Libfam Package Missing When Starting Autodesk Maya 2017
When i launch Autodesk Maya 2017 its stopped with this error command.
/usr/autodesk/maya2017/bin/maya.bin: error while loading shared libraries: libfam.so.0: cannot open shared object file: No such file or directory
I have searched in pacman and googled for libfam package, and i can't able to find it for Manjaro.
Thanks.
Where did you find Maya 2017? Maya 2020 is in the AUR as maya. It appears libfam.so is from the gamin AUR package which is a dependency of maya.
I have a backup of Maya 2017,
And installing gamin package solved the problem, thanks a lot. :slightly_smiling_face: :upside_down_face:
