Keyboard blocked with kernel 4.19
That's the point.
"Minor" updates should not been done on all existing kernels available in the repo. Some of them should be stable (in a so called repo), at least for a minimum duration from the time the others are updated. The fact that I would be the only one in the world to get this particular bug is not a fair reason to not respect this safe way of progress.
If you look at my very first post, you can find that the problem occurred between 4.18.16-1 and 4.18.16-2
I will provide the dmesg log to you
It works fine with the PS/2-USB adapter !
How to go to TTY without keyboard ?
$ dmesg
[    0.000000] microcode: microcode updated early to revision 0xa0b, date = 2010-09-28
[    0.000000] Linux version 4.19.2-1-MANJARO (builduser@development) (gcc version 8.2.1 20180831 (GCC)) #1 SMP PREEMPT Tue Nov 13 22:35:25 UTC 2018
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=24e4a66c-286b-4ac8-8783-409fa2a56157 rw quiet resume=UUID=114829ba-6756-4442-9518-b421d5c16cab
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Centaur CentaurHauls
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009cbff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009cc00-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000cff7ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000cff80000-0x00000000cff8dfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000cff8e000-0x00000000cffcffff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000cffd0000-0x00000000cfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000022fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.5 present.
[    0.000000] DMI: System manufacturer P5QL PRO/P5QL PRO, BIOS 0902    11/28/2008
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2830.782 MHz processor
[    0.003157] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.003160] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.003165] last_pfn = 0x230000 max_arch_pfn = 0x400000000
[    0.003170] MTRR default type: uncachable
[    0.003171] MTRR fixed ranges enabled:
[    0.003172]   00000-9FFFF write-back
[    0.003173]   A0000-BFFFF uncachable
[    0.003174]   C0000-DFFFF write-protect
[    0.003174]   E0000-EFFFF write-through
[    0.003175]   F0000-FFFFF write-protect
[    0.003176] MTRR variable ranges enabled:
[    0.003177]   0 base 000000000 mask E00000000 write-back
[    0.003178]   1 base 200000000 mask FE0000000 write-back
[    0.003179]   2 base 220000000 mask FF0000000 write-back
[    0.003180]   3 base 0D0000000 mask FF0000000 uncachable
[    0.003181]   4 base 0E0000000 mask FE0000000 uncachable
[    0.003182]   5 disabled
[    0.003183]   6 disabled
[    0.003183]   7 disabled
[    0.004548] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.004703] total RAM covered: 8192M
[    0.005441] Found optimal setting for mtrr clean up
[    0.005442]  gran_size: 64K 	chunk_size: 64K 	num_reg: 6  	lose cover RAM: 0G
[    0.006773] e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
[    0.006780] last_pfn = 0xcff80 max_arch_pfn = 0x400000000
[    0.016495] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [(____ptrval____)]
[    0.021536] Scanning 1 areas for low memory corruption
[    0.021539] Base memory trampoline at [(____ptrval____)] 96000 size 24576
[    0.021544] BRK [0x11ce01000, 0x11ce01fff] PGTABLE
[    0.021546] BRK [0x11ce02000, 0x11ce02fff] PGTABLE
[    0.021548] BRK [0x11ce03000, 0x11ce03fff] PGTABLE
[    0.021570] BRK [0x11ce04000, 0x11ce04fff] PGTABLE
[    0.021573] BRK [0x11ce05000, 0x11ce05fff] PGTABLE
[    0.021669] BRK [0x11ce06000, 0x11ce06fff] PGTABLE
[    0.021691] BRK [0x11ce07000, 0x11ce07fff] PGTABLE
[    0.021712] BRK [0x11ce08000, 0x11ce08fff] PGTABLE
[    0.021748] BRK [0x11ce09000, 0x11ce09fff] PGTABLE
[    0.021883] RAMDISK: [mem 0x36cf5000-0x37671fff]
[    0.021890] ACPI: Early table checksum verification disabled
[    0.021964] ACPI: RSDP 0x00000000000FBBE0 000014 (v00 ACPIAM)
[    0.021967] ACPI: RSDT 0x00000000CFF80000 000040 (v01 A_M_I_ OEMRSDT  11000828 MSFT 00000097)
[    0.021973] ACPI: FACP 0x00000000CFF80200 000084 (v02 A_M_I_ OEMFACP  11000828 MSFT 00000097)
[    0.021979] ACPI: DSDT 0x00000000CFF80440 008846 (v01 A1014  A1014001 00000001 INTL 20051117)
[    0.021983] ACPI: FACS 0x00000000CFF8E000 000040
[    0.021986] ACPI: APIC 0x00000000CFF80390 00006C (v01 A_M_I_ OEMAPIC  11000828 MSFT 00000097)
[    0.021990] ACPI: MCFG 0x00000000CFF80400 00003C (v01 A_M_I_ OEMMCFG  11000828 MSFT 00000097)
[    0.021993] ACPI: OEMB 0x00000000CFF8E040 000081 (v01 A_M_I_ AMI_OEM  11000828 MSFT 00000097)
[    0.021997] ACPI: HPET 0x00000000CFF88C90 000038 (v01 A_M_I_ OEMHPET  11000828 MSFT 00000097)
[    0.022000] ACPI: OSFR 0x00000000CFF88CD0 0000B0 (v01 A_M_I_ OEMOSFR  11000828 MSFT 00000097)
[    0.022004] ACPI: SSDT 0x00000000CFF8E9D0 000A7C (v01 DpgPmm CpuPm    00000012 INTL 20051117)
[    0.022013] ACPI: Local APIC address 0xfee00000
[    0.022081] No NUMA configuration found
[    0.022082] Faking a node at [mem 0x0000000000000000-0x000000022fffffff]
[    0.022085] NODE_DATA(0) allocated [mem 0x22fff8000-0x22fffbfff]
[    0.022111] Zone ranges:
[    0.022112]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.022114]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.022115]   Normal   [mem 0x0000000100000000-0x000000022fffffff]
[    0.022117]   Device   empty
[    0.022118] Movable zone start for each node
[    0.022119] Early memory node ranges
[    0.022119]   node   0: [mem 0x0000000000001000-0x000000000009bfff]
[    0.022120]   node   0: [mem 0x0000000000100000-0x00000000cff7ffff]
[    0.022121]   node   0: [mem 0x0000000100000000-0x000000022fffffff]
[    0.022128] Reserved but unavailable: 229 pages
[    0.022129] Initmem setup node 0 [mem 0x0000000000001000-0x000000022fffffff]
[    0.022130] On node 0 totalpages: 2096923
[    0.022131]   DMA zone: 64 pages used for memmap
[    0.022132]   DMA zone: 21 pages reserved
[    0.022133]   DMA zone: 3995 pages, LIFO batch:0
[    0.022221]   DMA32 zone: 13246 pages used for memmap
[    0.022222]   DMA32 zone: 847744 pages, LIFO batch:63
[    0.042251]   Normal zone: 19456 pages used for memmap
[    0.042252]   Normal zone: 1245184 pages, LIFO batch:63
[    0.072093] ACPI: PM-Timer IO Port: 0x808
[    0.072096] ACPI: Local APIC address 0xfee00000
[    0.072115] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[    0.072118] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.072120] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.072121] ACPI: IRQ0 used by override.
[    0.072122] ACPI: IRQ9 used by override.
[    0.072124] Using ACPI (MADT) for SMP configuration information
[    0.072126] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[    0.072133] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.072149] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.072150] PM: Registered nosave memory: [mem 0x0009c000-0x0009cfff]
[    0.072151] PM: Registered nosave memory: [mem 0x0009d000-0x0009ffff]
[    0.072151] PM: Registered nosave memory: [mem 0x000a0000-0x000e3fff]
[    0.072152] PM: Registered nosave memory: [mem 0x000e4000-0x000fffff]
[    0.072153] PM: Registered nosave memory: [mem 0xcff80000-0xcff8dfff]
[    0.072154] PM: Registered nosave memory: [mem 0xcff8e000-0xcffcffff]
[    0.072155] PM: Registered nosave memory: [mem 0xcffd0000-0xcfffffff]
[    0.072155] PM: Registered nosave memory: [mem 0xd0000000-0xfedfffff]
[    0.072156] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.072157] PM: Registered nosave memory: [mem 0xfee01000-0xffefffff]
[    0.072157] PM: Registered nosave memory: [mem 0xfff00000-0xffffffff]
[    0.072160] [mem 0xd0000000-0xfedfffff] available for PCI devices
[    0.072161] Booting paravirtualized kernel on bare hardware
[    0.072165] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.223261] random: get_random_bytes called from start_kernel+0x95/0x53f with crng_init=0
[    0.223269] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[    0.223847] percpu: Embedded 46 pages/cpu @(____ptrval____) s151552 r8192 d28672 u524288
[    0.223853] pcpu-alloc: s151552 r8192 d28672 u524288 alloc=1*2097152
[    0.223854] pcpu-alloc: [0] 0 1 2 3
[    0.223875] Built 1 zonelists, mobility grouping on.  Total pages: 2064136
[    0.223877] Policy zone: Normal
[    0.223879] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=24e4a66c-286b-4ac8-8783-409fa2a56157 rw quiet resume=UUID=114829ba-6756-4442-9518-b421d5c16cab
[    0.239169] Calgary: detecting Calgary via BIOS EBDA area
[    0.239172] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.300419] Memory: 8151268K/8387692K available (12300K kernel code, 1383K rwdata, 3688K rodata, 1536K init, 3804K bss, 236424K reserved, 0K cma-reserved)
[    0.300553] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.300564] Kernel/User page tables isolation: enabled
[    0.300626] ftrace: allocating 36074 entries in 141 pages
[    0.316928] rcu: Preemptible hierarchical RCU implementation.
[    0.316930] rcu: 	CONFIG_RCU_FANOUT set to non-default value of 32.
[    0.316930] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.316931] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.316932] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.316933] 	Tasks RCU enabled.
[    0.316934] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.319294] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[    0.319451] rcu: 	Offload RCU callbacks from CPUs: (none).
[    0.322634] Console: colour VGA+ 80x25
[    0.322639] console [tty0] enabled
[    0.322658] ACPI: Core revision 20180810
[    0.322817] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.322825] hpet clockevent registered
[    0.322829] APIC: Switch to symmetric I/O mode setup
[    0.323180] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.339495] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x28cdd796a76, max_idle_ns: 440795318065 ns
[    0.339506] Calibrating delay loop (skipped), value calculated using timer frequency.. 5663.46 BogoMIPS (lpj=9435940)
[    0.339508] pid_max: default: 32768 minimum: 301
[    0.339547] Security Framework initialized
[    0.339548] Yama: becoming mindful.
[    0.339553] AppArmor: AppArmor disabled by boot time parameter
[    0.342225] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.343941] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.344019] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.344075] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.344366] mce: CPU supports 6 MCE banks
[    0.344372] CPU0: Thermal monitoring enabled (TM2)
[    0.344375] process: using mwait in idle threads
[    0.344380] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[    0.344380] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[    0.344383] Spectre V2 : Mitigation: Full generic retpoline
[    0.344384] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.344385] Speculative Store Bypass: Vulnerable
[    0.344544] Freeing SMP alternatives memory: 28K
[    0.349496] smpboot: CPU0: Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz (family: 0x6, model: 0x17, stepping: 0xa)
[    0.366175] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[    0.366187] ... version:                2
[    0.366188] ... bit width:              40
[    0.366189] ... generic registers:      2
[    0.366190] ... value mask:             000000ffffffffff
[    0.366191] ... max period:             000000007fffffff
[    0.366192] ... fixed-purpose events:   3
[    0.366193] ... event mask:             0000000700000003
[    0.372835] rcu: Hierarchical SRCU implementation.
[    0.396242] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.402842] smp: Bringing up secondary CPUs ...
[    0.442850] x86: Booting SMP configuration:
[    0.442851] .... node  #0, CPUs:      #1 #2 #3
[    0.539587] smp: Brought up 1 node, 4 CPUs
[    0.539587] smpboot: Max logical packages: 1
[    0.539587] smpboot: Total of 4 processors activated (22655.85 BogoMIPS)
[    0.543261] devtmpfs: initialized
[    0.543261] x86/mm: Memory block size: 128MB
[    0.543854] PM: Registering ACPI NVS region [mem 0xcff8e000-0xcffcffff] (270336 bytes)
[    0.543854] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.543854] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.543854] pinctrl core: initialized pinctrl subsystem
[    0.543854] RTC time: 15:47:28, date: 11/21/18
[    0.543854] NET: Registered protocol family 16
[    0.543854] audit: initializing netlink subsys (disabled)
[    0.543854] audit: type=2000 audit(1542815248.219:1): state=initialized audit_enabled=0 res=1
[    0.543854] cpuidle: using governor ladder
[    0.543854] cpuidle: using governor menu
[    0.543854] ACPI: bus type PCI registered
[    0.543854] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.543854] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.543854] PCI: not using MMCONFIG
[    0.543854] PCI: Using configuration type 1 for base access
[    0.547484] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.547484] ACPI: Added _OSI(Module Device)
[    0.547484] ACPI: Added _OSI(Processor Device)
[    0.547484] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.547484] ACPI: Added _OSI(Processor Aggregator Device)
[    0.547484] ACPI: Added _OSI(Linux-Dell-Video)
[    0.547484] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.555112] ACPI: 2 ACPI AML tables successfully acquired and loaded
[    0.560589] ACPI: Dynamic OEM Table Load:
[    0.560595] ACPI: SSDT 0xFFFF89E36614D000 000235 (v01 DpgPmm P001Ist  00000011 INTL 20051117)
[    0.561076] ACPI: Dynamic OEM Table Load:
[    0.561081] ACPI: SSDT 0xFFFF89E36614E400 000235 (v01 DpgPmm P002Ist  00000012 INTL 20051117)
[    0.561561] ACPI: Dynamic OEM Table Load:
[    0.561566] ACPI: SSDT 0xFFFF89E36614D800 000235 (v01 DpgPmm P003Ist  00000012 INTL 20051117)
[    0.562049] ACPI: Dynamic OEM Table Load:
[    0.562053] ACPI: SSDT 0xFFFF89E36614DC00 000235 (v01 DpgPmm P004Ist  00000012 INTL 20051117)
[    0.562566] ACPI: Interpreter enabled
[    0.562588] ACPI: (supports S0 S1 S3 S4 S5)
[    0.562589] ACPI: Using IOAPIC for interrupt routing
[    0.562624] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.564179] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[    0.564195] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.564412] ACPI: Enabled 15 GPEs in block 00 to 3F
[    0.572657] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.572663] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.572668] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[    0.572991] PCI host bridge to bus 0000:00
[    0.572994] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.572995] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.572997] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.572998] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
[    0.573000] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xffffffff window]
[    0.573002] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.573009] pci 0000:00:00.0: [8086:2e20] type 00 class 0x060000
[    0.573030] DMAR: Disabling IOMMU for graphics on this chipset
[    0.573030] DMAR: Forcing write-buffer flush capability
[    0.573124] pci 0000:00:01.0: [8086:2e21] type 01 class 0x060400
[    0.573158] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.573277] pci 0000:00:1a.0: [8086:3a37] type 00 class 0x0c0300
[    0.573314] pci 0000:00:1a.0: reg 0x20: [io  0xb800-0xb81f]
[    0.573439] pci 0000:00:1a.1: [8086:3a38] type 00 class 0x0c0300
[    0.573475] pci 0000:00:1a.1: reg 0x20: [io  0xb880-0xb89f]
[    0.573599] pci 0000:00:1a.2: [8086:3a39] type 00 class 0x0c0300
[    0.573636] pci 0000:00:1a.2: reg 0x20: [io  0xbc00-0xbc1f]
[    0.573763] pci 0000:00:1a.7: [8086:3a3c] type 00 class 0x0c0320
[    0.573782] pci 0000:00:1a.7: reg 0x10: [mem 0xf9fffc00-0xf9ffffff]
[    0.573853] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[    0.573956] pci 0000:00:1b.0: [8086:3a3e] type 00 class 0x040300
[    0.573973] pci 0000:00:1b.0: reg 0x10: [mem 0xf9ff8000-0xf9ffbfff 64bit]
[    0.574033] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.574129] pci 0000:00:1c.0: [8086:3a40] type 01 class 0x060400
[    0.574194] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.574301] pci 0000:00:1c.1: [8086:3a42] type 01 class 0x060400
[    0.574376] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.574490] pci 0000:00:1c.4: [8086:3a48] type 01 class 0x060400
[    0.574554] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.574661] pci 0000:00:1c.5: [8086:3a4a] type 01 class 0x060400
[    0.574725] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    0.574833] pci 0000:00:1d.0: [8086:3a34] type 00 class 0x0c0300
[    0.574872] pci 0000:00:1d.0: reg 0x20: [io  0xb080-0xb09f]
[    0.574994] pci 0000:00:1d.1: [8086:3a35] type 00 class 0x0c0300
[    0.575031] pci 0000:00:1d.1: reg 0x20: [io  0xb400-0xb41f]
[    0.575157] pci 0000:00:1d.2: [8086:3a36] type 00 class 0x0c0300
[    0.575193] pci 0000:00:1d.2: reg 0x20: [io  0xb480-0xb49f]
[    0.575321] pci 0000:00:1d.7: [8086:3a3a] type 00 class 0x0c0320
[    0.575340] pci 0000:00:1d.7: reg 0x10: [mem 0xf9fff800-0xf9fffbff]
[    0.575411] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.575508] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.575641] pci 0000:00:1f.0: [8086:3a18] type 00 class 0x060100
[    0.575818] pci 0000:00:1f.2: [8086:3a22] type 00 class 0x010601
[    0.575833] pci 0000:00:1f.2: reg 0x10: [io  0xac00-0xac07]
[    0.575840] pci 0000:00:1f.2: reg 0x14: [io  0xa880-0xa883]
[    0.575846] pci 0000:00:1f.2: reg 0x18: [io  0xa800-0xa807]
[    0.575852] pci 0000:00:1f.2: reg 0x1c: [io  0xa480-0xa483]
[    0.575858] pci 0000:00:1f.2: reg 0x20: [io  0xa400-0xa41f]
[    0.575864] pci 0000:00:1f.2: reg 0x24: [mem 0xf9ffe800-0xf9ffefff]
[    0.575899] pci 0000:00:1f.2: PME# supported from D3hot
[    0.575995] pci 0000:00:1f.3: [8086:3a30] type 00 class 0x0c0500
[    0.576010] pci 0000:00:1f.3: reg 0x10: [mem 0xf9fff400-0xf9fff4ff 64bit]
[    0.576027] pci 0000:00:1f.3: reg 0x20: [io  0x0400-0x041f]
[    0.576156] pci 0000:01:00.0: [10de:0640] type 00 class 0x030000
[    0.576175] pci 0000:01:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[    0.576184] pci 0000:01:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.576192] pci 0000:01:00.0: reg 0x1c: [mem 0xfa000000-0xfbffffff 64bit]
[    0.576198] pci 0000:01:00.0: reg 0x24: [io  0xcc00-0xcc7f]
[    0.576204] pci 0000:01:00.0: reg 0x30: [mem 0xfe880000-0xfe8fffff pref]
[    0.576209] pci 0000:01:00.0: enabling Extended Tags
[    0.576258] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8 GT/s x16 link)
[    0.576309] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.576311] pci 0000:00:01.0:   bridge window [io  0xc000-0xcfff]
[    0.576313] pci 0000:00:01.0:   bridge window [mem 0xfa000000-0xfe8fffff]
[    0.576316] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.576354] pci 0000:00:1c.0: PCI bridge to [bus 05]
[    0.576362] pci 0000:00:1c.0:   bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
[    0.576414] pci 0000:04:00.0: [168c:002e] type 00 class 0x028000
[    0.576445] pci 0000:04:00.0: reg 0x10: [mem 0xfebf0000-0xfebfffff 64bit]
[    0.576557] pci 0000:04:00.0: supports D1
[    0.576558] pci 0000:04:00.0: PME# supported from D0 D1 D3hot
[    0.576594] pci 0000:04:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:1c.1 (capable of 7.876 Gb/s with 8 GT/s x1 link)
[    0.576653] pci 0000:00:1c.1: ASPM: current common clock configuration is broken, reconfiguring
[    0.586186] pci 0000:00:1c.1: PCI bridge to [bus 04]
[    0.586192] pci 0000:00:1c.1:   bridge window [mem 0xfeb00000-0xfebfffff]
[    0.586259] pci 0000:03:00.0: [11ab:6101] type 00 class 0x01018f
[    0.586284] pci 0000:03:00.0: reg 0x10: [io  0xec00-0xec07]
[    0.586295] pci 0000:03:00.0: reg 0x14: [io  0xe880-0xe883]
[    0.586307] pci 0000:03:00.0: reg 0x18: [io  0xe800-0xe807]
[    0.586318] pci 0000:03:00.0: reg 0x1c: [io  0xe480-0xe483]
[    0.586329] pci 0000:03:00.0: reg 0x20: [io  0xe400-0xe40f]
[    0.586341] pci 0000:03:00.0: reg 0x24: [mem 0xfeaffc00-0xfeaffdff]
[    0.586411] pci 0000:03:00.0: supports D1
[    0.586413] pci 0000:03:00.0: PME# supported from D0 D1 D3hot
[    0.586437] pci 0000:03:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:1c.4 (capable of 7.876 Gb/s with 8 GT/s x1 link)
[    0.586484] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device.  You can enable it with 'pcie_aspm=force'
[    0.586492] pci 0000:00:1c.4: PCI bridge to [bus 03]
[    0.586495] pci 0000:00:1c.4:   bridge window [io  0xe000-0xefff]
[    0.586498] pci 0000:00:1c.4:   bridge window [mem 0xfea00000-0xfeafffff]
[    0.586552] pci 0000:02:00.0: [1969:1026] type 00 class 0x020000
[    0.586582] pci 0000:02:00.0: reg 0x10: [mem 0xfe9c0000-0xfe9fffff 64bit]
[    0.586593] pci 0000:02:00.0: reg 0x18: [io  0xdc00-0xdc7f]
[    0.586688] pci 0000:02:00.0: PME# supported from D3hot D3cold
[    0.586718] pci 0000:02:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:1c.5 (capable of 7.876 Gb/s with 8 GT/s x1 link)
[    0.586765] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device.  You can enable it with 'pcie_aspm=force'
[    0.586772] pci 0000:00:1c.5: PCI bridge to [bus 02]
[    0.586775] pci 0000:00:1c.5:   bridge window [io  0xd000-0xdfff]
[    0.586778] pci 0000:00:1c.5:   bridge window [mem 0xfe900000-0xfe9fffff]
[    0.586795] pci_bus 0000:06: extended config space not accessible
[    0.586846] pci 0000:00:1e.0: PCI bridge to [bus 06] (subtractive decode)
[    0.586853] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.586855] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.586856] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.586858] pci 0000:00:1e.0:   bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
[    0.586859] pci 0000:00:1e.0:   bridge window [mem 0xd0000000-0xffffffff window] (subtractive decode)
[    0.587687] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[    0.587770] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.587851] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[    0.587932] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[    0.588013] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.588099] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[    0.588180] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
[    0.588262] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[    0.588333] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.588333] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.588333] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.588333] vgaarb: loaded
[    0.588333] ACPI: bus type USB registered
[    0.588333] usbcore: registered new interface driver usbfs
[    0.588333] usbcore: registered new interface driver hub
[    0.588341] usbcore: registered new device driver usb
[    0.588341] pps_core: LinuxPPS API ver. 1 registered
[    0.588341] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.588341] PTP clock support registered
[    0.588341] EDAC MC: Ver: 3.0.0
[    0.588341] PCI: Using ACPI for IRQ routing
[    0.591589] PCI: pci_cache_line_size set to 64 bytes
[    0.591636] e820: reserve RAM buffer [mem 0x0009cc00-0x0009ffff]
[    0.591637] e820: reserve RAM buffer [mem 0xcff80000-0xcfffffff]
[    0.592830] NetLabel: Initializing
[    0.592830] NetLabel:  domain hash size = 128
[    0.592830] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.592830] NetLabel:  unlabeled traffic allowed by default
[    0.593372] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
[    0.593376] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[    0.593380] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[    0.596253] clocksource: Switched to clocksource tsc-early
[    0.611266] VFS: Disk quotas dquot_6.6.0
[    0.611288] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.611379] pnp: PnP ACPI init
[    0.611497] system 00:00: [mem 0xfed14000-0xfed19fff] has been reserved
[    0.611503] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.611595] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.611854] system 00:02: [io  0x0290-0x029f] has been reserved
[    0.611859] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.612058] system 00:03: [io  0x04d0-0x04d1] has been reserved
[    0.612059] system 00:03: [io  0x0800-0x087f] has been reserved
[    0.612061] system 00:03: [io  0x0500-0x057f] has been reserved
[    0.612063] system 00:03: [mem 0xfed08000-0xfed08fff] has been reserved
[    0.612065] system 00:03: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.612067] system 00:03: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.612069] system 00:03: [mem 0xfed50000-0xfed8ffff] has been reserved
[    0.612074] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.612223] system 00:04: [mem 0xffc00000-0xffefffff] has been reserved
[    0.612228] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.612414] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.612416] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.612421] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.612740] pnp 00:06: [dma 0 disabled]
[    0.612807] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.612887] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.612892] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.613116] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.613118] system 00:08: [mem 0x000c0000-0x000cffff] could not be reserved
[    0.613119] system 00:08: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.613121] system 00:08: [mem 0x00100000-0xcfffffff] could not be reserved
[    0.613126] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.613302] pnp: PnP ACPI: found 9 devices
[    0.619554] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.619572] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 05] add_size 1000
[    0.619575] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 05] add_size 400000 add_align 100000
[    0.619583] pci 0000:00:1c.1: bridge window [io  0x1000-0x0fff] to [bus 04] add_size 1000
[    0.619585] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04] add_size 200000 add_align 100000
[    0.619592] pci 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[    0.619599] pci 0000:00:1c.5: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    0.619611] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf0000000-0xf03fffff]
[    0.619615] pci 0000:00:1c.1: BAR 15: assigned [mem 0xf0400000-0xf05fffff 64bit pref]
[    0.619619] pci 0000:00:1c.4: BAR 15: assigned [mem 0xf0600000-0xf07fffff 64bit pref]
[    0.619623] pci 0000:00:1c.5: BAR 15: assigned [mem 0xf0800000-0xf09fffff 64bit pref]
[    0.619625] pci 0000:00:1c.0: BAR 13: assigned [io  0x1000-0x1fff]
[    0.619627] pci 0000:00:1c.1: BAR 13: assigned [io  0x2000-0x2fff]
[    0.619631] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.619633] pci 0000:00:01.0:   bridge window [io  0xc000-0xcfff]
[    0.619635] pci 0000:00:01.0:   bridge window [mem 0xfa000000-0xfe8fffff]
[    0.619637] pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.619641] pci 0000:00:1c.0: PCI bridge to [bus 05]
[    0.619643] pci 0000:00:1c.0:   bridge window [io  0x1000-0x1fff]
[    0.619646] pci 0000:00:1c.0:   bridge window [mem 0xf0000000-0xf03fffff]
[    0.619649] pci 0000:00:1c.0:   bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
[    0.619653] pci 0000:00:1c.1: PCI bridge to [bus 04]
[    0.619656] pci 0000:00:1c.1:   bridge window [io  0x2000-0x2fff]
[    0.619659] pci 0000:00:1c.1:   bridge window [mem 0xfeb00000-0xfebfffff]
[    0.619662] pci 0000:00:1c.1:   bridge window [mem 0xf0400000-0xf05fffff 64bit pref]
[    0.619666] pci 0000:00:1c.4: PCI bridge to [bus 03]
[    0.619668] pci 0000:00:1c.4:   bridge window [io  0xe000-0xefff]
[    0.619672] pci 0000:00:1c.4:   bridge window [mem 0xfea00000-0xfeafffff]
[    0.619674] pci 0000:00:1c.4:   bridge window [mem 0xf0600000-0xf07fffff 64bit pref]
[    0.619679] pci 0000:00:1c.5: PCI bridge to [bus 02]
[    0.619681] pci 0000:00:1c.5:   bridge window [io  0xd000-0xdfff]
[    0.619684] pci 0000:00:1c.5:   bridge window [mem 0xfe900000-0xfe9fffff]
[    0.619687] pci 0000:00:1c.5:   bridge window [mem 0xf0800000-0xf09fffff 64bit pref]
[    0.619692] pci 0000:00:1e.0: PCI bridge to [bus 06]
[    0.619700] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.619702] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.619703] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.619705] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
[    0.619706] pci_bus 0000:00: resource 8 [mem 0xd0000000-0xffffffff window]
[    0.619708] pci_bus 0000:01: resource 0 [io  0xc000-0xcfff]
[    0.619709] pci_bus 0000:01: resource 1 [mem 0xfa000000-0xfe8fffff]
[    0.619711] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.619713] pci_bus 0000:05: resource 0 [io  0x1000-0x1fff]
[    0.619714] pci_bus 0000:05: resource 1 [mem 0xf0000000-0xf03fffff]
[    0.619715] pci_bus 0000:05: resource 2 [mem 0xf8f00000-0xf8ffffff 64bit pref]
[    0.619717] pci_bus 0000:04: resource 0 [io  0x2000-0x2fff]
[    0.619718] pci_bus 0000:04: resource 1 [mem 0xfeb00000-0xfebfffff]
[    0.619720] pci_bus 0000:04: resource 2 [mem 0xf0400000-0xf05fffff 64bit pref]
[    0.619721] pci_bus 0000:03: resource 0 [io  0xe000-0xefff]
[    0.619723] pci_bus 0000:03: resource 1 [mem 0xfea00000-0xfeafffff]
[    0.619724] pci_bus 0000:03: resource 2 [mem 0xf0600000-0xf07fffff 64bit pref]
[    0.619726] pci_bus 0000:02: resource 0 [io  0xd000-0xdfff]
[    0.619727] pci_bus 0000:02: resource 1 [mem 0xfe900000-0xfe9fffff]
[    0.619728] pci_bus 0000:02: resource 2 [mem 0xf0800000-0xf09fffff 64bit pref]
[    0.619730] pci_bus 0000:06: resource 4 [io  0x0000-0x0cf7 window]
[    0.619732] pci_bus 0000:06: resource 5 [io  0x0d00-0xffff window]
[    0.619733] pci_bus 0000:06: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.619735] pci_bus 0000:06: resource 7 [mem 0x000d0000-0x000dffff window]
[    0.619736] pci_bus 0000:06: resource 8 [mem 0xd0000000-0xffffffff window]
[    0.619819] NET: Registered protocol family 2
[    0.620048] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
[    0.620095] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.620325] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.620644] TCP: Hash tables configured (established 65536 bind 65536)
[    0.620698] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.620742] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.620830] NET: Registered protocol family 1
[    0.620836] NET: Registered protocol family 44
[    0.622064] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.622073] PCI: CLS 32 bytes, default 64
[    0.622121] Unpacking initramfs...
[    0.740588] Freeing initrd memory: 9716K
[    0.740593] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.740595] software IO TLB: mapped [mem 0xcbf80000-0xcff80000] (64MB)
[    0.740818] Scanning for low memory corruption every 60 seconds
[    0.741493] Initialise system trusted keyrings
[    0.741505] Key type blacklist registered
[    0.741632] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[    0.743292] zbud: loaded
[    0.743568] pstore: using zstd compression
[    0.747063] Key type asymmetric registered
[    0.747065] Asymmetric key parser 'x509' registered
[    0.747074] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.747168] io scheduler noop registered
[    0.747169] io scheduler deadline registered
[    0.747200] io scheduler cfq registered (default)
[    0.747201] io scheduler mq-deadline registered
[    0.747202] io scheduler kyber registered
[    0.747228] io scheduler bfq registered
[    0.747255] io scheduler bfq-sq registered
[    0.747256] BFQ I/O-scheduler: v9 (with cgroups support)
[    0.747258] blkcg_policy_register: BLKCG_MAX_POLS too small
[    0.747637] pcieport 0000:00:1c.0: enabling device (0106 -> 0107)
[    0.747745] pcieport 0000:00:1c.1: enabling device (0106 -> 0107)
[    0.748075] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.748153] intel_idle: does not run on family 6 model 23
[    0.748225] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.748235] ACPI: Power Button [PWRB]
[    0.748281] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.748295] ACPI: Power Button [PWRF]
[    0.748734] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.769284] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.770397] usbcore: registered new interface driver usbserial_generic
[    0.770403] usbserial: USB Serial support registered for generic
[    0.770422] rtc_cmos 00:01: RTC can wake from S4
[    0.770545] rtc_cmos 00:01: registered as rtc0
[    0.770562] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.770682] ledtrig-cpu: registered to indicate activity on CPUs
[    0.770937] NET: Registered protocol family 10
[    0.775185] Segment Routing with IPv6
[    0.775203] NET: Registered protocol family 17
[    0.775440] RAS: Correctable Errors collector initialized.
[    0.775480] microcode: sig=0x1067a, pf=0x10, revision=0xa0b
[    0.775539] microcode: Microcode Update Driver: v2.2.
[    0.775551] sched_clock: Marking stable (772172695, 3362329)->(925683766, -150148742)
[    0.775779] registered taskstats version 1
[    0.775787] Loading compiled-in X.509 certificates
[    0.778561] Loaded X.509 cert 'Build time autogenerated kernel key: 7f6e4b3182e05b628a0542b67232d36148044914'
[    0.778579] zswap: loaded using pool lzo/zbud
[    0.782207] Key type big_key registered
[    0.782563]   Magic number: 10:436:791
[    0.782667] rtc_cmos 00:01: setting system clock to 2018-11-21 15:47:28 UTC (1542815248)
[    0.784996] Freeing unused decrypted memory: 2040K
[    0.786014] Freeing unused kernel image memory: 1536K
[    0.786047] Write protecting the kernel read-only data: 18432k
[    0.786894] Freeing unused kernel image memory: 2008K
[    0.787087] Freeing unused kernel image memory: 408K
[    0.797717] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.797794] x86/mm: Checking user space page tables
[    0.808197] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.808200] Run /init as init process
[    0.896846] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.898042] ehci-pci: EHCI PCI platform driver
[    0.898222] ehci-pci 0000:00:1a.7: EHCI Host Controller
[    0.898229] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[    0.898240] ehci-pci 0000:00:1a.7: debug port 1
[    0.902217] SCSI subsystem initialized
[    0.903473] ehci-pci 0000:00:1a.7: cache line size of 32 is not supported
[    0.903492] ehci-pci 0000:00:1a.7: irq 18, io mem 0xf9fffc00
[    0.909885] libata version 3.00 loaded.
[    0.911446] scsi host0: pata_marvell
[    0.913738] ahci 0000:00:1f.2: version 3.0
[    0.913915] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[    0.913946] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
[    0.913949] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part ccc ems sxs
[    0.914028] scsi host1: pata_marvell
[    0.914138] ata1: PATA max UDMA/100 cmd 0xec00 ctl 0xe880 bmdma 0xe400 irq 16
[    0.914139] ata2: DUMMY
[    0.919490] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    0.919556] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.919558] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.919559] usb usb1: Product: EHCI Host Controller
[    0.919561] usb usb1: Manufacturer: Linux 4.19.2-1-MANJARO ehci_hcd
[    0.919562] usb usb1: SerialNumber: 0000:00:1a.7
[    0.919688] hub 1-0:1.0: USB hub found
[    0.919696] hub 1-0:1.0: 6 ports detected
[    0.919996] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    0.920001] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    0.920011] ehci-pci 0000:00:1d.7: debug port 1
[    0.923906] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported
[    0.923920] ehci-pci 0000:00:1d.7: irq 23, io mem 0xf9fff800
[    0.939456] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    0.939510] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.939513] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.939515] usb usb2: Product: EHCI Host Controller
[    0.939517] usb usb2: Manufacturer: Linux 4.19.2-1-MANJARO ehci_hcd
[    0.939519] usb usb2: SerialNumber: 0000:00:1d.7
[    0.939657] hub 2-0:1.0: USB hub found
[    0.939665] hub 2-0:1.0: 6 ports detected
[    0.941951] uhci_hcd: USB Universal Host Controller Interface driver
[    0.942070] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    0.942083] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    0.942090] uhci_hcd 0000:00:1a.0: detected 2 ports
[    0.942107] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000b800
[    0.942163] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.942165] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.942167] usb usb3: Product: UHCI Host Controller
[    0.942168] usb usb3: Manufacturer: Linux 4.19.2-1-MANJARO uhci_hcd
[    0.942169] usb usb3: SerialNumber: 0000:00:1a.0
[    0.942284] hub 3-0:1.0: USB hub found
[    0.942291] hub 3-0:1.0: 2 ports detected
[    0.942498] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    0.942502] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    0.942507] uhci_hcd 0000:00:1a.1: detected 2 ports
[    0.942531] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000b880
[    0.942579] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.942581] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.942583] usb usb4: Product: UHCI Host Controller
[    0.942584] usb usb4: Manufacturer: Linux 4.19.2-1-MANJARO uhci_hcd
[    0.942586] usb usb4: SerialNumber: 0000:00:1a.1
[    0.942684] hub 4-0:1.0: USB hub found
[    0.942753] hub 4-0:1.0: 2 ports detected
[    0.942968] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[    0.942973] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[    0.942979] uhci_hcd 0000:00:1a.2: detected 2 ports
[    0.942996] uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000bc00
[    0.943049] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.943051] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.943052] usb usb5: Product: UHCI Host Controller
[    0.943054] usb usb5: Manufacturer: Linux 4.19.2-1-MANJARO uhci_hcd
[    0.943055] usb usb5: SerialNumber: 0000:00:1a.2
[    0.943152] hub 5-0:1.0: USB hub found
[    0.943159] hub 5-0:1.0: 2 ports detected
[    0.943349] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    0.943354] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[    0.943359] uhci_hcd 0000:00:1d.0: detected 2 ports
[    0.943376] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b080
[    0.943422] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.943424] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.943426] usb usb6: Product: UHCI Host Controller
[    0.943427] usb usb6: Manufacturer: Linux 4.19.2-1-MANJARO uhci_hcd
[    0.943428] usb usb6: SerialNumber: 0000:00:1d.0
[    0.943533] hub 6-0:1.0: USB hub found
[    0.943540] hub 6-0:1.0: 2 ports detected
[    0.943734] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    0.943741] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[    0.943746] uhci_hcd 0000:00:1d.1: detected 2 ports
[    0.943769] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b400
[    0.943822] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.943823] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.943825] usb usb7: Product: UHCI Host Controller
[    0.943826] usb usb7: Manufacturer: Linux 4.19.2-1-MANJARO uhci_hcd
[    0.943828] usb usb7: SerialNumber: 0000:00:1d.1
[    0.943939] hub 7-0:1.0: USB hub found
[    0.943945] hub 7-0:1.0: 2 ports detected
[    0.944124] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    0.944129] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[    0.944134] uhci_hcd 0000:00:1d.2: detected 2 ports
[    0.944150] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000b480
[    0.944198] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.944200] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.944201] usb usb8: Product: UHCI Host Controller
[    0.944203] usb usb8: Manufacturer: Linux 4.19.2-1-MANJARO uhci_hcd
[    0.944204] usb usb8: SerialNumber: 0000:00:1d.2
[    0.944317] hub 8-0:1.0: USB hub found
[    0.944324] hub 8-0:1.0: 2 ports detected
[    0.966796] scsi host2: ahci
[    0.966913] scsi host3: ahci
[    0.967042] scsi host4: ahci
[    0.967147] scsi host5: ahci
[    0.967286] scsi host6: ahci
[    0.967393] scsi host7: ahci
[    0.967445] ata3: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffe900 irq 24
[    0.967447] ata4: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffe980 irq 24
[    0.967449] ata5: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffea00 irq 24
[    0.967450] ata6: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffea80 irq 24
[    0.967451] ata7: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffeb00 irq 24
[    0.967453] ata8: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffeb80 irq 24
[    1.076169] ata1.00: ATAPI: HL-DT-ST RW/DVD GCC-4320B, 1.00, max UDMA/33
[    1.084001] scsi 0:0:0:0: CD-ROM            HL-DT-ST RW/DVD GCC-4320B 1.00 PQ: 0 ANSI: 5
[    1.248881] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.401985] usb 1-1: New USB device found, idVendor=058f, idProduct=6364, bcdDevice= 1.00
[    1.401988] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.401990] usb 1-1: Product: Mass Storage Device
[    1.401992] usb 1-1: Manufacturer: Generic
[    1.401994] usb 1-1: SerialNumber: 058F63646476
[    1.405454] usb-storage 1-1:1.0: USB Mass Storage device detected
[    1.405569] scsi host8: usb-storage 1-1:1.0
[    1.405643] usbcore: registered new interface driver usb-storage
[    1.406174] usb 6-1: new low-speed USB device number 2 using uhci_hcd
[    1.406355] hidraw: raw HID events driver (C) Jiri Kosina
[    1.407216] usbcore: registered new interface driver uas
[    1.409672] usbcore: registered new interface driver usbhid
[    1.409673] usbhid: USB HID core driver
[    1.411440] hid-generic 0003:058F:6364.0001: hiddev0,hidraw0: USB HID v1.10 Device [Generic Mass Storage Device] on usb-0000:00:1a.7-1/input1
[    1.446178] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.446422] ata3.00: supports DRM functions and may not be fully accessible
[    1.446860] ata3.00: NCQ Send/Recv Log not supported
[    1.446862] ata3.00: ATA-9: Samsung SSD 850 EVO 250GB, EMT01B6Q, max UDMA/133
[    1.446864] ata3.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    1.448037] ata3.00: supports DRM functions and may not be fully accessible
[    1.448420] ata3.00: NCQ Send/Recv Log not supported
[    1.449332] ata3.00: configured for UDMA/133
[    1.449480] scsi 2:0:0:0: Direct-Access     ATA      Samsung SSD 850  1B6Q PQ: 0 ANSI: 5
[    1.595046] usb 6-1: New USB device found, idVendor=056a, idProduct=0062, bcdDevice= 2.00
[    1.595049] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.595051] usb 6-1: Product: CTF-420 V2.0-0
[    1.595053] usb 6-1: Manufacturer: WACOM
[    1.618707] input: WACOM CTF-420 V2.0-0 Mouse as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/0003:056A:0062.0002/input/input2
[    1.618767] hid-generic 0003:056A:0062.0002: input,hiddev1,hidraw1: USB HID v1.10 Mouse [WACOM CTF-420 V2.0-0] on usb-0000:00:1d.0-1/input0
[    1.759509] tsc: Refined TSC clocksource calibration: 2830.499 MHz
[    1.759515] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x28cccbbd7ae, max_idle_ns: 440795202126 ns
[    1.759533] clocksource: Switched to clocksource tsc
[    1.919519] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.061050] ata4.00: ATA-8: TOSHIBA HDWE160, FS2A, max UDMA/100
[    2.061052] ata4.00: 11721045168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.061952] ata4.00: configured for UDMA/100
[    2.062081] scsi 3:0:0:0: Direct-Access     ATA      TOSHIBA HDWE160  FS2A PQ: 0 ANSI: 5
[    2.159508] usb 8-1: new low-speed USB device number 2 using uhci_hcd
[    2.330530] usb 8-1: New USB device found, idVendor=04f3, idProduct=0103, bcdDevice= 1.07
[    2.330533] usb 8-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.426964] scsi 8:0:0:0: Direct-Access     Generic- SD/MMC           1.00 PQ: 0 ANSI: 0
[    2.427586] scsi 8:0:0:1: Direct-Access     Generic- Compact Flash    1.01 PQ: 0 ANSI: 0
[    2.428211] scsi 8:0:0:2: Direct-Access     Generic- SM/xD-Picture    1.02 PQ: 0 ANSI: 0
[    2.428835] scsi 8:0:0:3: Direct-Access     Generic- MS/MS-Pro        1.03 PQ: 0 ANSI: 0 CCS
[    2.431805] sd 3:0:0:0: [sdb] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[    2.431806] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[    2.431818] sd 3:0:0:0: [sdb] Write Protect is off
[    2.431820] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.431839] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.432144] sd 2:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[    2.432155] sd 2:0:0:0: [sda] Write Protect is off
[    2.432157] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.432175] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.433900]  sda: sda1 sda2 sda3 sda4 sda5 sda6 sda8 sda9
[    2.434901] sd 2:0:0:0: [sda] supports TCG Opal
[    2.434903] sd 2:0:0:0: [sda] Attached SCSI disk
[    2.437709] sd 8:0:0:2: [sde] Attached SCSI removable disk
[    2.439208] sd 8:0:0:0: [sdc] Attached SCSI removable disk
[    2.446459] sd 8:0:0:1: [sdd] Attached SCSI removable disk
[    2.447205] sd 8:0:0:3: [sdf] Attached SCSI removable disk
[    2.532850] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.533313] ata5.00: ATA-9: WDC WD40EZRZ-00WN9B0, 80.00A80, max UDMA/133
[    2.533315] ata5.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    2.533790] ata5.00: configured for UDMA/133
[    2.533920] scsi 4:0:0:0: Direct-Access     ATA      WDC WD40EZRZ-00W 0A80 PQ: 0 ANSI: 5
[    2.534132] sd 4:0:0:0: [sdg] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[    2.534134] sd 4:0:0:0: [sdg] 4096-byte physical blocks
[    2.534145] sd 4:0:0:0: [sdg] Write Protect is off
[    2.534146] sd 4:0:0:0: [sdg] Mode Sense: 00 3a 00 00
[    2.534174] sd 4:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.688382]  sdb: sdb1 sdb2 sdb3 sdb4
[    2.688781] sd 3:0:0:0: [sdb] Attached SCSI disk
[    2.949509] usb 8-2: new low-speed USB device number 3 using uhci_hcd
[    3.002843] ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    3.005862] ata6.00: ATAPI: PIONEER BD-RW   BDR-206D, 1.04, max UDMA/100
[    3.009212] ata6.00: configured for UDMA/100
[    3.019841] scsi 5:0:0:0: CD-ROM            PIONEER  BD-RW   BDR-206D 1.04 PQ: 0 ANSI: 5
[    3.110517] random: fast init done
[    3.131529] usb 8-2: New USB device found, idVendor=275d, idProduct=0ba6, bcdDevice= 1.00
[    3.131532] usb 8-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.131535] usb 8-2: Product: USB OPTICAL MOUSE
[    3.148939] input: USB OPTICAL MOUSE  as /devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.0/0003:275D:0BA6.0003/input/input4
[    3.148983] hid-generic 0003:275D:0BA6.0003: input,hidraw2: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-0000:00:1d.2-2/input0
[    3.154077]  sdg: sdg1 sdg2 sdg3 sdg4
[    3.154463] sd 4:0:0:0: [sdg] Attached SCSI disk
[    3.378899] ata7: SATA link down (SStatus 0 SControl 300)
[    3.692237] ata8: SATA link down (SStatus 0 SControl 300)
[    3.724390] sr 0:0:0:0: [sr0] scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
[    3.724394] cdrom: Uniform CD-ROM driver Revision: 3.20
[    3.724688] sr 0:0:0:0: Attached scsi CD-ROM sr0
[    3.765570] sr 5:0:0:0: [sr1] scsi3-mmc drive: 125x/125x writer cd/rw xa/form2 cdda tray
[    3.765739] sr 5:0:0:0: Attached scsi CD-ROM sr1
[    4.371372] PM: Image not found (code -22)
[    4.477083] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[    4.619055] systemd[1]: systemd 239 running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    4.632968] systemd[1]: Detected architecture x86-64.
[    4.635520] systemd[1]: Set hostname to <samspade>.
[    4.672193] random: crng init done
[    4.788797] systemd[1]: Reached target Host and Network Name Lookups.
[    4.788959] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.790233] systemd[1]: Created slice system-getty.slice.
[    4.790245] systemd[1]: Reached target Login Prompts.
[    4.790299] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.795343] systemd[1]: Listening on RPCbind Server Activation Socket.
[    4.795376] systemd[1]: Reached target RPC Port Mapper.
[    4.812183] EXT4-fs (sda5): re-mounted. Opts: discard
[    4.820988] sr 0:0:0:0: Attached scsi generic sg0 type 5
[    4.821026] sd 2:0:0:0: Attached scsi generic sg1 type 0
[    4.821061] sd 3:0:0:0: Attached scsi generic sg2 type 0
[    4.821102] sd 8:0:0:0: Attached scsi generic sg3 type 0
[    4.821143] sd 8:0:0:1: Attached scsi generic sg4 type 0
[    4.821181] sd 8:0:0:2: Attached scsi generic sg5 type 0
[    4.821226] sd 8:0:0:3: Attached scsi generic sg6 type 0
[    4.821263] sd 4:0:0:0: Attached scsi generic sg7 type 0
[    4.821298] sr 5:0:0:0: Attached scsi generic sg8 type 5
[    4.831051] vboxdrv: loading out-of-tree module taints kernel.
[    4.831384] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[    4.836421] vboxdrv: Found 4 processor cores
[    4.845610] vboxdrv: fAsync=0 offMin=0x220 offMax=0x237f
[    4.853548] audit: type=1130 audit(1542815252.566:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.858096] audit: type=1130 audit(1542815252.570:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.858862] audit: type=1130 audit(1542815252.570:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.875714] audit: type=1130 audit(1542815252.586:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.886304] RPC: Registered named UNIX socket transport module.
[    4.886305] RPC: Registered udp transport module.
[    4.886306] RPC: Registered tcp transport module.
[    4.886307] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    4.904098] audit: type=1130 audit(1542815252.616:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=keyboardctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.904109] audit: type=1131 audit(1542815252.616:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=keyboardctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.945281] audit: type=1130 audit(1542815252.656:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.945749] vboxdrv: TSC mode is Synchronous, tentative frequency 2830498699 Hz
[    4.945750] vboxdrv: Successfully loaded version 5.2.22 (interface 0x00290001)
[    4.947036] VBoxNetAdp: Successfully started.
[    4.948231] audit: type=1130 audit(1542815252.660:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.949215] VBoxNetFlt: Successfully started.
[    4.951541] VBoxPciLinuxInit
[    4.951546] vboxpci: IOMMU not found (not registered)
[    4.952636] audit: type=1130 audit(1542815252.663:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.968642] systemd-journald[270]: Received request to flush runtime journal from PID 1
[    4.969925] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    5.092800] Linux agpgart interface v0.103
[    5.146680] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20180810/utaddress-213)
[    5.146688] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.146691] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000053F (\GPS0) (20180810/utaddress-213)
[    5.146694] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.146695] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000053F (\GPS0) (20180810/utaddress-213)
[    5.146699] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.146700] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    5.246380] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.264176] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.311496] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1200: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[    5.311499] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    5.311501] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    5.311503] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    5.311504] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x11/0x1e
[    5.311505] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    5.311508] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    5.311509] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    5.311511] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    5.315886] input: Wacom Volito2 4x5 Pen as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/0003:056A:0062.0002/input/input5
[    5.315963] wacom 0003:056A:0062.0002: hidraw1: USB HID v1.10 Mouse [WACOM CTF-420 V2.0-0] on usb-0000:00:1d.0-1/input0
[    5.326912] mousedev: PS/2 mouse device common for all mice
[    5.343307] input: PC Speaker as /devices/platform/pcspkr/input/input9
[    5.350219] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    5.351004] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    5.351059] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    5.351111] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    5.351165] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[    5.351218] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[    5.351271] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[    5.351322] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[    5.351374] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[    5.363387] ACPI Warning: SystemIO range 0x0000000000000400-0x000000000000041F conflicts with OpRegion 0x0000000000000400-0x000000000000040F (\SMRG) (20180810/utaddress-213)
[    5.363395] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    5.533472] Adding 10485756k swap on /dev/sdb2.  Priority:-2 extents:1 across:10485756k FS
[    5.547628] kauditd_printk_skb: 64 callbacks suppressed
[    5.547629] audit: type=1325 audit(1542815253.246:35): table=filter family=10 entries=160
[    5.547634] audit: type=1300 audit(1542815253.246:35): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=29 a2=40 a3=55f636d8dcc0 items=0 ppid=312 pid=492 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables-resto" exe="/usr/bin/xtables-legacy-multi" key=(null)
[    5.547636] audit: type=1327 audit(1542815253.246:35): proctitle=6970367461626C65732D726573746F7265002D6E
[    5.553132] audit: type=1325 audit(1542815253.266:36): table=filter family=10 entries=178
[    5.553136] audit: type=1300 audit(1542815253.266:36): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=29 a2=40 a3=55ace0df4a90 items=0 ppid=312 pid=518 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="ip6tables-resto" exe="/usr/bin/xtables-legacy-multi" key=(null)
[    5.553139] audit: type=1327 audit(1542815253.266:36): proctitle=6970367461626C65732D726573746F7265002D6E
[    5.572701] audit: type=1130 audit(1542815253.283:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.582488] audit: type=1130 audit(1542815253.293:38): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2dlabel-Ubuntu comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.586092] iTCO_vendor_support: vendor-support=0
[    5.592168] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    5.592235] iTCO_wdt: Found a ICH10 TCO device (Version=2, TCOBASE=0x0860)
[    5.592345] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    5.594025] audit: type=1130 audit(1542815253.306:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2dlabel-VBMachines comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.598389] audit: type=1130 audit(1542815253.310:40): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2dlabel-Home comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.599530] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: discard
[    5.614379] ATL1E 0000:02:00.0 enp2s0: renamed from eth0
[    5.618936] EXT4-fs (sda6): mounted filesystem with writeback data mode. Opts: discard
[    5.627363] EXT4-fs (sda8): mounted filesystem with writeback data mode. Opts: discard
[    5.629973] EXT4-fs (sda4): mounting ext3 file system using the ext4 subsystem
[    5.637489] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
[    5.656832] intel_powerclamp: No package C-state available
[    5.659373] nouveau 0000:01:00.0: NVIDIA G96 (096000c1)
[    5.800132] ath: EEPROM regdomain: 0x809c
[    5.800134] ath: EEPROM indicates we should expect a country code
[    5.800134] ath: doing EEPROM country->regdmn map search
[    5.800135] ath: country maps to regdmn code: 0x52
[    5.800136] ath: Country alpha2 being used: CN
[    5.800137] ath: Regpair used: 0x52
[    5.806445] nouveau 0000:01:00.0: bios: version 62.94.29.00.00
[    5.808132] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    5.809154] ieee80211 phy0: Atheros AR9287 Rev:2 mem=0xffffaeb101470000, irq=17
[    5.811537] ath9k 0000:04:00.0 wlp4s0: renamed from wlan0
[    5.828336] nouveau 0000:01:00.0: bios: M0203T not found
[    5.828338] nouveau 0000:01:00.0: bios: M0203E not matched!
[    5.828341] nouveau 0000:01:00.0: fb: 512 MiB DDR2
[    5.841347] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[    5.869631] EXT4-fs (sdb4): mounted filesystem with ordered data mode. Opts: (null)
[    5.903756] [TTM] Zone  kernel: Available graphics memory: 4083502 kiB
[    5.903758] [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
[    5.903759] [TTM] Initializing pool allocator
[    5.903764] [TTM] Initializing DMA pool allocator
[    5.903783] nouveau 0000:01:00.0: DRM: VRAM: 512 MiB
[    5.903784] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[    5.903788] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[    5.903790] nouveau 0000:01:00.0: DRM: DCB version 4.0
[    5.903792] nouveau 0000:01:00.0: DRM: DCB outp 00: 02000300 00000028
[    5.903795] nouveau 0000:01:00.0: DRM: DCB outp 01: 01000302 00020030
[    5.903797] nouveau 0000:01:00.0: DRM: DCB outp 02: 04011310 00000028
[    5.903798] nouveau 0000:01:00.0: DRM: DCB outp 03: 02011312 00020030
[    5.903800] nouveau 0000:01:00.0: DRM: DCB outp 04: 010223f1 00c0c080
[    5.903802] nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
[    5.903803] nouveau 0000:01:00.0: DRM: DCB conn 01: 00002130
[    5.903805] nouveau 0000:01:00.0: DRM: DCB conn 02: 00000210
[    5.903806] nouveau 0000:01:00.0: DRM: DCB conn 03: 00000211
[    5.903808] nouveau 0000:01:00.0: DRM: DCB conn 04: 00000213
[    5.905023] nouveau 0000:01:00.0: DRM: failed to create encoder 0/1/0: -19
[    5.905025] nouveau 0000:01:00.0: DRM: TV-1 has no encoders, removing
[    5.905077] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    5.905078] [drm] Driver supports precise vblank timestamp query.
[    6.063271] EXT4-fs (sdb3): mounted filesystem with writeback data mode. Opts: (null)
[    6.157309] nouveau 0000:01:00.0: DRM: MM: using CRYPT for buffer copies
[    6.198496] nouveau 0000:01:00.0: DRM: allocated 1920x1080 fb: 0x70000, bo 000000006cb1a5fb
[    6.199796] fbcon: nouveaufb (fb0) is primary device
[    6.246724] EXT4-fs (sdg4): mounted filesystem with writeback data mode. Opts: (null)
[    6.251216] EXT4-fs (sdg2): mounted filesystem with ordered data mode. Opts: (null)
[    6.304023] EXT4-fs (sdg3): mounted filesystem with ordered data mode. Opts: (null)
[    6.330696] Console: switching to colour frame buffer device 240x67
[    6.333281] nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
[    6.353378] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[    6.383142] EXT4-fs (sdg1): mounted filesystem with ordered data mode. Opts: (null)
[    6.825728] NFSD: starting 45-second grace period (net f0000098)
[    7.061623] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[    7.061891] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[    7.064707] IPv6: ADDRCONF(NETDEV_UP): wlp4s0: link is not ready
[    7.423397] ATL1E 0000:02:00.0 enp2s0: NIC Link is Up <1000 Mbps Full Duplex>
[    7.423412] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[    8.571589] fuse init (API version 7.27)
[   10.836930] kauditd_printk_skb: 41 callbacks suppressed
[   10.836932] audit: type=1131 audit(1542815258.550:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.017857] audit: type=1131 audit(1542815264.730:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.706922] audit: type=1006 audit(1542815273.420:84): pid=911 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   25.730851] audit: type=1130 audit(1542815273.443:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.743540] audit: type=1006 audit(1542815273.456:86): pid=930 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[   25.762225] audit: type=1131 audit(1542815273.473:87): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.787633] audit: type=1131 audit(1542815273.500:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.848569] audit: type=1130 audit(1542815273.560:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.184984] audit: type=1130 audit(1542815273.896:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.906753] audit: type=1130 audit(1542815274.620:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   27.315008] audit: type=1130 audit(1542815275.026:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   27.889779] audit: type=1130 audit(1542815275.603:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   37.034736] kauditd_printk_skb: 1 callbacks suppressed
[   37.034738] audit: type=1131 audit(1542815284.750:95): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   47.798009] usb 8-1: USB disconnect, device number 2
[   53.789058] usb 8-1: new low-speed USB device number 4 using uhci_hcd
[   53.953553] usb 8-1: New USB device found, idVendor=04f3, idProduct=0103, bcdDevice= 1.07
[   53.953556] usb 8-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   59.610731] audit: type=1130 audit(1542815307.480:96): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   60.899821] audit: type=1131 audit(1542815308.771:97): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
No super powers?
That's a good thing, isn't it? :slight_smile:
Again, that's not how things work. Newer minor releases bring bugfixes and security fixes, and AFAIK the kernels are built semi-automatically with a script.
The source comes directly from kernel.org.
Check the history here:
What we can see is that there have effectively been changes to the HID subsystem, built as modules instead of baked into the kernel, plus two additional patches for i2c-hid.
I think it's possible that these changes might have introduced a problem.
I have the feeling that you are trying to explain me that things work badly.
Why don't we have a version n-1 not including a particular fix as well as a version n including that fix ?
Sometimes I can see a quick error boot message saying that some module(s) has(ve) could been loaded. Do you know how could I investigate this track ?
You apparently lack the ability to comprehend what @anon23612428 has explained to you several times now. Torvic has given you the solution to your issue, yet you continue to bemoan how poorly things work in Manjaro. What exactly is the issue now. From my outside perspective your problem was solved with an inexpensive adapter that you probably already had on hand.
I always keep a PS/2 keyboard on hand in case I run into problems. I guess that comes from being a Boy Scout as a kid. :wink:
This is possible by a user, creating a custom kernel adding or removing patches/commits from the standard provided kernels. I don't know how to do it, but if you want you can learn.
Provided kernels are kept at the minimum number, because of working hands missing, AFAIK.
You could inform upstream kernel development about it, so it maybe fixed upstream.
You described me very accurately: I am a fool !
And probably I could be a good benchmark for Manjaro: if I can use Manjaro, then it may be used by everyone.
But as a fool, I can still make the difference between a workaround and a real fix. Fortunately my PC motherboard has a PS/2 port, but my iMac does not. Fortunately, the USB (not-Apple) keyboard is well recognized under Manjaro on the iMac.
But more generally, it is a pity that a so basic USB keyboard may not been recognized with newer kernels. In IT we call that a regression. That means that any USB device may be in this case and I would like to be able to fix it or at least understand why it could not be fixed. Before I am stuck again, I need to consolidate my confidence.
As any linux distro is modular, I understand that Manjaro depends on the kernel development.
But it is still strange that there are 6 available versions in the repo (and it looks more than enough for me), and we came from a situation where NO of them gets the bug to a new situation where ALL of them get the bug, don't you think ?
No. Sorry..
Sorry I do
Can you please tell me where I can inform kernel development about this bug ?
I think it's at kernel.org it should be noted somewhere.
