Laptop Webcam not detected
Hello
I have a Lenovo e495, and recently, while trying to use microsoft Teams, I saw the inbuilt webcam was no longer detected. I has worked in the past, but now can't be detected by Teams, OBS, or any other method.
I have tried rolling back the kernel to 4.19, rebooting several times, and pressed all the function keys.
Here are my outputs for
inxi -Fxxxz
  Host: connor-pc Kernel: 5.5.19-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.3.0 Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 20NECTO1WW v: ThinkPad E495
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20NECTO1WW serial: <filter> UEFI: LENOVO
  v: R11ET32W (1.12 ) date: 12/23/2019
  ID-1: BAT0 charge: 45.1 Wh condition: 46.0/45.3 Wh (101%) volts: 12.5/11.1
  model: SMP 01AV446 type: Li-poly serial: <filter> status: Charging
  cycles: 42
  Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  Topology: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB
  bogomips: 33546
  Speed: 1243 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
  1: 1223 2: 1238 3: 1310 4: 1284 5: 1224 6: 1225 7: 1243 8: 1225
  Device-1: AMD Picasso vendor: Lenovo ThinkPad E595 driver: amdgpu
  v: kernel bus ID: 05:00.0 chip ID: 1002:15d8
  Display: x11 server: X.Org 1.20.8 driver: amdgpu
  resolution: 1920x1080~60Hz
  OpenGL: renderer: AMD RAVEN (DRM 3.36.0 5.5.19-1-MANJARO LLVM 10.0.0)
  v: 4.6 Mesa 20.0.6 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
  vendor: Lenovo ThinkPad E595 driver: snd_hda_intel v: kernel
  bus ID: 05:00.1 chip ID: 1002:15de
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Lenovo ThinkPad E595 driver: N/A bus ID: 05:00.5
  chip ID: 1022:15e2
  Device-3: AMD Family 17h HD Audio vendor: Lenovo ThinkPad E595
  driver: snd_hda_intel v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.5.19-1-MANJARO
  vendor: Lenovo ThinkPad E595 driver: r8169 v: kernel port: 3000
  bus ID: 02:00.0 chip ID: 10ec:8168
  Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Lenovo ThinkPad E595 driver: rtw_pci v: N/A port: 2000
  bus ID: 04:00.0 chip ID: 10ec:b822
  IF: wlp4s0 state: up mac: <filter>
  Local Storage: total: 238.47 GiB used: 49.97 GiB (21.0%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HBHQ-000L7
  size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 4M2QEXH7
  scheme: GPT
  ID-1: / size: 172.02 GiB used: 49.97 GiB (29.0%) fs: ext4
  dev: /dev/nvme0n1p2
  System Temperatures: cpu: 49.8 C mobo: 0.0 C gpu: amdgpu temp: 49 C
  Fan Speeds (RPM): cpu: 0
  Processes: 273 Uptime: 1d 21h 36m Memory: 5.75 GiB used: 3.70 GiB (64.4%)
  Init: systemd v: 245 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16
  running in: xfce4-terminal inxi: 3.0.37
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 0bda:b023 Realtek Semiconductor Corp. Bluetooth Radio
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:01.6 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)
04:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822BE 802.11a/b/g/n/ac WiFi adapter
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso (rev c2)
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
v4l2-ctl --list-devices
Cannot open device /dev/video0, exiting.
In the /dev/ folder, there is no video, video0 or video1
The webcam has worked in the past, but I don' know when it stopped working.
I have looked around the forum, and elsewhere, but no problems match my own.
Thank you for any tips.
I have the same problem with my HP G6 laptop.
The webcamera stopped working all of sudden.
Video capture utility does not load.
It worked fine in the past...don't know what happened.
Any help on this?
Thanks
