I am running Manjaro XFCE on a Lenovo T430 with a large monitor for my main machine. So I run it on ethernet instead of wifi as it never moves. I have 300Mbps internet. It is a fiber optics feed and I am 100% satisfied with it.
I have checked it several times for speed and I have always had between 275 ond 320 or so Mbps up and down. Wifi is another story as my Lenovo T430s older wireless cards do not support such speeds and I can deal with that. Other items I have like cell phones and my NUC with 8th gen i5, 8g RAM and a NVME ssd that is my media box are just as fast using Wifi. (The NUC overall is NO faster than the T430 with the much older 2nd gen i5 and the same 8G RAM. I wasn't impressed but it has HDMI and the older faster booting T430s do not have. That is another topic)
When I switched over to the 4.20 kernel to try it out I noticed it was much slower. Over a couple of days I tested it many times with several speed test sites. I was getting on average a little under 100Mbps. Never once did it test over 100Mbps. This wasn't a huge deal on Wifi as I don't get a lot over 100Mbps with the older cards anyway. So I just switched back to the 4.19 kernel and the speeds came right back.
Just thought it was interesting how the new kernel wasn't up to par on the T430s. Now, with that said, my NUC running Manaro XFCE gets the same 300Mbps with either kernel.
Host: Manjaro-1-T430 Kernel: 4.19.13-1-MANJARO x86_64
bits: 64 compiler: gcc v: 8.2.1 Console: tty 1
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 2347AY1
v: ThinkPad T430 serial:
Mobo: LENOVO model: 2347AY1 serial: UEFI: LENOVO
v: G1ET93WW (2.53 ) date: 03/08/2013
Topology: Dual Core model: Intel Core i5-3320M bits: 64
type: MT MCP arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 20759
Speed: 1198 MHz min/max: 1200/3300 MHz Core speeds (MHz):
1: 1197 2: 1197 3: 1197 4: 1197
Device-1: Intel 3rd Gen Core processor Graphics
vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
Display: server: X.org 1.20.3 driver: intel
unloaded: modesetting resolution:
OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile
v: 4.2 Mesa 18.3.1 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Sound Server: ALSA v: k4.19.13-1-MANJARO
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo
driver: e1000e v: 3.2.6-k port: 5080 bus ID: 00:19.0
IF: enp0s25 state: up speed: 100 Mbps duplex: full
mac:
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak]
driver: iwlwifi v: kernel port: efa0 bus ID: 03:00.0
IF: wlp3s0 state: down mac:
Local Storage: total: 409.88 GiB used: 152.76 GiB (37.3%)
ID-1: /dev/sda vendor: HGST (Hitachi)
model: HTS725032A7E630 size: 298.09 GiB
ID-2: /dev/sdb vendor: Zheino model: CHN mSATA01M 120
ID-1: / size: 101.39 GiB used: 11.57 GiB (11.4%) fs: ext4
dev: /dev/sdb2
ID-2: /home size: 292.41 GiB used: 141.19 GiB (48.3%)
fs: ext4 dev: /dev/sda1
ID-3: swap-1 size: 8.11 GiB used: 0 KiB (0.0%) fs: swap
dev: /dev/sdb3
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2498
Processes: 173 Uptime: 19m Memory: 7.61 GiB
used: 934.9 MiB (12.0%) Init: systemd Compilers: gcc: 8.2.1
Shell: bash v: 4.4.23 inxi: 3.0.28
