Login issue on Deepin
Anyone know how to solve login issue ? I am new to Linux and don't know much about terminal commands and i have important information in my laptop .
The old manjaro-deepin-settings is blocking you from getting the latest schemas.
press ctrl+alt+f3 to get a TTY, login and then run:
sudo pacman -R manjaro-deepin-settings
sudo pacman -Syyu deepin-desktop-schemas
Thanks a lot that solve the problem
Thanks, that helped for me too. However, after update the desktop is not right-clickable. Is it intended? How do I change wallpaper then? Or maybe something is wrong?
You need to install deepin-kwin
You are probably still using the old deepin-wm which is no longer supported in DDE 20.
Oh, yeah. I installed kwin-deepin now, rebooted and as expected, it doesn't work yet, I have no wallpaper now. How to I enable it? I don't remember it by heart. I tried to find it but it's super difficult and I get only obsolete info :frowning:.
Once deepin-kwin is installed, you should be able to right-click on the desktop and select "Wallpaper and screensaver"
Nope, the desktop is black, not right clickable. When I tried:
kwin_x11 --replace
I got a bunch of errors in terminal.
To not pollute this topic any further, I started a new one:
