Keyboard layout changes after Authenication failure/cancel
After changing the keyboard layout and clicking apply, it prompts with authentication required. even when you cancel or fail to put in your password in, it keeps the new layout that you had selected. This appears to happen for all layouts, me specifically changing form "English (Canada)" to "French (Canada, Dvorak)".
System:    Host: pc Kernel: 5.4.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: KDE Plasma 5.17.4 tk: Qt 5.14.0
           wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
           Mobo: Dell model: 0J3PPW v: A00 serial: <filter> UEFI: Dell v: 2.3.0 date: 02/06/2018
Battery:   ID-1: BAT0 charge: 9.8 Wh condition: 9.8/41.4 Wh (24%) volts: 17.0/14.8 model: SMP DELL VN3N047 type: Li-ion
           serial: <filter> status: Full
CPU:       Topology: Dual Core model: Intel Core i3-7100U bits: 64 type: MT MCP arch: Amber Lake rev: 9 L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19204
           Speed: 800 MHz min/max: 400/2400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5916
           Display: x11 server: X.Org 1.20.6 driver: intel unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
           resolution: 1366x768~60Hz, 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.6 Mesa 19.3.1 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:9d71
           Sound Server: ALSA v: k5.4.6-2-MANJARO
Network:   Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Dell driver: ath9k v: kernel
           port: f040 bus ID: 01:00.0 chip ID: 168c:0036
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: e000
           bus ID: 02:00.0 chip ID: 10ec:8136
           Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-8:17 chip ID: 0cf3:e005
Drives:    Local Storage: total: 931.51 GiB used: 15.70 GiB (1.7%)
           ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB speed: 6.0 Gb/s serial: <filter> rev: 3B6Q
           scheme: GPT
Partition: ID-1: / size: 906.94 GiB used: 14.99 GiB (1.7%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 8.80 GiB used: 726.0 MiB (8.1%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 45.0 C mobo: 44.0 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 188 Uptime: 3d 7h 01m Memory: 7.65 GiB used: 1.43 GiB (18.7%) Init: systemd v: 242 Compilers: gcc: 9.2.0
           Shell: bash v: 5.0.11 running in: konsole inxi: 3.0.37
The authorization is not for changing the keyboard but to write the change to configuration files located in /etc.
So after reboot your keyboard will be restored to the settings defined in configuration.
