KDE Plasma freeze when I use Screen Edges (KWin hang regression)
Hello guys,
So, I am experiencing Plasma freeze (sometimes cursor freezes, sometimes don't) when I put some window on a Screen Edge (left, right or top one) to resize it. That happens it's been a while. I don't know when this started to happen. I already tried remove PRIME and install Optimus Manager, but that doesn't solved the problem.
The system unfreezes after some time.
Some useful outputs:
$ inxi -Fxxxz
System:    Host: Gh05t Kernel: 5.1.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.15.5 tk: Qt 5.12.3
           wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 81FE v: Lenovo ideapad 330-15IKB serial: <filter> Chassis: type: 10
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40679 WIN serial: <filter> UEFI: LENOVO v: 8TCN51WW date: 12/08/2018
Battery:   ID-1: BAT0 charge: 26.9 Wh condition: 27.6/30.0 Wh (92%) volts: 8.5/7.5 model: SMP L16M2PB1 type: Li-poly
           serial: <filter> status: Unknown
CPU:       Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
           Speed: 2657 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 2657 2: 2047 3: 1886 4: 1931 5: 1536 6: 2865 7: 2817
           8: 2033
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
           Device-2: NVIDIA GP108M [GeForce MX150] vendor: Lenovo driver: nvidia v: 418.74 bus ID: 01:00.0 chip ID: 10de:1d10
           Display: x11 server: X.Org 1.20.4 driver: modesetting,nvidia compositor: kwin_x11 resolution: 1366x768~60Hz
           OpenGL: renderer: GeForce MX150/PCIe/SSE2 v: 4.6.0 NVIDIA 418.74 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:9d71
           Sound Server: ALSA v: k5.1.1-2-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8168 v: 8.047.01-NAPI
           port: 3000 bus ID: 02:00.0 chip ID: 10ec:8168
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo driver: ath10k_pci v: kernel
           port: 3000 bus ID: 03:00.0 chip ID: 168c:0042
           Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-7:4 chip ID: 0cf3:e500
Drives:    Local Storage: total: 1.13 TiB used: 278.85 GiB (24.1%)
           ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB speed: 6.0 Gb/s serial: <filter> rev: 61K1
           scheme: GPT
           ID-2: /dev/sdb vendor: Western Digital model: WD10SPZX-24Z10T0 size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm
           serial: <filter> rev: 1A01 scheme: GPT
Partition: ID-1: / size: 25.00 GiB used: 22.73 GiB (90.9%) fs: f2fs dev: /dev/sda5
           ID-2: /home size: 134.57 GiB used: 100.28 GiB (74.5%) fs: f2fs dev: /dev/sda6
           ID-3: swap-1 size: 4.00 GiB used: 1024 KiB (0.0%) fs: swap dev: /dev/sda7
Sensors:   System Temperatures: cpu: 53.5 C mobo: N/A gpu: nvidia temp: 47 C
Info:      Processes: 236 Uptime: 25m Memory: 7.70 GiB used: 3.05 GiB (39.6%) Init: systemd v: 242 Compilers: gcc: 8.3.0
           Shell: zsh v: 5.7.1 running in: yakuake inxi: 3.0.
$ cat /etc/X11/xorg.conf.d/optimus.conf
Section "Module"
    Load "modesetting"
EndSection
Section "Device"
    Identifier  "nvidia"
    Driver      "nvidia"
    BusID       "PCI:1:0:0"
    Option      "AllowEmptyInitialConfiguration"
    Option      "DPI" "96x96"
    Option      "metamodes" "nvidia-auto-select +0+0 {ForceFullCompositionPipeline=On}"
    Option      "AllowIndirectGLXProtocol" "off"
    Option      "TripleBuffer" "on"
EndSection
Hello,
Your Laptop has a new BIOS update, might want to start there.
I see you have a SWAP partition on the SSD. In many instances is better to use a swapfile, have a look at that. Also check entropy and maybe enable haveged.
Is this freeze present in LTS kernels too?
Even tho this link is from a desktop related post, the logic somehow applies. See also the schedulers part:
I would suggest clearing cache for plasma elements and try the Archwiki-plasma suggestions for that.
1 - I have updated the BIOS;
2 - I deleted the SWAP partition and add the ZRAM using this;
3 - My entropy ($ cat /proc/sys/kernel/random/entropy_avail) is 3946. Do I still need to enable haveged?
4 - Yes, the freeze is present in LTS kernel (4.19.45-1-MANJARO, at least);
5 - I have add this schedulers to /etc/udev/rules.d/60-schedulers.rules, but nothing happened.
I tried this but without success.
I suggest yes. It's a frequently reported issue, so it doesn't hurt to be on the safe side.
Make some free space (again, to be sure).
Have you deleted the cache folder?
For freezes, there should be some evidence in the logs
journalctl -p3 --no-pager --no-hostname
cat /var/log/Xorg.0.log
ok. Let's go... I have reinstalled the system with free drivers and haven't noticed freezing any more.. However, after install PRIME the freezing has begin again. Now my root partition is bigger (Partition: ID-1: / size: 40.00 GiB used: 11.51 GiB (28.8%) fs: f2fs dev: /dev/sda6).
Yes, I have deleted the cache folder before reinstall the system and I got no solution. Here are the commands outputs:
journalctl -p3 --no-pager --no-hostname;
So, it is obviously some mistake on the way you applied PRIME.
Don't you agree?
Maybe @dglt can guess better what is wrong and @bogdancovaciu can "translate" journal errors on plasma and sddm.
You need to review again the tutorial and how you implemented it.
Check your conf files
inxi -SMGxxz
pacman -Qs nvidia
mhwd -li
xrandr
cat /etc/X11/xorg.conf.d/*.conf
cat /etc/modules-load.d/*.conf
cat /etc/modprobe.d/*.conf
journalctl -b -p3
I don't know... I already read the HowTo one hundred times.
inxi -SMGxxz
System:    Host: gh05t Kernel: 4.19.45-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.15.5
           tk: Qt 5.12.3 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40679 WIN serial: <filter> UEFI: LENOVO v: 8TCN52WW date: 04/22/2019
 $ pacman -Qs nvidia
local/lib32-nvidia-cg-toolkit 3.1-7
    NVIDIA Cg libraries
local/lib32-nvidia-utils 1:418.74-1
    NVIDIA drivers utilities (32-bit)
local/lib32-opencl-nvidia 1:418.74-1
    OpenCL implemention for NVIDIA (32-bit)
local/libvdpau 1.2-1
    Nvidia VDPAU library
local/linux419-nvidia 1:418.74-5 (linux419-extramodules)
    NVIDIA drivers for linux.
local/mhwd-nvidia 1:418.74-1
    MHWD module-ids for nvidia 418.74
local/mhwd-nvidia-340xx 340.107-1
    MHWD module-ids for nvidia 340.107
local/mhwd-nvidia-390xx 390.116-1
    MHWD module-ids for nvidia 390.116
local/nvidia-cg-toolkit 3.1-5
    NVIDIA Cg libraries
local/nvidia-utils 1:418.74-1
local/opencl-nvidia 1:418.74-1
$ mhwd -li
> Installed PCI configs:
         network-r8168            2016.04.20                true            PCI
          video-nvidia            2018.08.09               false            PCI
$ xrandr
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 32767 x 32767
eDP-1-1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768      60.00*+
   1280x720      60.00    59.99    59.86    59.74
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   960x540       59.96    59.99    59.63    59.82
   800x600       60.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   640x400       59.88    59.98
   640x360       59.86    59.83    59.84    59.32
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
$ cat /etc/X11/xorg.conf.d/*.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "br"
        Option "XkbModel" "pc105"
EndSection
Section "Module"
    Load "modesetting"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:1:0.0"
EndSection
$ cat /etc/modules-load.d/*.conf
## Generated by mhwd - Manjaro Hardware Detection
nvidia
nvidia-drm
# List of modules to load at boot
$ cat /etc/modprobe.d/*.conf
blacklist nouveau
blacklist nvidiafb
blacklist rivafb
options nvidia_drm modeset=1
blacklist r8169
$ journalctl -b -p3
-- Logs begin at Sun 2019-05-26 12:17:28 -03, end at Sun 2019-05-26 20:56:18 -03. --
-- No entries --
you shouldnt need this, and hurts performance. though it's also not your freezing problem, just thought i would mention it.
i see your using the 5.1 kernel, and you mentioned trying 4.19 with same result?
5.1 for me either wont boot to a graphical desktop and/or locks up. have you tried 5.0 ?
your logs have a lot of nouveau errors, nouveau is supposed to be blacklisted during a prime setup.
mai 26 12:17:31 kernel: nouveau 0000:01:00.0: DRM: Pointer to TMDS table invalid
mai 26 12:17:33 kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ TIMEOUT ]
mai 26 12:17:35 kernel: nouveau 0000:01:00.0: gr: init failed, -16
mai 26 19:18:57 kernel: nouveau 0000:01:00.0: DRM: failed to idle channel 1 [DRM]
mai 26 19:21:29 kernel: [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=13598 end=13599) time 256 us, min 763, max 767, scanline start 757, end 769
mai 26 19:21:48 kernel: [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=14770 end=14771) time 261 us, min 763, max 767, scanline start 758, end 7
did you run the cleanup script before uninstalling optimus-manager? (this is important)
did you install any video drivers from anywhere other than mhwd ?
also, have you tried using alternative composting options?
I remove it.
I tried with 4.19.x-LTS, 5.0.x and 5.1.x. Same results.
Yes, I did.
No, I never do that.
I already tried OpeGL 2.0 and 3.0. No result.
As I said above, I reinstalled the system and after install PRIME, the freeze begin again. Doesn't happen with free drivers.
post output:
cat /etc/default/grub | grep CMDLINE
cat /var/log/Xorg.0.log | grep -E "(EE)|(WW)|error|failed|Time|i915|nouveau|"
$ cat /etc/default/grub | grep CMDLINE
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
GRUB_CMDLINE_LINUX=""
$ cat /var/log/Xorg.0.log | grep -E "(EE)|(WW)|error|failed|Time|i915|nouveau|"
[     6.415] (--) Log file renamed from "/var/log/Xorg.pid-699.log" to "/var/log/Xorg.0.log"
[     6.417]
X.Org X Server 1.20.4
[     6.417] Build Operating System: Linux Arch Linux
[     6.417] Current Operating System: Linux gh05t 4.19.45-1-MANJARO #1 SMP PREEMPT Wed May 22 17:16:41 UTC 2019 x86_64
[     6.417] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=110e259a-45ca-46b0-815f-2ecdf7b23c04 rw quiet
[     6.417] Build Date: 27 February 2019  04:04:00PM
[     6.417]
[     6.417] Current version of pixman: 0.38.4
[     6.417]    Before reporting problems, check http://wiki.x.org
[     6.417] Markers: (--) probed, (**) from config file, (==) default setting,
[     6.417] (==) Log file: "/var/log/Xorg.0.log", Time: Sun May 26 21:21:12 2019
[     6.418] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     6.418] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     6.418] (==) No Layout section.  Using the first Screen section.
[     6.418] (==) No screen section available. Using defaults.
[     6.418] (**) |-->Screen "Default Screen Section" (0)
[     6.418] (**) |   |-->Monitor "<default monitor>"
[     6.419] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[     6.419] (**) |   |-->Device "nvidia"
[     6.419] (==) No monitor specified for screen "Default Screen Section".
[     6.419] (==) Automatically adding devices
[     6.419] (==) Automatically enabling devices
[     6.419] (==) Automatically adding GPU devices
[     6.419] (==) Automatically binding GPU devices
[     6.419] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     6.420] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     6.420]    Entry deleted from font path.
[     6.420] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     6.420] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     6.420]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     6.420] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     6.420]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     6.420] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[     6.420] (==) ModulePath set to "/usr/lib/xorg/modules"
[     6.420] (II) The server relies on udev to provide the list of input devices.
[     6.420] (II) Module ABI versions:
[     6.420]    X.Org ANSI C Emulation: 0.4
[     6.420]    X.Org Video Driver: 24.0
[     6.420]    X.Org XInput driver : 24.1
[     6.420]    X.Org Server Extension : 10.0
[     6.421] (++) using VT number 1
[     6.421] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     6.421] (II) xfree86: Adding drm device (/dev/dri/card1)
[     6.436] (II) xfree86: Adding drm device (/dev/dri/card0)
[     6.436] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     6.436] (**) OutputClass "nvidia" setting /dev/dri/card0 as PrimaryGPU
[     6.437] (--) PCI: (0@0:2:0) 8086:5917:17aa:3963 rev 7, Mem @ 0xa2000000/16777216, 0xb0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[     6.437] (--) PCI:*(1@0:0:0) 10de:1d10:17aa:3963 rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128
[     6.437] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     6.437] (II) "glx" will be loaded by default.
[     6.437] (II) LoadModule: "modesetting"
[     6.440] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     6.443] (II) Module modesetting: vendor="X.Org Foundation"
[     6.443]    compiled for 1.20.4, module version = 1.20.4
[     6.443]    Module class: X.Org Video Driver
[     6.443]    ABI class: X.Org Video Driver, version 24.0
[     6.443] (II) LoadModule: "glx"
[     6.443] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[     6.500] (II) Module glx: vendor="NVIDIA Corporation"
[     6.500]    compiled for 4.0.2, module version = 1.0.0
[     6.500]    Module class: X.Org Server Extension
[     6.501] (II) NVIDIA GLX Module  418.74  Wed May  1 11:24:49 CDT 2019
[     6.501] (II) LoadModule: "nvidia"
[     6.501] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     6.507] (II) Module nvidia: vendor="NVIDIA Corporation"
[     6.507]    compiled for 4.0.2, module version = 1.0.0
[     6.507]    Module class: X.Org Video Driver
[     6.508] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     6.509] (II) NVIDIA dlloader X Driver  418.74  Wed May  1 11:26:02 CDT 2019
[     6.509] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     6.509] (WW) Falling back to old probe method for modesetting
[     6.510] (II) Loading sub module "fb"
[     6.510] (II) LoadModule: "fb"
[     6.510] (II) Loading /usr/lib/xorg/modules/libfb.so
[     6.512] (II) Module fb: vendor="X.Org Foundation"
[     6.512]    compiled for 1.20.4, module version = 1.0.0
[     6.512]    ABI class: X.Org ANSI C Emulation, version 0.4
[     6.512] (II) Loading sub module "wfb"
[     6.512] (II) LoadModule: "wfb"
[     6.512] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     6.513] (II) Module wfb: vendor="X.Org Foundation"
[     6.513]    compiled for 1.20.4, module version = 1.0.0
[     6.513]    ABI class: X.Org ANSI C Emulation, version 0.4
[     6.513] (II) Loading sub module "ramdac"
[     6.513] (II) LoadModule: "ramdac"
[     6.513] (II) Module "ramdac" already built-in
[     6.519] (II) modeset(G0): using drv /dev/dri/card1
[     6.519] (II) NVIDIA(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[     6.519] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[     6.519] (==) NVIDIA(0): RGB weight 888
[     6.519] (==) NVIDIA(0): Default visual is TrueColor
[     6.519] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     6.519] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     6.519] (**) NVIDIA(0): Option "DPI" "96x96"
[     6.519] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     6.520] (**) NVIDIA(0): Enabling 2D acceleration
[     6.539] (II) NVIDIA(0): NVIDIA GPU GeForce MX150 (GP108-A) at PCI:1:0:0 (GPU-0)
[     6.539] (--) NVIDIA(0): Memory: 2097152 kBytes
[     6.539] (--) NVIDIA(0): VideoBIOS: 86.08.28.00.42
[     6.539] (II) NVIDIA(0): Detected PCI Express Link width: 4X
[     6.539] (II) NVIDIA(0): Validated MetaModes:
[     6.539] (II) NVIDIA(0):     "NULL"
[     6.539] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[     6.539] (**) NVIDIA(0): DPI set to (96, 96); computed from "DPI" X config option
[     6.539] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[     6.539] (==) modeset(G0): RGB weight 888
[     6.539] (==) modeset(G0): Default visual is TrueColor
[     6.539] (II) Loading sub module "glamoregl"
[     6.539] (II) LoadModule: "glamoregl"
[     6.539] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     6.547] (II) Module glamoregl: vendor="X.Org Foundation"
[     6.547]    compiled for 1.20.4, module version = 1.0.1
[     6.547]    ABI class: X.Org ANSI C Emulation, version 0.4
[     6.626] (II) modeset(G0): glamor X acceleration enabled on Mesa DRI Intel(R) UHD Graphics 620 (Kabylake GT2)
[     6.626] (II) modeset(G0): glamor initialized
[     6.628] (II) modeset(G0): Output eDP-1-1 has no monitor section
[     6.631] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[     6.633] (II) modeset(G0): EDID for output eDP-1-1
[     6.633] (II) modeset(G0): Manufacturer: CMN  Model: 15db  Serial#: 0
[     6.633] (II) modeset(G0): Year: 2015  Week: 45
[     6.633] (II) modeset(G0): EDID Version: 1.4
[     6.633] (II) modeset(G0): Digital Display Input
[     6.633] (II) modeset(G0): 6 bits per channel
[     6.633] (II) modeset(G0): Digital interface is DisplayPort
[     6.633] (II) modeset(G0): Max Image Size [cm]: horiz.: 34  vert.: 19
[     6.633] (II) modeset(G0): Gamma: 2.20
[     6.633] (II) modeset(G0): No DPMS capabilities specified
[     6.633] (II) modeset(G0): Supported color encodings: RGB 4:4:4
[     6.633] (II) modeset(G0): First detailed timing is preferred mode
[     6.633] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[     6.633] (II) modeset(G0): redX: 0.569 redY: 0.332   greenX: 0.328 greenY: 0.581
[     6.633] (II) modeset(G0): blueX: 0.163 blueY: 0.147   whiteX: 0.313 whiteY: 0.329
[     6.633] (II) modeset(G0): Manufacturer's mask: 0
[     6.633] (II) modeset(G0): Supported detailed timing:
[     6.633] (II) modeset(G0): clock: 76.4 MHz   Image Size:  344 x 193 mm
[     6.633] (II) modeset(G0): h_active: 1366  h_sync: 1434  h_sync_end 1479 h_blank_end 1592 h_border: 0
[     6.633] (II) modeset(G0): v_active: 768  v_sync: 772  v_sync_end 779 v_blanking: 800 v_border: 0
[     6.633] (II) modeset(G0):  N156BGA-EA2
[     6.633] (II) modeset(G0):  CMN
[     6.633] (II) modeset(G0): EDID (in hex):
[     6.633] (II) modeset(G0):  00ffffffffffff000daedb1500000000
[     6.633] (II) modeset(G0):  2d1901049522137802c3f59155549429
[     6.633] (II) modeset(G0):  25505400000001010101010101010101
[     6.633] (II) modeset(G0):  010101010101da1d56e250002030442d
[     6.633] (II) modeset(G0):  470058c110000018000000fe004e3135
[     6.633] (II) modeset(G0):  364247412d4541320a20000000fe0043
[     6.633] (II) modeset(G0):  4d4e0a202020202020202020000000fe
[     6.633] (II) modeset(G0):  004e3135364247412d4541320a2000f4
[     6.633] (II) modeset(G0): Printing probed modes for output eDP-1-1
[     6.633] (II) modeset(G0): Modeline "1366x768"x60.0   76.42  1366 1434 1479 1592  768 772 779 800 -hsync -vsync (48.0 kHz eP)
[     6.633] (II) modeset(G0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[     6.633] (II) modeset(G0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[     6.633] (II) modeset(G0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[     6.633] (II) modeset(G0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[     6.633] (II) modeset(G0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[     6.633] (II) modeset(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[     6.633] (II) modeset(G0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[     6.633] (II) modeset(G0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[     6.633] (II) modeset(G0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[     6.633] (II) modeset(G0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[     6.633] (II) modeset(G0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[     6.633] (II) modeset(G0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[     6.633] (II) modeset(G0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[     6.633] (II) modeset(G0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[     6.633] (II) modeset(G0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[     6.633] (II) modeset(G0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[     6.633] (II) modeset(G0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[     6.633] (II) modeset(G0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[     6.634] (II) modeset(G0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[     6.634] (II) modeset(G0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[     6.634] (II) modeset(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[     6.634] (II) modeset(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[     6.634] (II) modeset(G0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[     6.634] (II) modeset(G0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[     6.634] (II) modeset(G0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[     6.634] (II) modeset(G0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[     6.634] (II) modeset(G0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[     6.634] (II) modeset(G0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[     6.634] (II) modeset(G0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[     6.634] (II) modeset(G0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[     6.634] (II) modeset(G0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[     6.634] (II) modeset(G0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[     6.634] (II) modeset(G0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[     6.634] (II) modeset(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[     6.634] (II) modeset(G0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[     6.634] (II) modeset(G0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[     6.634] (II) modeset(G0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[     6.634] (II) modeset(G0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[     6.634] (II) modeset(G0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[     6.634] (II) modeset(G0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[     6.634] (II) modeset(G0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[     6.634] (II) modeset(G0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[     6.634] (II) modeset(G0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[     6.634] (II) modeset(G0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[     6.634] (II) modeset(G0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[     6.634] (II) modeset(G0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[     6.634] (II) modeset(G0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[     6.634] (II) modeset(G0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[     6.634] (II) modeset(G0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[     6.634] (II) modeset(G0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[     6.634] (II) modeset(G0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[     6.634] (II) modeset(G0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[     6.634] (II) modeset(G0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[     6.634] (II) modeset(G0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[     6.634] (II) modeset(G0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[     6.634] (II) modeset(G0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[     6.634] (II) modeset(G0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[     6.634] (II) modeset(G0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[     6.638] (II) modeset(G0): EDID for output HDMI-1-1
[     6.638] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[     6.638] (==) modeset(G0): DPI set to (96, 96)
[     6.638] (II) Loading sub module "fb"
[     6.638] (II) LoadModule: "fb"
[     6.638] (II) Loading /usr/lib/xorg/modules/libfb.so
[     6.638] (II) Module fb: vendor="X.Org Foundation"
[     6.638]    compiled for 1.20.4, module version = 1.0.0
[     6.638]    ABI class: X.Org ANSI C Emulation, version 0.4
[     6.646] (==) modeset(G0): Backing store enabled
[     6.646] (==) modeset(G0): Silken mouse disabled
[     6.686] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[     6.686] (==) modeset(G0): DPMS enabled
[     6.686] (II) modeset(G0): [DRI2] Setup complete
[     6.686] (II) modeset(G0): [DRI2]   DRI driver: i965
[     6.686] (II) modeset(G0): [DRI2]   VDPAU driver: i965
[     6.687] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[     6.687] (II) NVIDIA:     access.
[     6.692] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     6.692] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[     6.692] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[     6.692] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[     6.692] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[     6.692] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[     6.692] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     6.692] (II) NVIDIA(0):     Config Options in the README.
[     6.712] (II) NVIDIA(0): Setting mode "NULL"
[     6.717] (==) NVIDIA(0): Disabling shared memory pixmaps
[     6.717] (==) NVIDIA(0): Backing store enabled
[     6.717] (==) NVIDIA(0): Silken mouse disabled
[     6.717] (==) NVIDIA(0): DPMS enabled
[     6.718] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[     6.718] (II) Loading sub module "dri2"
[     6.718] (II) LoadModule: "dri2"
[     6.718] (II) Module "dri2" already built-in
[     6.718] (II) NVIDIA(0): [DRI2] Setup complete
[     6.718] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     6.718] (II) Initializing extension Generic Event Extension
[     6.718] (II) Initializing extension SHAPE
[     6.718] (II) Initializing extension MIT-SHM
[     6.718] (II) Initializing extension XInputExtension
[     6.718] (II) Initializing extension XTEST
[     6.718] (II) Initializing extension BIG-REQUESTS
[     6.718] (II) Initializing extension SYNC
[     6.719] (II) Initializing extension XKEYBOARD
[     6.719] (II) Initializing extension XC-MISC
[     6.719] (II) Initializing extension SECURITY
[     6.719] (II) Initializing extension XFIXES
[     6.719] (II) Initializing extension RENDER
[     6.719] (II) Initializing extension RANDR
[     6.719] (II) Initializing extension COMPOSITE
[     6.719] (II) Initializing extension DAMAGE
[     6.719] (II) Initializing extension MIT-SCREEN-SAVER
[     6.719] (II) Initializing extension DOUBLE-BUFFER
[     6.719] (II) Initializing extension RECORD
[     6.719] (II) Initializing extension DPMS
[     6.720] (II) Initializing extension Present
[     6.720] (II) Initializing extension DRI3
[     6.720] (II) Initializing extension X-Resource
[     6.720] (II) Initializing extension XVideo
[     6.720] (II) Initializing extension XVideo-MotionCompensation
[     6.720] (II) Initializing extension GLX
[     6.720] (II) Indirect GLX disabled.
[     6.720] (II) Initializing extension XFree86-VidModeExtension
[     6.720] (II) Initializing extension XFree86-DGA
[     6.720] (II) Initializing extension XFree86-DRI
[     6.720] (II) Initializing extension DRI2
[     6.720] (II) Initializing extension NV-GLX
[     6.720] (II) Initializing extension NV-CONTROL
[     7.013] (II) modeset(G0): Damage tracking initialized
[     7.079] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[     7.079] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     7.079] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     7.079] (**) Video Bus: Applying InputClass "system-keyboard"
[     7.079] (II) LoadModule: "libinput"
[     7.079] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     7.084] (II) Module libinput: vendor="X.Org Foundation"
[     7.084]    compiled for 1.20.3, module version = 0.28.2
[     7.084]    Module class: X.Org XInput Driver
[     7.084]    ABI class: X.Org XInput driver, version 24.1
[     7.084] (II) Using input driver 'libinput' for 'Video Bus'
[     7.084] (**) Video Bus: always reports core events
[     7.084] (**) Option "Device" "/dev/input/event11"
[     7.084] (**) Option "_source" "server/udev"
[     7.086] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[     7.086] (II) event11 - Video Bus: device is a keyboard
[     7.086] (II) event11 - Video Bus: device removed
[     7.170] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13/event11"
[     7.170] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[     7.170] (**) Option "xkb_model" "pc105"
[     7.170] (**) Option "xkb_layout" "br"
[     7.186] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[     7.186] (II) event11 - Video Bus: device is a keyboard
[     7.187] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[     7.187] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     7.187] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     7.187] (**) Video Bus: Applying InputClass "system-keyboard"
[     7.187] (II) Using input driver 'libinput' for 'Video Bus'
[     7.187] (**) Video Bus: always reports core events
[     7.187] (**) Option "Device" "/dev/input/event12"
[     7.187] (**) Option "_source" "server/udev"
[     7.187] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[     7.187] (II) event12 - Video Bus: device is a keyboard
[     7.187] (II) event12 - Video Bus: device removed
[     7.277] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:33/LNXVIDEO:01/input/input14/event12"
[     7.277] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     7.277] (**) Option "xkb_model" "pc105"
[     7.277] (**) Option "xkb_layout" "br"
[     7.277] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[     7.277] (II) event12 - Video Bus: device is a keyboard
[     7.278] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     7.278] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     7.278] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     7.278] (**) Power Button: Applying InputClass "system-keyboard"
[     7.278] (II) Using input driver 'libinput' for 'Power Button'
[     7.278] (**) Power Button: always reports core events
[     7.278] (**) Option "Device" "/dev/input/event1"
[     7.278] (**) Option "_source" "server/udev"
[     7.278] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     7.278] (II) event1  - Power Button: device is a keyboard
[     7.278] (II) event1  - Power Button: device removed
[     7.300] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     7.300] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[     7.300] (**) Option "xkb_model" "pc105"
[     7.300] (**) Option "xkb_layout" "br"
[     7.301] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     7.301] (II) event1  - Power Button: device is a keyboard
[     7.301] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[     7.301] (II) No input driver specified, ignoring this device.
[     7.301] (II) This device may have been added with another device file.
[     7.302] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event3)
[     7.302] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[     7.302] (**) USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[     7.302] (II) Using input driver 'libinput' for 'USB Optical Mouse'
[     7.302] (**) USB Optical Mouse: always reports core events
[     7.302] (**) Option "Device" "/dev/input/event3"
[     7.302] (**) Option "_source" "server/udev"
[     7.357] (II) event3  - USB Optical Mouse: is tagged by udev as: Mouse
[     7.357] (II) event3  - USB Optical Mouse: device is a pointer
[     7.357] (II) event3  - USB Optical Mouse: device removed
[     7.417] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1BCF:0005.0001/input/input3/event3"
[     7.417] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 9)
[     7.417] (**) Option "AccelerationScheme" "none"
[     7.417] (**) USB Optical Mouse: (accel) selected scheme none/0
[     7.417] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[     7.417] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[     7.474] (II) event3  - USB Optical Mouse: is tagged by udev as: Mouse
[     7.474] (II) event3  - USB Optical Mouse: device is a pointer
[     7.475] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[     7.475] (II) No input driver specified, ignoring this device.
[     7.475] (II) This device may have been added with another device file.
[     7.475] (II) config/udev: Adding input device USB USB Keyboard (/dev/input/event4)
[     7.475] (**) USB USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     7.475] (**) USB USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     7.475] (**) USB USB Keyboard: Applying InputClass "system-keyboard"
[     7.475] (II) Using input driver 'libinput' for 'USB USB Keyboard'
[     7.475] (**) USB USB Keyboard: always reports core events
[     7.475] (**) Option "Device" "/dev/input/event4"
[     7.475] (**) Option "_source" "server/udev"
[     7.476] (II) event4  - USB USB Keyboard: is tagged by udev as: Keyboard
[     7.476] (II) event4  - USB USB Keyboard: device is a keyboard
[     7.476] (II) event4  - USB USB Keyboard: device removed
[     7.507] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:1A2C:2D23.0002/input/input4/event4"
[     7.507] (II) XINPUT: Adding extended input device "USB USB Keyboard" (type: KEYBOARD, id 10)
[     7.507] (**) Option "xkb_model" "pc105"
[     7.507] (**) Option "xkb_layout" "br"
[     7.509] (II) event4  - USB USB Keyboard: is tagged by udev as: Keyboard
[     7.509] (II) event4  - USB USB Keyboard: device is a keyboard
[     7.509] (II) config/udev: Adding input device USB USB Keyboard Consumer Control (/dev/input/event5)
[     7.509] (**) USB USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     7.509] (**) USB USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     7.509] (**) USB USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     7.509] (II) Using input driver 'libinput' for 'USB USB Keyboard Consumer Control'
[     7.509] (**) USB USB Keyboard Consumer Control: always reports core events
[     7.509] (**) Option "Device" "/dev/input/event5"
[     7.509] (**) Option "_source" "server/udev"
[     7.510] (II) event5  - USB USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     7.510] (II) event5  - USB USB Keyboard Consumer Control: device is a keyboard
[     7.510] (II) event5  - USB USB Keyboard Consumer Control: device removed
[     7.524] (II) libinput: USB USB Keyboard Consumer Control: needs a virtual subdevice
[     7.524] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:1A2C:2D23.0003/input/input5/event5"
[     7.524] (II) XINPUT: Adding extended input device "USB USB Keyboard Consumer Control" (type: MOUSE, id 11)
[     7.524] (**) Option "AccelerationScheme" "none"
[     7.524] (**) USB USB Keyboard Consumer Control: (accel) selected scheme none/0
[     7.524] (**) USB USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[     7.524] (**) USB USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[     7.525] (II) event5  - USB USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     7.525] (II) event5  - USB USB Keyboard Consumer Control: device is a keyboard
[     7.526] (II) config/udev: Adding input device USB USB Keyboard System Control (/dev/input/event6)
[     7.526] (**) USB USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[     7.526] (**) USB USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[     7.526] (**) USB USB Keyboard System Control: Applying InputClass "system-keyboard"
[     7.526] (II) Using input driver 'libinput' for 'USB USB Keyboard System Control'
[     7.526] (**) USB USB Keyboard System Control: always reports core events
[     7.526] (**) Option "Device" "/dev/input/event6"
[     7.526] (**) Option "_source" "server/udev"
[     7.527] (II) event6  - USB USB Keyboard System Control: is tagged by udev as: Keyboard
[     7.527] (II) event6  - USB USB Keyboard System Control: device is a keyboard
[     7.527] (II) event6  - USB USB Keyboard System Control: device removed
[     7.557] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:1A2C:2D23.0003/input/input6/event6"
[     7.557] (II) XINPUT: Adding extended input device "USB USB Keyboard System Control" (type: KEYBOARD, id 12)
[     7.557] (**) Option "xkb_model" "pc105"
[     7.557] (**) Option "xkb_layout" "br"
[     7.560] (II) event6  - USB USB Keyboard System Control: is tagged by udev as: Keyboard
[     7.560] (II) event6  - USB USB Keyboard System Control: device is a keyboard
[     7.562] (II) config/udev: Adding input device EasyCamera: EasyCamera (/dev/input/event10)
[     7.562] (**) EasyCamera: EasyCamera: Applying InputClass "evdev keyboard catchall"
[     7.562] (**) EasyCamera: EasyCamera: Applying InputClass "libinput keyboard catchall"
[     7.562] (**) EasyCamera: EasyCamera: Applying InputClass "system-keyboard"
[     7.562] (II) Using input driver 'libinput' for 'EasyCamera: EasyCamera'
[     7.562] (**) EasyCamera: EasyCamera: always reports core events
[     7.562] (**) Option "Device" "/dev/input/event10"
[     7.562] (**) Option "_source" "server/udev"
[     7.563] (II) event10 - EasyCamera: EasyCamera: is tagged by udev as: Keyboard
[     7.563] (II) event10 - EasyCamera: EasyCamera: device is a keyboard
[     7.563] (II) event10 - EasyCamera: EasyCamera: device removed
[     7.613] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/input/input11/event10"
[     7.613] (II) XINPUT: Adding extended input device "EasyCamera: EasyCamera" (type: KEYBOARD, id 13)
[     7.613] (**) Option "xkb_model" "pc105"
[     7.613] (**) Option "xkb_layout" "br"
[     7.616] (II) event10 - EasyCamera: EasyCamera: is tagged by udev as: Keyboard
[     7.616] (II) event10 - EasyCamera: EasyCamera: device is a keyboard
[     7.618] (II) config/udev: Adding input device Synaptics TM3336-001 (/dev/input/event9)
[     7.618] (**) Synaptics TM3336-001: Applying InputClass "evdev touchpad catchall"
[     7.618] (**) Synaptics TM3336-001: Applying InputClass "libinput touchpad catchall"
[     7.618] (II) Using input driver 'libinput' for 'Synaptics TM3336-001'
[     7.618] (**) Synaptics TM3336-001: always reports core events
[     7.618] (**) Option "Device" "/dev/input/event9"
[     7.618] (**) Option "_source" "server/udev"
[     7.621] (II) event9  - Synaptics TM3336-001: is tagged by udev as: Touchpad
[     7.632] (II) event9  - Synaptics TM3336-001: device is a touchpad
[     7.632] (II) event9  - Synaptics TM3336-001: device removed
[     7.678] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-SYNA2B49:00/0018:06CB:8251.0004/input/input12/event9"
[     7.678] (II) XINPUT: Adding extended input device "Synaptics TM3336-001" (type: TOUCHPAD, id 14)
[     7.680] (**) Option "AccelerationScheme" "none"
[     7.680] (**) Synaptics TM3336-001: (accel) selected scheme none/0
[     7.680] (**) Synaptics TM3336-001: (accel) acceleration factor: 2.000
[     7.680] (**) Synaptics TM3336-001: (accel) acceleration threshold: 4
[     7.684] (II) event9  - Synaptics TM3336-001: is tagged by udev as: Touchpad
[     7.706] (II) event9  - Synaptics TM3336-001: device is a touchpad
[     7.708] (II) config/udev: Adding input device Synaptics TM3336-001 (/dev/input/mouse1)
[     7.708] (II) No input driver specified, ignoring this device.
[     7.708] (II) This device may have been added with another device file.
[     7.709] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event8)
[     7.709] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[     7.709] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[     7.709] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[     7.709] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[     7.709] (**) Ideapad extra buttons: always reports core events
[     7.709] (**) Option "Device" "/dev/input/event8"
[     7.709] (**) Option "_source" "server/udev"
[     7.711] (II) event8  - Ideapad extra buttons: is tagged by udev as: Keyboard
[     7.711] (II) event8  - Ideapad extra buttons: device is a keyboard
[     7.711] (II) event8  - Ideapad extra buttons: device removed
[     7.757] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input8/event8"
[     7.757] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 15)
[     7.757] (**) Option "xkb_model" "pc105"
[     7.757] (**) Option "xkb_layout" "br"
[     7.761] (II) event8  - Ideapad extra buttons: is tagged by udev as: Keyboard
[     7.761] (II) event8  - Ideapad extra buttons: device is a keyboard
[     7.762] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[     7.762] (II) No input driver specified, ignoring this device.
[     7.762] (II) This device may have been added with another device file.
[     7.763] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event14)
[     7.763] (II) No input driver specified, ignoring this device.
[     7.763] (II) This device may have been added with another device file.
[     7.764] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event15)
[     7.764] (II) No input driver specified, ignoring this device.
[     7.764] (II) This device may have been added with another device file.
[     7.765] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event16)
[     7.765] (II) No input driver specified, ignoring this device.
[     7.765] (II) This device may have been added with another device file.
[     7.765] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event17)
[     7.766] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event18)
[     7.766] (II) No input driver specified, ignoring this device.
[     7.766] (II) This device may have been added with another device file.
[     7.767] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event19)
[     7.767] (II) No input driver specified, ignoring this device.
[     7.767] (II) This device may have been added with another device file.
[     7.768] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[     7.768] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[     7.768] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     7.768] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     7.768] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     7.768] (**) AT Translated Set 2 keyboard: always reports core events
[     7.768] (**) Option "Device" "/dev/input/event2"
[     7.768] (**) Option "_source" "server/udev"
[     7.771] (II) event2  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     7.771] (II) event2  - AT Translated Set 2 keyboard: device is a keyboard
[     7.773] (II) event2  - AT Translated Set 2 keyboard: device removed
[     7.791] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[     7.791] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[     7.791] (**) Option "xkb_model" "pc105"
[     7.791] (**) Option "xkb_layout" "br"
[     7.794] (II) event2  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     7.794] (II) event2  - AT Translated Set 2 keyboard: device is a keyboard
[     7.797] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     7.797] (II) No input driver specified, ignoring this device.
[     7.797] (II) This device may have been added with another device file.
[     7.808] (**) USB USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     7.808] (**) USB USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     7.808] (**) USB USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     7.808] (II) Using input driver 'libinput' for 'USB USB Keyboard Consumer Control'
[     7.808] (**) USB USB Keyboard Consumer Control: always reports core events
[     7.808] (**) Option "Device" "/dev/input/event5"
[     7.808] (**) Option "_source" "_driver/libinput"
[     7.808] (II) libinput: USB USB Keyboard Consumer Control: is a virtual subdevice
[     7.808] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:1A2C:2D23.0003/input/input5/event5"
[     7.808] (II) XINPUT: Adding extended input device "USB USB Keyboard Consumer Control" (type: KEYBOARD, id 17)
[     7.808] (**) Option "xkb_model" "pc105"
[     7.808] (**) Option "xkb_layout" "br"
[     7.822] (EE) Failed to open authorization file "/var/run/sddm/{8bbdf09d-68cb-4c39-82d2-8f983fd6e0d1}": No such file or directory
Obs.: nouveau is already blacklisted.
$ cat /etc/modprobe.d/nvidia.conf
blacklist nouveau
blacklist nvidiafb
blacklist rivafb
made a mistake on that command, i mistakenly added | to the end. post output of this:
cat /var/log/Xorg.0.log | grep -E "(EE)|(WW)|error|failed|Time|i915|nouveau"
no problem.
$ cat /var/log/Xorg.0.log | grep -E "(EE)|(WW)|error|failed|Time|i915|nouveau"
[     7.123] Current Operating System: Linux gh05t 4.19.45-1-MANJARO #1 SMP PREEMPT Wed May 22 17:16:41 UTC 2019 x86_64
[     7.124] (==) Log file: "/var/log/Xorg.0.log", Time: Sun May 26 18:33:51 2019
[     7.127] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     7.127] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     7.127] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     7.127] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     7.145] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     7.223] (WW) Falling back to old probe method for modesetting
[     7.418] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     7.446] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[     7.447] (II) Initializing extension MIT-SCREEN-SAVER
[     8.521] (EE) Failed to open authorization file "/var/run/sddm/{7a52f779-336e-4003-a576-13ddff1de3d6}": No such file or directory
try this:
sudo nano /etc/modprobe.d/i915.conf
copy/paste
#i915.conf
options i915 preliminary_hw_support=1
options i915 edp_vswing=2
options i915 enable_psr=0
options i915 fastboot=1
options drm_kms_helper poll=0
save/exit/reboot/test
no success...
try adding this line to i915.conf
options i915 alpha_support=1
save/exit/reboot
still no success...
i seen a post in my search about changing the accelmethod of i915 to uxa but im not sure how that could be done on an optimus laptop with a prime setup.
