsole inxi: 3.0.21
[leo4kw@leo-pckde ~]$ systemctl --failed
0 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
I can't conclude on something helpful.
Maybe say something more about when exactly, how, which update, what widgets/conky functions. If you could say about when you did what and when this change started happening, we could compare with the error logs and pacman.log.
I think I know something....
After disable all additional widget, also disable Conky Manager on startup (settings), transition from Splash screen become smoothly as the first time boot after fresh install. Enable two addtional widget would not degrade speed of transition, still smoothly. After enable Conky Manager, transition become degrade. So, I can conclude the source of the problem is from Conky Manager which use three themes as seen below. Manjaro KDE might be too fast on loading into main desktop, then it could be conflict when loading Conky Manager themes. I set delay on CM about 10 seconds, problem is gone, then transition from Splash screen can be smooth as wishes.
DeepinScreenshot_Desktop_20180903233546
NB: It also could be the effect after upgrade to 4.19.x kernel? I'm still wondering.
Possibly not.
It makes sense conky system scanning functions create CPU extra load. That's why I mentioned that..
You may verify yourself of course and report your findings. Change kernel, remove Conky delay and reboot.
Conky Manager could be source of problem, and set delay to 10 seconds. Change kernel possibility not resolve the problem as @AgentS , but on Conky Manager.
Thanks.
....isnt conky manager just for setting up your conkys and such? ... not the thing that you actually want autostarting after every login?
Boot time on Manjaro KDE is too fast, less than 5 seconds on splash screen, then displaying common desktop. After several times, I think the source of problem came from Conky script which running on Conky-lua-nv. When I switch to Conky, transition more smoothly. I just loss on one Conky theme. I'm not sure, but I think it could be more smoothly or perfect transition animation speed.
You can't have it all!!
conky-lua has a whole programming language that creates complex graphics with HW sensors values and such!..
Finally I've got track the solution for get full transition animation from Splash screen into main desktop. Go to Settings, Startup & Shutdown, choose Desktop Session. Look at "On Login", turn from "Restore previous session" to "Start with an empty session". The problem not from Conky, nor from widget, but on startup sequence.
