kde integration for pamac
kpacman is a krunner plugin for list packages (installed or not) - not aur
One click open pamac at package page
acapture_20200415_004042
thanks to Gnome integration for pamac for idea
For the moment not in aur
PKGBUILD :
pkgname=krunner-pacman
pkgver=0.1.2
pkgrel=1
pkgdesc="list installed packages"
arch=('any')
license=('GPL')
depends=('krunner' 'pyalpm')
optdepends=('pamac: A Gtk3 frontend for libalpm')
source=("https://github.com/papajoker/krunner-pacman/archive/v0.1.2.tar.gz")
sha512sums=('SKIP')
package() {
  cd "${srcdir}/${pkgname}-${pkgver}"
  install -d ${pkgdir}/usr/{share/{kservices5,dbus-1/services},lib/qt/plugins}
  cp resources/net.kpacman2.service ${pkgdir}/usr/share/dbus-1/services/
  cp resources/plasma-runner-kpacman.desktop ${pkgdir}/usr/share/kservices5/
  install -m755 plugin/krunner_pacman.py ${pkgdir}/usr/lib/qt/plugins/krunner_pacman.py
After install, run this command for load plugin
kquitapp5 krunner
The title says it's KDE integreation for Pamac. Therefore, shouldn't the project be called
kpamac? :thinking:
@philm I think this would be good for the coming kde edition release
@Yochanan
Right now it's a mock-up, it uses alpm and not pamac(optional). If pamac not installed, action go to package url
@Chrysostomus
with plasma we have krunner appstream plugin but load discover (not found source code, only this ! )...
For best integration, if @guinux like, the best is to write this plugin in pamac ? code is simple : 2 dbus functions
Pamac 9.5 will support appstream links so we could start testing
yes, but here this plugin is not as appstream
appstream display only apps for install, here we have a pacman -Ss , therefore more technical and completely package and not only for install as appstream
acapture_krun21
Then make it only use libpamac and we can simply add it into pamac code.
new version 0.1.1 krunner-pamac
thanks to @guinux for precious help
exists a pkgbuild test :
wget https://gitlab.manjaro.org/papajoke/krunner-pamac/-/raw/master/resources/PKGBUILD
makepkg -sfci
news:
  • use pamac for search
  • 2 options in ~/.config/krunnerrc
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
