kernel 5.4 - r8168 vs r8169 - ethernet
Hi guys
Ever since I got kernel 5.4 I got random ethernet disconnections and lower overall speed with r8169 (uninstalled r8168).
I finally removed kernel 5.4 - running now 4.19 - and have noticed no problem with r8169.
Does anyone have this problem too?
What do i do?
Should I just keep kernel 4.19 for as long as it is supported?
Should I try kernel 5.4 with r8168? Is that even possible?
Thanks
S.
# inxi -SN
System:    Host: {removed} Kernel: 4.19.91-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.14.1 Distro: Manjaro Linux
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
It's not the driver, ethernet networking on the 5.4 kernel has been problematic for many, just do a search. I can't use the 5.4 kernel on my system either, the whole system slows to a crawl, and seems frozen for hours. If it wasn't for the fact that I can tell it's not frozen as things I initiated fifteen minutes, to an hour earlier, finally happen. It's almost like a really bad memory leak, that i'm running out of system resources, or that the processor is over taxed.
Which is strange since I have a pretty beefy system:
System:    Host: {removed} Kernel: 4.19.91-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.17.4 Distro: Manjaro Linux
Machine:   Type: Desktop System: HP product: 24-g227c v: N/A serial: <root required>
           Mobo: HP model: 82DD v: 0000 serial: <root required> UEFI: AMI v: F.36 date: 06/21/2018
CPU:       Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP L2 cache: 3072 KiB
           Speed: 1601 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 1600 2: 1601 3: 1588 4: 1560
Graphics:  Device-1: Intel HD Graphics 620 driver: i915 v: kernel
           Display: x11 server: X.Org 1.20.6 driver: intel unloaded: modesetting tty: N/A
           OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.6 Mesa 19.3.1
Audio:     Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
           Sound Server: ALSA v: k4.19.91-1-MANJARO
           IF: enp1s0 state: down mac: c8:d3:ff:e7:c4:47
           Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter driver: rtl8723be
           IF: wlp2s0 state: up mac: 3c:a0:67:9e:cf:2d
Drives:    Local Storage: total: 931.51 GiB used: 736.23 GiB (79.0%)
           ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1SB102 size: 931.51 GiB
Partition: ID-1: / size: 881.71 GiB used: 736.23 GiB (83.5%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 34.43 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 50.0 C mobo: N/A
Info:      Processes: 175 Uptime: 7d 21h 33m Memory: 31.30 GiB used: 2.05 GiB (6.5%) Shell: bash inxi: 3.0.37
I had no issues before, or after going back to the 4.19.x kernel.
Thank you very much for the reply.
I had found 5.4 ethernet issues posts but I thought they were somehow resolved in the meantime.
And to think that 5.4 is supposed to be a LTS kernel!
A: Upstream still has 5.4 marked as stable, it won't be an LTS until 5.5 moves into the stable branch.
B: Just because the releases tab has a kernel scheduled to become an LTS, does not mean it will.
C: Even if it was, what does that matter?
I have one system here that has various issues with every kernel past 4.9, and another one with stability issues on anything past 3.16.
