Launcher's favorites are always empty
Manjaro KDE Edition (17.1.11)
Removed " ~/.config/menus"
Removed " ~/.local/share/kactivitymanagerd/resources/*"
nothing helps..
Did you try on clean, test user? Do favorites are visible there?
Also from lack of better description it begs to ask: did you add some favorites?
You can also try to delete ~/.config/kactivitymanagerd-statsrc
already did it, nothing help :frowning: , yes it's visible, after reboot or logout it's become empty....
I believe that favorites are stored in ~/.config/kactivitymanagerd-statsrc
Try renaming this to kactivitymanagerd-statsrc.bak then relogg session to see if it helped.
thanks, i was removing it, than add to favorites and after that i was logging out :smile: :wink:
