This , probably ,is not related with Manjaro but I'm interested about other Manjaro users experience on subject.
I'm new to Manjaro and bravo for Manjaro team, unique and beautiful experience, thanks, So, after installing non free nvidia drivers I've lost switch resolution on Kodi (HD to 4K). Video linux driver works OK , but lags on using Kodi interface. So going back to free drivers is not solution. Using Kodi DE works but I don'y like doing loging out-log in procedure just to watch some TV show. Anybody with same problem , solution maybe?
I use Kodi with nvidia non-free but not on 4K.
If you describe your issues and provide some info on your nvidia setup, we could compare and may find something.
Does Kodi work well with HD?
Thanx for the fast response. That was one off the things I've decided for Manjaro. The community. I'm watching this forum for more than one week and it's nice place to be.
I'm using Kodi on Manjaro KDE stable with nvidia non free 390.xx (probably 59) on the system with i7 2600, 16gb Ram, nvidia 950, 18 TB HDD, 4k Philips 65 inch TV, mainly internet, watching TV shows, movies and sometimes puzzle games. Everything work smooth, system, interface, much faster than my previous Win 10 experience. The only drawback is switching resolution in Kodi from full HD to 4K. I've tried this in Manjaro gnome, Fedora gnome and other distros with no positive results. I'm not going to win 10 again because I love this new environment ( it gives me back my old passion for computers and every day I learn something new and I'm not young, so perfect).
So what info on my system will be useful for future comm.
Any particular reason for not using the latest nvidia driver 396.xx?
Since you have a newer generation than Fermi why not using latest NVIDIA 396.* driver drops support for Fermi-based GPUs
I was thinking that I'm using the latest diver. I'll check for newer and report back.
Thank you!.
I've instaled drivers using this, same thing, no 4K
Btw. is there any solution for small fonts on login screen after forcing 96 dpi in DE.
After reading the previously posted link, post these for a start
inxi -SGxxz
mhwd --pci -li
cat /etc/X11/xorg.conf.d/*.conf
journalctl -b -p 3
Your current boot's Xorg.?.log
(at /var/log/
or ~/.local/share/xorg/
Keep them in code blocks, please. Use </> button.
[saso@Server ~]$ inxi -SGxxz
Host: Server Kernel: 4.14.44-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 8.1.0 Desktop: KDE Plasma 5.12.5 tk: Qt 5.10.1 dm: sddm
Distro: Manjaro Linux 17.1.10 Hakoila
Card-1: NVIDIA GM206 [GeForce GTX 950] driver: nvidia v: 396.24
bus ID: 01:00.0 chip ID: 10de:1402
Display: x11 server: X.Org 1.19.6 driver: nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 950/PCIe/SSE2 v: 4.6.0 NVIDIA 396.24
direct render: Yes
[saso@Server ~]$ mhwd --pci -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
video-nvidia 2018.05.04 false PCI
[saso@Server ~]$ cat /etc/X11/xorg.conf.d/*.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "us"
Option "XkbModel" "pc105"
EndSection
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 396.24 (buildmeister@swio-display-x64-rhel04-13) Thu Apr 26 01:13:52 PDT 2018
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
[saso@Server ~]$ journalctl -b -p 3
-- Logs begin at Sat 2018-05-26 18:10:08 CEST, end at Sun 2018-05-27 15:36:4>
мај 27 15:08:15 Server kernel: ACPI Error: [DSSP] Namespace lookup failure, >
мај 27 15:08:15 Server kernel: ACPI Error: Method parse/execution failed \_S>
[ 10.806] (--) Log file renamed from "/var/log/Xorg.pid-533.log" to "/var/log/Xorg.0.log"
[ 10.807]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 10.807] X Protocol Version 11, Revision 0
[ 10.807] Build Operating System: Linux 4.17.0-1-MANJARO x86_64
[ 10.807] Current Operating System: Linux Server 4.14.44-1-MANJARO #1 SMP PREEMPT Fri May 25 18:35:59 UTC 2018 x86_64
[ 10.807] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.14-x86_64 root=UUID=2d1cc287-0b63-4504-9ad6-1a0560bf8824 rw quiet resume=UUID=af92ba36-b152-4cbd-82c0-5a62b8eaf597
[ 10.808] Build Date: 20 May 2018 06:17:37PM
[ 10.808]
[ 10.808] Current version of pixman: 0.34.0
[ 10.808] Before reporting problems, check http://wiki.x.org
[ 10.808] Markers: (--) probed, (**) from config file, (==) default setting,
[ 10.808] (==) Log file: "/var/log/Xorg.0.log", Time: Sun May 27 15:08:20 2018
[ 10.810] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 10.810] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 10.812] (==) ServerLayout "Layout0"
[ 10.812] (**) |-->Screen "Screen0" (0)
[ 10.812] (**) | |-->Monitor "Monitor0"
[ 10.814] (**) | |-->Device "Device0"
[ 10.814] (**) |-->Input Device "Keyboard0"
[ 10.814] (**) |-->Input Device "Mouse0"
[ 10.814] (==) Automatically adding devices
[ 10.814] (==) Automatically enabling devices
[ 10.814] (==) Automatically adding GPU devices
[ 10.814] (==) Automatically binding GPU devices
[ 10.814] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 10.815] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[ 10.815] Entry deleted from font path.
[ 10.815] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[ 10.815] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[ 10.815] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[ 10.815] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[ 10.815] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[ 10.815] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/
[ 10.815] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 10.815] (**) Extension "Composite" is enabled
[ 10.815] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 10.815] (WW) Disabling Keyboard0
[ 10.815] (WW) Disabling Mouse0
[ 10.816] (II) Loader magic: 0x559e9927cd40
[ 10.816] (II) Module ABI versions:
[ 10.816] X.Org ANSI C Emulation: 0.4
[ 10.816] X.Org Video Driver: 23.0
[ 10.816] X.Org XInput driver : 24.1
[ 10.816] X.Org Server Extension : 10.0
[ 10.816] (++) using VT number 1
[ 10.817] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 10.817] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 10.818] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 10.818] (**) OutputClass "nvidia" setting /dev/dri/card0 as PrimaryGPU
[ 10.818] (--) PCI:*(0:1:0:0) 10de:1402:1043:8554 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 10.818] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 10.819] (II) LoadModule: "glx"
[ 10.821] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[ 10.890] (II) Module glx: vendor="NVIDIA Corporation"
[ 10.890] compiled for 4.0.2, module version = 1.0.0
[ 10.890] Module class: X.Org Server Extension
[ 10.891] (II) NVIDIA GLX Module 396.24 Wed Apr 25 23:17:01 PDT 2018
[ 10.892] (II) LoadModule: "nvidia"
[ 10.896] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 10.905] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 10.905] compiled for 4.0.2, module version = 1.0.0
[ 10.905] Module class: X.Org Video Driver
[ 10.906] (II) NVIDIA dlloader X Driver 396.24 Wed Apr 25 22:53:34 PDT 2018
[ 10.906] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 10.908] (II) Loading sub module "fb"
[ 10.908] (II) LoadModule: "fb"
[ 10.908] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 10.909] (II) Module fb: vendor="X.Org Foundation"
[ 10.909] compiled for 1.19.6, module version = 1.0.0
[ 10.909] ABI class: X.Org ANSI C Emulation, version 0.4
[ 10.909] (II) Loading sub module "wfb"
[ 10.909] (II) LoadModule: "wfb"
[ 10.909] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 10.911] (II) Module wfb: vendor="X.Org Foundation"
[ 10.911] compiled for 1.19.6, module version = 1.0.0
[ 10.911] ABI class: X.Org ANSI C Emulation, version 0.4
[ 10.911] (II) Loading sub module "ramdac"
[ 10.911] (II) LoadModule: "ramdac"
[ 10.911] (II) Module "ramdac" already built-in
[ 10.914] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 10.914] (==) NVIDIA(0): RGB weight 888
[ 10.914] (==) NVIDIA(0): Default visual is TrueColor
[ 10.914] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 10.914] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 10.914] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 10.914] (**) NVIDIA(0): Enabling 2D acceleration
[ 11.653] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 11.653] (--) NVIDIA(0): CRT-0
[ 11.653] (--) NVIDIA(0): DFP-0
[ 11.653] (--) NVIDIA(0): DFP-1
[ 11.653] (--) NVIDIA(0): DFP-2
[ 11.653] (--) NVIDIA(0): DFP-3 (boot)
[ 11.653] (--) NVIDIA(0): DFP-4
[ 11.654] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 950 (GM206-A) at PCI:1:0:0 (GPU-0)
[ 11.654] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 11.654] (--) NVIDIA(0): VideoBIOS: 84.06.2f.00.79
[ 11.654] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 11.658] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 11.658] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 11.662] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 11.662] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 11.662] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 11.662] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 11.662] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 11.662] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 11.663] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 11.663] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 11.663] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 11.693] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 11.693] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 11.693] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 11.693] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 11.693] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 11.693] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 11.694] (--) NVIDIA(GPU-0):
[ 11.697] (==) NVIDIA(0):
[ 11.697] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 11.697] (==) NVIDIA(0): will be used as the requested mode.
[ 11.697] (II) NVIDIA(0): Validated MetaModes:
[ 11.697] (II) NVIDIA(0): "DFP-3:nvidia-auto-select"
[ 11.697] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 11.702] (--) NVIDIA(0): DPI set to (33, 33); computed from "UseEdidDpi" X config
[ 11.702] (--) NVIDIA(0): option
[ 11.702] (--) Depth 24 pixmap format is 32 bpp
[ 11.702] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 11.702] (II) NVIDIA: access.
[ 11.704] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 11.704] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 11.704] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 11.704] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 11.704] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 11.704] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 11.704] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 11.704] (II) NVIDIA(0): Config Options in the README.
[ 11.723] (II) NVIDIA(0): Setting mode "DFP-3:nvidia-auto-select"
[ 11.788] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 11.788] (==) NVIDIA(0): Backing store enabled
[ 11.788] (==) NVIDIA(0): Silken mouse enabled
[ 11.789] (**) NVIDIA(0): DPMS enabled
[ 11.792] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[ 11.792] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 11.792] (II) Loading sub module "dri2"
[ 11.792] (II) LoadModule: "dri2"
[ 11.792] (II) Module "dri2" already built-in
[ 11.792] (II) NVIDIA(0): [DRI2] Setup complete
[ 11.792] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 11.792] (--) RandR disabled
[ 11.795] (II) Initializing extension GLX
[ 11.795] (II) Indirect GLX disabled.
[ 11.859] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 11.859] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 11.859] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 11.859] (**) Power Button: Applying InputClass "system-keyboard"
[ 11.859] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 11.859] (II) LoadModule: "libinput"
[ 11.859] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 11.864] (II) Module libinput: vendor="X.Org Foundation"
[ 11.864] compiled for 1.19.6, module version = 0.27.1
[ 11.864] Module class: X.Org XInput Driver
[ 11.864] ABI class: X.Org XInput driver, version 24.1
[ 11.864] (II) Using input driver 'libinput' for 'Power Button'
[ 11.864] (**) Power Button: always reports core events
[ 11.864] (**) Option "Device" "/dev/input/event3"
[ 11.864] (**) Option "_source" "server/udev"
[ 11.864] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 11.864] (II) event3 - Power Button: device is a keyboard
[ 11.864] (II) event3 - Power Button: device removed
[ 11.890] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 11.890] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 11.890] (**) Option "xkb_model" "pc105"
[ 11.890] (**) Option "xkb_layout" "us"
[ 11.890] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 11.912] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 11.912] (II) event3 - Power Button: device is a keyboard
[ 11.913] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 11.913] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 11.913] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 11.913] (**) Power Button: Applying InputClass "system-keyboard"
[ 11.913] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 11.913] (II) Using input driver 'libinput' for 'Power Button'
[ 11.913] (**) Power Button: always reports core events
[ 11.913] (**) Option "Device" "/dev/input/event2"
[ 11.913] (**) Option "_source" "server/udev"
[ 11.914] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 11.914] (II) event2 - Power Button: device is a keyboard
[ 11.914] (II) event2 - Power Button: device removed
[ 11.940] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[ 11.940] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 11.940] (**) Option "xkb_model" "pc105"
[ 11.940] (**) Option "xkb_layout" "us"
[ 11.940] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 11.940] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 11.940] (II) event2 - Power Button: device is a keyboard
[ 11.941] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event11)
[ 11.941] (II) No input driver specified, ignoring this device.
[ 11.941] (II) This device may have been added with another device file.
[ 11.942] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event12)
[ 11.942] (II) No input driver specified, ignoring this device.
[ 11.942] (II) This device may have been added with another device file.
[ 11.942] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event13)
[ 11.942] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event14)
[ 11.943] (II) This device may have been added with another device file.
[ 11.943] (II) config/udev: Adding input device UVC Camera (046d:0807) (/dev/input/event5)
[ 11.943] (**) UVC Camera (046d:0807): Applying InputClass "evdev keyboard catchall"
[ 11.943] (**) UVC Camera (046d:0807): Applying InputClass "libinput keyboard catchall"
[ 11.943] (**) UVC Camera (046d:0807): Applying InputClass "system-keyboard"
[ 11.943] (**) UVC Camera (046d:0807): Applying InputClass "Keyboard Defaults"
[ 11.943] (II) Using input driver 'libinput' for 'UVC Camera (046d:0807)'
[ 11.943] (**) UVC Camera (046d:0807): always reports core events
[ 11.943] (**) Option "Device" "/dev/input/event5"
[ 11.943] (**) Option "_source" "server/udev"
[ 11.944] (II) event5 - UVC Camera (046d:0807): is tagged by udev as: Keyboard
[ 11.944] (II) event5 - UVC Camera (046d:0807): device is a keyboard
[ 11.944] (II) event5 - UVC Camera (046d:0807): device removed
[ 11.990] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input5/event5"
[ 11.990] (II) XINPUT: Adding extended input device "UVC Camera (046d:0807)" (type: KEYBOARD, id 8)
[ 11.990] (**) Option "xkb_model" "pc105"
[ 11.990] (**) Option "xkb_layout" "us"
[ 11.990] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 11.990] (II) event5 - UVC Camera (046d:0807): is tagged by udev as: Keyboard
[ 11.990] (II) event5 - UVC Camera (046d:0807): device is a keyboard
[ 11.991] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event10)
[ 11.991] (II) No input driver specified, ignoring this device.
[ 11.991] (II) This device may have been added with another device file.
[ 11.991] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event6)
[ 11.992] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)
[ 11.992] (II) No input driver specified, ignoring this device.
[ 11.992] (II) This device may have been added with another device file.
[ 11.992] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event8)
[ 11.993] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event9)
[ 11.993] (II) No input driver specified, ignoring this device.
[ 11.993] (II) This device may have been added with another device file.
[ 11.994] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event0)
[ 11.994] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 11.994] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 11.994] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 11.994] (**) Logitech USB Receiver: Applying InputClass "Keyboard Defaults"
[ 11.994] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 11.994] (**) Logitech USB Receiver: always reports core events
[ 11.994] (**) Option "Device" "/dev/input/event0"
[ 11.994] (**) Option "_source" "server/udev"
[ 11.994] (II) event0 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 11.994] (II) event0 - Logitech USB Receiver: device is a keyboard
[ 11.994] (II) event0 - Logitech USB Receiver: device removed
[ 12.020] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1.5/4-1.5:1.0/0003:046D:C534.0001/input/input0/event0"
[ 12.020] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 9)
[ 12.020] (**) Option "xkb_model" "pc105"
[ 12.020] (**) Option "xkb_layout" "us"
[ 12.020] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 12.021] (II) event0 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 12.021] (II) event0 - Logitech USB Receiver: device is a keyboard
[ 12.021] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event1)
[ 12.022] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 12.022] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 12.022] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 12.022] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 12.022] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 12.022] (**) Logitech USB Receiver: Applying InputClass "Keyboard Defaults"
[ 12.022] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 12.022] (**) Logitech USB Receiver: always reports core events
[ 12.022] (**) Option "Device" "/dev/input/event1"
[ 12.022] (**) Option "_source" "server/udev"
[ 12.022] (II) event1 - Logitech USB Receiver: is tagged by udev as: Keyboard Mouse
[ 12.022] (II) event1 - Logitech USB Receiver: device is a pointer
[ 12.022] (II) event1 - Logitech USB Receiver: device is a keyboard
[ 12.022] (II) event1 - Logitech USB Receiver: device removed
[ 12.040] (II) libinput: Logitech USB Receiver: needs a virtual subdevice
[ 12.040] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1.5/4-1.5:1.1/0003:046D:C534.0002/input/input1/event1"
[ 12.040] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 10)
[ 12.040] (**) Option "AccelerationScheme" "none"
[ 12.040] (**) Logitech USB Receiver: (accel) selected scheme none/0
[ 12.040] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 12.040] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 12.041] (II) event1 - Logitech USB Receiver: is tagged by udev as: Keyboard Mouse
[ 12.041] (II) event1 - Logitech USB Receiver: device is a pointer
[ 12.041] (II) event1 - Logitech USB Receiver: device is a keyboard
[ 12.041] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 12.041] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 12.041] (**) Logitech USB Receiver: Applying InputClass "Keyboard Defaults"
[ 12.041] (II) No input driver specified, ignoring this device.
[ 12.041] (II) This device may have been added with another device file.
[ 12.042] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 12.042] (II) No input driver specified, ignoring this device.
[ 12.042] (II) This device may have been added with another device file.
[ 12.047] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 12.047] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 12.047] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 12.047] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 12.047] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 12.047] (**) Logitech USB Receiver: Applying InputClass "Keyboard Defaults"
[ 12.047] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 12.047] (**) Logitech USB Receiver: always reports core events
[ 12.047] (**) Option "Device" "/dev/input/event1"
[ 12.047] (**) Option "_source" "_driver/libinput"
[ 12.047] (II) libinput: Logitech USB Receiver: is a virtual subdevice
[ 12.047] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1.5/4-1.5:1.1/0003:046D:C534.0002/input/input1/event1"
[ 12.047] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 11)
[ 12.047] (**) Option "xkb_model" "pc105"
[ 12.048] (**) Option "xkb_layout" "us"
[ 12.048] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 17.954] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 17.954] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 17.958] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 17.958] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 17.958] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 17.958] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 17.958] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 17.958] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 17.958] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 17.958] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 17.958] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 17.993] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 17.993] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 17.993] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 17.993] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 17.993] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 17.993] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 18.616] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 18.616] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 18.620] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 18.620] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 18.620] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 18.620] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 18.620] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 18.620] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 18.620] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 18.620] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 18.620] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 18.655] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 18.655] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 18.655] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 18.655] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 18.655] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 18.655] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 50.657] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 50.657] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 50.661] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 50.661] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 50.661] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 50.661] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 50.661] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 50.661] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 50.661] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 50.661] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 50.661] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 50.696] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 50.696] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 50.696] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 50.696] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 50.696] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 50.696] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 62.895] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 62.895] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 62.899] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 62.899] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 62.899] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 62.899] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 62.899] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 62.899] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 62.899] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 62.899] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 62.899] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 62.935] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 62.935] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 62.935] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 62.935] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 62.935] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 62.935] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 62.951] (II) NVIDIA(0): Setting mode "HDMI-0: 1920x1080_24_0 @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 63.408] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 63.408] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 63.413] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 63.413] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 63.413] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 63.413] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 63.413] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 63.413] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 63.413] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 63.413] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 63.413] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 63.447] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 63.447] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 63.447] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 63.447] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 63.447] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 63.447] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 68.815] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 68.815] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 68.819] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 68.819] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 68.819] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 68.819] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 68.819] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 68.819] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 68.819] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 68.819] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 68.819] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 68.853] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 68.853] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 68.853] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 68.854] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 68.854] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 68.854] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 68.870] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 69.368] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 69.368] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 69.373] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 69.373] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 69.373] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 69.373] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 69.373] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 69.373] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 69.373] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 69.373] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 69.373] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 69.407] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 69.407] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 69.407] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 69.407] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 69.407] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 69.407] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 136.746] (II) NVIDIA(0): Setting mode "DPY-4:nvidia-auto-select+0+0{ForceCompositionPipeline=On}"
[ 142.370] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 142.370] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 142.375] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 142.375] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 142.375] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 142.375] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 142.375] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 142.375] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 142.375] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 142.375] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 142.375] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 142.410] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 142.410] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 142.410] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 142.410] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 142.410] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 142.410] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 151.772] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 151.772] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 151.776] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 151.776] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 151.776] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 151.776] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 151.776] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 151.776] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 151.776] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 151.776] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 151.776] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 151.811] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 151.811] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 151.811] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 151.811] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 151.811] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 151.811] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 151.831] (II) NVIDIA(0): Setting mode "HDMI-0: 1920x1080_24_0 @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0, ForceCompositionPipeline=On}"
[ 152.305] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 152.305] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 152.309] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 152.309] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 152.309] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 152.309] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 152.309] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 152.309] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 152.309] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 152.309] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 152.309] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 152.344] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 152.344] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 152.344] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 152.344] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 152.344] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 152.344] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 159.130] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 159.130] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 159.134] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 159.134] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 159.135] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 159.135] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 159.135] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 159.135] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 159.135] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 159.135] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 159.135] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 159.169] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 159.169] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 159.169] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 159.169] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 159.170] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 159.170] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 159.185] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0, ForceCompositionPipeline=On}"
[ 159.789] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 159.789] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 159.793] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 159.793] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 159.793] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 159.793] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 159.793] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 159.793] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 159.793] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 159.793] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 159.793] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 159.828] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 159.828] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 159.828] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 159.828] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 159.828] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 159.828] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 1627.163] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 1627.163] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 1627.168] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 1627.168] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 1627.168] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 1627.168] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 1627.168] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 1627.168] (--) NVIDIA(GPU-0): DFP-1: 960.0 MHz maximum pixel clock
[ 1627.168] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 1627.168] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 1627.168] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 1627.205] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): connected
[ 1627.205] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): Internal TMDS
[ 1627.205] (--) NVIDIA(GPU-0): Philips FTV (DFP-3): 600.0 MHz maximum pixel clock
[ 1627.206] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 1627.206] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 1627.206] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
I hope I've done it right. Thank again for your attention.
Almost perfect! (journalctl log is a drag-copy from screen which cuts it improperly, but it doesn't have anything useful anyway).
Quick thoughts:
- It doesn't report EDID recognition, I think. First thing you should try is to provide Xorg-nvidia with EDID. Open Nvidia X settings GUI and under GPU-0 => your monitor => Information, use the button Aquire EDID.... If it is successful, save it for backup. You may use the Archwiki instructions to embed it to KMS and GRUB. This may solve most of your issues, DPI as well.
- If the above is not possible you can easily adjust DPI in your current Xorg config, using
Option DPI "96x96"
in the Screen section and only if needed
Option UseEdidDpi "FALSE"
- Other advice is to test some settings in the Nvidia Config GUI and even create an Application Profile (I have never done it)
- What is curious is that nvidia-auto-select does not find the 4K resolution, so how can the Kodi use it? That's why you should start from the monitor's EDID. Is it really 4K?
I've generated edid.bin VIA nvidia settings, put it grub in command line using method explained here, and no changes, small fonts on log screen and no 4K switch in Kodi. And yes my Philips TV has 4k resolution which I'm not using in interface , only for watching 4K content.
I don't know where to check if the command line in grub is executed.
But you don't have 4K in your system. Kodi is just a symptom.. IDK..
Please verify, what you did was as it is advised at the link I posted.
Or explain what you did. ??? How can we know ?
EDID detection is done automatically by Xorg with an HDMI connection
Have such a connection with a 1060, check in any case the system settings ==> Monitor
Which model / type of Philips Tv is an insight into the documentary
Apropos having 4K res this is partial screenshot of nvidia settings
and of course I'm not using that res on desktop. I need it only in Kodi on 4K content.
About info on my TV in settings>display and monitor states only Philips TV.
I don't know if that is possible. What is the problem running your desktop on high res?
You can change DPI setting for desktop so you don't have tiny letters/icons and try if Kodi can work on 4K.
This is not unusual.
This is true but not absolute. Some times it may get wrong info.
check about that,please.
Thank you petsam for not leaving me with my problem. So, what I have done is
I have acquired edid.bin from nvidia settings, saved file. moved to folder edid I've created, and move folder into /usr/lib/firmware.
Put the line
drm_kms_helper.edid_firmware=edid/your_edid.bin
into /etc/default/grub
and
grub-mkconfig -o /boot/grub/grub.cfg
and reboot
As far Kodi resolution switching worked with free video driver maybe the problem is with Kodi and nvidia drivers. I'll check on Kodi forums.
My suggestion is to manually set the resolution and refresh rate, and save that to /etc/X11/mhwd.d/nvidia.conf
Also did you try to add this to the conf (is not necessary, but on my end was always helping)
Section "Module"
Load "dbe"
Load "type1"
Load "freetype"
EndSection
then on Section "Device"
Option "TripleBuffer" "On"
Option "ConnectToAcpid" "Off"
EndSection
Thank you bogdancovaciu, I'll try,. Just to report on my search for solution. And yes , Kodi has a problem with new nvidia drivers but not related with resolution switch, it's about hardware decoding in linux of hevc 10 bit video. Trying out Linux mint with old nvidia non free drivers I think 384.111 (not sure) everything works like expected on switching res issue.. So, I've instaled on my spare ssd linux mint, which seems stable and good looking cinnamon so for a while I will have dual boot Manjaro and Mint.
How about using older drivers on manjaro? How to install specific version of non free driver for nvidia?
