Hi there! I recently received my new XPS 9570 and decided to try out Manjaro (used Ubuntu 16.04 before). However, I have run into trouble with the installation.
The steps I took:
I used etcher to create burn the manjaro-kde-17.1.11-stable-x86_64 onto a USB (I checked the ISO file with sha1).
Went to BIOS and set UEFI mode, disabled secure boot and set AHCI instead of RAID as suggested in the guide for XPS 9560: https://gist.github.com/MeirBon/c99ae4e9e40f7e542361f646e4f637f5
Then, I got into the boot menu for Manjaro, set drivers to nonfree and went into kernel parameters by pressing 'e' and tried first the configurations from the aforementioned guide and afterwards various combinations from this thread: forum.manjaro .org/t/dell-xps-15-9570-help/51283 (wont let me post more than 2 links when i submit post)
For example, I tried setting acpi_rev_override=1 nouveau.modeset=0 and also just nouveau.modeset=0 which seemed to be the takeaway from the thread above. However, I always seem to get stuck at 'Started TLP system startup/shutdown.'! The following screenshot is after I had all the parameters mentioned in the guide on github together with the parameters acpi_rev_override=1 nouveau.modeset=0
I am running out of ideas, and I would be very grateful if anyone could guide me in the right direction!
