Laptop Waking From Sleep While Closed
My laptop is waking from sleep while closed. From an external appearance, it seems like it goes fully to sleep - the laptop goes silent and the LED on the side begins flashing - but then some time later it resumes, so when I come back into the room the LED is on fully, the fan is spinning, and depending on how long or where I've left it, the bottom of the laptop is warm to the touch. When I open the lid the screen is on but black and the system is unresponsive, so I have to hard reboot. The first time I attempt to power on, it consistently boots to black, but then after a second hard reboot it boots to KDE just fine, no terminal fixes required. I've searched the forums and found similar issues but nothing that clearly describes what I'm experiencing. The closest thing I found was that bluetooth blocks suspend for some people, so I tried disabling it to no avail.
Looking at the logs for last night, it looks like perhaps there's something blocking suspend and the system isn't going to sleep as clearly as I thought, despite the visual cues. I can't make out what's blocking it though, and why there's a delay between it resuming and the LED/fan coming back on. Notably, there is nothing in the log pertaining to my lid open and hard shutdown (which took place an hour later) or my first attempted boot (which took place at 7:30 this morning). Instead, the logs go straight from the failed suspend to my successful second boot this morning. I also notice that there are references to Bluetooth despite the fact that I have it turned off. Any ideas about what could be causing this?
Here's the output from journalctl -b -1 surrounding the last time I tried to suspend.
Apr 27 20:18:51 ben-pc systemd-logind[707]: Lid closed.
Apr 27 20:18:51 ben-pc org_kde_powerdevil[1309]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("Type", QVariant(uint, 1)))
Apr 27 20:18:51 ben-pc org_kde_powerdevil[1309]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("SkipFade", QVariant(bool, true))("Type", QVariant(uint, 1)))
Apr 27 20:18:51 ben-pc org_kde_powerdevil[1309]: powerdevil: Starting Login1 suspend job
Apr 27 20:18:51 ben-pc kded5[1200]: bluedevil: About to suspend
Apr 27 20:18:51 ben-pc NetworkManager[702]: <info>  [1588033131.3013] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Apr 27 20:18:51 ben-pc NetworkManager[702]: <info>  [1588033131.3013] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Apr 27 20:18:51 ben-pc NetworkManager[702]: <info>  [1588033131.3018] manager: NetworkManager state is now ASLEEP
Apr 27 20:18:51 ben-pc org_kde_powerdevil[1309]: powerdevil: Pausing all media players before sleep
Apr 27 20:18:51 ben-pc ksmserver[1239]: lock called
Apr 27 20:18:51 ben-pc ksmserver[1239]: Lock window Id:  18874395
Apr 27 20:18:51 ben-pc ksmserver[1239]: CreateNotify: 18874395
Apr 27 20:18:51 ben-pc ksmserver[1239]: CreateNotify: 48234500
Apr 27 20:18:51 ben-pc kscreenlocker_greet[11796]: Qt: Session management error: networkIdsList argument is NULL
Apr 27 20:18:51 ben-pc ksmserver[1239]: CreateNotify: 48234504
Apr 27 20:18:51 ben-pc ksmserver[1239]: CreateNotify: 48234516
Apr 27 20:18:51 ben-pc ksmserver[1239]: CreateNotify: 48234525
Apr 27 20:18:51 ben-pc kscreenlocker_greet[11796]: kf5.kpackage: No metadata file in the package, expected it at: "/home/ben/Pictures/"
Apr 27 20:18:51 ben-pc kscreenlocker_greet[11796]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:76:9: Unable to assign [undefined] to QStringList
Apr 27 20:18:51 ben-pc kscreenlocker_greet[11796]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:75:9: Unable to assign [undefined] to int
Apr 27 20:18:51 ben-pc ksmserver[1239]: CreateNotify: 48234527
Apr 27 20:18:51 ben-pc ksmserver[1239]: CreateNotify: 48234529
Apr 27 20:18:51 ben-pc ksmserver[1239]: MapNotify: 48234527
Apr 27 20:18:51 ben-pc ksmserver[1239]: CreateNotify: 48234531
Apr 27 20:18:51 ben-pc ksmserver[1239]: MapNotify: 18874395
Apr 27 20:18:51 ben-pc systemd[1]: Reached target Sleep.
Apr 27 20:18:51 ben-pc systemd[1]: Starting Suspend; Hibernate if not used for a period of time...
Apr 27 20:18:51 ben-pc kscreenlocker_greet[11796]: UdevQt: unable to create udev monitor connection
Apr 27 20:18:51 ben-pc ksmserver[1239]: CreateNotify: 48234544
Apr 27 20:18:51 ben-pc kscreenlocker_greet[11796]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Apr 27 20:18:51 ben-pc systemd-sleep[11817]: Suspending system...
Apr 27 20:18:51 ben-pc kernel: PM: suspend entry (deep)
Apr 27 22:18:52 ben-pc kernel: Filesystems sync: 0.005 seconds
Apr 27 22:18:52 ben-pc kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
Apr 27 22:18:52 ben-pc kernel: OOM killer disabled.
Apr 27 22:18:52 ben-pc kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Apr 27 22:18:52 ben-pc kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Apr 27 22:18:52 ben-pc kernel: wlp1s0: deauthenticating from ec:ad:e0:a6:c2:d0 by local choice (Reason: 3=DEAUTH_LEAVING)
Apr 27 22:18:52 ben-pc kernel: ACPI: EC: interrupt blocked
Apr 27 22:18:52 ben-pc kernel: ACPI: Preparing to enter system sleep state S3
Apr 27 22:18:52 ben-pc kernel: ACPI: EC: event blocked
Apr 27 22:18:52 ben-pc kernel: ACPI: EC: EC stopped
Apr 27 22:18:52 ben-pc kernel: PM: Saving platform NVS memory
Apr 27 22:18:52 ben-pc kernel: Disabling non-boot CPUs ...
Apr 27 22:18:52 ben-pc kernel: smpboot: CPU 1 is now offline
Apr 27 22:18:52 ben-pc kernel: smpboot: CPU 2 is now offline
Apr 27 22:18:52 ben-pc kernel: smpboot: CPU 3 is now offline
Apr 27 22:18:52 ben-pc kernel: ACPI: Low-level resume complete
Apr 27 22:18:52 ben-pc kernel: ACPI: EC: EC started
Apr 27 22:18:52 ben-pc kernel: PM: Restoring platform NVS memory
Apr 27 22:18:52 ben-pc kernel: Enabling non-boot CPUs ...
Apr 27 22:18:52 ben-pc kernel: x86: Booting SMP configuration:
Apr 27 22:18:52 ben-pc kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
Apr 27 22:18:52 ben-pc kernel: microcode: CPU1: patch_level=0x08108102
Apr 27 22:18:52 ben-pc kernel: ACPI: \_PR_.P001: Found 2 idle states
Apr 27 22:18:52 ben-pc kernel: CPU1 is up
Apr 27 22:18:52 ben-pc kernel: smpboot: Booting Node 0 Processor 2 APIC 0x2
Apr 27 22:18:52 ben-pc kernel: microcode: CPU2: patch_level=0x08108102
Apr 27 22:18:52 ben-pc kernel: ACPI: \_PR_.P002: Found 2 idle states
Apr 27 22:18:52 ben-pc kernel: CPU2 is up
Apr 27 22:18:52 ben-pc kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Apr 27 22:18:52 ben-pc kernel: microcode: CPU3: patch_level=0x08108102
Apr 27 22:18:52 ben-pc kernel: ACPI: \_PR_.P003: Found 2 idle states
Apr 27 22:18:52 ben-pc kernel: CPU3 is up
Apr 27 22:18:52 ben-pc kernel: ACPI: Waking up from system sleep state S3
Apr 27 22:18:52 ben-pc kernel: ACPI: EC: interrupt unblocked
Apr 27 22:18:52 ben-pc kernel: ACPI: EC: event unblocked
Apr 27 22:18:52 ben-pc kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
Apr 27 22:18:52 ben-pc kernel: [drm] PSP is resuming...
Apr 27 22:18:52 ben-pc kernel: iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
Apr 27 22:18:52 ben-pc kernel: [drm] reserve 0x400000 from 0xf47f800000 for PSP TMR
Apr 27 22:18:52 ben-pc kernel: [drm] psp command (0x5) failed and response status is (0xFFFF0007)
Apr 27 22:18:52 ben-pc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Apr 27 22:18:52 ben-pc kernel: [drm] failed to load ucode id (17)
Apr 27 22:18:52 ben-pc kernel: [drm] psp command (0x6) failed and response status is (0xFFFF300F)
Apr 27 22:18:52 ben-pc kernel: [drm] failed to load ucode id (18)
Apr 27 22:18:52 ben-pc kernel: [drm] psp command (0x6) failed and response status is (0xFFFF000F)
Apr 27 22:18:52 ben-pc kernel: [drm] failed to load ucode id (19)
Apr 27 22:18:52 ben-pc kernel: iwlwifi 0000:01:00.0: FW already configured (0) - re-configuring
Apr 27 22:18:52 ben-pc kernel: usb 1-6: reset high-speed USB device number 4 using xhci_hcd
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: RAS: ras ta ucode is not available
Apr 27 22:18:52 ben-pc kernel: [drm] kiq ring mec 2 pipe 1 q 0
Apr 27 22:18:52 ben-pc kernel: amdgpu: [powerplay] dpm has been enabled
Apr 27 22:18:52 ben-pc kernel: ata1: SATA link down (SStatus 0 SControl 300)
Apr 27 22:18:52 ben-pc kernel: [drm] VCN decode and encode initialized successfully(under SPG Mode).
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring gfx uses VM inv eng 0 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring sdma0 uses VM inv eng 0 on hub 1
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring vcn_dec uses VM inv eng 1 on hub 1
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring vcn_enc0 uses VM inv eng 4 on hub 1
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring vcn_enc1 uses VM inv eng 5 on hub 1
Apr 27 22:18:52 ben-pc kernel: amdgpu 0000:03:00.0: ring jpeg_dec uses VM inv eng 6 on hub 1
Apr 27 22:18:52 ben-pc kernel: usb 1-5: reset high-speed USB device number 3 using xhci_hcd
Apr 27 22:18:52 ben-pc kernel: usb 1-6.1: reset full-speed USB device number 5 using xhci_hcd
Apr 27 22:18:52 ben-pc kernel: usb 1-6.2: reset high-speed USB device number 6 using xhci_hcd
Apr 27 22:18:52 ben-pc kernel: OOM killer enabled.
Apr 27 22:18:52 ben-pc kernel: Restarting tasks ...
Apr 27 22:18:52 ben-pc kernel: Bluetooth: hci0: Firmware revision 0.1 build 50 week 12 2019
Apr 27 22:18:52 ben-pc bluetoothd[1072]: Endpoint unregistered: sender=:1.53 path=/MediaEndpoint/A2DPSink/sbc
Apr 27 22:18:52 ben-pc NetworkManager[702]: <warn>  [1588040332.9445] sup-iface[0x55fbd613fcc0,wlp1s0]: connection disconnected (reason -3)
Apr 27 22:18:52 ben-pc bluetoothd[1072]: Endpoint unregistered: sender=:1.53 path=/MediaEndpoint/A2DPSource/sbc
Apr 27 22:18:52 ben-pc systemd[1]: Starting Load/Save RF Kill Switch Status...
Apr 27 22:18:52 ben-pc wpa_supplicant[1064]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=0 noise=9999 txrate=0
Apr 27 22:18:52 ben-pc NetworkManager[702]: <info>  [1588040332.9493] device (wlp1s0): supplicant interface state: completed -> disconnected
Apr 27 22:18:52 ben-pc wpa_supplicant[1064]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=ec:ad:e0:a6:c2:d0 reason=3 locally_generated=1
Apr 27 22:18:52 ben-pc wpa_supplicant[1064]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Apr 27 22:18:52 ben-pc systemd[1161]: Stopped target Bluetooth.
Apr 27 22:18:52 ben-pc kernel: done.
Apr 27 22:18:52 ben-pc systemd[1]: Stopped target Bluetooth.
Apr 27 22:18:52 ben-pc systemd-sleep[11817]: System resumed.
Apr 27 22:18:52 ben-pc kernel: PM: suspend exit
Apr 27 22:18:52 ben-pc systemd[1161]: Reached target Bluetooth.
Apr 27 22:18:52 ben-pc systemd[1]: Reached target Bluetooth.
Apr 27 22:18:52 ben-pc systemd[1]: Started Load/Save RF Kill Switch Status.
Apr 27 22:18:52 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 27 22:18:52 ben-pc kernel: audit: type=1130 audit(1588040332.966:131): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 27 22:18:53 ben-pc wpa_supplicant[1064]: wlp1s0: Reject scan trigger since one is already pending
Apr 27 22:18:53 ben-pc wpa_supplicant[1064]: wlp1s0: Failed to initiate AP scan
Apr 27 22:18:53 ben-pc bluetoothd[1072]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSink/sbc
Apr 27 22:18:53 ben-pc bluetoothd[1072]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSource/sbc
Apr 27 22:18:53 ben-pc kscreenlocker_greet[11796]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Apr 27 22:18:53 ben-pc ksmserver[1239]: CreateNotify: 48234559
Apr 27 22:18:53 ben-pc systemd-sleep[11817]: Suspending system...
Apr 27 22:18:53 ben-pc kernel: PM: hibernation: hibernation entry
Here's my system info:
System:    Kernel: 5.6.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64 root=UUID=988d48e5-be76-4d72-bdcd-65398369173e rw quiet apparmor=1
           security=apparmor resume=UUID=77286308-81da-4326-a125-3bc340b857fa udev.log_priority=3
           Desktop: KDE Plasma 5.18.4 tk: Qt 5.14.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X512DA v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: X512DA v: 1.0 serial: <filter> UEFI: American Megatrends v: X512DA.308 date: 11/05/2019
Battery:   ID-1: BAT0 charge: 33.4 Wh condition: 33.4/37.1 Wh (90%) volts: 7.8/7.8 model: ASUSTeK ASUS Battery type: Li-ion
           serial: <filter> status: Not charging cycles: 69
CPU:       Topology: Dual Core model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen+
           family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102 L2 cache: 1024 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 20770
           Speed: 1253 MHz min/max: 1400/2600 MHz boost: enabled Core speeds (MHz): 1: 1564 2: 1869 3: 1272 4: 1212
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 03:00.0
           chip ID: 1002:15d8
           Display: x11 server: X.Org 1.20.8 driver: amdgpu FAILED: ati unloaded: modesetting alternate: fbdev,vesa
           compositor: kwin_x11 resolution: 1366x768~60Hz
           OpenGL: renderer: AMD RAVEN2 (DRM 3.36.0 5.6.7-1-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.0.5 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
           bus ID: 03:00.1 chip ID: 1002:15de
           Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A bus ID: 03:00.5
           chip ID: 1022:15e2
           Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 03:00.6 chip ID: 1022:15e3
           Sound Server: ALSA v: k5.6.7-1-MANJARO
Network:   Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel bus ID: 01:00.0 chip ID: 8086:24fd
Drives:    Local Storage: total: 476.94 GiB used: 43.27 GiB (9.1%)
           ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB block size: physical: 512 B logical: 512 B
           speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 002C scheme: GPT
Partition: ID-1: / raw size: 467.84 GiB size: 459.50 GiB (98.22%) used: 43.27 GiB (9.4%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap swappiness: 60 (default) cache pressure: 100 (default)
           dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 59.4 C mobo: N/A gpu: amdgpu temp: 59 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 187 Uptime: 32m Memory: 5.82 GiB used: 2.02 GiB (34.7%) Init: systemd v: 245 Compilers: gcc: 9.3.0
           Shell: bash v: 5.0.16 running in: konsole inxi: 3.0.37
  1. Depending on how hard your hard reboot is, please read this:
  1. Have you tried with a fresh reboot and no applications running (turn off all autostart items as well) as some applications wake up a computer.
  2. We're missing anything after the 80th column of your journalctl -b -1: copy-paste from a maximised window or redirect to a file and copy-paste that.
:innocent:
Thanks for the helpful article Fabby. I'll try to use that next time.
I don't know how I never noticed that logs get truncated that way before. Here's the full output; I'll change the original post too so it's easy to see for anyone coming across the post.
You missed this bit:
:question:
You're right, I totally missed that! I haven't and I will as I eat supper hehehe.
If it was a particular program interfering, would it show up somewhere in the logs?
It would depend on the application. That's why it's easiest to turn them all off an try again and then turn them on one by one...
¯\_(ツ)_/¯
Makes sense. The issue is inconsistent, which made me think it was an application, but I hadn't been able to nail down a pattern, and when I couldn't see anything in the log I figured I would reach out for help. I didn't have any issues this time with a nothing-running fresh boot. I'll keep trying that and test out programs one by one and see if I can narrow it down.
So, I think it's caused by wine or a particular app I run in wine, which is what my original suspicion was. It may be linked to another issue I've been having which requires me to run my game using AMD_DEBUG=nodmacopyimage. However, when I look under system activity, nothing pertaining to wine seems to be running before I close the laptop lid. Is there any way to identify more clearly why it's blocking the sleep function so I can attempt to resolve it?
Also, REISUB doesn't seem to be working for me. I've tried following the instructions in your article closely and searched around to see if there was something unique about my laptop but not seeing any good reason why. Any tips for troubleshooting it?
  • Try sleep from the log-in screen and if that works,
    • log in
    • sudo htop and F9 kill any applications that seem dubious to you
  • If sleep doesn't work even from the login screen, it's one of your systemd services: disable the ones you don't need.
What does GRUB_CMDLINE_LINUX_DEFAULT show in your /etc/default/grub and did you do a sudo update-grub after you changed it (if you changed it)?
:innocent:
I haven't had the issue since I started using AMD_DEBUG=nodmacopyimage as an environmental variable instead of running it for every application I needed it for, so I'm hopeful that there was something in the way I was executing that that was causing the problem. I'll let you know if it comes back up again.
Re. REISUB, my GRUB has been updated and reads GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=77286308-81da-4326-a125-3bc340b857fa udev.log_priority=3 sysrq_always_enabled=1"
When I activate the REISUB sequence, the first three steps seem to work, but as far as I can tell SUB don't do anything. After I press I, I end up back at my login screen but when I press S, U, and then B nothing appears to happen visually. Certainly the computer doesn't restart. Also, my login password doesn't work, so the only thing I can do from there is to restart "normally," by which I mean pressing the restart button on the login page. Here's the relevant portion of my boot log from my last attempt.
Apr 30 09:17:54 ben-pc kernel: sysrq: Keyboard mode set to system default
Apr 30 09:17:56 ben-pc systemd-journald[267]: Journal stopped
Apr 30 09:17:57 ben-pc kernel: sysrq: Terminate All Tasks
Apr 30 09:17:57 ben-pc systemd-journald[267]: Received SIGTERM.
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.695:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.712:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: cronie.service: Succeeded.
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.712:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: systemd-udevd.service: Succeeded.
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.715:137): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: ModemManager.service: Succeeded.
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.715:138): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: systemd-timesyncd.service: Succeeded.
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.719:139): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: avahi-daemon.service: Succeeded.
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.719:140): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: dbus.service: Succeeded.
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.722:141): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: polkit.service: Succeeded.
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.722:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: bluetooth.service: Succeeded.
Apr 30 09:17:57 ben-pc kernel: audit: type=1131 audit(1588252676.722:143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: org.cups.cupsd.service: Succeeded.
Apr 30 09:17:57 ben-pc systemd[1]: rtkit-daemon.service: Succeeded.
Apr 30 09:17:57 ben-pc systemd[1]: udisks2.service: Succeeded.
Apr 30 09:17:57 ben-pc systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
Apr 30 09:17:57 ben-pc systemd[1]: systemd-udevd.service: Scheduled restart job, restart counter is at 1.
Apr 30 09:17:57 ben-pc systemd[1]: systemd-timesyncd.service: Scheduled restart job, restart counter is at 1.
Apr 30 09:17:57 ben-pc systemd[1]: upower.service: Succeeded.
Apr 30 09:17:57 ben-pc systemd[1]: Started D-Bus System Message Bus.
Apr 30 09:17:57 ben-pc systemd[1]: Stopping Flush Journal to Persistent Storage...
Apr 30 09:17:57 ben-pc systemd[1]: Stopped Network Time Synchronization.
Apr 30 09:17:57 ben-pc systemd[1]: Starting Network Time Synchronization...
Apr 30 09:17:57 ben-pc systemd[1]: Stopped udev Kernel Device Manager.
Apr 30 09:17:57 ben-pc systemd[1]: Starting udev Kernel Device Manager...
Apr 30 09:17:57 ben-pc systemd[1]: systemd-journal-flush.service: Succeeded.
Apr 30 09:17:57 ben-pc systemd[1]: Stopped Flush Journal to Persistent Storage.
Apr 30 09:17:57 ben-pc systemd[1]: Stopped Journal Service.
Apr 30 09:17:57 ben-pc systemd[1]: Starting Journal Service...
Apr 30 09:17:57 ben-pc kernel: wlp1s0: deauthenticating from ec:ad:e0:a6:c2:d0 by local choice (Reason: 3=DEAUTH_LEAVING)
Apr 30 09:17:57 ben-pc systemd[1]: Created slice system-systemd\x2dcoredump.slice.
Apr 30 09:17:57 ben-pc systemd[1]: Started Process Core Dump (PID 6138/UID 0).
Apr 30 09:17:57 ben-pc systemd[1]: NetworkManager.service: Succeeded.
Apr 30 09:17:57 ben-pc systemd[1]: cronie.service: Scheduled restart job, restart counter is at 1.
Apr 30 09:17:57 ben-pc systemd[1]: Stopped Periodic Command Scheduler.
Apr 30 09:17:57 ben-pc systemd[1]: Started Periodic Command Scheduler.
Apr 30 09:17:57 ben-pc systemd[1]: wpa_supplicant.service: Succeeded.
Apr 30 09:17:57 ben-pc systemd[1]: systemd-logind.service: Succeeded.
Apr 30 09:17:57 ben-pc systemd[1]: systemd-logind.service: Scheduled restart job, restart counter is at 1.
Apr 30 09:17:57 ben-pc systemd[1]: Stopped Login Service.
Apr 30 09:17:57 ben-pc systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
Apr 30 09:17:57 ben-pc systemd[1]: Starting Login Service...
Apr 30 09:17:57 ben-pc systemd[1]: sddm.service: Succeeded.
Apr 30 09:17:57 ben-pc systemd-journald[6142]: Journal started
Apr 30 09:17:57 ben-pc systemd-journald[6142]: System Journal (/var/log/journal/e71c0736b60d4ce79b5d4ab780f42be3) is 296.1M, max 4.0G, 3.7G free.
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1293]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1293 comm="kwin_x11" exe="/usr/bin/kwin_x11" sig=6 res=1
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=25 op=LOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=26 op=LOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=23 op=UNLOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=24 op=UNLOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=18 op=UNLOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=17 op=UNLOAD
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: Started Journal Service.
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=19 op=UNLOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=20 op=UNLOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=27 op=LOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=28 op=LOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=29 op=LOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=30 op=LOAD
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-6138-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=31 op=LOAD
Apr 30 09:17:56 ben-pc audit: AUDIT1334 prog-id=32 op=LOAD
Apr 30 09:17:57 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc audit: CONFIG_CHANGE op=set audit_enabled=1 old=1 auid=4294967295 ses=4294967295 subj==unconfined res=1
Apr 30 09:17:56 ben-pc systemd[1]: run-user-1000-gvfs.mount: Succeeded.
Apr 30 09:17:56 ben-pc obexd[1465]: Terminating
Apr 30 09:17:57 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc NetworkManager[502]: <info>  [1588252676.6984] caught SIGTERM, shutting down normally.
Apr 30 09:17:56 ben-pc ModemManager[595]: <info>  Caught signal, shutting down...
Apr 30 09:17:56 ben-pc NetworkManager[502]: <info>  [1588252676.6986] modem-manager: ModemManager no longer available
Apr 30 09:17:56 ben-pc systemd[1206]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[ben] ruser=[<unknown>] rhost=[<unknown>]
Apr 30 09:17:57 ben-pc audit: AUDIT1334 prog-id=16 op=UNLOAD
Apr 30 09:17:57 ben-pc audit: AUDIT1334 prog-id=15 op=UNLOAD
Apr 30 09:17:57 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:56 ben-pc systemd[1]: lvm2-lvmetad.service: Succeeded.
Apr 30 09:17:56 ben-pc wpa_supplicant[1061]: nl80211: deinit ifname=p2p-dev-wlp1s0 disabled_11b_rates=0
Apr 30 09:17:56 ben-pc sddm[774]: Signal received: SIGTERM
Apr 30 09:17:56 ben-pc bluetoothd[1117]: Terminating
Apr 30 09:17:56 ben-pc sddm[774]: Socket server stopping...
Apr 30 09:17:56 ben-pc avahi-daemon[498]: Disconnected from D-Bus, exiting.
Apr 30 09:17:56 ben-pc sddm[774]: Socket server stopped.
Apr 30 09:17:56 ben-pc avahi-daemon[498]: Got SIGTERM, quitting.
Apr 30 09:17:56 ben-pc sddm[774]: Display server stopping...
Apr 30 09:17:56 ben-pc avahi-daemon[498]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::dfe0:9847:891d:ca9e.
Apr 30 09:17:56 ben-pc systemd[1205]: run-user-1000-gvfs.mount: Succeeded.
Apr 30 09:17:56 ben-pc avahi-daemon[498]: Leaving mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.0.169.
Apr 30 09:17:56 ben-pc kded5[1244]: bluedevil: Bluetooth operational changed false
Apr 30 09:17:56 ben-pc avahi-daemon[498]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Apr 30 09:17:56 ben-pc systemd[1205]: obex.service: Succeeded.
Apr 30 09:17:56 ben-pc avahi-daemon[498]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Apr 30 09:17:56 ben-pc kded5[1244]: The X11 connection broke (error 1). Did the X11 server die?
Apr 30 09:17:56 ben-pc ModemManager[595]: <info>  ModemManager is shut down
Apr 30 09:17:56 ben-pc systemd[1205]: Stopped Bluetooth OBEX service.
Apr 30 09:17:56 ben-pc bluetoothd[1117]: Disconnected from D-Bus. Exiting.
Apr 30 09:17:56 ben-pc systemd[1205]: Stopped target Bluetooth.
Apr 30 09:17:56 ben-pc bluetoothd[1117]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSink/sbc
Apr 30 09:17:56 ben-pc NetworkManager[502]: <info>  [1588252676.7113] dhcp4 (wlp1s0): canceled DHCP transaction
Apr 30 09:17:56 ben-pc bluetoothd[1117]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/sbc
Apr 30 09:17:56 ben-pc NetworkManager[502]: <info>  [1588252676.7113] dhcp4 (wlp1s0): state changed bound -> done
Apr 30 09:17:56 ben-pc bluetoothd[1117]: Stopping SDP server
Apr 30 09:17:56 ben-pc NetworkManager[502]: <info>  [1588252676.7114] device (wlp1s0): DHCPv4: trying to acquire a new lease within 90 seconds
Apr 30 09:17:56 ben-pc bluetoothd[1117]: Exit
Apr 30 09:17:56 ben-pc NetworkManager[502]: <info>  [1588252676.7117] manager: NetworkManager state is now CONNECTED_SITE
Apr 30 09:17:56 ben-pc crond[499]: (CRON) INFO (Shutting down)
Apr 30 09:17:56 ben-pc NetworkManager[502]: <info>  [1588252676.7118] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Apr 30 09:17:56 ben-pc avahi-daemon[498]: avahi-daemon 0.8 exiting.
Apr 30 09:17:56 ben-pc systemd[1]: systemd-journald.service: Succeeded.
Apr 30 09:17:56 ben-pc wpa_supplicant[1061]: p2p-dev-wlp1s0: CTRL-EVENT-TERMINATING
Apr 30 09:17:56 ben-pc NetworkManager[502]: <info>  [1588252676.7194] exiting (success)
Apr 30 09:17:56 ben-pc wpa_supplicant[1061]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=ec:ad:e0:a6:c2:d0 reason=3 locally_generated=1
Apr 30 09:17:56 ben-pc kwin_x11[1293]: The X11 connection broke: I/O error (code 1)
Apr 30 09:17:56 ben-pc wpa_supplicant[1061]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
Apr 30 09:17:56 ben-pc wpa_supplicant[1061]: wlp1s0: CTRL-EVENT-TERMINATING
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:58: TypeError: Cannot read property 'smallSpacing' of null
Apr 30 09:17:56 ben-pc crond[6145]: (CRON) STARTUP (1.5.5)
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:214: TypeError: Cannot read property 'smallSpacing' of null
Apr 30 09:17:56 ben-pc crond[6145]: (CRON) INFO (Syslog will be used instead of sendmail.)
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:215: TypeError: Cannot read property 'smallSpacing' of null
Apr 30 09:17:56 ben-pc crond[6145]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 97% if used.)
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:231: TypeError: Cannot read property 'smallSpacing' of null
Apr 30 09:17:56 ben-pc crond[6145]: (CRON) INFO (running with inotify support)
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:232: TypeError: Cannot read property 'smallSpacing' of null
Apr 30 09:17:56 ben-pc crond[6145]: (CRON) INFO (@reboot jobs will be run at computer's startup.)
Apr 30 09:17:56 ben-pc systemd[1205]: Stopped target Main User Target.
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:109: TypeError: Cannot read property 'iconSizes' of null
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:110: TypeError: Cannot read property 'iconSizes' of null
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:105: TypeError: Cannot read property 'smallSpacing' of null
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:86: TypeError: Cannot read property 'smallSpacing' of null
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:87: TypeError: Cannot read property 'smallSpacing' of null
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:88: TypeError: Cannot read property 'smallSpacing' of null
Apr 30 09:17:56 ben-pc kwin_x11[1293]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:80: TypeError: Cannot read property 'longDuration' of null
Apr 30 09:17:57 ben-pc sddm[774]: Display server stopped.
Apr 30 09:17:57 ben-pc sddm[774]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
Apr 30 09:17:57 ben-pc sddm[774]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
Apr 30 09:17:57 ben-pc systemd[1]: sddm.service: Scheduled restart job, restart counter is at 1.
Apr 30 09:17:57 ben-pc systemd[1]: Stopped Simple Desktop Display Manager.
Apr 30 09:17:57 ben-pc systemd[1]: Starting Flush Journal to Persistent Storage...
Apr 30 09:17:57 ben-pc systemd[1]: Started Network Time Synchronization.
Apr 30 09:17:57 ben-pc systemd[1]: Started udev Kernel Device Manager.
Apr 30 09:17:57 ben-pc systemd[1]: Finished Flush Journal to Persistent Storage.
Apr 30 09:17:57 ben-pc systemd-logind[6148]: New seat seat0.
Apr 30 09:17:57 ben-pc systemd-logind[6148]: Failed to add user by file name 1000, ignoring: Invalid argument
Apr 30 09:17:57 ben-pc systemd-logind[6148]: User enumeration failed: Invalid argument
Apr 30 09:17:57 ben-pc systemd-logind[6148]: User of session 2 not known.
Apr 30 09:17:57 ben-pc systemd-logind[6148]: Session enumeration failed: No such file or directory
Apr 30 09:17:57 ben-pc systemd-logind[6148]: Watching system buttons on /dev/input/event3 (Power Button)
Apr 30 09:17:57 ben-pc systemd-logind[6148]: Watching system buttons on /dev/input/event0 (Lid Switch)
Apr 30 09:17:57 ben-pc systemd-logind[6148]: Watching system buttons on /dev/input/event1 (Power Button)
Apr 30 09:17:57 ben-pc systemd-logind[6148]: Watching system buttons on /dev/input/event2 (Sleep Button)
Apr 30 09:17:57 ben-pc systemd-logind[6148]: Watching system buttons on /dev/input/event5 (AT Translated Set 2 keyboard)
Apr 30 09:17:57 ben-pc systemd[1]: Started Login Service.
Apr 30 09:17:57 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:57 ben-pc systemd[1]: Started Simple Desktop Display Manager.
Apr 30 09:17:57 ben-pc sddm[6155]: Initializing...
Apr 30 09:17:57 ben-pc sddm[6155]: Starting...
Apr 30 09:17:57 ben-pc sddm[6155]: Logind interface found
Apr 30 09:17:57 ben-pc sddm[6155]: Adding new display on vt 1 ...
Apr 30 09:17:57 ben-pc sddm[6155]: Loading theme configuration from ""
Apr 30 09:17:57 ben-pc sddm[6155]: Display server starting...
Apr 30 09:17:57 ben-pc sddm[6155]: Running: /usr/bin/X -nolisten tcp -auth /var/run/sddm/{54262642-67e0-4e79-83fb-8a3da8ff1ad4} -background none -noreset -displayfd 17 -seat seat0 vt1
Apr 30 09:17:59 ben-pc sddm[6155]: Setting default cursor
Apr 30 09:17:59 ben-pc sddm[6155]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Apr 30 09:17:59 ben-pc sddm[6155]: Display server started.
Apr 30 09:17:59 ben-pc sddm[6155]: Socket server starting...
Apr 30 09:17:59 ben-pc sddm[6155]: Socket server started.
Apr 30 09:17:59 ben-pc sddm[6155]: Loading theme configuration from "/usr/share/sddm/themes/breath2/theme.conf"
Apr 30 09:17:59 ben-pc sddm[6155]: Greeter starting...
Apr 30 09:17:59 ben-pc sddm[6155]: Adding cookie to "/var/run/sddm/{54262642-67e0-4e79-83fb-8a3da8ff1ad4}"
Apr 30 09:17:59 ben-pc sddm-helper[6173]: [PAM] Starting...
Apr 30 09:17:59 ben-pc sddm-helper[6173]: [PAM] Authenticating...
Apr 30 09:17:59 ben-pc audit[6173]: USER_AUTH pid=6173 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:59 ben-pc sddm-helper[6173]: [PAM] returning.
Apr 30 09:17:59 ben-pc audit[6173]: USER_ACCT pid=6173 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:59 ben-pc audit[6173]: CRED_ACQ pid=6173 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:59 ben-pc sddm-helper[6173]: pam_unix(sddm-greeter:session): session opened for user sddm by (uid=0)
Apr 30 09:17:59 ben-pc systemd[1]: Created slice User Slice of UID 968.
Apr 30 09:17:59 ben-pc systemd[1]: Starting User Runtime Directory /run/user/968...
Apr 30 09:17:59 ben-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Apr 30 09:17:59 ben-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Apr 30 09:17:59 ben-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Apr 30 09:17:59 ben-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Apr 30 09:17:59 ben-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Apr 30 09:17:59 ben-pc systemd-logind[6148]: New session c1 of user sddm.
Apr 30 09:17:59 ben-pc systemd[1]: Finished User Runtime Directory /run/user/968.
Apr 30 09:17:59 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:59 ben-pc systemd[1]: Starting User Manager for UID 968...
Apr 30 09:17:59 ben-pc audit[6176]: USER_ACCT pid=6176 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:59 ben-pc systemd[6176]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Apr 30 09:17:59 ben-pc audit[6176]: CRED_ACQ pid=6176 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:17:59 ben-pc systemd[6176]: pam_unix(systemd-user:session): session opened for user sddm by (uid=0)
Apr 30 09:17:59 ben-pc audit[6176]: USER_START pid=6176 uid=0 auid=968 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:59 ben-pc audit: AUDIT1334 prog-id=33 op=LOAD
Apr 30 09:17:59 ben-pc audit: AUDIT1334 prog-id=33 op=UNLOAD
Apr 30 09:17:59 ben-pc systemd-coredump[6144]: Core file was truncated to 2147483648 bytes.
Apr 30 09:17:59 ben-pc systemd[6176]: Reached target Paths.
Apr 30 09:17:59 ben-pc systemd[6176]: Reached target Timers.
Apr 30 09:17:59 ben-pc systemd[6176]: Starting D-Bus User Message Bus Socket.
Apr 30 09:17:59 ben-pc systemd[6176]: Listening on GnuPG network certificate management daemon.
Apr 30 09:17:59 ben-pc systemd[6176]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Apr 30 09:17:59 ben-pc systemd[6176]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Apr 30 09:17:59 ben-pc systemd[6176]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Apr 30 09:17:59 ben-pc systemd[6176]: Listening on GnuPG cryptographic agent and passphrase cache.
Apr 30 09:17:59 ben-pc systemd[6176]: Listening on p11-kit server.
Apr 30 09:17:59 ben-pc systemd[6176]: Listening on Multimedia System.
Apr 30 09:17:59 ben-pc systemd[6176]: Listening on Sound System.
Apr 30 09:17:59 ben-pc systemd[6176]: Listening on D-Bus User Message Bus Socket.
Apr 30 09:17:59 ben-pc systemd[6176]: Reached target Sockets.
Apr 30 09:17:59 ben-pc systemd[6176]: Reached target Basic System.
Apr 30 09:17:59 ben-pc systemd[1]: Started User Manager for UID 968.
Apr 30 09:17:59 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:59 ben-pc systemd[1]: Started Session c1 of user sddm.
Apr 30 09:17:59 ben-pc systemd[6176]: Starting Update XDG user dir configuration...
Apr 30 09:17:59 ben-pc audit[6173]: USER_START pid=6173 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Apr 30 09:17:59 ben-pc sddm[6155]: Greeter session started successfully
Apr 30 09:17:59 ben-pc systemd[6176]: xdg-user-dirs-update.service: Succeeded.
Apr 30 09:17:59 ben-pc systemd[6176]: Finished Update XDG user dir configuration.
Apr 30 09:17:59 ben-pc systemd[6176]: Reached target Main User Target.
Apr 30 09:17:59 ben-pc systemd[6176]: Startup finished in 330ms.
Apr 30 09:17:59 ben-pc sddm-greeter[6186]: High-DPI autoscaling not Enabled
Apr 30 09:17:59 ben-pc sddm-greeter[6186]: Reading from "/usr/share/xsessions/plasma.desktop"
Apr 30 09:17:59 ben-pc sddm-greeter[6186]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
Apr 30 09:17:59 ben-pc sddm-greeter[6186]: Loading theme configuration from "/usr/share/sddm/themes/breath2/theme.conf"
Apr 30 09:17:59 ben-pc systemd[6176]: Started D-Bus User Message Bus.
Apr 30 09:17:59 ben-pc sddm-greeter[6186]: Connected to the daemon.
Apr 30 09:17:59 ben-pc sddm[6155]: Message received from greeter: Connect
Apr 30 09:17:59 ben-pc sddm-greeter[6186]: Loading file:///usr/share/sddm/themes/breath2/Main.qml...
Apr 30 09:17:59 ben-pc sddm-greeter[6186]: QObject: Cannot create children for a parent that is in a different thread.
                                           (Parent is QGuiApplication(0x7ffd91e7f3f0), parent's thread is QThread(0x55828ab7c530), current thread is QThread(0x55828ac65000)
Apr 30 09:17:59 ben-pc sddm-greeter[6186]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Apr 30 09:17:59 ben-pc systemd-coredump[6144]: Process 1293 (kwin_x11) of user 1000 dumped core.
                                               Stack trace of thread 1293:
                                               #0  0x00007f729ee5fce5 n/a (n/a + 0x0)
Apr 30 09:17:59 ben-pc dbus-daemon[6136]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.9' (uid=968 pid=6186 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-wfrfWd" label="unconfined")
Apr 30 09:17:59 ben-pc systemd[1]: Starting Disk Manager...
Apr 30 09:17:59 ben-pc udisksd[6205]: udisks daemon version 2.8.4 starting
Apr 30 09:17:59 ben-pc dbus-daemon[6136]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.10' (uid=0 pid=6205 comm="/usr/lib/udisks2/udisksd " label="unconfined")
Apr 30 09:17:59 ben-pc systemd[1]: Starting Authorization Manager...
Apr 30 09:17:59 ben-pc polkitd[6209]: Started polkitd version 0.116
Apr 30 09:17:59 ben-pc polkitd[6209]: Loading rules from directory /etc/polkit-1/rules.d
Apr 30 09:17:59 ben-pc polkitd[6209]: Loading rules from directory /usr/share/polkit-1/rules.d
Apr 30 09:17:59 ben-pc polkitd[6209]: Finished loading, compiling and executing 6 rules
Apr 30 09:17:59 ben-pc dbus-daemon[6136]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Apr 30 09:17:59 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:59 ben-pc systemd[1]: Started Authorization Manager.
Apr 30 09:17:59 ben-pc polkitd[6209]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Apr 30 09:17:59 ben-pc dbus-daemon[6136]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Apr 30 09:17:59 ben-pc systemd[1]: Started Disk Manager.
Apr 30 09:17:59 ben-pc udisksd[6205]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Apr 30 09:17:59 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:17:59 ben-pc dbus-daemon[6136]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.9' (uid=968 pid=6186 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-wfrfWd" label="unconfined")
Apr 30 09:17:59 ben-pc audit: AUDIT1334 prog-id=34 op=LOAD
Apr 30 09:17:59 ben-pc audit: AUDIT1334 prog-id=35 op=LOAD
Apr 30 09:17:59 ben-pc systemd[1]: Starting Daemon for power management...
Apr 30 09:18:00 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-6138-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:00 ben-pc systemd[1]: systemd-coredump@0-6138-0.service: Succeeded.
Apr 30 09:18:00 ben-pc systemd[1]: session-2.scope: Succeeded.
Apr 30 09:18:00 ben-pc audit: AUDIT1334 prog-id=30 op=UNLOAD
Apr 30 09:18:00 ben-pc audit: AUDIT1334 prog-id=29 op=UNLOAD
Apr 30 09:18:00 ben-pc dbus-daemon[6136]: [system] Successfully activated service 'org.freedesktop.UPower'
Apr 30 09:18:00 ben-pc systemd[1]: Started Daemon for power management.
Apr 30 09:18:00 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:00 ben-pc sddm-greeter[6186]: file:///usr/share/sddm/themes/breath2/components/VirtualKeyboard.qml:22:1: Type InputPanel unavailable
Apr 30 09:18:00 ben-pc sddm-greeter[6186]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Apr 30 09:18:00 ben-pc sddm-greeter[6186]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Apr 30 09:18:00 ben-pc sddm-greeter[6186]: Adding view for "eDP" QRect(0,0 1366x768)
Apr 30 09:18:00 ben-pc sddm-greeter[6186]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.10'
Apr 30 09:18:00 ben-pc sddm-greeter[6186]: Message received from daemon: Capabilities
Apr 30 09:18:00 ben-pc sddm-greeter[6186]: Message received from daemon: HostName
Apr 30 09:18:01 ben-pc kernel: sysrq: Kill All Tasks
Apr 30 09:18:01 ben-pc systemd[1]: sddm.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: sddm.service: Killing process 6162 (Xorg:disk$3) with signal SIGKILL.
Apr 30 09:18:01 ben-pc systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 2.
Apr 30 09:18:01 ben-pc systemd[1]: Stopping Flush Journal to Persistent Storage...
Apr 30 09:18:01 ben-pc systemd[1]: systemd-timesyncd.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: systemd-timesyncd.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: dbus.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: dbus.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: systemd-udevd.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: systemd-udevd.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: cronie.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: cronie.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: systemd-timesyncd.service: Scheduled restart job, restart counter is at 2.
Apr 30 09:18:01 ben-pc systemd[1]: systemd-udevd.service: Scheduled restart job, restart counter is at 2.
Apr 30 09:18:01 ben-pc systemd[1]: Started D-Bus System Message Bus.
Apr 30 09:18:01 ben-pc systemd[1]: Stopped Network Time Synchronization.
Apr 30 09:18:01 ben-pc systemd[1]: Starting Network Time Synchronization...
Apr 30 09:18:01 ben-pc systemd[1]: Stopped udev Kernel Device Manager.
Apr 30 09:18:01 ben-pc systemd[1]: Starting udev Kernel Device Manager...
Apr 30 09:18:01 ben-pc systemd[1]: systemd-journal-flush.service: Succeeded.
Apr 30 09:18:01 ben-pc systemd[1]: Stopped Flush Journal to Persistent Storage.
Apr 30 09:18:01 ben-pc systemd[1]: Stopped Journal Service.
Apr 30 09:18:01 ben-pc systemd[1]: Starting Journal Service...
Apr 30 09:18:01 ben-pc systemd[1]: upower.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: upower.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: polkit.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: polkit.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: udisks2.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: udisks2.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: user@1000.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: user@1000.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: Stopping User Runtime Directory /run/user/1000...
Apr 30 09:18:01 ben-pc systemd[1]: run-user-1000.mount: Succeeded.
Apr 30 09:18:01 ben-pc systemd[1]: user-runtime-dir@1000.service: Succeeded.
Apr 30 09:18:01 ben-pc systemd[1]: Stopped User Runtime Directory /run/user/1000.
Apr 30 09:18:01 ben-pc systemd[1]: user@968.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: user@968.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: Removed slice User Slice of UID 1000.
Apr 30 09:18:01 ben-pc systemd[1]: session-c1.scope: Succeeded.
Apr 30 09:18:01 ben-pc systemd[1]: Stopping User Runtime Directory /run/user/968...
Apr 30 09:18:01 ben-pc systemd[1]: run-user-968.mount: Succeeded.
Apr 30 09:18:01 ben-pc systemd[1]: user-runtime-dir@968.service: Succeeded.
Apr 30 09:18:01 ben-pc systemd[1]: Stopped User Runtime Directory /run/user/968.
Apr 30 09:18:01 ben-pc systemd[1]: Removed slice User Slice of UID 968.
Apr 30 09:18:01 ben-pc systemd[1]: systemd-logind.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc systemd[1]: systemd-logind.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc systemd[1]: systemd-logind.service: Scheduled restart job, restart counter is at 2.
Apr 30 09:18:01 ben-pc systemd[1]: Stopped Login Service.
Apr 30 09:18:01 ben-pc systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
Apr 30 09:18:01 ben-pc systemd[1]: Starting Login Service...
Apr 30 09:18:01 ben-pc systemd[1]: cronie.service: Scheduled restart job, restart counter is at 2.
Apr 30 09:18:01 ben-pc systemd[1]: upower.service: Scheduled restart job, restart counter is at 1.
Apr 30 09:18:01 ben-pc systemd[1]: Stopped Periodic Command Scheduler.
Apr 30 09:18:01 ben-pc systemd[1]: Started Periodic Command Scheduler.
Apr 30 09:18:01 ben-pc systemd[1]: Stopped Daemon for power management.
Apr 30 09:18:01 ben-pc systemd[1]: Starting Daemon for power management...
Apr 30 09:18:01 ben-pc systemd-journald[6260]: Journal started
Apr 30 09:18:01 ben-pc systemd-journald[6260]: System Journal (/var/log/journal/e71c0736b60d4ce79b5d4ab780f42be3) is 304.1M, max 4.0G, 3.7G free.
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=36 op=LOAD
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=37 op=LOAD
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc systemd[1]: Started Journal Service.
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=38 op=LOAD
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=39 op=LOAD
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=28 op=UNLOAD
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=27 op=UNLOAD
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=26 op=UNLOAD
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=25 op=UNLOAD
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=40 op=LOAD
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=41 op=LOAD
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=42 op=LOAD
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=43 op=LOAD
Apr 30 09:18:01 ben-pc audit: CONFIG_CHANGE op=set audit_enabled=1 old=1 auid=4294967295 ses=4294967295 subj==unconfined res=1
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=32 op=UNLOAD
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=31 op=UNLOAD
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=35 op=UNLOAD
Apr 30 09:18:01 ben-pc audit: AUDIT1334 prog-id=34 op=UNLOAD
Apr 30 09:18:01 ben-pc crond[6268]: (CRON) STARTUP (1.5.5)
Apr 30 09:18:01 ben-pc systemd[1]: systemd-journald.service: Main process exited, code=killed, status=9/KILL
Apr 30 09:18:01 ben-pc crond[6268]: (CRON) INFO (Syslog will be used instead of sendmail.)
Apr 30 09:18:01 ben-pc systemd[1]: systemd-journald.service: Failed with result 'signal'.
Apr 30 09:18:01 ben-pc crond[6268]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 31% if used.)
Apr 30 09:18:01 ben-pc systemd[1]: Starting Flush Journal to Persistent Storage...
Apr 30 09:18:01 ben-pc crond[6268]: (CRON) INFO (running with inotify support)
Apr 30 09:18:01 ben-pc systemd[1]: Started udev Kernel Device Manager.
Apr 30 09:18:01 ben-pc crond[6268]: (CRON) INFO (@reboot jobs will be run at computer's startup.)
Apr 30 09:18:01 ben-pc systemd[1]: Finished Flush Journal to Persistent Storage.
Apr 30 09:18:01 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:01 ben-pc systemd[1]: Started Network Time Synchronization.
Apr 30 09:18:01 ben-pc systemd-logind[6267]: New seat seat0.
Apr 30 09:18:01 ben-pc systemd-logind[6267]: Failed to add user by file name 968, ignoring: Invalid argument
Apr 30 09:18:01 ben-pc systemd-logind[6267]: Failed to add user by file name 1000, ignoring: Invalid argument
Apr 30 09:18:01 ben-pc systemd-logind[6267]: User enumeration failed: Invalid argument
Apr 30 09:18:01 ben-pc systemd-logind[6267]: User of session c1 not known.
Apr 30 09:18:01 ben-pc systemd-logind[6267]: User of session 2 not known.
Apr 30 09:18:01 ben-pc systemd-logind[6267]: Session enumeration failed: No such file or directory
Apr 30 09:18:01 ben-pc systemd-logind[6267]: Watching system buttons on /dev/input/event3 (Power Button)
Apr 30 09:18:01 ben-pc systemd-logind[6267]: Watching system buttons on /dev/input/event0 (Lid Switch)
Apr 30 09:18:01 ben-pc systemd-logind[6267]: Watching system buttons on /dev/input/event1 (Power Button)
Apr 30 09:18:01 ben-pc systemd-logind[6267]: Watching system buttons on /dev/input/event2 (Sleep Button)
Apr 30 09:18:01 ben-pc dbus-daemon[6257]: [system] Activating via systemd: service name='org.freedesktop.login1' unit='dbus-org.freedesktop.login1.service' requested by ':1.3' (uid=0 pid=6269 comm="/usr/lib/upowerd " label="unconfined")
Apr 30 09:18:02 ben-pc systemd-logind[6267]: Watching system buttons on /dev/input/event5 (AT Translated Set 2 keyboard)
Apr 30 09:18:02 ben-pc dbus-daemon[6257]: [system] Successfully activated service 'org.freedesktop.login1'
Apr 30 09:18:02 ben-pc systemd[1]: Started Login Service.
Apr 30 09:18:02 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:02 ben-pc kernel: kauditd_printk_skb: 117 callbacks suppressed
Apr 30 09:18:02 ben-pc kernel: audit: type=1130 audit(1588252682.030:261): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:02 ben-pc systemd[1]: Started Daemon for power management.
Apr 30 09:18:02 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:02 ben-pc kernel: audit: type=1130 audit(1588252682.137:262): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:02 ben-pc systemd[1]: sddm.service: Failed with result 'signal'.
Apr 30 09:18:02 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:02 ben-pc kernel: audit: type=1131 audit(1588252682.360:263): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:02 ben-pc systemd[1]: sddm.service: Scheduled restart job, restart counter is at 2.
Apr 30 09:18:02 ben-pc kernel: audit: type=1130 audit(1588252682.641:264): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:02 ben-pc kernel: audit: type=1131 audit(1588252682.641:265): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:02 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:02 ben-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:02 ben-pc systemd[1]: Stopped Simple Desktop Display Manager.
Apr 30 09:18:02 ben-pc systemd[1]: Started Simple Desktop Display Manager.
Apr 30 09:18:02 ben-pc kernel: audit: type=1130 audit(1588252682.641:266): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:02 ben-pc sddm[6295]: Initializing...
Apr 30 09:18:02 ben-pc sddm[6295]: Starting...
Apr 30 09:18:02 ben-pc sddm[6295]: Logind interface found
Apr 30 09:18:02 ben-pc sddm[6295]: Adding new display on vt 1 ...
Apr 30 09:18:02 ben-pc sddm[6295]: Loading theme configuration from ""
Apr 30 09:18:02 ben-pc sddm[6295]: Display server starting...
Apr 30 09:18:02 ben-pc sddm[6295]: Running: /usr/bin/X -nolisten tcp -auth /var/run/sddm/{483ee69a-f3df-4626-b325-8ac08e99bfcf} -background none -noreset -displayfd 17 -seat seat0 vt1
Apr 30 09:18:03 ben-pc sddm[6295]: Setting default cursor
Apr 30 09:18:03 ben-pc sddm[6295]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Apr 30 09:18:03 ben-pc sddm[6295]: Display server started.
Apr 30 09:18:03 ben-pc sddm[6295]: Socket server starting...
Apr 30 09:18:03 ben-pc sddm[6295]: Socket server started.
Apr 30 09:18:03 ben-pc sddm[6295]: Loading theme configuration from "/usr/share/sddm/themes/breath2/theme.conf"
Apr 30 09:18:03 ben-pc sddm[6295]: Greeter starting...
Apr 30 09:18:03 ben-pc sddm[6295]: Adding cookie to "/var/run/sddm/{483ee69a-f3df-4626-b325-8ac08e99bfcf}"
Apr 30 09:18:03 ben-pc sddm-helper[6313]: [PAM] Starting...
Apr 30 09:18:03 ben-pc kernel: audit: type=1100 audit(1588252683.609:267): pid=6313 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc kernel: audit: type=1101 audit(1588252683.612:268): pid=6313 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc audit[6313]: USER_AUTH pid=6313 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc audit[6313]: USER_ACCT pid=6313 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc audit[6313]: CRED_ACQ pid=6313 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc sddm-helper[6313]: [PAM] Authenticating...
Apr 30 09:18:03 ben-pc sddm-helper[6313]: [PAM] returning.
Apr 30 09:18:03 ben-pc sddm-helper[6313]: pam_unix(sddm-greeter:session): session opened for user sddm by (uid=0)
Apr 30 09:18:03 ben-pc kernel: audit: type=1103 audit(1588252683.612:269): pid=6313 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc systemd[1]: Created slice User Slice of UID 968.
Apr 30 09:18:03 ben-pc systemd[1]: Starting User Runtime Directory /run/user/968...
Apr 30 09:18:03 ben-pc systemd-logind[6267]: New session c1 of user sddm.
Apr 30 09:18:03 ben-pc systemd[1]: Finished User Runtime Directory /run/user/968.
Apr 30 09:18:03 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc kernel: audit: type=1130 audit(1588252683.629:270): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc systemd[1]: Starting User Manager for UID 968...
Apr 30 09:18:03 ben-pc audit[6316]: USER_ACCT pid=6316 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc audit[6316]: CRED_ACQ pid=6316 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Apr 30 09:18:03 ben-pc systemd[6316]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Apr 30 09:18:03 ben-pc systemd[6316]: pam_unix(systemd-user:session): session opened for user sddm by (uid=0)
Apr 30 09:18:03 ben-pc audit[6316]: USER_START pid=6316 uid=0 auid=968 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc audit: AUDIT1334 prog-id=44 op=LOAD
Apr 30 09:18:03 ben-pc audit: AUDIT1334 prog-id=44 op=UNLOAD
Apr 30 09:18:03 ben-pc systemd[6316]: Reached target Paths.
Apr 30 09:18:03 ben-pc systemd[6316]: Reached target Timers.
Apr 30 09:18:03 ben-pc systemd[6316]: Starting D-Bus User Message Bus Socket.
Apr 30 09:18:03 ben-pc systemd[6316]: Listening on GnuPG network certificate management daemon.
Apr 30 09:18:03 ben-pc systemd[6316]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Apr 30 09:18:03 ben-pc systemd[6316]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Apr 30 09:18:03 ben-pc systemd[6316]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Apr 30 09:18:03 ben-pc systemd[6316]: Listening on GnuPG cryptographic agent and passphrase cache.
Apr 30 09:18:03 ben-pc systemd[6316]: Listening on p11-kit server.
Apr 30 09:18:03 ben-pc systemd[6316]: Listening on Multimedia System.
Apr 30 09:18:03 ben-pc systemd[6316]: Listening on Sound System.
Apr 30 09:18:03 ben-pc systemd[6316]: Listening on D-Bus User Message Bus Socket.
Apr 30 09:18:03 ben-pc systemd[6316]: Reached target Sockets.
Apr 30 09:18:03 ben-pc systemd[6316]: Reached target Basic System.
Apr 30 09:18:03 ben-pc systemd[1]: Started User Manager for UID 968.
Apr 30 09:18:03 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:03 ben-pc systemd[6316]: Starting Update XDG user dir configuration...
Apr 30 09:18:03 ben-pc systemd[1]: Started Session c1 of user sddm.
Apr 30 09:18:03 ben-pc systemd[6316]: xdg-user-dirs-update.service: Succeeded.
Apr 30 09:18:03 ben-pc systemd[6316]: Finished Update XDG user dir configuration.
Apr 30 09:18:03 ben-pc systemd[6316]: Reached target Main User Target.
Apr 30 09:18:03 ben-pc systemd[6316]: Startup finished in 63ms.
Apr 30 09:18:03 ben-pc audit[6313]: USER_START pid=6313 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Apr 30 09:18:03 ben-pc sddm[6295]: Greeter session started successfully
Apr 30 09:18:03 ben-pc sddm-greeter[6326]: High-DPI autoscaling not Enabled
Apr 30 09:18:03 ben-pc sddm-greeter[6326]: Reading from "/usr/share/xsessions/plasma.desktop"
Apr 30 09:18:03 ben-pc sddm-greeter[6326]: Reading from "/usr/share/wayland-sessions/plasmawayland.desktop"
Apr 30 09:18:03 ben-pc sddm-greeter[6326]: Loading theme configuration from "/usr/share/sddm/themes/breath2/theme.conf"
Apr 30 09:18:03 ben-pc systemd[6316]: Started D-Bus User Message Bus.
Apr 30 09:18:03 ben-pc sddm-greeter[6326]: Connected to the daemon.
Apr 30 09:18:03 ben-pc sddm[6295]: Message received from greeter: Connect
Apr 30 09:18:03 ben-pc sddm-greeter[6326]: Loading file:///usr/share/sddm/themes/breath2/Main.qml...
Apr 30 09:18:03 ben-pc sddm-greeter[6326]: QObject: Cannot create children for a parent that is in a different thread.
                                           (Parent is QGuiApplication(0x7ffde6b83c20), parent's thread is QThread(0x5634628d6530), current thread is QThread(0x5634629bf050)
Apr 30 09:18:03 ben-pc sddm-greeter[6326]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Apr 30 09:18:04 ben-pc dbus-daemon[6257]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.10' (uid=968 pid=6326 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-rXeocF" label="unconfined")
Apr 30 09:18:04 ben-pc systemd[1]: Starting Disk Manager...
Apr 30 09:18:04 ben-pc udisksd[6343]: udisks daemon version 2.8.4 starting
Apr 30 09:18:04 ben-pc dbus-daemon[6257]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.11' (uid=0 pid=6343 comm="/usr/lib/udisks2/udisksd " label="unconfined")
Apr 30 09:18:04 ben-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Apr 30 09:18:04 ben-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Apr 30 09:18:04 ben-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Apr 30 09:18:04 ben-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Apr 30 09:18:04 ben-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Apr 30 09:18:04 ben-pc systemd[1]: Starting Authorization Manager...
Apr 30 09:18:04 ben-pc polkitd[6347]: Started polkitd version 0.116
Apr 30 09:18:04 ben-pc polkitd[6347]: Loading rules from directory /etc/polkit-1/rules.d
Apr 30 09:18:04 ben-pc polkitd[6347]: Loading rules from directory /usr/share/polkit-1/rules.d
Apr 30 09:18:04 ben-pc polkitd[6347]: Finished loading, compiling and executing 6 rules
Apr 30 09:18:04 ben-pc dbus-daemon[6257]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Apr 30 09:18:04 ben-pc systemd[1]: Started Authorization Manager.
Apr 30 09:18:04 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:04 ben-pc polkitd[6347]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Apr 30 09:18:04 ben-pc dbus-daemon[6257]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Apr 30 09:18:04 ben-pc udisksd[6343]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Apr 30 09:18:04 ben-pc systemd[1]: Started Disk Manager.
Apr 30 09:18:04 ben-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 30 09:18:04 ben-pc sddm-greeter[6326]: file:///usr/share/sddm/themes/breath2/components/VirtualKeyboard.qml:22:1: Type InputPanel unavailable
Apr 30 09:18:04 ben-pc sddm-greeter[6326]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Apr 30 09:18:04 ben-pc sddm-greeter[6326]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Apr 30 09:18:04 ben-pc sddm-greeter[6326]: Adding view for "eDP" QRect(0,0 1366x768)
Apr 30 09:18:04 ben-pc sddm-greeter[6326]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.11'
Apr 30 09:18:04 ben-pc sddm-greeter[6326]: Message received from daemon: Capabilities
Apr 30 09:18:04 ben-pc sddm-greeter[6326]: Message received from daemon: HostName
Apr 30 09:18:07 ben-pc kernel: sysrq: Emergency Remount R/O
  1. Does Ctrl+Alt+F2 and then a light tap on the power button work?
  2. Do you wait at least 1 sec between each keypress?
    • if yes: try 2 sec between I and S
    • If no: please do
Report back in either case, so I can adapt that procedure...
:innocent:
  1. Do you mean I should press Ctrl+Alt+F2 then tap the power button before doing any of REISUB, or after I've arrived at the login screen following I?
  2. Yes I've tried waiting quite a long time (20+ seconds) between I and S just to see if background functions needed to catch up.
  1. That's an alternative to REISUO (= power down gracefully)
  2. Weird, never have experienced this but thanks for the feed-back...
:thinking:
OK, I've had time to read your log file now and that's weird...
Could you do me a favour and change your theme to Breath2 (=Manjaro theme) and see if it still happens???
Anyway, it does all of the REISU and then it goes to the login screen, so another REISUB there should do the trick as a workaround, but this should not be happening!
I believe I am using Breath2 already... is there something in the log that suggests I'm not? Here are screenshots of my system settings. The only thing I've changed is my background. I can try changing that back if you think that would cause the issue.
Screenshot_20200430_124759
Screenshot_20200430_124916
I was on the wrong track then, because in your log file, breeze gets referenced...
My apologies!
:sob:
Haha no worries. I have set things up so the light power button tap shuts down the computer, as per your article's instructions, and I'll try the second go-through for REISUB if that doesn't work when I stall out. In the meantime, I'm hoping the issue was related to my graphics workaround and I won't need to do any hard/soft resets anytime soon! Thanks for offering so much time and attention to my issue, it's been a big help.
You're welcome... Too bad I haven't been able to solve your original issue!
:sob:
Alas, I'm sad to report that A) the issue happened again last night and B) neither REISUO or Ctrl+Alt+F2 helped, so I had to hard reset again. Here's the relevant output from journalctl -b -1 (note: I tried to paste this directly as preformatted text but it told me I had exceeded the character limit for posts so I've used Google Drive):
As I looked more closely at this log I realized that the difference between this and other attempts to sleep is that the sleep state lasted long enough for the computer to attempt to enter into hibernation. With that in mind I thought that perhaps hibernation is the issue, not an interrupted suspend. So I manually hibernated this morning. At first it looked like I was experiencing the same issue: the screen was black but clearly still on, the LED on the side of the computer was still fully illuminated, and the system was unresponsive: no buttons brought it back to life, and neither REISUO or Ctrl+Alt+F2 visibly did anything. So, I held down the power button until it powered off and pressed the power button again to turn it back on. To my surprise, instead of booting to a black screen (as normally happens after the issue arises), it booted back to my desktop session, with Chrome open to the same tab I had been on when I put it into hibernation! Here's the relevant section of journalctl -b:
Notably, in this log there doesn't seem to be any recognition that I used sysrq after the hibernation began, whereas in the previous log, you can see the same thing happening that goes on when I try to use REISUB/O from a normally functioning desktop: REISU all seem to do something but it seems to stall at remounting and B/O never does anything, even when the sequence is repeated.
Despite the different behaviour, I'm going to try disabling hibernation functions in the power settings and see if that helps prevent the issue moving forward, but figured it was worth sharing these logs since the solution to both issues (the original issue and REISUB not working) continue. I could do a clean install if you think that would be helpful but didn't want to do that yet, in case further experimentation would be beneficial first.
