Hey Guys.
So I got this Asus Tuf A15 a couple weeks ago and I installed Manjaro on it today (as it was too buggy before). But the problem is, Manjaro can't adjust my screen brightness. It's always at full and I can't change it. When it is booting it gives this error:
[FAILED] Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0
See 'systemctl status systemd-backlight@backlight:acpi_video0.service' for details.
and when I'm normally shutting down my computer it gives me just the first lines and gets stuck there so I need to press the power button to shut it down. When I run the commad on the second line I get this:
● systemd-backlight@backlight:acpi_video0.service - Load/Save Screen Backlight Brightness of backlight:acpi_video0
Loaded: loaded (/usr/lib/systemd/system/systemd-backlight@.service; static; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2020-06-12 23:28:32 +03; 28min ago
Docs: man:systemd-backlight@.service(8)
Process: 967 ExecStart=/usr/lib/systemd/systemd-backlight load backlight:acpi_video0 (code=exited, status=1/FAILURE)
Main PID: 967 (code=exited, status=1/FAILURE)
Haz 12 23:28:32 kaan-laptop systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
Haz 12 23:28:32 kaan-laptop systemd-backlight[967]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
Haz 12 23:28:32 kaan-laptop systemd[1]: systemd-backlight@backlight:acpi_video0.service: Main process exited, code=exited, status=1/FAILURE
Haz 12 23:28:32 kaan-laptop systemd[1]: systemd-backlight@backlight:acpi_video0.service: Failed with result 'exit-code'.
Haz 12 23:28:32 kaan-laptop systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
As I said I am using Asus Tuf A15 FA506II
-Ryzen 4600H with Radeon Graphics
-GTX 1650Ti
-8G 3200MHz
-256 NVMe
Thanks in advance
