I know this has been solved so many times but I've read so much about it and now I'm so confused.
Recently my manjaro was unable to boot it was giving an error
ERROR: resume: hibernation device 'UUID=xxxx,xxxx,xxxx,xxxx' not found
ERROR device UUID=xxxx,xxxxx,xxxx,xxx not found
mount: /new_root: can't find UUID=xxxx,xxxx,xxxx,xxxxx
you're now being dropped into emergency shell.
Luckily I found the solution that all I had to boot a live USB backup the data either a fresh install or update the existing one, I'm going for fresh install because it's been a while
But now I'm so confused what should I go for
I want only manjaro in my laptop
I have 1TB hard drive and its MBR right now
it support both legacy and UEFI
I don't do gaming at all
