Fresh install on a new (to me) laptop. Manjaro KDE.
Was able to start Kget once, closed it, tried to open it again later on, but nothing happened.
If I use the terminal nothing happens, if I use "sudo kget" in the terminal, this is what I get:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
"Session bus not found\nTo circumvent this problem try the following command (with Linux and bash)\nexport $(dbus-launch)"
Any tips or tricks to solve this? I've used the search, some other people had the same problem a while ago but there's not solution in any of the threads.
