KDE setting primary login monitor?
I have 2 monitors, one that's 2K and one 1080p to the right. Whenever I login after turning the computer on, the 1080p monitor is treated as the primary one on the login screen, and as a result the plasmoids I've set up on my 2K primary monitor get pushed over to the left upon login. Like so:
How can I fix this?
I have dug around in system settings and searched the forums to no avail. Perhaps my searching skills aren't up to snuff.
My inxi
           Distro: Manjaro Linux
Machine:   Type: Desktop System: Micro-Star product: MS-7C35 v: 1.0 serial: <filter>
           Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.50
           date: 09/16/2019
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 charge: 100% (should be ignored)
           status: Discharging
CPU:       Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115232
           Speed: 3590 MHz min/max: N/A Core speeds (MHz): 1: 3590 2: 3970 3: 3790 4: 3734 5: 4150 6: 3792 7: 4305 8: 3753
           9: 3862 10: 4311 11: 3863 12: 3769 13: 3982 14: 4084 15: 4034 16: 3675
Graphics:  Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: ASUSTeK driver: nvidia v: 435.21 bus ID: 2d:00.0
           Display: x11 server: X.Org 1.20.5 driver: nvidia resolution: 1920x1080~75Hz, 2560x1440~60Hz
           OpenGL: renderer: GeForce GTX 1070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 435.21 direct render: Yes
Audio:     Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 2d:00.1
           Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus ID: 2f:00.4
           Device-3: Razer USA Razer USB Audio Controller type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-2:2
           Sound Server: ALSA v: k5.3.6-1-MANJARO
Network:   Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb v: 5.6.0-k port: e000 bus ID: 26:00.0
           IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           Device-2: Realtek vendor: Micro-Star MSI driver: N/A port: d000 bus ID: 27:00.0
Drives:    Local Storage: total: 7.97 TiB used: 2.07 TiB (26.0%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
           ID-2: /dev/sda vendor: Samsung model: SSD 840 EVO 500GB size: 465.76 GiB
           ID-3: /dev/sdb vendor: Western Digital model: WD30EZRZ-00GXCB0 size: 2.73 TiB
           ID-4: /dev/sdc vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB
           ID-5: /dev/sdd type: USB vendor: Samsung model: Flash Drive FIT size: 239.02 GiB
Partition: ID-1: / size: 51.05 GiB used: 27.31 GiB (53.5%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: /home size: 864.11 GiB used: 121.54 GiB (14.1%) fs: ext4 dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 42.6 C mobo: N/A gpu: nvidia temp: 52 C
Info:      Processes: 344 Uptime: 4h 12m Memory: 31.38 GiB used: 3.83 GiB (12.2%) Init: systemd Compilers: gcc: 9.2.0
           Shell: bash v: 5.0.11 inxi: 3.0.36
NVidia X Server Settings
nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings:  version 435.21
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Ancor Communications Inc MX27AQ"
    HorizSync       30.0 - 83.0
    VertRefresh     56.0 - 75.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 1070 Ti"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-5"
    Option         "metamodes" "DP-2: nvidia-auto-select +0+0, HDMI-0: nvidia-auto-select +2560+260"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Use a fixed layout config instead, like so:
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    Option  "ConnectToAcpid"    "Off"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-0"
    Option         "metamodes" "DP-2: 2560x1440_60 +0+0, HDMI-0: 1920x1080_60 +2560+260"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "ServerFlags"
    Option "IndirectGLX" "On"
EndSection
Section "InputClass"
	Identifier          "Keyboard Defaults"
	MatchIsKeyboard	    "yes"
	Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Of course, replace the 2560x1440_60 with the correct resolution and refresh rate your monitor is capable, if 60 is too low.
I added the Option "ConnectToAcpid" "Off" because on a desktop pc there is no need that the Nvidia X connects to it to test for AC/Battery power, docking events ...
In the same place, just above, you can add Option "TripleBuffer" "On" that will be somehow helpful with KWin, but the you have to make use of (create the file if doesn't exist) /etc/profile.d/kwin.sh with this content in it:
export KWIN_TRIPLE_BUFFER=1
export __GL_MaxFramesAllowed=1
Also added the last 3 sections that people always miss to add when they manually edit the config.
Reboot after making this modifications and set the KDE Display and Monitor to match. After that there will be no more issues as you described.
Thanks very much, I'll try this when I get home.
That did not work for me. The smaller monitor is still being treated as the primary one only on the login screen. Just to confirm, I should be editing /etc/X11/mhwd.d/nvidia.conf, correct?
Could you describe how do you want it to behave?
Which one should be Primary and why?
Have you tried the "Primary" settings either at Plasma monitors or Nvidia?
In general, setting a Primary monitor on Xorg conf and using a xrandr command in SDDM Xsetup script should do whatever you want.
Then, there is the local setting, inside your session, which could/would change system (boot) settings. These are in two places, Plasma (Displays) and Nvidia (local config autostarted).
First decide what would you like the system and your local session should do.
Also the "boot" monitor is important. Check current
grep "(boot)" /var/log/Xorg.0.log | awk '{print $5}'
Sorry if I'm not being clear enough.
The Asus (Ancor Communications) 2K monitor should be primary, because it's the larger of the 2 and what I have centered on my desktop.
I currently have the 2K monitor set as the primary monitor, and have no issues during normal use. It is set as primary in both plasma and Nvidia. Grub shows up only on the 2K monitor, as intended. However, when I turn on my PC or reboot it, the the smaller 1080p monitor is treated as the primary only on the login screen. Because of that, my plasmoid layout set up for the 2K monitor gets messed up. It's honestly confusing behavior.
$ grep "(boot)" /var/log/Xorg.0.log | awk '{print $5}'
DFP-5
meaning initially starting the system, not any suspend function. But you say
Then when does it switch? I am sorry I cannot follow the description.
Whenever the switch happens, we need the corresponding Xorg logs and maybe journal logs.
  • Have you set any Xsetup script for SDDM? Why not?
It switches after GRUB and before Plasma. I do not have an xsetup script for SDDM. Honestly didn't realize one was needed. I'm pretty new to KDE in general.
Xorg Log
[     5.337] (--) Log file renamed from "/var/log/Xorg.pid-1284.log" to "/var/log/Xorg.0.log"
[     5.338]
X.Org X Server 1.20.5
[     5.338] Build Operating System: Linux Arch Linux
[     5.338] Current Operating System: Linux jiibus-pc 5.3.6-1-MANJARO #1 SMP PREEMPT Sat Oct 12 09:30:05 UTC 2019 x86_64
[     5.338] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.3-x86_64 root=UUID=fd7961d9-819a-46a2-8158-d1de97601bd3 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[     5.338] Build Date: 14 August 2019  10:50:56PM
[     5.338]
[     5.338] Current version of pixman: 0.38.4
[     5.338] 	Before reporting problems, check http://wiki.x.org
[     5.338] Markers: (--) probed, (**) from config file, (==) default setting,
[     5.338] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 22 19:18:10 2019
[     5.339] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     5.339] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     5.339] (==) ServerLayout "layout"
[     5.339] (**) |-->Screen "Screen0" (0)
[     5.339] (**) |   |-->Monitor "Monitor0"
[     5.340] (**) |   |-->Device "Device0"
[     5.340] (**) Option "IndirectGLX" "On"
[     5.340] (==) Automatically adding devices
[     5.340] (==) Automatically enabling devices
[     5.340] (==) Automatically adding GPU devices
[     5.340] (==) Automatically binding GPU devices
[     5.340] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     5.340] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     5.340] 	Entry deleted from font path.
[     5.341] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     5.341] 	Entry deleted from font path.
[     5.341] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     5.341] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     5.341] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     5.341] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     5.341] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     5.341] (==) ModulePath set to "/usr/lib/xorg/modules"
[     5.341] (**) Extension "COMPOSITE" is enabled
[     5.341] (II) The server relies on udev to provide the list of input devices.
[     5.341] (II) Module ABI versions:
[     5.341] 	X.Org ANSI C Emulation: 0.4
[     5.341] 	X.Org Video Driver: 24.0
[     5.341] 	X.Org XInput driver : 24.1
[     5.341] 	X.Org Server Extension : 10.0
[     5.341] (++) using VT number 1
[     5.341] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     5.341] (II) xfree86: Adding drm device (/dev/dri/card0)
[     5.343] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     5.343] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     5.344] (--) PCI:*(45@0:0:0) 10de:1b82:1043:861d rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[     5.344] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     5.344] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[     5.344] (II) LoadModule: "dbe"
[     5.344] (II) Module "dbe" already built-in
[     5.344] (II) LoadModule: "extmod"
[     5.344] (II) Module "extmod" already built-in
[     5.344] (II) LoadModule: "glx"
[     5.344] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     5.349] (II) Module glx: vendor="X.Org Foundation"
[     5.349] 	compiled for 1.20.5, module version = 1.0.0
[     5.349] 	ABI class: X.Org Server Extension, version 10.0
[     5.349] (II) LoadModule: "nvidia"
[     5.349] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     5.351] (II) Module nvidia: vendor="NVIDIA Corporation"
[     5.351] 	compiled for 1.6.99.901, module version = 1.0.0
[     5.351] 	Module class: X.Org Video Driver
[     5.352] (II) NVIDIA dlloader X Driver  435.21  Sun Aug 25 08:17:08 CDT 2019
[     5.352] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     5.352] (II) Loading sub module "fb"
[     5.352] (II) LoadModule: "fb"
[     5.352] (II) Loading /usr/lib/xorg/modules/libfb.so
[     5.353] (II) Module fb: vendor="X.Org Foundation"
[     5.353] 	compiled for 1.20.5, module version = 1.0.0
[     5.353] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     5.353] (II) Loading sub module "wfb"
[     5.353] (II) LoadModule: "wfb"
[     5.353] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     5.353] (II) Module wfb: vendor="X.Org Foundation"
[     5.353] (II) Loading sub module "ramdac"
[     5.353] (II) LoadModule: "ramdac"
[     5.353] (II) Module "ramdac" already built-in
[     5.400] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     5.400] (==) NVIDIA(0): RGB weight 888
[     5.400] (==) NVIDIA(0): Default visual is TrueColor
[     5.400] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     5.400] (**) Option "AllowNVIDIAGpuScreens"
[     5.400] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     5.400] (**) NVIDIA(0): Option "Stereo" "0"
[     5.400] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[     5.400] (**) NVIDIA(0): Option "SLI" "Off"
[     5.400] (**) NVIDIA(0): Option "MultiGPU" "Off"
[     5.400] (**) NVIDIA(0): Option "TripleBuffer"
[     5.400] (**) NVIDIA(0): Option "ConnectToAcpid" "Off"
[     5.400] (**) NVIDIA(0): Option "BaseMosaic" "off"
[     5.400] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     5.400] (**) NVIDIA(0): Stereo disabled by request
[     5.400] (**) NVIDIA(0): NVIDIA SLI disabled.
[     5.400] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[     5.400] (**) NVIDIA(0): Option "MetaModes" "DP-2: 2560x1440_60 +0+0, HDMI-0: 1920x1080_60 +2560+240"
[     5.401] (**) NVIDIA(0): Enabling 2D acceleration
[     5.401] (II) Loading sub module "glxserver_nvidia"
[     5.401] (II) LoadModule: "glxserver_nvidia"
[     5.401] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[     5.419] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     5.419] 	compiled for 1.6.99.901, module version = 1.0.0
[     5.419] 	Module class: X.Org Server Extension
[     5.419] (II) NVIDIA GLX Module  435.21  Sun Aug 25 08:14:27 CDT 2019
[     5.420] (II) NVIDIA: The X server supports PRIME Render Offload.
[     6.151] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:45:0:0
[     6.151] (--) NVIDIA(0):     DFP-0
[     6.151] (--) NVIDIA(0):     DFP-1
[     6.151] (--) NVIDIA(0):     DFP-2
[     6.151] (--) NVIDIA(0):     DFP-3
[     6.151] (--) NVIDIA(0):     DFP-4
[     6.151] (--) NVIDIA(0):     DFP-5 (boot)
[     6.151] (--) NVIDIA(0):     DFP-6
[     6.151] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1070 Ti (GP104-A) at PCI:45:0:0
[     6.151] (II) NVIDIA(0):     (GPU-0)
[     6.151] (--) NVIDIA(0): Memory: 8388608 kBytes
[     6.151] (--) NVIDIA(0): VideoBIOS: 86.04.85.00.72
[     6.151] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[     6.152] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     6.152] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[     6.152] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[     6.181] (--) NVIDIA(GPU-0): Acer SB220Q (DFP-1): connected
[     6.181] (--) NVIDIA(GPU-0): Acer SB220Q (DFP-1): Internal TMDS
[     6.181] (--) NVIDIA(GPU-0): Acer SB220Q (DFP-1): 600.0 MHz maximum pixel clock
[     6.181] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     6.181] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[     6.181] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[     6.181] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     6.181] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[     6.181] (--) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[     6.181] (--) NVIDIA(GPU-0): DFP-4: disconnected
[     6.181] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[     6.181] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[     6.182] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): connected
[     6.182] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): Internal DisplayPort
[     6.182] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): 1440.0 MHz maximum pixel clock
[     6.184] (--) NVIDIA(GPU-0): DFP-6: disconnected
[     6.184] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[     6.184] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[     6.195] (II) NVIDIA(0): Validated MetaModes:
[     6.195] (II) NVIDIA(0):     "DP-2:2560x1440_60+0+0,HDMI-0:1920x1080_60+2560+240"
[     6.195] (II) NVIDIA(0): Virtual screen size determined to be 4480 x 1440
[     6.199] (--) NVIDIA(0): DPI set to (101, 101); computed from "UseEdidDpi" X config
[     6.199] (--) NVIDIA(0):     option
[     6.199] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[     6.199] (II) NVIDIA:     access.
[     6.215] (II) NVIDIA(0): Setting mode "DP-2:2560x1440_60+0+0,HDMI-0:1920x1080_60+2560+240"
[     6.309] (==) NVIDIA(0): Disabling shared memory pixmaps
[     6.309] (==) NVIDIA(0): Backing store enabled
[     6.309] (==) NVIDIA(0): Silken mouse disabled
[     6.310] (**) NVIDIA(0): DPMS enabled
[     6.310] (II) Loading sub module "dri2"
[     6.310] (II) LoadModule: "dri2"
[     6.310] (II) Module "dri2" already built-in
[     6.310] (II) NVIDIA(0): [DRI2] Setup complete
[     6.310] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     6.311] (II) Initializing extension Generic Event Extension
[     6.311] (II) Initializing extension SHAPE
[     6.311] (II) Initializing extension MIT-SHM
[     6.311] (II) Initializing extension XInputExtension
[     6.311] (II) Initializing extension XTEST
[     6.311] (II) Initializing extension BIG-REQUESTS
[     6.311] (II) Initializing extension SYNC
[     6.311] (II) Initializing extension XKEYBOARD
[     6.311] (II) Initializing extension XC-MISC
[     6.311] (II) Initializing extension SECURITY
[     6.311] (II) Initializing extension XFIXES
[     6.311] (II) Initializing extension RENDER
[     6.311] (II) Initializing extension RANDR
[     6.311] (II) Initializing extension COMPOSITE
[     6.312] (II) Initializing extension DAMAGE
[     6.312] (II) Initializing extension MIT-SCREEN-SAVER
[     6.312] (II) Initializing extension DOUBLE-BUFFER
[     6.312] (II) Initializing extension RECORD
[     6.312] (II) Initializing extension DPMS
[     6.312] (II) Initializing extension Present
[     6.312] (II) Initializing extension DRI3
[     6.312] (II) Initializing extension X-Resource
[     6.312] (II) Initializing extension XVideo
[     6.312] (II) Initializing extension XVideo-MotionCompensation
[     6.312] (II) Initializing extension GLX
[     6.312] (II) GLX: Another vendor is already registered for screen 0
[     6.312] (II) Initializing extension XFree86-VidModeExtension
[     6.312] (II) Initializing extension XFree86-DGA
[     6.312] (II) Initializing extension XFree86-DRI
[     6.312] (II) Initializing extension DRI2
[     6.312] (II) Initializing extension NV-GLX
[     6.312] (II) Initializing extension NV-CONTROL
[     6.312] (II) Initializing extension XINERAMA
[     6.343] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     6.343] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     6.343] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.343] (**) Power Button: Applying InputClass "system-keyboard"
[     6.343] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     6.343] (II) LoadModule: "libinput"
[     6.343] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     6.345] (II) Module libinput: vendor="X.Org Foundation"
[     6.345] 	compiled for 1.20.5, module version = 0.29.0
[     6.345] 	Module class: X.Org XInput Driver
[     6.345] 	ABI class: X.Org XInput driver, version 24.1
[     6.345] (II) Using input driver 'libinput' for 'Power Button'
[     6.346] (**) Power Button: always reports core events
[     6.346] (**) Option "Device" "/dev/input/event1"
[     6.346] (**) Option "_source" "server/udev"
[     6.348] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     6.348] (II) event1  - Power Button: device is a keyboard
[     6.348] (II) event1  - Power Button: device removed
[     6.380] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     6.380] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     6.380] (**) Option "xkb_model" "pc105"
[     6.380] (**) Option "xkb_layout" "us"
[     6.380] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.390] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     6.390] (II) event1  - Power Button: device is a keyboard
[     6.390] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     6.390] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     6.390] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.390] (**) Power Button: Applying InputClass "system-keyboard"
[     6.390] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     6.390] (II) Using input driver 'libinput' for 'Power Button'
[     6.390] (**) Power Button: always reports core events
[     6.390] (**) Option "Device" "/dev/input/event0"
[     6.390] (**) Option "_source" "server/udev"
[     6.391] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     6.391] (II) event0  - Power Button: device is a keyboard
[     6.391] (II) event0  - Power Button: device removed
[     6.413] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     6.413] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     6.413] (**) Option "xkb_model" "pc105"
[     6.413] (**) Option "xkb_layout" "us"
[     6.413] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.413] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     6.413] (II) event0  - Power Button: device is a keyboard
[     6.414] (II) config/udev: Adding input device Razer Razer USB Audio Controller Consumer Control (/dev/input/event3)
[     6.414] (**) Razer Razer USB Audio Controller Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.414] (**) Razer Razer USB Audio Controller Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.414] (**) Razer Razer USB Audio Controller Consumer Control: Applying InputClass "system-keyboard"
[     6.414] (**) Razer Razer USB Audio Controller Consumer Control: Applying InputClass "Keyboard Defaults"
[     6.414] (II) Using input driver 'libinput' for 'Razer Razer USB Audio Controller Consumer Control'
[     6.414] (**) Razer Razer USB Audio Controller Consumer Control: always reports core events
[     6.414] (**) Option "Device" "/dev/input/event3"
[     6.414] (**) Option "_source" "server/udev"
[     6.415] (II) event3  - Razer Razer USB Audio Controller Consumer Control: is tagged by udev as: Keyboard
[     6.415] (II) event3  - Razer Razer USB Audio Controller Consumer Control: device is a keyboard
[     6.415] (II) event3  - Razer Razer USB Audio Controller Consumer Control: device removed
[     6.460] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.1/usb1/1-2/1-2:1.5/0003:1532:0520.0002/input/input3/event3"
[     6.460] (II) XINPUT: Adding extended input device "Razer Razer USB Audio Controller Consumer Control" (type: KEYBOARD, id 8)
[     6.460] (**) Option "xkb_model" "pc105"
[     6.460] (**) Option "xkb_layout" "us"
[     6.460] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.461] (II) event3  - Razer Razer USB Audio Controller Consumer Control: is tagged by udev as: Keyboard
[     6.461] (II) event3  - Razer Razer USB Audio Controller Consumer Control: device is a keyboard
[     6.461] (II) config/udev: Adding input device Razer Razer USB Audio Controller (/dev/input/event4)
[     6.461] (**) Razer Razer USB Audio Controller: Applying InputClass "evdev keyboard catchall"
[     6.461] (**) Razer Razer USB Audio Controller: Applying InputClass "libinput keyboard catchall"
[     6.461] (**) Razer Razer USB Audio Controller: Applying InputClass "system-keyboard"
[     6.461] (**) Razer Razer USB Audio Controller: Applying InputClass "Keyboard Defaults"
[     6.461] (II) Using input driver 'libinput' for 'Razer Razer USB Audio Controller'
[     6.461] (**) Razer Razer USB Audio Controller: always reports core events
[     6.461] (**) Option "Device" "/dev/input/event4"
[     6.461] (**) Option "_source" "server/udev"
[     6.462] (II) event4  - Razer Razer USB Audio Controller: is tagged by udev as: Keyboard
[     6.462] (II) event4  - Razer Razer USB Audio Controller: device is a keyboard
[     6.462] (II) event4  - Razer Razer USB Audio Controller: device removed
[     6.530] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.1/usb1/1-2/1-2:1.5/0003:1532:0520.0002/input/input4/event4"
[     6.530] (II) XINPUT: Adding extended input device "Razer Razer USB Audio Controller" (type: KEYBOARD, id 9)
[     6.530] (**) Option "xkb_model" "pc105"
[     6.530] (**) Option "xkb_layout" "us"
[     6.530] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.531] (II) event4  - Razer Razer USB Audio Controller: is tagged by udev as: Keyboard
[     6.531] (II) event4  - Razer Razer USB Audio Controller: device is a keyboard
[     6.531] (II) config/udev: Adding input device MSI MEG X570 ACE (/dev/input/event2)
[     6.531] (II) No input driver specified, ignoring this device.
[     6.531] (II) This device may have been added with another device file.
[     6.531] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event19)
[     6.531] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event20)
[     6.531] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event21)
[     6.532] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event22)
[     6.532] (II) No input driver specified, ignoring this device.
[     6.532] (II) This device may have been added with another device file.
[     6.532] (II) config/udev: Adding input device Massdrop Inc. CTRL Keyboard (/dev/input/event5)
[     6.532] (**) Massdrop Inc. CTRL Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.532] (**) Massdrop Inc. CTRL Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.532] (**) Massdrop Inc. CTRL Keyboard: Applying InputClass "system-keyboard"
[     6.532] (**) Massdrop Inc. CTRL Keyboard: Applying InputClass "Keyboard Defaults"
[     6.532] (II) Using input driver 'libinput' for 'Massdrop Inc. CTRL Keyboard'
[     6.532] (**) Massdrop Inc. CTRL Keyboard: always reports core events
[     6.532] (**) Option "Device" "/dev/input/event5"
[     6.532] (**) Option "_source" "server/udev"
[     6.533] (II) event5  - Massdrop Inc. CTRL Keyboard: is tagged by udev as: Keyboard
[     6.533] (II) event5  - Massdrop Inc. CTRL Keyboard: device is a keyboard
[     6.533] (II) event5  - Massdrop Inc. CTRL Keyboard: device removed
[     6.574] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-1/5-1.2/5-1.2:1.0/0003:04D8:EED2.0006/input/input10/event5"
[     6.574] (II) XINPUT: Adding extended input device "Massdrop Inc. CTRL Keyboard" (type: KEYBOARD, id 10)
[     6.574] (**) Option "xkb_model" "pc105"
[     6.574] (**) Option "xkb_layout" "us"
[     6.574] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.575] (II) event5  - Massdrop Inc. CTRL Keyboard: is tagged by udev as: Keyboard
[     6.575] (II) event5  - Massdrop Inc. CTRL Keyboard: device is a keyboard
[     6.575] (II) config/udev: Adding input device Massdrop Inc. CTRL Keyboard System Control (/dev/input/event6)
[     6.575] (**) Massdrop Inc. CTRL Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[     6.575] (**) Massdrop Inc. CTRL Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[     6.575] (**) Massdrop Inc. CTRL Keyboard System Control: Applying InputClass "system-keyboard"
[     6.575] (**) Massdrop Inc. CTRL Keyboard System Control: Applying InputClass "Keyboard Defaults"
[     6.575] (II) Using input driver 'libinput' for 'Massdrop Inc. CTRL Keyboard System Control'
[     6.575] (**) Massdrop Inc. CTRL Keyboard System Control: always reports core events
[     6.575] (**) Option "Device" "/dev/input/event6"
[     6.575] (**) Option "_source" "server/udev"
[     6.576] (II) event6  - Massdrop Inc. CTRL Keyboard System Control: is tagged by udev as: Keyboard
[     6.576] (II) event6  - Massdrop Inc. CTRL Keyboard System Control: device is a keyboard
[     6.576] (II) event6  - Massdrop Inc. CTRL Keyboard System Control: device removed
[     6.620] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-1/5-1.2/5-1.2:1.1/0003:04D8:EED2.0008/input/input11/event6"
[     6.620] (II) XINPUT: Adding extended input device "Massdrop Inc. CTRL Keyboard System Control" (type: KEYBOARD, id 11)
[     6.620] (**) Option "xkb_model" "pc105"
[     6.620] (**) Option "xkb_layout" "us"
[     6.620] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.621] (II) event6  - Massdrop Inc. CTRL Keyboard System Control: is tagged by udev as: Keyboard
[     6.621] (II) event6  - Massdrop Inc. CTRL Keyboard System Control: device is a keyboard
[     6.621] (II) config/udev: Adding input device Massdrop Inc. CTRL Keyboard Consumer Control (/dev/input/event7)
[     6.621] (**) Massdrop Inc. CTRL Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.621] (**) Massdrop Inc. CTRL Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.621] (**) Massdrop Inc. CTRL Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     6.621] (**) Massdrop Inc. CTRL Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[     6.621] (II) Using input driver 'libinput' for 'Massdrop Inc. CTRL Keyboard Consumer Control'
[     6.621] (**) Massdrop Inc. CTRL Keyboard Consumer Control: always reports core events
[     6.621] (**) Option "Device" "/dev/input/event7"
[     6.621] (**) Option "_source" "server/udev"
[     6.622] (II) event7  - Massdrop Inc. CTRL Keyboard Consumer Control: is tagged by udev as: Keyboard
[     6.622] (II) event7  - Massdrop Inc. CTRL Keyboard Consumer Control: device is a keyboard
[     6.622] (II) event7  - Massdrop Inc. CTRL Keyboard Consumer Control: device removed
[     6.667] (II) libinput: Massdrop Inc. CTRL Keyboard Consumer Control: needs a virtual subdevice
[     6.667] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-1/5-1.2/5-1.2:1.1/0003:04D8:EED2.0008/input/input12/event7"
[     6.667] (II) XINPUT: Adding extended input device "Massdrop Inc. CTRL Keyboard Consumer Control" (type: MOUSE, id 12)
[     6.667] (**) Option "AccelerationScheme" "none"
[     6.667] (**) Massdrop Inc. CTRL Keyboard Consumer Control: (accel) selected scheme none/0
[     6.667] (**) Massdrop Inc. CTRL Keyboard Consumer Control: (accel) acceleration factor: 2.000
[     6.667] (**) Massdrop Inc. CTRL Keyboard Consumer Control: (accel) acceleration threshold: 4
[     6.668] (II) event7  - Massdrop Inc. CTRL Keyboard Consumer Control: is tagged by udev as: Keyboard
[     6.668] (II) event7  - Massdrop Inc. CTRL Keyboard Consumer Control: device is a keyboard
[     6.668] (II) config/udev: Adding input device Massdrop Inc. CTRL Keyboard (/dev/input/event8)
[     6.668] (**) Massdrop Inc. CTRL Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.668] (**) Massdrop Inc. CTRL Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.668] (**) Massdrop Inc. CTRL Keyboard: Applying InputClass "system-keyboard"
[     6.668] (**) Massdrop Inc. CTRL Keyboard: Applying InputClass "Keyboard Defaults"
[     6.668] (II) Using input driver 'libinput' for 'Massdrop Inc. CTRL Keyboard'
[     6.668] (**) Massdrop Inc. CTRL Keyboard: always reports core events
[     6.668] (**) Option "Device" "/dev/input/event8"
[     6.668] (**) Option "_source" "server/udev"
[     6.669] (II) event8  - Massdrop Inc. CTRL Keyboard: is tagged by udev as: Keyboard
[     6.669] (II) event8  - Massdrop Inc. CTRL Keyboard: device is a keyboard
[     6.669] (II) event8  - Massdrop Inc. CTRL Keyboard: device removed
[     6.710] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-1/5-1.2/5-1.2:1.2/0003:04D8:EED2.0009/input/input13/event8"
[     6.710] (II) XINPUT: Adding extended input device "Massdrop Inc. CTRL Keyboard" (type: KEYBOARD, id 13)
[     6.710] (**) Option "xkb_model" "pc105"
[     6.710] (**) Option "xkb_layout" "us"
[     6.710] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.711] (II) event8  - Massdrop Inc. CTRL Keyboard: is tagged by udev as: Keyboard
[     6.711] (II) event8  - Massdrop Inc. CTRL Keyboard: device is a keyboard
[     6.711] (II) config/udev: Adding input device Logitech MX Master 3 (/dev/input/event9)
[     6.711] (**) Logitech MX Master 3: Applying InputClass "evdev pointer catchall"
[     6.711] (**) Logitech MX Master 3: Applying InputClass "evdev keyboard catchall"
[     6.711] (**) Logitech MX Master 3: Applying InputClass "libinput pointer catchall"
[     6.711] (**) Logitech MX Master 3: Applying InputClass "libinput keyboard catchall"
[     6.711] (**) Logitech MX Master 3: Applying InputClass "system-keyboard"
[     6.711] (**) Logitech MX Master 3: Applying InputClass "Keyboard Defaults"
[     6.711] (II) Using input driver 'libinput' for 'Logitech MX Master 3'
[     6.711] (**) Logitech MX Master 3: always reports core events
[     6.712] (**) Option "Device" "/dev/input/event9"
[     6.712] (**) Option "_source" "server/udev"
[     6.712] (II) event9  - Logitech MX Master 3: is tagged by udev as: Keyboard Mouse
[     6.712] (II) event9  - Logitech MX Master 3: device is a pointer
[     6.712] (II) event9  - Logitech MX Master 3: device is a keyboard
[     6.712] (II) event9  - Logitech MX Master 3: device removed
[     6.747] (II) libinput: Logitech MX Master 3: needs a virtual subdevice
[     6.747] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-2/5-2:1.2/0003:046D:C52B.0005/0003:046D:4082.000A/input/input19/event9"
[     6.747] (II) XINPUT: Adding extended input device "Logitech MX Master 3" (type: MOUSE, id 14)
[     6.747] (**) Option "AccelerationScheme" "none"
[     6.747] (**) Logitech MX Master 3: (accel) selected scheme none/0
[     6.747] (**) Logitech MX Master 3: (accel) acceleration factor: 2.000
[     6.747] (**) Logitech MX Master 3: (accel) acceleration threshold: 4
[     6.748] (II) event9  - Logitech MX Master 3: is tagged by udev as: Keyboard Mouse
[     6.748] (II) event9  - Logitech MX Master 3: device is a pointer
[     6.748] (II) event9  - Logitech MX Master 3: device is a keyboard
[     6.748] (II) config/udev: Adding input device Logitech MX Master 3 (/dev/input/mouse0)
[     6.748] (**) Logitech MX Master 3: Applying InputClass "system-keyboard"
[     6.748] (**) Logitech MX Master 3: Applying InputClass "Keyboard Defaults"
[     6.748] (II) No input driver specified, ignoring this device.
[     6.748] (II) This device may have been added with another device file.
[     6.748] (II) config/udev: Adding input device Yubico YubiKey OTP+FIDO+CCID (/dev/input/event11)
[     6.748] (**) Yubico YubiKey OTP+FIDO+CCID: Applying InputClass "evdev keyboard catchall"
[     6.748] (**) Yubico YubiKey OTP+FIDO+CCID: Applying InputClass "libinput keyboard catchall"
[     6.748] (**) Yubico YubiKey OTP+FIDO+CCID: Applying InputClass "system-keyboard"
[     6.748] (**) Yubico YubiKey OTP+FIDO+CCID: Applying InputClass "Keyboard Defaults"
[     6.748] (II) Using input driver 'libinput' for 'Yubico YubiKey OTP+FIDO+CCID'
[     6.748] (**) Yubico YubiKey OTP+FIDO+CCID: always reports core events
[     6.748] (**) Option "Device" "/dev/input/event11"
[     6.748] (**) Option "_source" "server/udev"
[     6.749] (II) event11 - Yubico YubiKey OTP+FIDO+CCID: is tagged by udev as: Keyboard
[     6.749] (II) event11 - Yubico YubiKey OTP+FIDO+CCID: device is a keyboard
[     6.749] (II) event11 - Yubico YubiKey OTP+FIDO+CCID: device removed
[     6.813] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-3/5-3.3/5-3.3:1.0/0003:1050:0407.000B/input/input21/event11"
[     6.813] (II) XINPUT: Adding extended input device "Yubico YubiKey OTP+FIDO+CCID" (type: KEYBOARD, id 15)
[     6.813] (**) Option "xkb_model" "pc105"
[     6.813] (**) Option "xkb_layout" "us"
[     6.813] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.814] (II) event11 - Yubico YubiKey OTP+FIDO+CCID: is tagged by udev as: Keyboard
[     6.814] (II) event11 - Yubico YubiKey OTP+FIDO+CCID: device is a keyboard
[     6.814] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event12)
[     6.814] (II) No input driver specified, ignoring this device.
[     6.814] (II) This device may have been added with another device file.
[     6.814] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event13)
[     6.815] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event14)
[     6.815] (II) No input driver specified, ignoring this device.
[     6.815] (II) This device may have been added with another device file.
[     6.815] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event15)
[     6.815] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event16)
[     6.815] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event17)
[     6.815] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event18)
[     6.815] (II) config/udev: Adding input device PC Speaker (/dev/input/event10)
[     6.817] (**) Massdrop Inc. CTRL Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.817] (**) Massdrop Inc. CTRL Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.817] (**) Massdrop Inc. CTRL Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     6.817] (**) Massdrop Inc. CTRL Keyboard Consumer Control: Applying InputClass "Keyboard Defaults"
[     6.817] (II) Using input driver 'libinput' for 'Massdrop Inc. CTRL Keyboard Consumer Control'
[     6.817] (**) Massdrop Inc. CTRL Keyboard Consumer Control: always reports core events
[     6.817] (**) Option "Device" "/dev/input/event7"
[     6.817] (**) Option "_source" "_driver/libinput"
[     6.817] (II) libinput: Massdrop Inc. CTRL Keyboard Consumer Control: is a virtual subdevice
[     6.817] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-1/5-1.2/5-1.2:1.1/0003:04D8:EED2.0008/input/input12/event7"
[     6.817] (II) XINPUT: Adding extended input device "Massdrop Inc. CTRL Keyboard Consumer Control" (type: KEYBOARD, id 16)
[     6.817] (**) Option "xkb_model" "pc105"
[     6.817] (**) Option "xkb_layout" "us"
[     6.817] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.817] (**) Logitech MX Master 3: Applying InputClass "evdev pointer catchall"
[     6.817] (**) Logitech MX Master 3: Applying InputClass "evdev keyboard catchall"
[     6.817] (**) Logitech MX Master 3: Applying InputClass "libinput pointer catchall"
[     6.817] (**) Logitech MX Master 3: Applying InputClass "libinput keyboard catchall"
[     6.817] (**) Logitech MX Master 3: Applying InputClass "system-keyboard"
[     6.817] (**) Logitech MX Master 3: Applying InputClass "Keyboard Defaults"
[     6.817] (II) Using input driver 'libinput' for 'Logitech MX Master 3'
[     6.817] (**) Logitech MX Master 3: always reports core events
[     6.817] (**) Option "Device" "/dev/input/event9"
[     6.817] (II) libinput: Logitech MX Master 3: is a virtual subdevice
[     6.817] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2f:00.3/usb5/5-2/5-2:1.2/0003:046D:C52B.0005/0003:046D:4082.000A/input/input19/event9"
[     6.817] (II) XINPUT: Adding extended input device "Logitech MX Master 3" (type: KEYBOARD, id 17)
[     6.818] (**) Option "xkb_model" "pc105"
[     6.818] (**) Option "xkb_layout" "us"
[     6.818] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.818] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): connected
[     6.818] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): Internal DisplayPort
[     6.818] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): 1440.0 MHz maximum pixel clock
[     6.822] (EE) Failed to open authorization file "/var/run/sddm/{febd75a9-4aad-4763-b961-06a9ed3a90a9}": No such file or directory
[    18.433] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    18.433] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    18.433] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    18.463] (--) NVIDIA(GPU-0): Acer SB220Q (DFP-1): connected
[    18.463] (--) NVIDIA(GPU-0): Acer SB220Q (DFP-1): Internal TMDS
[    18.463] (--) NVIDIA(GPU-0): Acer SB220Q (DFP-1): 600.0 MHz maximum pixel clock
[    18.463] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    18.463] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[    18.463] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[    18.463] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    18.463] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[    18.463] (--) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[    18.463] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    18.463] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[    18.463] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[    18.463] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): connected
[    18.463] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): Internal DisplayPort
[    18.463] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): 1440.0 MHz maximum pixel clock
[    18.466] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    18.466] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[    18.466] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[    18.822] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    18.822] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    18.822] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    18.852] (--) NVIDIA(GPU-0): Acer SB220Q (DFP-1): connected
[    18.852] (--) NVIDIA(GPU-0): Acer SB220Q (DFP-1): Internal TMDS
[    18.852] (--) NVIDIA(GPU-0): Acer SB220Q (DFP-1): 600.0 MHz maximum pixel clock
[    18.852] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    18.852] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[    18.852] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[    18.852] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    18.852] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[    18.852] (--) NVIDIA(GPU-0): DFP-3: 1440.0 MHz maximum pixel clock
[    18.853] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    18.853] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[    18.853] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[    18.853] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): connected
[    18.853] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): Internal DisplayPort
[    18.853] (--) NVIDIA(GPU-0): Ancor Communications Inc MX27AQ (DFP-5): 1440.0 MHz maximum pixel clock
[    18.855] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    18.855] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[    18.855] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[    21.552] (II) NVIDIA(0): Setting mode "DP-2: 2560x1440_60 @2560x1440 +0+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}, HDMI-0: nvidia-auto-select @1920x1080 +2560+260 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[  2428.922] (EE) client bug: timer event9 debounce: offset negative (-3ms)
[  2428.922] (EE) client bug: timer event9 debounce short: offset negative (-16ms)
[  2773.151] (EE) client bug: timer event9 debounce: offset negative (-10ms)
[  2773.151] (EE) client bug: timer event9 debounce short: offset negative (-23ms)
Try changing this to "DFP-1" to see any change in behavior.
Also, there is a possibility that there maybe some Plasma cache that creates this behavior.
Or an auto-started local nvidia config (have you used this?).
Do you always change Displays setting in Plasma-Monitors after login?
What does xrandr show (on Primary monitor property)?
It maybe only an Xsetup script to add to SDDM, with xrandr --auto or a more precise config.
Or use a Nvidia local config to autostart with preferred settings.
As you realize, you have to test/check which option suits to your needs.
Changing to DFP-1 didn't have the desired effect.
I do not have to change the primary monitor after logging in, my 2K monitor takes back over after entering my password.
I shall experiment with adding a script to SDDM, thank you for the advice!
