Hi @FadeMind
I have no problem posting the output of the command you gave or the one tbg linked me to (only removed my home directory path for security reasons ) - it's just they way someone asks
System: Kernel: 5.7.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Console: tty 1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: Z97 Killer serial: <filter> UEFI: American Megatrends v: P2.60 date: 03/06/2018
Memory: RAM: total: 31.32 GiB used: 2.82 GiB (9.0%)
Array-1: capacity: 32 GiB slots: 4 EC: None max module size: 8 GiB note: est.
Device-1: ChannelA-DIMM0 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous bus width: 64 bits
total: 64 bits manufacturer: 0420 part-no: DDR3 1600 serial: <filter>
Device-2: ChannelA-DIMM1 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous bus width: 64 bits
Device-3: ChannelB-DIMM0 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous bus width: 64 bits
Device-4: ChannelB-DIMM1 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous bus width: 64 bits
CPU: Topology: Quad Core model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell rev: 3 L1 cache: 256 KiB
L2 cache: 8192 KiB L3 cache: 8192 KiB bogomips: 64011
Speed: 4334 MHz min/max: 800/4400 MHz Core speeds (MHz): 1: 4334 2: 4279 3: 4264 4: 4344 5: 4376 6: 4382 7: 4252
8: 4328
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc
nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67df
Display: server: X.Org 1.20.8 driver: amdgpu FAILED: ati unloaded: modesetting alternate: fbdev,vesa
compositor: kwin_x11 resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.37.0 5.7.0-1-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.0.7
direct render: Yes
Audio: Device-1: Intel 9 Series Family HD Audio vendor: ASRock driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:8ca0
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Sapphire Limited driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 1002:aaf0
Device-3: VIA VT1720/24 [Envy24PT/HT] PCI Multi-Channel Audio driver: snd_ice1724 v: kernel bus ID: 04:00.0
chip ID: 1412:1724
Sound Server: ALSA v: k5.7.0-1-MANJARO
Network: Device-1: Intel 82574L Gigabit Network driver: e1000e v: 3.2.6-k port: c000 bus ID: 05:00.0 chip ID: 8086:10d3
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: eth1 state: down mac: <filter>
Drives: Local Storage: total: 3.65 TiB used: 1.26 TiB (34.5%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB speed: 6.0 Gb/s serial: <filter> rev: 3B6Q
scheme: GPT
ID-2: /dev/sdb vendor: A-Data model: SU800 size: 476.94 GiB speed: 6.0 Gb/s serial: <filter> rev: 2FS scheme: GPT
ID-3: /dev/sdc vendor: Western Digital model: WD30EZRZ-00GXCB0 size: 2.73 TiB speed: 6.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: 0A80 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS55 rev: 1.03 dev-links: cdrom
Features: speed: 47 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 411.31 GiB used: 240.42 GiB (58.5%) fs: ext4 dev: /dev/sda2 label: LinuxSystem
uuid: 442e3e6b-2a90-43f2-a832-f54c88754190
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: 9FA1-83F2
ID-3: /home/<filter>/.dataHDD size: 2.68 TiB used: 732.37 GiB (26.7%) fs: ext4 dev: /dev/sdc1 label: LinuxDataHDD
uuid: 024f0e83-e238-4d86-a6d2-34e18d7c7639
ID-4: /home/<filter>/.dataSSD size: 421.51 GiB used: 318.34 GiB (75.5%) fs: ext4 dev: /dev/sdb1 label: LinuxDataSSD
uuid: 58f44ab5-ac5f-4755-ada8-97856d6639ed
ID-5: /home/<removed>/.dataHDD raw size: 2.72 TiB size: N/A (hidden?) used: N/A (hidden?) fs: ext4 dev: /dev/sdc1
label: LinuxDataHDD uuid: 024f0e83-e238-4d86-a6d2-34e18d7c7639
ID-6: /home/<removed>/.dataSSD raw size: 429.25 GiB size: N/A (hidden?) used: N/A (hidden?) fs: ext4 dev: /dev/sdb1
label: LinuxDataSSD uuid: 58f44ab5-ac5f-4755-ada8-97856d6639ed
ID-7: /run/media/<removed>/<removed> size: 7.86 GiB used: 7.86 GiB (100.0%) fs: udf dev: /dev/sr0
label: <removed> uuid: <removed>
ID-8: swap-1 size: 6.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdc2 label: N/A
uuid: eb564a3e-5725-42a2-9cc4-a5088116a5e7
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8009
Device-1: 1-1.6:3 info: Corsair type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 1b1c:1b2e serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-2: 2-11:2 info: Cherry Mechanical Keyboard type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 046a:00b0
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 3-1:2 info: Intel ports: 8 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8001
Hub: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 29.0 C mobo: N/A gpu: amdgpu temp: 41 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 809
Info: Processes: 282 Uptime: 6h 39m Init: systemd v: 245 Compilers: gcc: 10.1.0 Shell: bash (sudo) v: 5.0.17
running in: fish inxi: 3.0.37
But I really doubt that information would have helped any further in this case, as it didn't seemed like a driver issue to me - I'm used to only give necessary and specific data I'm asked for, as I don't want to flood developers with unnecessary data they have to dig through.
